- blowing up plans for twin Otter
- Buillding twisted trailing edges
- P-38 Lightning Plans
- Scratch build suggestions?
- Glassing wings / Need help
- Where can I find some good plans to build from
- anyone have some extra 300 3 veiws?
- Where can I find a 40 or larger size decathlon plan?
- acrobat,jpeg gif to dfx ?
- Seamaster 40 (kit) C of G?
- Melting lead for balast
- Balsa USA Enforcer
- a-10 twin ducted fan
- Diablotin plans?
- cbm f-16 instant mold???
- NEED HELP!!! Scratch-building a V-22 Osprey
- Weedwacker powered Spad!!!!!
- Beech Starship & or b1b
- Does any one have the april 2002 issue of model airplane news?
- Are there any good FREE aircraft design programs out there?
- tutor 3-views
- How do you join wing halves for transport?
- making fiberglass fuselages
- Foam plug question
- Laser cutting
- Anyone built the Modified Seamaster 40 from Glenn Morris Plans ?
- Scratch Build Discontinued US Aircore Planes?
- Cutting small pieces from big pieces (stated as simply as I could)
- brown paper??????
- Paints to match ULTRACOTE??
- help electric push prop jet
- How do you guys cut balsa from plans?
- Tailplane Positive Incidence / WASHOUT
- glassing?????
- Ugly Stick Plans.
- R/C Hang Glider?
- denatured alcahol??????
- hot epoxy??????
- Kamera Karrying Kadet (from tbzep post in "big and slow" thread)
- Thick wall AL tubing for pushrods
- Which airfoil software?
- Oracoat Oracover?
- seeking saito engine 3-view
- Templates
- Documentation
- Where to download CAD programs
- Uravitch OV-10 Bronco 80"
- Foam Cutting- Nicrome wire???
- Looking for Plans for the GP F4 phantom
- Is It Fussy Or A Must?
- Re: Sizing Spars
- Dassault Falcon 7X
- great planes f-4 phantom????
- scratch build Gee Bee
- FanTrainer
- Looking for a Big and Slow Airplane
- Bob Holman Plans
- O.K., no built-up balsa/ply delta plans. How about profile .15 fun-fly's?
- Spitfire and Zero
- Ziroli Ringmaster?
- too big???????
- crashed trainer, needs a fuse, plans?
- c/g question
- Built-up Delta plans, anyone?
- Byron Web Site
- New gallery/tutorial for CAD added
- Hovercraft plans
- articulate good builder, interested?
- Wing Tubes: Where To Buy?
- Brazing/soldering 1/4 in LG wire??
- wing design
- Duplicating plastic model parts to R/C size
- Reforming a canopy
- dh2 instruction manual
- What company has the best quality Balsa?
- horizontal stab size
- Engine Cowl Painting
- Spruce Goose
- first scratch building project...edge 540 profile
- I found them thanx please close
- Wings?
- Lettering
- when did you first scratch build?
- T-tail mounting glue, screw or both?
- Astro Hog
- building some planes blue foam
- Do I still have to 'glass it?
- Downthrust? Rules of thumb?
- Help with landing gear design.
- Christen Eagle 3-views
- Fiberglass fuel tanks
- kits built
- jet airfoils
- Alotta design questions...
- What does it take to build a ziroli aircraft?
- I need a source for Blue foam
- how do i cover a plane with silk or glass
- How to Calculate Control Surface Power
- Vacuum form custom canopy
- Carl Layden plans (Caps)
- Help w/ TurboCAD files
- West Systems Resin Epoxy
- Source for balsa
- Full flying control surfaces
- Airfoil design software
- Monocoat Hinges?
- Macchi C202/205 Wing
- V-Tail design Question
- piper cub wheel help please
- Homebuilt lazer cutter
- Plans for extra/cap
- avonds f-14 plans info?
- four stroke pump?
- Transferring Large Patterns to Balsa
- Plans anyone ?
- avonds f-14 tomcat
- i think i need to see a head doctor
- Dura Fix
- Kevlar Question
- Bob Holman
- Lettering
- First plans-built project - Balsa Spars???
- Sopwith Triplane
- Scaling Up A Set of Plans
- band-saw
- 33% edge 540 need help
- Thinking of scratching a large profile...
- Plot files from DXF Files ?
- band saw?
- From 3 views to plug?
- Too much side thrust???
- testors paint on foam?
- vacum bagging??
- painting foam question
- Minature Hobby Band Saw?????
- Scratchbuilding on a budget
- Baseball Bat Plane?
- Biplane Quirks!! Incidence??
- autocad
- plans for planes
- AV-8 Harrier ?
- Help in CAD Design
- inland hobby band saw??
- problem plotting with HPBL plt files
- pattern making
- Drilling holes in balsa sheet
- 1/3 scale Edge 540T plans
- KC-135 R Strato tanker
- F-16 Agravation
- Philip Avonds F-14?????????
- Model Cad?
- Single fuel tank twin
- f-14 info
- haideez bomb?????
- Interesting thread, should be here.
- What CAD/Scratch build projects are u working on?
- homemade ducted fan????
- Formica?????
- a-10, Dean question
- Super Hots Bipe by Floyd Manly
- Speed Wing Bipe by Hal DeBolt
- F-14 Plans
- A-5A scale info
- A-10? Plans
- A-10
- A-10???
- Cg.....on F-16????
- Getting started with scratch building
- Excellent Choice
- Fiberglass finishing
- alternative spar materials
- ThrustHP a Little Optimistic?
- Canopy for Long EZ?
- strengthening 80" foam wing
- ShoeString
- need canopy
- Foam Ribs
- Bit Map to ?
- Help! Need to find Ultimate Bipe Plans(Thanks For the Help) (Please Delete)
- Recommended Online Sources for Balsa?
- Flying Novelty Board
- Plans
- Gotta love the twin Otter
- Fly Baby...
- thinning epoxy
- Leading edge flaps
- Styrofoam
- C-130 Hercules Blue Angels Fat Albert
- momas iron??????
- How do I go about designing a simple EDF beginner model?
- Hi-wing profile? Possible?
- Need advice on V-tail! Help!
- SPAD Debonair
- How do I make a foam cutter?
- Foam/Composite Source Here
- How to transfer root and tip rib to a PC program
- what is a .dc file?
- (please delete)
- B1B pics
- Playmate Troubles (Help!) Please
- Master Cam *
- templates?
- Is it better to design and build a smaller model and then scale it up?
- Does anyone know any tricks or rules to making a scratch-built?
- Custom vacuum formed parts ? Who makes them ?
- laser cutting
- Airfoil for elevator?
- Laser cut with AutoCad
- Sniff....My Dremel Table Saw #580 is toast.
- Plan stuff ?
- Engine thrust angle
- Canadian Kit Cutters
- Scanning photos to cad
- Hots Plans
- Engine placement question
- flying lawnmower
- Painting Checkerboard Pattern
- Harrier DF plans?
- Composite Plane Project
- Water base polyurethane for cowl construction ?
- Which airfoil for me? (using Stefano Duranti's Profili 1.2)
- Connecting Wing Half to Fuselage
- What about plastic fuses?
- resins?
- Area ratio, wing to H. Stab??
- Where can I get a CAD designed engine?
- How many ribs do I need in a 60 inch wing?
- Freeware airfoil program?
- Mac Headers????
- 3D Meshes for Gas Engines?
- Corel Designer
- Thrust offset for Twin
- AUTOCAD Question
- SPAD Trainer or Foamie trainer
- Economical Plotter/Printer?
- Scanning large images
- Pro/E for non-commercial use for $15
- SNS-7 Hyperbipe Plans
- Wing rib lofting
- Engine Boxes
- Laser cutting
- Just Plane Dumb
- Bagging wing skins
- aluminum wing tubes and phenolic sockets
- Cutting Kevlar
- CG calculations...HELP!!!!
- Retracts
- Does anyone use CorelDraw for plans?
- Cutting foam wings
- Design Software
