- Wingloading and ballast calculator
- Scratch-Buildong?
- BeckerCAD
- Digitizer Tablet ***SOLD***
- Hot wire cutting foam-Stainless steel
- Heat treating muisc wire.
- How do I scan full size plans?
- 3D CAD Aircraft
- Anybody know where I can get plans copied cheaply?
- Two Sheeting Thicknesses in CompuFoil?
- What's this?
- New Fuse
- Precision Scale King Air Project - Updated 08-23-03
- Aluminum spar channel...where to get them?
- CAD refrences for first time builders
- Rc Cad??
- lazer cutting video
- Why A Female Mold?
- PolyU over finish resin glass
- Foam Wing cutting
- Plugs and molds
- C-130 Hercules Photo
- Cost of printing dxf
- Rapid Modeling
- extremely high gloss clear coat?????
- rc flight unlimited
- nichrome wire ??????
- CAD. Where to start?
- Forward Swept Wing
- 3'' foam ??????????
- Combat Models F-16n Modified
- Laser Cut Ribs
- Scratch built canopies...how to?
- brown paper covering
- Looking for 42%-46% 330 cowl&canopy
- Heli Pilots?????????
- giant giles 202
- towerhobbies
- Horten IX plans
- os engine 91fx woodruff key
- pink foam??????????????
- Let's see your CAD RC images here
- RCM Seamaster II
- How do I print a .dxf?
- heli engine-homemade pipe
- pusher pusher pusher--
- mini tools
- Sheeting An All Foam F-16
- Airfoil for vintage scale glider
- foam fusealges etc.
- r/c trike??
- Grumman F3F-1/2/3
- C-130 Hercules Templates
- foam
- Weight - Foam vs. Built Up Wings
- plans for a quaker
- Cutting ribs when you have only tip & root sections
- autoCAD98lt
- Composite hollow wing seam
- Plans for Fairchild KR-34C aka Kneider-Reisner C4C Challenger
- canard airfoils and info???
- turbocad update
- Plans 3-views for Hawker Series
- Bob Holman Plans
- Charlie Smith Plans
- copying plans
- Good aerobatic airfoils
- help with corsair flaps
- Good source for photos and 3-views
- Engine mounting
- Scaled down airfoil
- make your own pusrods?
- This is your "Design Specifications" library!
- Scratch built Speed 400 Fantrainer
- Foam Wings
- Forward Swept Wings
- Right Thrust question
- Yf-22
- Big Lazy Bee fuse w/ Arf wing??
- Cutting balsa from plans...
- Three piece wing how-to
- Plans for building scale corsair (who's & why)
- Fiberglass skin over foam wings vs. balsa
- CAD Software
- Check In - What CAD Tool ya Using?
- CAD Parts (everything that goes IN the model)
- CAD Model Engines
- New ideas for the Design/CAD/3D threads
- Added aircraft design/3D/CAD to this forum!
- Blue foam
- How do I start scratch building a new plane?
- Citabria/Decathalon 3-views
- Ordering Wood For Plans ?
- cutting wing tube holes in foam wings question
- Long-ez or BD-5
- Alternative Materials
- Ziroli Suhkoi 1/2 plans
- design help
- wing loading
- Big printers ?
- "LAZER WORKS" ***Quality Kits!***
- Scratch Builders! What Set of Plans are the Best to Build ?
- Cowl flaps ?
- I have an odd question ?
- Vacuum bagging ?
- Fiberglass fuse and wings ?
- Hinges
- Kit Cutting?
- Covering
- palmer plans BD-5
- How to cut holes in ribs?
- Plug-In Wings? How to...
- Basswood vs. Spruce- What's the diff?
- Cessna T-50/UC-78/Bobcat/Bamboo Bomber
- Cleveland model supply corsair plans
- OS 61 FX CAD Drawing Needed
- What types of wood????
- Ugly Stick
- Is there really a need to mess with laser cutting parts?
- Has anyone ever seen plans for one of these?
- Balsa wood for project, Please Help!!
- Grumman Skyrocket XF5F -1 & XF50
- OV-10 Bronco
- CNC Foam cutter
- White J-3 Cub
- wholesale hardware???
- Retractable Gear
- scratch FA/18 .20-.25 pusher control throw help
- Landing gear size
- 3D computer aircraft models
- Looking for a builder
- Buiding a Foam Cutter
- Carbon Fiber
- Washout
- Foam Wing cutter
- Anyone familiar with the Pole Star?
- Scratch newbie
- Cutting wing tubes on foam wing
- Making a Fiberglass Nose Cone
- Aerobatic Plane
- Wood.
- 1st. Scratch Project-Lazy Ace
- mould maker
- Wing Plug-ins
- New Moderator
- Cessna T-50 Bobcat
- ...and I mean SCRATCH
- Breezy?
- Curtiss Jenny JN-4 Plans
- Getting Started
- MAN - Plans Service?
