- CAD and formers
- Anyone got Bob Dively's number?
- scale edge540
- Cessna 150/152
- Need advice on design resources
- airfoiled tail
- help for designing a crazy plane
- midwest GILES 202
- Drop Box Plans Wanted
- 3D scanner & cnc mill
- help me identifi this staudacher
- Wheel Pants
- please help choosing airfoil
- Prop Hub....
- giles 202 3 view
- TurboCAD Question
- Chuck Cunninghams 62" Lazy Ace question
- First time design - thoughts needed
- Sig Kadet LT-40 Plans
- Make your own retracts
- Template transfer to wood
- Small 3d help
- Scratch Building
- 1/4-20 nylon screws on big birds
- Help choosing canopy
- PBF plans
- 25% Extra 300 plan needed
- Wing hold down configuration
- pasting fabric to plane
- A little CAD fun (Movie)
- vac forming questions
- Feathercut Video Online?
- Enlarging BT Typhoon?
- designing help needed
- Compufoil for fuselages
- Tail Volume Coeff of 0.3!!! is tht the problem?
- Wing materials
- I need help about using compufoil.
- Plan Resizing
- From normal to a canard.
- Airfoil analysis
- Miss Texas
- Looking for Plans of Parc - Amber FU 2 Funfly
- scanning into autocad
- Rebuild suggestions
- Swick Taylorcraft
- A Gas Powered Se-5
- rebilding a Sky Ranger Fighter
- Autodesk Inventor x Solid Works
- scale up sportster
- Why / When does taildraggers take over trikes
- Jack Bale Plans
- Anyone in Fla who can do Plug and mold work
- need help building scale emphanage
- Glass Cowl for an 83" Stinson
- %MAC and CG
- In need of a foam supplier
- Canopy
- wing strut materials
- Questions about Top Flight Cessna 182
- Feather Cut Instruction Manual?
- help me---what plane to build?
- Best Way to build a slab rudder?
- Mig 15 Drawings
- Recommended wingspan ?
- Looking for Canard Pusher
- Spars on swept wings
- Drawing Formers
- my next scratchbuilt project
- CG Formula for delta
- sliding canopy, how to make work??
- Ignorant Question(s)
- Canopy
- Laser Cutting from SolidWorks Models
- MLG Placement
- Where do you go to find.......
- New balsa supplier
- Gee Bee Z
- First SPA3D flight. needs heavy adjustments??
- scratch building without balsa
- do you qaxu?
- Help with ModelCad 99
- DeHavilland Dash 8 - 202
- SPAD Mustang
- another dihedral question
- First RC: uni assignment: has to be scratch-built! help!
- Opinions - Good aerobat airfoil???
- CAD Preference personal poll
- electric profile
- Scale Undercarriage
- Designing a "paraglider airboat"
- Great CARBIDE TIPPED blades for DREMEL Tabelsaws!!!
- Fiber Glass Cowl for ACE 230
- need help with ADDING flaps
- of plugs and moulds!!
- Calculating plane size for a given weight
- Plans for Spitfire 60 size
- Mike Pastro's A 10 Pusher
- Hostetler Cessna 182
- Fowler flaps
- please give yor opinion + photo's
- Star Wars X-Wing Fighter
- Ct-114
- building Sig SE - wood question
- Looking for composite aircraft plans
- Tower Hobbies Balsa
- Slow-N-Low
- autocad 2000
- Making a Kadet Senior fly even slower!
- Hostetler Pitts S1-11
- Wing Tube
- making my own fuselage...
- Profili airfoil help
- CNC foam cutter?
- Boeing C-17 globemaster III plans
- Vacuum bagging brown paper and foam
- Any extra 300L plans in the 70 or so inch range
- Springs in oleo´s???
- How to make a prop in SolidWorks
- cap 20L
- Nemesis 3 view needed
- Wing Area/Weight
- Chevalier's book
- Best Source For Balsa Ply????
- Another question on scaling up plans.
- New at this
- Plan for Edge 540
- floats for the super sporster!
- Super Chipmunk
- dlg glider design
- Newbie questions for building from scratch from Experts
- B777 Cad Plans, Needed
- AutoCAD Hatch patterns for Balsa
- Wing area scale factor....duhhh!
- Extreme Competition Fun Fly Plans
- Transall C160 Please please Help!!!
- DeHavilland Dash-7 or Dash-8
- Extra 300 specs
- Supercoupe II ??
- Plans for Edge 540 (for 90 sized engine)
- plan building
- Plan building, cutting out pieces
- Trimming soft balsa
- B-1B building.
- Horten IX V1 Center of Gravity
- Gee Bee Z
- Engine Drawings
- cg extra 300 fuel tank question?
- the chopperIII ???????
- RCV Engines
- AVRO Triplane - First steps
- looking for plans
- Hazer 1 Industries work horse
- Engine sidethrust and down-upthrust
- Edge 540 3 View?
- 'Nice Little Biplane'
- Need plan for small bipe....
- Musketeer
- Alum. tubing
- Control symmetry
- Computing Wing Area
- Building wings from plans? Help
- Shoestring in July Model Aviation
- Plane lighting
- Question on Wing Mounted Ailerons
- Been awhile
- Foam wing ribs
- Fuse Lofting Help
- Ultra Hots - Source for a short kit?
- new project - is this stabilizer big enough? + photo's
- dihedral question
- Wing Warps
- Su-31 cross section
- Pzl-62
- Mig 25
- Machining
- Australian Airtruck crop-duster
- Dennis Bryant 1/8 Typhoon(cutting)
- DIY Retracts?
- Morris Knife ???
- Wing Fairing Detail
- CNC Router
- Vintage planes
- EPP in the UK
- Can this plane fly, somthing totally differ
- Plans transferring on wood
- need info. on moldmaking & casting
- doing a re-design of a plane I destroyed!!!
- vac forming canopy question
- Tri-Star Dihedral ??
- how to convert a scanned image into an autocad file?
- Aluminum angle needed
- Quick, easy, airfoil designs
- Scale Measurements 1/72 to 1/5 scale
- question on nick zeroli corsair
- coreplast sheets
- Can it fly?
- Looking for Plans
- RE-Designing a Giant Telemaster
- PBY-2 (RCM Plan #649)
- Tapered Wing, only have root rib
- Can this plane fly?
- Question for you smart designers
- obeechi wing skins
- Glass Nose
- About to start building Ryan's Rebel
- Learning to Scratch Build
- My project. Your opinion???
- Source for aircraft plywwod needed. Please help
- wing bag
- Ohio Models GS540 Profile Plans???
- Not your everyday Laser cutting question.
- Not Really R/C But....CAD
- b-29 project
- fowler flaps
- Cad Software?? What to buy??
- crop duster?
- navion kit?
- Swick Taylorcraft
- turtle deck construction question
- URGENT!!! i need VERTIGO .46 VTOL plans
- Scratch Building A Frame
- Close post please
- 1/4 scale Republic Seebee Plans
- good 3-views
- Will It Fly? 5/27/03
- Trim to Spline in CAD?
- Need Help!!!
- Plans for 3D Giles
- Plans for WW1 Planes
- Sandwich techinique on building wings
- Full fuse to Profile fuse
- Edge 540T wing profile needed
- Fuselage length
- light ply sources
- Modified Ultra Hots Takes Flight
- Cloud Dancer 60
- looking for fast build plans
- cessna 170 plans ?
- help to down size of EDGE540T 33% to use .60 engine
- plans for a gee-bee Y, (80inches+)
- Looking For Drawings Of..........
- Is the Spruce Goose Finished?
- Bigger Ailerons
- Frise Ailerons
- Dream tools
- Looking for someone who converts Paper Plans to AutoCAD
- How do you attach YOUR canopy?
- Transavia AIR TRUK help!
- where to place main gear
