PDA
View Full Version : Scratch Building, Aircraft Design, 3D/CAD
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36
  1. Transferring Patterns from CAD to Wood
  2. Quick CAD-question
  3. ? about Hot Hots aileron servo hatch
  4. Scan Pro for Windows
  5. Hi
  6. Autocad DXFIN problem/solution
  7. Props on deltas
  8. Outer Correx Inner Foam
  9. Nooby Wanting to build
  10. Modelling foam?
  11. Nacelle Help Needed
  12. Max Products Inc. (MPI) on board glow Any one else haveing problems?
  13. Horten Go229 Drawings
  14. Vought XF5U-1 Drawings
  15. B-57 for 5" fan's
  16. What size engine on a 90"WS Waco
  17. Lets see your crazy designs!
  18. shear webs
  19. Spars and CG
  20. Covering and doping
  21. ModelCAD Conversion
  22. Easiest way to go from paper to CAD
  23. Finding the correct C.G of an airplane
  24. Changing CG
  25. Wing profile needed
  26. Pattern Plane Plans in CAD or DXF
  27. Scratch Building, Aircraft Design, 3D/CAD FAQ
  28. Modeling Software
  29. Update on my .32 3DX
  30. Best wire for foam wing cutter
  31. need 3 vu
  32. whic one of those prop is batter for 3D
  33. PLASTICS EXPERT HELP NEEDED
  34. PLANS TO CAD TO CNC
  35. Building foam core wings
  36. CAD
  37. Scratch Building 10% Scale DC-8
  38. What to do ?
  39. I need a set of 4 * 120 Plans
  40. New Plane, PSHYCO 3D!!
  41. custom kit cutting service?
  42. EA-6B Plans?
  43. Trying to get into scratch building...
  44. how to make a huge lazy bee for a G23???
  45. Where to start with throws
  46. Custom Foam Cutting
  47. What Airfoil for Extra
  48. Katana or Funtana
  49. Plans for senior Telemaster
  50. Question about Foam Cutting, wing making, etc
  51. Plans
  52. Extra 300s 46 size
  53. C130
  54. lazybee cad file for laser cutting
  55. Single wire foam cutter HOW TO MAKE ONE?
  56. Free CAD
  57. How much does "wood" weigh?
  58. Autocad, Autocad Mechanical, Mechanical Desktop, Inventor, What's the difference?
  59. 80 inch Canard Pusher Foamie?
  60. Fishing for designs for Production
  61. Partners Wanted
  62. Durine Turbulent Plans
  63. Linear Tracking Servos
  64. How do I get a pdf into my CAD program?
  65. Wing Thickness
  66. Bamboo dowel source ??
  67. Need 3 view for Mr. Mulligan
  68. Senior Telemaster spar strengthening?
  69. NEED HELP WITH AN AIRFOIL
  70. Engine size vs. Wing area
  71. HALF SIZE PLANS.
  72. How to do wing tubes?
  73. Any self designed AND OR plans builders out there? Post pictures!
  74. RCM plan builders?
  75. Servo sizing
  76. I need a wing rib cad drawing, Where to find?
  77. Star Wars X-wing fighter
  78. High Wing Attachment
  79. Cutting Fiberglass
  80. #871AMA DUSTER
  81. HELP ??
  82. Gurus wanted!
  83. Adobe to CAD
  84. Autodesk Inventor
  85. Uploading AutoCad Pictures
  86. Kraft Das Liddle Stik
  87. Retract Linkage
  88. desigining a plane.
  89. I found some free CAD stuff...
  90. Giant Scale Tires
  91. 3 Piece foam wing ..Need help
  92. Need some help with design info......
  93. Looking for CAD expert to share a project with
  94. Laser-cut Plastic
  95. Wanted -Rcm article 12/1971 Arrowbile
  96. Spacewalker Incidence?
  97. MiG-29 Fulcrum
  98. 1/2A Foamy airplane?
  99. scratch built Edge 540T
  100. Retracts and foam wings
  101. Need help with tapering solid piece's of balsa
  102. Aerocar 1/4 scale- Where to start?
  103. scrach cowls
  104. Supply for foam (in Fl)
  105. Full-Scale Drawings?
  106. Design help
  107. Looking for Someone
  108. Constant cross section wing?
  109. 3d cad drawing
  110. Notes on thrust lines and engine mounting
  111. Using foam internals w/ balsa covering for larger models?
  112. CNC foam cutter
  113. Intro to Laser Cutting
  114. Laser Cutting
  115. Why different pieces
  116. REARWIN SKYRANGER
  117. Extra 300 CG from RCm Plan 1117
  118. Robinhood 80 - 100 Tanks
  119. Ultra Stick 120 Plans?
  120. 1/12 Lancaster scratch build
  121. Nose gear for A-26
  122. Stinson Reliant plan wanted
  123. Contact w/ W.E. Technical Plans?
  124. old timer scratch build for a .30???
  125. Check this out!
  126. Converting ABS to Fiberglass
  127. That's depressing
  128. Starting a new project, where do I start?
  129. Fokker Dr1 Incidence Angle
  130. Bulk Balsa ..Where do you find it like in the hobby stores
  131. help with autocad 2004
  132. Making a collapsable fuselage?
  133. Giant Delta! 96 inches! H2O!
  134. looking for air tractor plans
  135. Scratch Building Help :)
  136. Best way to accurately expand plans?
  137. Extra 3.25
  138. R.C. Sweitzer --Rapide Accessories
  139. source for miniature 'piano' hinge?
  140. Saito FA-90TS in what plane
  141. Airfoil and other design aspects for ultra slow flight plane
  142. mishaps
  143. rib construction
  144. Ducted fan unit plans, drawings etc.
  145. MOVED: Help with modified Rocket
  146. c-17 globemaster plans/drawings
  147. Cessna Plans
  148. Table Saw
  149. Crooked Cowl.
  150. HUGHES H1 racer
  151. Cad designing
  152. Cad designing
  153. guidance needed desparately
  154. How to scale plans in Autocad 2004?
  155. power panel mounting dims needed
  156. AIRCRAFT SPEED
  157. Foam cutting device
  158. Online Canadian wood
  159. Any one want to Trade Plans?
  160. Help Getting Started in Scratch Building.
  161. Gas trainer
  162. Anybody heard of a Time Machine
  163. Airfoil
  164. CG HELP
  165. fiberglass mold maker wanted
  166. Need ideas on a plane quick!!!
  167. Calculating the CG..
  168. Skool Project.
  169. Help importing Bit Maps into Turbo CAD
  170. Nifty 80
  171. Wing Placement
  172. Turbo CAD 2D 3D V9.2 problem
  173. obeche veneer
  174. Scratch Built 3D
  175. Heavy Foam Wings
  176. Looking for Ideas for 1st plane
  177. Need Auto Cad 2004.
  178. Design template for conical tube ??
  179. First scratch build. (Cessna 182)
  180. Krier Kraft
  181. Dow Hi-Load 60 Foam
  182. laser 3d plan in dwg. format
  183. Free Cad Plans and Programs..
  184. Looking for a plan for Dalotel (.40)
  185. 2 oz FUEL TANK
  186. CAD engine plans
  187. How much vertical area for aerobatic Bipes?
  188. Anyone seen disc brakes?
  189. Tiger Moth landing gear plans
  190. ultimate Bipe - CG for Scratch build
  191. GLOW ENGINES
  192. Plotting on Autocad 2002
  193. vacum former and motor size
  194. Foam wing cutter from RCM plans
  195. DXF error
  196. Sig Smith Mini Plane
  197. Horten Ho229 ( version 3
  198. MOVED: ADVICE ON AUTOGYRO
  199. GIANT SLOWPOKE FLIGHT REPORT
  200. 40 size 3d plan
  201. Cutting accurate wing ribs on very tapered wing
  202. Calculating Wing Area?
  203. Building with lasers
  204. How should I finish my model ?
  205. Balsa and Ply densities.
  206. Yellow Bird
  207. This is worth checking out!
  208. wendell edge 540T HELP PLEASE
  209. Basic Model Airplane Calculator
  210. 3D CAD PROGRAMS
  211. Building Project Plane
  212. Midwest Delta Hustler
  213. Scratch Built Zlin 50L Update
  214. Wendell edge 540T
  215. MOVED: is a rudder really needed?
  216. Marking Balsa By ironing plans over ?
  217. WING SWEEP WITH BELL LIFT DISTRIBUTION
  218. Is a Lockheed P-38 lighting good 1st scratcher?
  219. Weed Whacker Aircraft Plans
  220. Plans wanted - help please
  221. CG on EDGE 540 is VERY SENSITVE
  222. How Much Dihedral?
  223. Center of Gravity
  224. North American Rockwell T-39 / CT-39 Sabreliner
  225. super sportster bipe plans wanted
  226. Adding flaps - proportions needed please
  227. Colour printer for custom Decals
  228. Carl Goldberg Extra / Ultimate
  229. Home made ducted fan
  230. Cadkey .dxf to ACAD opens poorly - ideas?
  231. HELP Royal Gull Amphibian plans?
  232. New plane out of foam
  233. Hot Wire Foam Cutter Connection?
  234. what would you like to see in kit form
  235. No Sweat
  236. Inverted V-tail or dual rudder P-38 style tail?
  237. Splicing balsa to make wide ribs?
  238. Contest balsa shortage?
  239. Built-up fuselages with CF tape ?
  240. Scale Bulkheads & Stringers?
  241. Looking fot Pilatus PC6 Plans
  242. Ultimate Bipe cabane and outer strut detail
  243. Super Stearman Airfoil
  244. Hot Wire Foam Cutter Guide?
  245. AutoCAD 2000 3D help needed
  246. Can this thing fly?
  247. Where to put CG on a flying wing?
  248. How to fix V-Tail to Carbon Tube
  249. Calling All RC Designers!!!
  250. Kudo's to you scratch builders
