PDA
View Full Version : Scratch Building, Aircraft Design, 3D/CAD
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. Goldberg Bucker Jungman templates & patterns
  2. Scratch built Hog-Bipe in Havana.
  3. Will a spar cause lift, or drop?
  4. Yard Sign Coro 3D-Design
  5. Large Format (Banner) Printer
  6. Noob power system questions
  7. Millennium RC X-Gear
  8. PDF to TurboCad
  9. Designing my first Dollar Tree Foam Board plane FB-1
  10. C-141 design
  11. Scratch jet design
  12. Replacement Extra 300S & Cessna 180 Kit Plans Needed
  13. Senior Telemaster Engine Thrust Angle and Wing Washout?
  14. First timer at scratch
  15. biplane plans
  16. Hobbico Hobbistar 60
  17. Venom2.0
  18. Spacewalker 2.2m wingspan
  19. Latest design
  20. Converting *.PDF files to *.bmp, *.tiff, etc.
  21. Nitro Foamie design overview
  22. 3-View help, Curtiss R2C
  23. Martin Baker MB.5 Giant Scale Build
  24. Self,Rotating,ROTARYWING Thread
  25. Check Out the GREEN Hornet S.R.W.
  26. before I do it, I ask "what would you do"
  27. new plane creating
  28. Looking for Byron MIG-15 drwings and manual
  29. Hughes H1 3D Printing and Composites
  30. Which wood can i replace with basswood?
  31. Easy 200
  32. New Era III from RCM Plans
  33. sport bipe plans
  34. Meisner 96 inch Spitfire
  35. Design Plans RC Laser Cutting DXF.
  36. Regular guy scratch build an f-14 tomcat
  37. Draftsight Does Not Download
  38. Tower Trainer 60 ARF
  39. First time plans builder
  40. Looking for Aeroworks graphics
  41. Is there a formula for adding flaps and ailerons to a wing ?
  42. Laser cutter
  43. Designing Controls Circuit of a plane
  44. Cessna 208
  45. Nick Zoroli Turbinator Scratch Build
  46. Junkers corrugated skin
  47. !/4 scale Cessna O1Birddog
  48. Pattern Material
  49. Old glow trainer to electric
  50. Controls Schematic for a rc plane built from scratch
  51. Mounting fixed landing gear without glue
  52. Dynam dc3 with hobby zone floats none permanent idea
  53. Pitts S 12 plans
  54. Electric start system and on board glow system,
  55. Electric start system and on board glow system,
  56. Motor burning out troubleshoot
  57. Balsa wood Supplier ?
  58. Would this design work?
  59. Airbus A 380 Rubber Powered - 3
  60. F86 Sabre + A 380 designed in Rhino
  61. Rc fighter ultralight
  62. My 4th homemade rc plane Carf Yak 55
  63. Turbinator sport kept scratch build from nick zoroli plans
  64. How to design based on landing and take off distance.
  65. My 3rd scratch built Sbach 342
  66. My 2nd scratch built plane AJ Slick
  67. My First Scratch built plane Cessna 182
  68. Building 1/12 scale radial engine cowl
  69. Pellicano glider plan
  70. Fuselage Jig
  71. Wing Bolts binding up in receiver
  72. Scratch build McDonnell XP-67
  73. Models of model aircraft for laser or CNC cutting.
  74. Models of model aircraft for laser or CNC cutting.
  75. plotter to mill conversion
  76. Scratch Built Kwik Fli III
  77. F-35 EDF to pusher conv. [General build help]
  78. Looking for Blue Flash Plan from Fly RC July 2007 Issue
  79. Lazy Ace Biplane build from coroplast
  80. Handley Page O/400
  81. Slim Jim by Lazer Works Engraving??????????
  82. What materials to use?
  83. de Havilland DH88Comet - Joe Colletti plans
  84. Plan Enlargement
  85. The Ultimate Buddy Box Club Trainer
  86. Materials Required
  87. yellow angry bird
  88. Need DC-4 / DC-6 plans
  89. Henschel Hs 132
  90. Draftsight Will Not Download
  91. TBM 700 scratch build at 35% scale.
  92. precision cut kits vs lasercuts usa
  93. determine how much balsa sticks needed for scratch build
  94. Looking for C130 Plans
  95. AutoCAD Circle Dimension Leader
  96. Cutting wing and fuse off a PDF any ideas?
  97. Flat Head Screw Hole Dimensions
  98. Help My Computer Crashed
  99. How do I figure CG?
  100. Scratchbuild 20cc STOL
  101. Engine offset
  102. Painting Depron
  103. Second Iron-On Covering Job
  104. Spraying latex paint
  105. bud nosen cub
  106. 3D Modeling/3D Printing
  107. Scratchbuild a Curtiss Hawk III (BF2C-1) in 1/4.5
  108. Hysol vs. 30-minute epoxy w/microballoons
  109. Thinking of useing carbon fiber tube for leading edge of elevator.
  110. hinges
  111. Looking for F14 Plans
  112. Good laser cutting job from Lasercut USA
  113. Wing servo mounts
  114. Good place to copy plans 1:1 or enlarge them.
  115. Gee Bee Z (my homemade)
  116. First Time Building from Plans - Grumman Cougar Twin
  117. Checking those drwaings before sending them to the cutter. using 2d CAD
  118. Starting New Project RCM Cessna T-50
  119. Grumman Cougar - From Plans
  120. Top Flite Seafury Ribs and former templates wanted
  121. Ultra Stick 120
  122. If only one saw for scratch/plans building, BAND or SCROLL... which one to go with
  123. Blender-Tutorial for a RC-F-104 Starfighter ready for 3D-printout
  124. C/L to R/C with an I-Beam Type Wing
  125. How do I find my CG of my scratch built delta wing before I fly it ?
  126. Cnc Foam cutting with Arduino - Development log
  127. AJ Savage plans by lewis pencoast
  128. Help with finding Golden Era Plans by Lewis Pencoast
  129. scaling up
  130. Plan for Lockheeed L188 Electra.
  131. Good Place To Buy Balsa
  132. Fuse Former Question.
  133. Satisfactory power to weight ratio for sport flying .
  134. Plan Modifications
  135. 2007 to 2010 Workstation
  136. pica kit parts needed
  137. Question about cutting parts from the plans
  138. devSim Cnc Foam, a new free application
  139. Pitts Special plans
  140. Decals
  141. someone to cut foam cores
  142. Box-o-plywood or Box-o-balsa
  143. Speedwing dart
  144. Bud nosen mr. Mulligan windshield.
  145. A10 Thunderbolt II Scratch Build
  146. KFM6 wing help
  147. Building a wing from scratch (no plan)
  148. Ugly Stik Wing
  149. Would someone here cut some foam core wings for me?
  150. S.T.A.R.S. Fokker DVIII build
  151. Cessna L-19
  152. 120% TF Red Box P-40 in 21 Days
  153. Pitts 12 41% Trueworthy Plans bigairplanes
  154. Looking for Canard Stick CAD plans
  155. SW or iges F-15 CAD
  156. Super Sportster 90-120 and Easy Sport 60 from plans
  157. Feiseler Fi-156 Storch 1/4 Scale CAD
  158. Faded plans can you restore them? Trick to getting color back
  159. Aerodynamic design
  160. Big flying wing design
  161. Wing joiner
  162. microlight wing plans
  163. MayDay, I mean Maiden Flight
  164. Free-flight to RC B-36
  165. Templete
  166. First foam rib plane design
  167. LOCKHEED S-3a VIKING TURBINE INCLINATION
  168. washout question
  169. North American T-6F Texan 62" 1/8 Scale
  170. Tricycle landing gear mains angle of attack?
  171. Wing Design Program I'm making
  172. Isabella Electric to ENYA Conversion
  173. Allen's Ziroli B-25 101" Build Log
  174. Escapade
  175. Twice the Spirit of ST. Louis ?
  176. Big Hots (91") Bill of Materials
  177. Laser Scan Service
  178. Amazing New 3D printer
  179. OPtions for Enlarging Plans
  180. Boeing 727 question
  181. Goldberg extra 300
  182. Aircraft wing design questions
  183. Big slow floater for 60 PAW diesel that can swing a 18" prop
  184. Airbus A321 scratch build
  185. G M Sunbird
  186. NotForSale plans??????????
  187. foam floats
  188. Savoia-Marchetti 56. My lifelong obsession!
  189. Building Tips and Tricks Sticky
  190. Giant Scale about 50%
  191. 72" spitfire from 1/4 inch foam
  192. i just want to be clear on this.
  193. 71 inch wing on a trainer meant for a 64 inch wing,....any problem ?.
  194. Custom Zagi HP-60. Build Thread!! GoPro Canopy with Carbon Spars
  195. larger version of Miss 2 with ailerons - dihedral ?
  196. We may not be able to this anymore...
  197. too heavy ?.
  198. Balsa nose cone construction
  199. Super Contender Build
  200. Don Muddiman Flying Machine???????
  201. putting stringer notches in polyline or regions.
  202. Ov10-D 96"plan
  203. float plane down thrust
  204. tricycle gear placement ?.
  205. AutoCAD 14 Incompatible With Windows 10
  206. Scratch building flying boat
  207. Pull-Pull cable routing
  208. Scratch Build Electric Conversion Based on Midwest Super Sweet Stick .60
  209. Tail Skid
  210. 1:8.5 mu-2j
  211. Pusher thrust angle
  212. 3D Laser Scanning
  213. enlargeing plans
  214. Polecat rc plane
  215. Cessna 188 Ag Wagon
  216. 130% Lazy Bee scratch build...complete build
  217. cg question
  218. Doc Mathews "Big Old Bipe" plans wanted
  219. make an offset fowler flap linkage
  220. Fpv 49 flying wing
  221. Modifying AW Pitts Python 50 cc
  222. Light Lite Ply
  223. Darth vader secretly filmed in his latest death machine protected by stormtroopers!!!
  224. Hand made aluminum wheels (With Bearings)
  225. Ambroid gone?
  226. Design Tips for Lighter and Stronger Builds
  227. Hemlock spar size?
  228. Sabre XLT Giant Scratch Built Turbine Flying WIng
  229. Lockheed Electra 12A Build
  230. B-17 Build
  231. Finished Avro Lancaster - 5' wing span
  232. C-47 / DC-3 - Build
  233. De Havilland Mosquito - Build
  234. Free Foam Board Plans
  235. Airtronics Jetfire 20
  236. Looking for an online wood suppy house
  237. 1/3 Cub Build
  238. Kwik Stick I
  239. How to cut out for muffler
  240. Bench
  241. DHC-3 Dehavilland Otter
  242. Stitts Sky Baby-A Giant Among Lesser Planes
  243. Looking for trainer plans
  244. DTF trainer build
  245. 3-D CAD model of .40 size glow engine needed
  246. Globe/Temco Swift
  247. How to Determine Engine Placement?
  248. Royal Marine scratch built seaplane
  249. Corsair canopy
  250. Scratch building a foam Wing.
