- FUSELAGE CONSTRUCTION NEED HELP GUYS!!!!!!!!!!!!!!!!!!!!!!!!!
- Need a mentor scratch build Bob Aberle's Piper Cub PA-11
- Ultra Sport 1000 bash (help!!!!)
- Scaling down a " Flying Machine"
- I can't be the first do do this: $5 Foam FF Plane to R/C Conversion
- engine mounts
- Dave Fritzke Jr Falcon Flys!
- LOOKING FOR PLANS FOR THE SIG KAVILIER
- SAAB JA37 Viggen
- Does anyone still just hack it & see?
- Snoopy's dog house plans
- need help finding parts...
- Another 'HOTS' only bigger !
- could someone demonstrate something for me?
- A new sport plane using Stick 40+ parts
- CadKAOS
- wingmast software question
- What is scratch building?
- first kit build
- Ryans Rebel Build Thread
- Gee Bee Racer
- Help with my own creation
- model airplane news may 2010 shoestring racer scratch build
- Need some help with cutting formers
- Scratch Built Flight Box
- CAD Parts Library
- J2M3 Raiden in 1:5 scale
- Mount engine on top
- Extreme Kaos
- Can anyone help identify this plane ?
- Solid Foam Plane
- WHICH TOOL?
- MAN 04742 Pitts S1S
- Super Lazy Ace
- 1/3 Scale Pitts Build
- Anyone using National Balsa?
- Vailly Aviation Typhoon
- Lofting formers
- Equavalent material
- TSR-2 in 3D
- Anyone built the Super Hots .60????
- new plane
- quesion about drawing plans from an arf
- Maiden flight!
- Dave Platt - Bucker Jungmeister
- RCM Ultra Sport 60 parts list
- Airfoil questions
- OS .40 LA CAD Drawings
- Scratchbuild 50cc whatever
- OCE Pen Plotter
- Canard building tips
- From 3D to foam plug
- 2000-EF Typhoon project
- kadet senior plans
- Can I use these plans?
- Ever use plans from Cleveland Model & Supply Co
- steen skybolt R (culp special)
- building a rubber band powered flying wing
- How to make a complex canopy??? (for a Ziroli Ercoupe)
- LITE WING
- "A Beginner's Guide to Cutting and Bagging Foam Wings" DVD
- PTC Pro/Engineer: anyone designed in it?
- Amazing SU27 build!
- Stinger 120
- RC Modeler Magazine?
- Making Your Own Veneer Plywood
- Decals
- finding CG?
- Hughes H-1 1/4 scale
- 1/2a stealth sport
- FOAM CORES CUT CNC
- Scratch Built Cartoon Cub Model
- airfoil template
- Anyone built a Canada Goose?
- profile plans?
- F-104 Landing Gear
- should I
- scratch build
- Scale AGC-8 Waco Cabin Bipe Build Thread
- Balsa
- CorelDraw for Drafting
- K&E Drafting Machine
- Laser CNC router help
- prop plane to DF conversion
- Plans Available
- 1941 Aetna-Timm Aerocraft plans search
- Aluminum Landing Gear
- Skyvan
- Scratch Built Predator Drone
- CHALLENGE!
- Need Help With Retractable Nose Gear set up.
- Cessna 337
- HOW TO MEASURE THE CC OF A TWO STROKE ENGINE?
- Pilatus PC9 1/3 scale
- 3d to 2d exporting?
- Phoenix Az Bluecore??
- looking for 1/3 plans
- Any other Tile Printing programs out there?
- B-17b plans highly detailed
- Comet Jetliner Help
- strip planking
- scratch built Extra 330
- Working with Balsa Sheet
- telemaster plans
- Laser Cutting Service? / RFQ
- Small Aerobatic help
- inexpensive cad programs
- Need Edge 540 plans!
- 3D Printing for Protoyping
- cheap software
- cooling a warbird engine?
- many plans for model aircraft for free
- How to build louvers for Curtiss Jenny Cowl?
- Costum Airplane Help needed !
- I am building a Not for sale
- Gee Bee R3 anyone?
- B2 Stealth Foam Bomber..cheap way
- First Profile plane
- Little Foamy
- Anyone building a Ziroli P51 with a fiberglass fuse?
- Malyuta Avionics: How to design your own aircraft walkthrough
- Ziroli Dr.1, need laser cutter recommendation
- WACO Custom Cabin project
- Malyuta Avionics: Low-wing docile flyer build (designed by me)
- How do you get your plane sponsored?
- New wing design for a different plane
- Any free rib plotting software for wings?
- Midwest Tri Squire
- extra 3.25 plan questions
- I need a good idea for relocating wing servo
- piper tri pacer
- Check out David Glen's 1/5 Spitfire!
- Any body want free plans for an Extra 300?
- 1/2 scale Stits Sky Baby Build
- Looking for help from you. How best to cover the CAD topics?
- CAD Discussions and Model Design Tools
- Heat forming clear plastic
- Free Plans and Design Aids Links
- Norseman project
- PA-18 Super Cub- Ed Westwood Plans?
- 33% and up sporting aircraft plans
- Home Made Strut Clearances
- Maricardo 60 build
- good for something...
- RC Modeler Magazine search
- FOAM CUTTER POWER SUPPLY???
- FREE Vultee XP-54 Modeling Data Guide
- Strach build Extra 300
- MOVED: naca airfoils
- Foam Wing Question
- Micro Telemaster Converted To Old Timer
- helpp...ULTİMATE or PİTTS special plans !!!!
- 1/4 Scale Ryan STA
- Drilling Lighting Holes
- wash in and wash out
- Cessna 172 Wing cross section ?
- triplane
- I have A Major Problem
- Christian Eagle Plans
- Scratch Build Graphics Tools
- Making Carbon Fiber Landing gear?
- Workshop size
- Please, need plans
- wing angle of attack
- Sorry Autocad
- Wing camber and chord - grand caravan
- scratch built hot wire cutter
- Source for fiberglass panels? (circuit board type)
- Fuse Sheet Grain Direction Question
- New build
- sig kougar wings?
- CNC Foam Cutter Build Thread
- Dumb Air Cylinder Question
- 1/12 to 40 size..??
- Model of Yukikaze?
- Building a scratch drop box. Imput requested on design.
- Need help
- Spitfire Kit
- Dave Platt FW190
- 72INCH TRAINER
- Help with Fabrication...?
- MAN Plans
- How to model an aircraft
- Cad files for common parts?
- Ordering balsa etc.?
- D&L design edge 540
- Hughes H1 scratch build.........
- CAP 21 (great planes)
- Fiberglass cowl build advice needed
- Travel Air 6000 Scratch Build growing in my head
- nemesis racer
- Laser cut kits
- Need help designing front end of Antic/Jenny
- First Scratch-Built. Does it look like it could fly someday?
- what kind of foam is this?
- what do you think
- plans to kit
- Custom Cowl and Canopy???
- Nelson's clear coat
- Where do you get your Balsa from?
- Weights to glue joints?
- Arizona Models' Fokker D7 and Albatross D5
- Curved gear door hinge line????????
- Trailing Link Strut Replacement Spring
- Chrome Plated decals?
- Source for spar quality spruce for monster Warbird?
- Shortening ARF Wingspans
- Laser cutter?
- Adjustable pitch props?
- COVERING MATERIALS.
- Printing decals
- royal clipped wing supercub
- 3D Pilots Busts ...
- "CAD for Modelers, Volume Three" coming in late November, 2009
- What airfoil to use?
- mister mulligan plans
- Hughes H1 Racer plans?
- Sheeting a tapered wing
- Glow-powered foamies??
- Full Wing Flutter
- Bigger Ugly Stick
- wing tips ugly stik
- extra gone bipe
- servo tubes
- Scratch Builidng a Plane
- Plans for AT-6
- Pica History
- Ash Chamber Added To An Ugly Stick
- Check If I Have CG Figured Out Correct
- Landing gear construction
- Need help picking materials to build with ;)
- Overweight Precedent BI-Fly 25 : what to do ?
- Ikon N West Plans for Vega, Winnie Mae
- This book is Volume 1, were any other volumes published?
- PLYWOOD SUBSTITUTION
- 3D Pantograph to copy models?
- Buil a mini F3A / practice machine. Need input from scratch builders.
- 0
- 0
- Canablize this park flyer?
- Wing tubes
- Wing tubes
- Robart #677 1/2" Trailing Link
- plans..wilga
- best canard?
- Nostalgia
- Landing Gear
- Me-334
- Cheap and Easy Static Display Props
