PDA
View Full Version : Scratch Building, Aircraft Design, 3D/CAD
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36
  1. do you have any neat CAD plans?
  2. Warped wing
  3. CAD airfoils, engines, etc...
  4. Elevator Horn
  5. Designer NEEDED!!!
  6. How to make foam cutouts for wing spar?
  7. Miniature Table Saw
  8. Styrofoam Sheets
  9. Profile plane
  10. Aircraft Design HELP NEEDED
  11. Burt Rutan's Quickie (Q1) Design
  12. Where to buy good plans not a kit.
  13. p2v plans needed
  14. Piper Seminole lll -_-_-_-_-_-_-_-_- !!!!!!!
  15. c-130 cad plans
  16. How to lay out Plans on CAD?
  17. Need help - Building from scratch
  18. plans for pober pixie
  19. Mig
  20. 1/4 scale Pitts Special Plans Help!!!
  21. Question about carving propellers
  22. Where can I get a custom canopy?
  23. Foam Density
  24. CAD or Hand Designed
  25. Best Piper Cub Plans
  26. bob holman bf-109e
  27. sources for learning
  28. hOSTETTLER CESSNA 206 DRAWINGS
  29. CAD drawn engines/misc
  30. how to view the full document in photoshop???
  31. b-2 bomber
  32. HowDoI aluminum blade spars
  33. Fokker DR 1 Plans
  34. top flites stinson reliant anyone built one of these
  35. Lockheed U-2 plans?
  36. graphics for decals
  37. selecting a suitable airfoil section
  38. photoshop error what does it mean????
  39. kit cutter??
  40. Decal & Lettering
  41. what software do i use to convert tif format???
  42. what can i do??
  43. md-80 airliner
  44. Beech 18 - Graham Hughes ??
  45. cherokee plans?
  46. plan elarging help please?
  47. Aluminum instead of Balsa?
  48. Laser 3D
  49. Hiperbipe Plans
  50. Plotting question
  51. Own made planes
  52. what software or procedure do kit manufacturers use?
  53. cg super chipmunk wing type?
  54. question about rccad
  55. my some what own design, IT FLIES GREAT!! Update: rudder problems.
  56. what glue to use????
  57. whats the best way to attatch wings?
  58. giant pt 40
  59. giant pt-40
  60. 3D Models in Flight Sim Programs
  61. Converting To Dfx?????
  62. Washout Question
  63. Pro Engineer 2000 Software
  64. Setting up pull/pull system
  65. How do I clean the wire from my hot wire bow?
  66. Falcon 56 and Sr Falcon
  67. giant pt 40
  68. Our Big Delta (82")
  69. help, I need drawings !!!
  70. Shoestring
  71. need some sugestions please
  72. another
  73. First Build from plans..... Were to begin?
  74. Help with Propeller Design!!!!!!!!
  75. An easy to use CAD program
  76. Scan to AutoCAd
  77. Dornier 335
  78. Delta Building plan(n)es ?
  79. Software name search
  80. weight vs thrust
  81. Airfoil for Quickie 40 or other speed plane?
  82. RCM Construction article wanted
  83. G.55 Centauro - 3 views anyone?
  84. Zagi Style Wing Dimensions Anyone?
  85. servo calculations for giant delta
  86. Plan for a 0.40 trainer..
  87. 3D designing Software?
  88. Cowl Design: "X" in = ? out.
  89. 3/16 ply?????
  90. Laser-cut parts on AutoCAD???
  91. Prototype Flying wing
  92. aeromaster plans?
  93. Crash course in plaster of paris
  94. Help!!!
  95. Plans from a 3-view
  96. just wonering....
  97. just wonering.....
  98. Best Cad & rastor/vector Combo?
  99. First scratch for the itch....
  100. Need Info on Plane - Bar Fli
  101. whats everwons oppioin on the 50sx
  102. Large foam blocks
  103. Foam cutting of irregular shapes? Please advise...
  104. Foam cutting of irregular shapes? Please advise...
  105. Plans for Super H.O.T.S. 60 size
  106. acad2000 Scaling
  107. Looking for Storch Cad Plans or 3 Views
  108. What material to use for non metalic pull-pull setup?
  109. Autocad Scaling Question
  110. Plans enlargement
  111. Those who have quasi-machine shops...
  112. Custom Built Wing Building Jigs For Sale
  113. Plug surface finishing question...
  114. Foam Wings
  115. aerodynamic books
  116. Looking for Scale C130 Plans
  117. One more foam cutting question - bend in wing core ok?
  118. Twin Boom
  119. Need Help CG For Sig Sometin Extra
  120. twin engine ?s
  121. Looking for A-12 Drawings
  122. Shrinking plans?
  123. Convertible Bipe
  124. Wing Building
  125. Anyone built a Cessna 208 Caravan?
  126. Civilian plans,can't find THE airplane
  127. Remove or leave the line of the pattern when cutting out ribs,formers,etc ?
  128. Incidence In Ziroli P38
  129. P-51 30"....Will it fly? Please HELP
  130. 37% ultimate aileron servos
  131. 3D Modelling
  132. Cleveland airline plans
  133. Fibreglass vs. Built-up cowl
  134. 10" Table Saw v.s. a 4" Table Saw?
  135. Ziroli P38 Center Lines
  136. CAD questions?
  137. stickit v
  138. Beginner Scratch Building Questions
  139. Plans in .DFX format
  140. grate table
  141. In flight CG adjustment.
  142. Need a viable foamboard airfoil design...help.
  143. Looking for Piper Tri-Pacer Plans
  144. yak 54 plan or drawings
  145. Need advice for balsa stock purchase
  146. foam cutting - tougher than it looks!
  147. Starlet
  148. Homemade Sanding Tool
  149. Join a design group
  150. Source for Shaped Leading Edge ?
  151. Help on CG
  152. Decals?
  153. General Questions
  154. Giant Delta! 86 inches!!
  155. First scratch built kit, need some help.
  156. 33% Extra 300s wing cores
  157. Henry Haffke GeeBee model Y
  158. Avro Arrow Cad plans
  159. Spar notches???
  160. Foam Rib Construction ?
  161. Aircraft outlines?
  162. First design... need help, using AutoCAD R14 AEC
  163. 3D Design Help Needed
  164. Fuselage construction
  165. Tricycle gear or tail dragger?
  166. Beginner's question
  167. OV-10 assembly suggestions
  168. Delta
  169. wing tube Q&A
  170. Former thickness
  171. thread rolling
  172. Help with Servo control line Installation
  173. desighning and building a delta.
  174. help
  175. Howard Hughes H-4 (Spruce Goose)
  176. I am not worthy!
  177. pneumatic cylinders for retracts
  178. Importing scanned drawings into Drawing package for resizing?
  179. coroplast
  180. Polyester resin over epoxy resin??
  181. Where do I start
  182. CNC Programs
  183. Beaver plans
  184. where to get plans down sized in n.c.
  185. Joining three piece wing
  186. wanted plans for Kingfisher seaplane
  187. D-18 beechcraft
  188. Rutan Proteus 3 view
  189. plans for ultimate for 100cc motor?
  190. Biplane vs Single Wing
  191. Scaling a .pdf file
  192. Where can I find plans for a Dehavilland Twin Otter ?
  193. 4 planes linked together
  194. Dual Fuel Tanks
  195. Freeware program to print dxf file?
  196. Need Help in V-tail area size selection
  197. Mr. aerodesign
  198. cnc foam cutter plans wanted
  199. Need Font for registration numbers
  200. Pushrod Question For 1/2 Scale
  201. WTB 1/3 scale J3 cub plans
  202. You can build a cnc balsa plane part cutter!
  203. Has anyone built a Curtis Hawk P6-e?
  204. CNC WING CUtting
  205. Is it possible to scratch build a plane with Bob Banka's(sp?) 3-views and foto paaks?
  206. Purpose of Dihedral
  207. where to get plan?
  208. "Open" Design
  209. A-6E intruder
  210. TurboCad V8
  211. Physics sim proofs unique concept
  212. 3c/cad
  213. Looking for plans or partial kit of MacchiMc72
  214. Bowman R/C address
  215. Where to get .cor and .dat files for airfoils?
  216. biplane windscreens
  217. please help
  218. Three View Drawings of Ultimate Biblane
  219. avond's 1/10 F-14 Tomcat
  220. Software for 3D modeling
  221. Upscaling/downscaling plans - ??
  222. Oversize Laser Cutting ?
  223. Edge 40 Scratchbuilt
  224. Foam wing building
  225. Rich Uravitch 52" OV-10 Bronco, Linkages?
  226. Fome cutting bow
  227. laser cutting costs
  228. Hinge Poll
  229. Browning .303 Machine Gun
  230. edge 540 airfoil
  231. Looking for plans
  232. Three View Drawings
  233. How much right thrust for 150/180 Saito FS?
  234. Curtis XP55 .61 on the building board anyone??
  235. Custom-built gearbox?
  236. Tinting canopy darker
  237. Check This Out........
  238. edge 540 airfoil
  239. 120 powered Pitts
  240. bending balsa laminations
  241. Profili programme
  242. "Profile" software - anywhere on web for download?
  243. XB 70 Drawings and info.
  244. Some Help Please!!
  245. Art Chester Jeep Plans #758
  246. New version of Profili, 2.10
  247. Scale 3-views
  248. Aichi Val D3A2
  249. enlarging tiger 60 140%
  250. Space Shuttle ?
