PDA
View Full Version : Scratch Building, Aircraft Design, 3D/CAD
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37
  1. Calculating wing area
  2. Need F22 Raptor Plans
  3. Toot Sweet
  4. covering painted fiberglass
  5. Mark Sirianni 80 inch Sukhoi.
  6. scratch built seafury
  7. installing & aligning retracts in foam wing
  8. Tango ultralight
  9. Advice on wing modifications.
  10. Making ailerons?
  11. What to use for balance weight?
  12. Film over foam---help !!!!!!!
  13. Is there any site about the weight of the plane with the side of the engine?
  14. Wing / stab height difference
  15. I have a problem with schratching 3-views to plan.
  16. Template for a CAD drawing?
  17. Scale Rivets
  18. Books on designing model airplanes?
  19. My design....
  20. Fibreglass fuse techniques
  21. CNC foam cutter ?
  22. Are You Finished building that 35% kit?
  23. Anyone built a Vertigo, designed by Tom Hunt?
  24. e-powered glider
  25. Kit Cutters
  26. Layup ?
  27. plan gauge for finding correct angles?
  28. Custom Cores
  29. Hughes XF-11
  30. floats
  31. to FLAP or not to FLAp that is the ?
  32. Songbird's color scheme?
  33. ModelCAD?
  34. Plotting airfoil in AutoCAD
  35. butyrate dope? where can I find it
  36. Cd's of Plans
  37. twin tail superstar---With new inflight/rebuild/recover/crash pics!!!!!
  38. Copies of purchased plans
  39. Predator!
  40. ACAD plan copy legal ????
  41. Need 1/4 Scale or 1/2 scale plans.
  42. Foam Cutter Wire Help !
  43. Need help printing/plotting
  44. I plan to build pod & boom r/c - first plane
  45. CNC file compatability?
  46. All set up!
  47. will this fly
  48. Which Stpper Motor Controller?
  49. can i do this with a cg extra 300?
  50. Looking for decals for a 1:5 scale WWII Bird
  51. What CAD to go to, or stay?
  52. CG question
  53. VAC U FORMs
  54. Ace Parts ?
  55. best machine for
  56. tailfeather reduction?
  57. Physics Project
  58. spy planes
  59. Wing design, airfoil & dimensions
  60. Profili 2 is looking for suggestions...
  61. Carbon Fiber Spar???
  62. I want a plan for a Sport model of 72 in wingspan
  63. Engine + prop size decision for flying wing
  64. First "Scratch Built" plane questions.
  65. Lining Up Templates on a foam wing for hotwire cutting???
  66. CAD files of SU27
  67. Best place to buy bulk balsa in Australia (Melbourne)
  68. Is Sullivan S523 Kevlar cable coated?
  69. Beaver plans
  70. A Quick CG Question
  71. competition grade balsa
  72. F-117
  73. Building Royal Corsair and SCALE Tail Wheel!
  74. Laminating foam core wings
  75. Where to get Balsa the cheepest
  76. What to use for tiller on pull/pull rudder?
  77. Dual Wing plane
  78. CNC Wingtip Tanks
  79. How to build wash out in a foam wing
  80. Does anyone have plans or working on kitting H9 330L?
  81. Metric Plywood
  82. Scratch Built Cowl
  83. Searching for 2 views of Rascal
  84. Landing gear fabrication: Bending Steel Rod
  85. Extra 300S test
  86. spar question
  87. Lightning an Ugly Stik
  88. stringers/size/scratch
  89. Scratch building G.Morfis 1/12 Spitfire
  90. HELP! Model Cad or Whatever???
  91. 1/20th balsa.
  92. My Design
  93. Got 2 questions
  94. At-6
  95. Giant Goldberg Tiger
  96. Machinist wanted in Scotland, UK
  97. Scaleing up a twin
  98. iron-on covering
  99. Radios
  100. Scratch Building
  101. Hangar 9 control horns
  102. Need Cabanes bent!!
  103. Ultralights
  104. 3D Model for a Prop
  105. Vacuum bagging for a beginning modeler?
  106. Bruce Lund Plans?
  107. How to run rudder cables?
  108. Sukhoi Su 37
  109. Which way for grain of a tapered D-box sheeting?
  110. sealing a plane with clearcoat
  111. Autocad R13
  112. Su-27
  113. building plane/electronics
  114. Will Crisco work for me??
  115. NEED PLANS FOR A Extra 300s
  116. Auto Cad Help
  117. CNC Foam wingcutter
  118. Monokote and ultracote-Limit sales?
  119. Scratch building a Corsair Tail Wheel
  120. Will this Engine mount work?
  121. Need Painting Tips
  122. Wauplane, does this fly?
  123. Can Someone Help Me Find Plans That Are Free?
  124. 1970 Bridi Kaos from Plans - Balance problems
  125. Plotting service
  126. GP F-15 Custum cowl
  127. Root Ribs & Diahedrel ??
  128. HELP NEEDED: Scratch building Vulcan B2
  129. Make a wing tube socket?
  130. Balsa questions
  131. looking forlazy ace 62" plans
  132. canopy Help
  133. 36 Inch With Limit On Printing ? Why?
  134. My edge 540
  135. Need Patch for Cad 2000 to win Xp
  136. Can Anyone Print A Plan Sheet For Me?
  137. looking for plans?
  138. DH.71 Tigermoth-still looking
  139. Shark!
  140. Edge 540 Plans
  141. When to begin scratch building?
  142. FeatherCut Bow Wire
  143. How do you design your scratch built jets?
  144. How Do I: Aileron Differential
  145. Need Plans Drawn
  146. just wanted to share L-39 I wokring on
  147. cad plans drawn for you.
  148. JM-II -- Anybody see this before?????
  149. Covering the plane!
  150. building question?
  151. Bobcat / Bobcat XL 3-views Wanted!
  152. Printing .dxf )("&/%)(/")/("!!!!!!
  153. predator feat. global hawk
  154. bash 4* into Corsair??
  155. Floats
  156. how much wieght for a.61 motor?
  157. Looking for Su-27 dxf drawings
  158. toni
  159. Giant Su-Do-Koy
  160. can anyone here print plans
  161. Big stik 60, funny one
  162. oleo struts?
  163. pilatus pc12 or cessna caravan plans?
  164. Miles 20
  165. Any one building a F-5 Freedom Fighter / Tiger
  166. How to calculate control surface deflections given servo arm lengths and rotation?
  167. Scale gear...... who makes them?
  168. i am stumped hope someone can help
  169. Big Ole Bipe
  170. My first scratch build (tips)
  171. Glass Tape?
  172. Scratchbuilding: Ribs & Bulkheads
  173. RCM Magazine
  174. enlarging plans help please
  175. How to calculate the CG???
  176. Plan info on the The Vamp
  177. Sheeting thickness for foam fuse
  178. Turtle Deck
  179. Fuel Tanks
  180. Glider engine??
  181. Wing-it
  182. This good ?
  183. How to from plans
  184. Plans
  185. Lazer cut wing ribs
  186. Scale down plans ?
  187. Operating Cowl Flaps
  188. Fuel Pump
  189. Enlarging Brian Taylor plans?
  190. Autocad R14 Help!
  191. what are the guidelines for designing your own plane
  192. Any alternatives to fiberglassing a fully balsa sheeted airplane?
  193. Spray Paint instead of Dope
  194. Ju-878 Stuka from Ziroli Plans.
  195. Design CAD Good or Bad ?
  196. Need HELPPPP Painting / Covering WOOD..
  197. Need Help on Fiberglassing Materials
  198. Need Help With Heatseeker II
  199. G loads
  200. B&D Retracts
  201. Monocote stretching?
  202. Scratch Building Tech Help on cutting
  203. Wright building board
  204. vacuum bagging equipment
  205. Need Your Input - 3D/SA Airplane Design
  206. wing sheeting
  207. filling the gaps, or, good looks are everything
  208. Diy Cnc
  209. looking for good Free cad for win xp
  210. My scratch built bipe
  211. Drawings for .60 rear needed
  212. Getting Started!!!
  213. Scale Drawings Needed
  214. Construction Website for Palmer C130
  215. where to find A 10 warthawg Plans? 60-120 size
  216. Cutting parts
  217. Wax
  218. Plan Enlargement???
  219. Sending Large Files By E-mail?
  220. GMax
  221. CRJ-700
  222. adope photoshope qyestion
  223. Foamcutting tapered wings - attachment points?
  224. Christian Eagle Plans
  225. Canopie plastic
  226. What does "SPAD" mean?
  227. removing monocote
  228. HOMEMADE RC airboat
  229. Plastic Covering debate
  230. Laser Cut Parts...
  231. Where can I get carbon fiber sheets? online or otherwise?
  232. Ultra Hots Kit Bashing
  233. Where can I buy Obeche veneer?
  234. Three questions: Carbon fiber and Coroplast
  235. Need a good airfoil for a foam wing
  236. My Next Scratch Built Will Be....
  237. Is there anything stronger than balsa with which to build a plane?.......
  238. Adrenaline (my latest design) - Pictures!
  239. Servo Three Views
  240. Bu-133 Jungmiester plans?
  241. Check out this link in the Half-A Forum....
  242. Sig Cobra
  243. Rutan Quickie
  244. plans for hobbico spectrum
  245. Lazy Bee Giant? need help!!
  246. Pull_Pull
  247. Fairey Barracuda plans
  248. Newbie Questions.
  249. kLETT LANDING GEAR
