PDA
View Full Version : Scratch Building, Aircraft Design, 3D/CAD
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36
  1. Where to find list, disappeared??
  2. Is rudder required ?
  3. CAD to laser cut question
  4. Pilatus Porter PC6
  5. Lines, show them or not ?
  6. Tiling a plan for printing
  7. turbocad qeustion
  8. mechanical vs Air Retracts
  9. Built up Wing
  10. 40 Size Laser 200
  11. new type of wing construction
  12. Champion 45 L Wing Leading Edge
  13. rudder size for bipe
  14. E-3 Sentry (AWACS a.k.a Boeing 707)
  15. Kit Bash - Add airfoil tail to Giant 9' Ugly Stick; Suggestions?
  16. Laser cut parts
  17. Retract installation help
  18. flattening a frustum
  19. ModelCAD or TurboCAD?
  20. 2deg washout but what incidence
  21. Hostetler Cessna
  22. Vari EZ 3-side drawing...
  23. Don't forget to look at the top post on this page
  24. Bill of MAterials (BOM) RCM Advanced Trainer
  25. Any good place whit plans?
  26. Wing design: When to use washout?
  27. Laser 200
  28. Airfoil on Kingair 200
  29. Advice Needed on Building Foam Core Wings
  30. My First RC Plane
  31. CAP 232 Wing
  32. CNC router motors
  33. New to design !!!!!!!!
  34. Anyone Have Plans for Cessna Agwagon
  35. URLs for Making Cowls/Canopies
  36. Where to buy Balsa?
  37. Agmaster Plans
  38. Have some questions about the plane i'm building.
  39. BF109 - Electric build
  40. plans
  41. JU-87 Stuka
  42. DOES ANYBODY MAKE PROPELLERS?
  43. transfering parts from plan to wood
  44. mm converted to inches
  45. P-47 Cad draw'ns ????
  46. scaled up CG Chipmunk
  47. Shutting down for the building season
  48. Swing Wing Aileron Function
  49. is there a "Beginners CAD" program out there ?
  50. Howto Remove old fabic and dope coverings
  51. Aerofoil Name ?
  52. Making a wing longer, what effect will it have ?
  53. Want to make a 3 ch plane, 4ch. Need help...
  54. I need a foam core wing for Edge 540
  55. kingcat cad
  56. New design question?
  57. Tutorial: How to use a plastic display model to create RC plans
  58. Plans hanger?
  59. Design idea?
  60. What Wing Profile ?
  61. Looking for Velocity XL RG Plans
  62. DC-3
  63. Control surface construction
  64. More tools
  65. MOVED: Computer generated NACA airfoils
  66. will this wing work?
  67. Ziroli panther nearing an end
  68. Plywood Question
  69. How do you build a two piece wing ?
  70. How to import airfoils into autocad?
  71. How much diheral for rudder only?
  72. Sig Trainers, from dihedral to a polyhedral. Can it be done ?
  73. need powerplant help
  74. Need help with wing spar dimensions and grain
  75. Electric Chipmunk Plans
  76. TurboCad Question
  77. Turtle Deck Equation
  78. Help please.....
  79. Stinson Reliant 3 Views
  80. Changing Rib Notch Size in R14
  81. Where can I find Plans
  82. calculating engine size
  83. Kadet LT-40 custom symmetrical wing
  84. Excellent Builder Wanted for Small Project
  85. calculating cg
  86. Lite ply reinforcement of wing spar necessary?
  87. C5A plans
  88. Uravitch A-7
  89. Ohio Chipmunk canopy
  90. Identifying airfoil
  91. halloween design
  92. Gear Design
  93. Free airfoil software
  94. Airfoils?
  95. F-19
  96. Hot Wire?
  97. Plug In Wing Tubes
  98. Reverse dihedral in foam wing
  99. wing location help needed
  100. Fiberglass Cloth???????
  101. Magazine construction article
  102. Tower hobbies...Is it a good source for wood. Where do you get wood?
  103. Aerobatic .45 profile
  104. 3D CAD AIRCRAFT MODELS
  105. Copying Plans
  106. AutoCAD 2002 question...cutting mlines
  107. Covering foam question
  108. How do you cut foam wing cores for a Spitfire?
  109. Ryan's rebel
  110. Need some wing guidance please.
  111. Monocote Hinges?????????????
  112. new to CAD...any suggestions?
  113. mass prod. balsa sheeted wings, how?
  114. First build
  115. 10mm aluminium square tubing
  116. CAD at Home
  117. Where to buy wing tubes (receiving side)?
  118. B-17C
  119. Having Trouble with foam cutting power source
  120. XFY-1 Pogo 3-view
  121. WingMaster II (Latest Project)
  122. .60/.90 Edge 540
  123. How to draw up plans?
  124. RcCad experiance?
  125. Plans for a P-51 mustang
  126. wing design
  127. Looking for Article
  128. Kerf in laser cutting - how much?
  129. 5 questions about scratch building! Please help
  130. Help! How will CG change if I add 1" in front & 2" behind the wing to enlarge fuse?
  131. Calcomp plotter manual
  132. simple plane to build
  133. Embossed paper tape rivets
  134. Butt Planking to Stringers?
  135. How many G's?
  136. Fuselage Lofting Programs
  137. Home Made Retracts
  138. Scratching a B-52
  139. Where do i start to build a P-51?
  140. B-29 or B-17 Planes
  141. need info on this plane
  142. Cutting out Wing Ribs
  143. Am i ready for scratch building?
  144. Foam Cutter
  145. New wing for my trainer
  146. Graupner extra airfoil
  147. printing to scale
  148. Where to buy foam for project
  149. Building photos
  150. fowler flaps
  151. Plans for large towplane needed
  152. BD-5 KIT
  153. Fundango Rudder
  154. Modified Sig Kobra
  155. Scanning Plans for reference and tranfer to CAD
  156. pre made foam wings
  157. Need plotter recommendation
  158. 3 view plans
  159. enlarging a Sig SE
  160. laser cutting of balsa wood
  161. designing a larger wing ?
  162. My Newest Creation
  163. rear end design
  164. solidworks files
  165. Piper Arrow 2
  166. Landing gear
  167. how many dpi to scan ?
  168. Question from a complete newbie
  169. Cloud Dancer 40
  170. epoxy or resin for making fiberglass parts
  171. Down thrust ?
  172. source for obeeche ( obechi, sp ? ) veneer ?
  173. What engine shoudl I get?
  174. Question about Autocad
  175. GP Big STick 40 Plans???
  176. Airfoil for 40% Extra330s
  177. Question about fuselage building
  178. Where's all the old threads?
  179. Model Cad 3000
  180. Straw vote on scratch building
  181. building two fuselages out of foam/ C130 hercules and a B17
  182. Sig Extra Airfoil
  183. 1/4 scale plane given to me! Questions
  184. Model Builder Plans Catalogue
  185. hatch pattern
  186. Gee Bee Z build report
  187. What size engines?
  188. WWII PLANS
  189. what is scratch building
  190. Mosquito advice
  191. Extra 300 and Cap 232 Airfoils
  192. Foam Wing Cutting...in the UK
  193. Flying Wing
  194. Drawingboard LT
  195. acad splines to polylines
  196. Wing Airfoil for IMAC Aerobat
  197. Wood hatch patterns for TurboCAD
  198. Looking at Biplane Plans
  199. will this work
  200. G. Bertella plans info?
  201. Cad Viewer ???
  202. RC Rocket Glider
  203. Any A-10 builders out there? (George Miller plans or 1/9th scale)
  204. Looking for canopys and cowls
  205. Landing Gear Dimensions
  206. Kadet Senior 200% Advice
  207. keith sparks a-10 plans
  208. wing design
  209. 60 size carbon fiber rear gear
  210. anyone have free autocad airplane designs?
  211. Supplies List for Bingo
  212. I need to build a profile fuselage - help
  213. Ordering Plans from RCM
  214. Cowl Painting
  215. Looking for Plans/Drawings 3-views
  216. eps foam?????????
  217. plywood help please
  218. counter-inboard drive
  219. Anyone Build this one
  220. Effects of increasing wingspan on G-202?
  221. Decal Making?
  222. Ken Willard design
  223. Time Saver
  224. Square Shooter Plan
  225. Constant airfoil thickness on a tapered wing?
  226. Concepts - Aircraft Power
  227. Ugly Stick Plans
  228. Really Big Hinges?
  229. "Big Pink" Foamie - 96 inches!!!
  230. Scratch-building canopy
  231. cutting foam for newbie
  232. New to CAD
  233. Compufoil Restore
  234. How difficult?
  235. Getting wing sections from Autocad.
  236. Fun Fly Airfoil needed
  237. morris the knife, from scratch
  238. Tiger Moth Construction steps (updated 09/09)
  239. Original construction article for Dirty Birdy?
  240. engine cowl
  241. Is it strong enough?
  242. graphics
  243. Rotary Launcher Assembly ?
  244. How to make a "plug" to do down/right thrust for slowstick
  245. what engine
  246. Spring Struts and Wheel Hubs
  247. who/where are ARFs built (profitable?)
  248. RC Dragonfly
  249. My 2 cent contribution
  250. Scale Conversion Program
