- spad gnat combat
- PROJECT: SPAD WONDER
- My first SPAD
- Spad S.P.A.D
- NEED CORO IN INDIA OR UAE
- Electric DDUST pusher
- my pair of 3d spads
- Another Deb takes off
- Mini Gee Bee Spad
- Tail Wheel for Spa3dt
- CORO WINDFALL??
- Spadet question??
- Flying Pumpkin
- SPAD3d-40 size
- HARBOR SALES
- SERVO PROTACTION?
- Help new guy
- Plans for a new spadder?
- HOR flying
- a smaller SPAD
- SPAD receiver foam
- New SPA3DT
- Weight and Balance Question
- 2mm coro?
- how do you make a symmetrical airfoil?
- CA???
- What is the best 3D SPAD design?
- spadet lc-40
- Need Help
- Todays the day!!!
- Windy SPAD Flying
- Anyone ever thought of a spad biplane
- Big Spads Question
- Has anyone build and flew a GNAT with a.25
- Anybody tried this yet?
- QHOR 40, OS 50 Ok?
- check out my new Spadet or is this just a spa3d forum
- SPA3DT--Whats the minimum power?
- debonair
- SPAD Deb and Wing build
- Winter in Russia (Moscow)
- Stiffer coro
- Thank You!
- Gluing Coroplast
- SPA3DT Square Tubing?
- most popular
- Drop a parachuter w/out an extra servo!
- Simple Plastic Shin Protectors
- S.P.A.D questions
- WHAT ENGINE TO USE?
- Another MCP question for Dave
- SPA3DT Question
- Hybrid? McDDD-T finished RTF!!!
- engine question for spadders
- Where the SPAD meets the Balsa
- New S.P.A.D. pilot
- SPAD3D landing Gear
- Anyone ever built a weevil?
- SPAD radio
- Bucket handle landing gear
- SPA3D Wing Question
- Spad 3-D landing percentage
- SPA3D Question
- Pizza Boxer
- 1/2 A SPAD delta wing.
- SPA3D Spars
- Another McDDD
- Enough Power
- Question about a Flat Spin
- really dumb question?
- Question about the SPAD Demon?
- Aluminum U-channel too small
- Question on wing building
- my firts own design!
- Too much fun!!
- New McDDD-T ?
- Which fly's better ?
- At LAST I GOT IT
- Modified SPA3D
- My SPA3D
- wire hanger for pushrods
- Another Spa3D
- New To S.P.A.D.
- Where can I get a Spa3d?
- Spa3d and 25cc Homelite Ultra Stick videos
- Mini Coro-Zagi = SPAGI
- SPA3D flat spin
- Rocket Assist SPAD
- Anyone have plans for a Piranha-type SPAD ?
- Spa3dthp (tubular holey profile)
- 90 DEGREE SPA3D PICS & FLIGHT REPORT
- SPA3D or SPA3DT
- good picture during take off
- PBF Videos
- fastest spad
- spad3d photos
- Free Coroplast?
- Spad 3DT
- Which One?
- SPA3D, first flat spins!
- Electric HOR
- SPA3D Inverted Flight???
- Design Question
- All new Spad3D
- SpadStick :stupid builder mistake
- SPAD3D Wing and General Coroplast Question
- SPAD3D
- Handy coroplast cutter
- Which prop for a little bit heavy Spadet with debonair wing
- wHAT IS THE BEST COMBAT SPAD PLANE
- Gliders
- SPAD Hinges
- what servos to use with deb
- Help find This SPAD's Design?
- SPAD3D-J Wing performance upside down
- Cor-Star 60 Version 2.0 plans and pics
- Help w/ SPAD3D
- SPAD: How to pronounce?
- Giant Ultra Stick Spad
- Liability of SPAD
- PBF like QHOR
- UK SPAD Builder / Supplier
- Corrplast for Spad3D
- TWO MUCH THROW??
- throttle servo?
- servo size/spa3d
- New biggun
- New engine for my DPS
- Debonair wreck
- 11 x 7 prop
- Easy 2mm coroplast in Australia!!
- flown my new pbf
- gutter pipe?
- New Engine
- Bipe Flat PBF!
- www.spaduk.com - any one home?
- Cor-Star 60...V2.0
- Ok all u spadas@'s i got a BUHOR ???
- wing mount
- HELP WITH TOWER .46
- coroplast questions
- SPA3D Engine
- My new Dapstik
- I'm burnin extensions
- SPA3D idea. has anyone tried it??
- A SPAD3D varient
- Really small PBF
- help on pbf
- Stinger by Kramer????
- nylon or plastic tubing for pushrods
- 2mm Wing vs. RNAF Wing - Which One?
- flew DDust in the high wind today....SERVOS to small???
- SPA3D more fun
- FNS.40 size ? anyone done LG on this thing?
- spadet tail question
- Building my first SPAD and got a question
- SPAD for RealFlight G2
- MY NEW PLANE!!!!! :)
- My First SPA3D
- Can I use a Debonair wing on a Spadet?
- Need Some Spar Design Advice
- Giant Flying Car info
- control surface problem
- First big Spad
- Correx/Coroplast in the UK
- SPAD3D Balance
- SPA3DT
- My SPA3D (A little modified from the original)
- Need 2 mil coroplast! SE Wis.
- Spad 3D first flight
- What SPAD to build with a Mag 80 4-stroke
- Lite SPA3D build and (CALM WINDS) Flight report.
- palns for .074 PBF
- What size prop
- HOR mods
- First spad3d ever
- SPA3D setup
- PQPorsche Flying Car
- rigid, light square tube fuselage for McDDD
- SPAD SRR
- QHOR/SPA3D HYBRID
- Dirty SPA3D
- Japanese Zero
- What do you think this will do????
- Coroplast supplier in Dallas Tx.
- SPAD parkflyer
- Help with flying fish
- SPA3D Modificationsfor better KE performance
- coro weight?
- Looking for PVC Downspout in Houston, TX
- SPA3D Prop & Wing Question
- More secure horizontal on SPA3D?????
- Hovering Combat
- Has anyone built the PQPorsche Flying Car?
- Need a Bit Of SPA3D Help
- Please suggest a good starter with upper end possibilities
- PQHOR Oscillation
- tailwheel fix for SPA3D
- DDust 1st flight .....fast, are'nt they?
- Night Flight
- 48" spa3d
- SPA3D Plans
- SPA3D vs QHOR
- Nothing Special
- McDDD videos
- Big McDDD videos
- HOR with LG...what will happen if.....?
- how to remove colors on used coroplast ?
- Kite plane
- PVC glue
- Spad3D videos! check it out!
- spad trainer
- SPAD3D
- Any spadders in South Carolina?
- QHOR Motor Mount Breaking
- No More Bent Channel or LG on SPA3D
- Opinions on the BUHOR
- SPA3D Question
- gluing wing spar on sat nite special
- calculating build dimensons?
- Type of glue for coroplast
- Flying Car ???
- Monokote covering on CorPlas wings
- Spazzler plans
- Coroplast in the Houston, TX area
- When is a SPAD a SPAD?
- Hey Tattoo!
- Spads strange behaviour
- Oh No! Another Of His Dumb CG Question
- Set up poblems with dual aileron setup
- Another QHOR Question "What Prop."
- SPA3D HOVER QUESTION
- SPAD
- wingtip question
- GeeBee PQHOR CoB
- I'd like to build a trainer for my son, is SPAD recommended?
- What You Need?
- QHOR Question
- Tattoo is back on RCU!!! ???
- How do you get hardened fuel off 4 stroke exhaust ?
- Handibond Plastic CA
- Spad Glider
- Heavyweight
- voting time is good!(Free coro)
- Coroplast mail bins
- Gnat Question...
- Help on building 60" wing
- painting spads
- Calling All Engine Experts
