- Star Wars X-wing fighter
- High Wing Attachment
- Cutting Fiberglass
- #871AMA DUSTER
- HELP ??
- Gurus wanted!
- Adobe to CAD
- Autodesk Inventor
- Uploading AutoCad Pictures
- Kraft Das Liddle Stik
- Retract Linkage
- desigining a plane.
- I found some free CAD stuff...
- Giant Scale Tires
- 3 Piece foam wing ..Need help
- Need some help with design info......
- Looking for CAD expert to share a project with
- Laser-cut Plastic
- Wanted -Rcm article 12/1971 Arrowbile
- Spacewalker Incidence?
- MiG-29 Fulcrum
- 1/2A Foamy airplane?
- scratch built Edge 540T
- Retracts and foam wings
- Need help with tapering solid piece's of balsa
- Aerocar 1/4 scale- Where to start?
- scrach cowls
- Supply for foam (in Fl)
- Full-Scale Drawings?
- Design help
- Looking for Someone
- Constant cross section wing?
- 3d cad drawing
- Notes on thrust lines and engine mounting
- Using foam internals w/ balsa covering for larger models?
- CNC foam cutter
- Intro to Laser Cutting
- Laser Cutting
- Why different pieces
- REARWIN SKYRANGER
- Extra 300 CG from RCm Plan 1117
- Robinhood 80 - 100 Tanks
- Ultra Stick 120 Plans?
- 1/12 Lancaster scratch build
- Nose gear for A-26
- Stinson Reliant plan wanted
- Contact w/ W.E. Technical Plans?
- old timer scratch build for a .30???
- Check this out!
- Converting ABS to Fiberglass
- That's depressing
- Starting a new project, where do I start?
- Fokker Dr1 Incidence Angle
- Bulk Balsa ..Where do you find it like in the hobby stores
- help with autocad 2004
- Making a collapsable fuselage?
- Giant Delta! 96 inches! H2O!
- looking for air tractor plans
- Scratch Building Help :)
- Best way to accurately expand plans?
- Extra 3.25
- R.C. Sweitzer --Rapide Accessories
- source for miniature 'piano' hinge?
- Saito FA-90TS in what plane
- Airfoil and other design aspects for ultra slow flight plane
- mishaps
- rib construction
- Ducted fan unit plans, drawings etc.
- MOVED: Help with modified Rocket
- c-17 globemaster plans/drawings
- Cessna Plans
- Table Saw
- Crooked Cowl.
- HUGHES H1 racer
- Cad designing
- Cad designing
- guidance needed desparately
- How to scale plans in Autocad 2004?
- power panel mounting dims needed
- AIRCRAFT SPEED
- Foam cutting device
- Online Canadian wood
- Any one want to Trade Plans?
- Help Getting Started in Scratch Building.
- Gas trainer
- Anybody heard of a Time Machine
- Airfoil
- CG HELP
- fiberglass mold maker wanted
- Need ideas on a plane quick!!!
- Calculating the CG..
- Skool Project.
- Help importing Bit Maps into Turbo CAD
- Nifty 80
- Wing Placement
- Turbo CAD 2D 3D V9.2 problem
- obeche veneer
- Scratch Built 3D
- Heavy Foam Wings
- Looking for Ideas for 1st plane
- Need Auto Cad 2004.
- Design template for conical tube ??
- First scratch build. (Cessna 182)
- Krier Kraft
- Dow Hi-Load 60 Foam
- laser 3d plan in dwg. format
- Free Cad Plans and Programs..
- Looking for a plan for Dalotel (.40)
- 2 oz FUEL TANK
- CAD engine plans
- How much vertical area for aerobatic Bipes?
- Anyone seen disc brakes?
- Tiger Moth landing gear plans
- ultimate Bipe - CG for Scratch build
- GLOW ENGINES
- Plotting on Autocad 2002
- vacum former and motor size
- Foam wing cutter from RCM plans
- DXF error
- Sig Smith Mini Plane
- Horten Ho229 ( version 3
- MOVED: ADVICE ON AUTOGYRO
- GIANT SLOWPOKE FLIGHT REPORT
- 40 size 3d plan
- Cutting accurate wing ribs on very tapered wing
- Calculating Wing Area?
- Building with lasers
- How should I finish my model ?
- Balsa and Ply densities.
- Yellow Bird
- This is worth checking out!
- wendell edge 540T HELP PLEASE
- Basic Model Airplane Calculator
- 3D CAD PROGRAMS
- Building Project Plane
- Midwest Delta Hustler
- Scratch Built Zlin 50L Update
- Wendell edge 540T
- MOVED: is a rudder really needed?
- Marking Balsa By ironing plans over ?
- WING SWEEP WITH BELL LIFT DISTRIBUTION
- Is a Lockheed P-38 lighting good 1st scratcher?
- Weed Whacker Aircraft Plans
- Plans wanted - help please
- CG on EDGE 540 is VERY SENSITVE
- How Much Dihedral?
- Center of Gravity
- North American Rockwell T-39 / CT-39 Sabreliner
- super sportster bipe plans wanted
- Adding flaps - proportions needed please
- Colour printer for custom Decals
- Carl Goldberg Extra / Ultimate
- Home made ducted fan
- Cadkey .dxf to ACAD opens poorly - ideas?
- HELP Royal Gull Amphibian plans?
- New plane out of foam
- Hot Wire Foam Cutter Connection?
- what would you like to see in kit form
- No Sweat
- Inverted V-tail or dual rudder P-38 style tail?
- Splicing balsa to make wide ribs?
- Contest balsa shortage?
- Built-up fuselages with CF tape ?
- Scale Bulkheads & Stringers?
- Looking fot Pilatus PC6 Plans
- Ultimate Bipe cabane and outer strut detail
- Super Stearman Airfoil
- Hot Wire Foam Cutter Guide?
- AutoCAD 2000 3D help needed
- Can this thing fly?
- Where to put CG on a flying wing?
- How to fix V-Tail to Carbon Tube
- Calling All RC Designers!!!
- Kudo's to you scratch builders
- ducted fan
- Scratching a bipe
- Need help on choosing airfoil
- ? engine for foam delta
- Looking for Concorde Plans
- Sig 90" Cub
- Built up wing construction questions - 75 inch Ultimate
- Beam motor mount question.
- Enlarged plans = Enlarged balsa ?
- 25" WS .10 POWERED STOP SIGN
- New wing airfoil for GeeBee r2
- Sure Fun Model AirPlane News 1957
- Wanted F7F Tiger cat drawing
- Aerobatic plans?
- ME - 110 Plans in a 60" span?
- Mitsubishi MU-2
- help DXF files
- foam wings
- A3D/A-3 Skywarrior
- Plans for 1\3 Scale Fokker Dr1
- First plan build
- DXF to . PLT converter
- my first scratch build
- new to scratch building
- landing gear
- Scratch Building requirement?
- Plans needed for Ninja Star.
- Finished my Ugly Stick
- needed plans for seduction aircraft
- Some help needed
- bi-plane CG?
- monocoat help
- Help with CG calculation
- Balsa or foam
- compufoil help
- Springfield Bulldog
- CAD advice needed
- R/C Trike
- Star Trek Fans check this out!!!!!!!!!!!
- Need plans for a stick
- CAD Models
- Electric Twin Engine Question
- Shear webs for a scratchbuilt
- home made paraplane
- A Gift for AutoCAD Users...
- software
- Need Some Plotter Help
- Flying Chair
- no more kits for me
- Beginner builder in need of help
- To Sheet or to build up?
- Plans for good trainer
- Cirrus Servo drawings
- What tools needed for Drawing your on plans?
- FINISHED! 154" Flying Wing
- 60size wing spar, spruce or balsa?
- How do I design my own plane?
- optimum dimensions for .46 3D profile?
- Exclusive-Modelbau the Funtana Pro
- Building within a fiberglass fuselage
- scratch building - i think i'll scratch that idea!
- looking for free plans for good second plane (low wing) e.g. sig 4 star
- How do you accurately transfer former position to fuse
- Anyone need plans converted to CAD
- What Biplane is this???
- Looking for plans
- Monokote Woodpecker
- die cut / laser cut service needed
- Scratch Built Ailerons and Flaps - QUESTION
- ACAD Mouswheel Zoom, Resolved
- bob holman cowl
- Ironcad Users
- Super twin motors.
- WHAT HOTS ?
- Swallow OX5
