PDA
View Full Version : S.P.A.D. Aircraft - Coroplast design
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18
  1. A Plan for a Barracuda
  2. Best prop
  3. 1st. Malaysian-Spad DELTA
  4. Switch location
  5. spads in northern alberta
  6. Coroblast (Qhor with fuse)
  7. spar location?
  8. wing and horiz stab alignment issue
  9. How easy is this?
  10. Another probably already answered question
  11. What's a good spad combat?
  12. Another DEB question
  13. The New Improved PBF
  14. Can't get 2 mil Coro
  15. This pizza has pants!
  16. E-Dazi question
  17. Design help
  18. Purple 24" .15 coro delta. Swap meet style.
  19. 65" WS All 2mm
  20. Cranking up the QHOR
  21. Looking for H9 Ultra Stick 40 tail Dimensions
  22. Another question about Firewall Material
  23. Iron Spad
  24. What to do ?
  25. Another annoying question from gr8johnson3
  26. New Spader
  27. Woops! with Video!
  28. Large Stick - Wing Question
  29. .25 Trainer
  30. My PBF Indoctrination
  31. Fun Fly Wing Thickness
  32. Demon
  33. New wing for HOR?
  34. Best open class spad?
  35. spad intercepter
  36. Spar QHOR
  37. Big Ugly
  38. Scorpion flight report
  39. BUHOR Weights
  40. LHS question for everyone...
  41. My Profile spad
  42. 106MPH from a CoroDust
  43. Spads and friends!
  44. Deb Fuel Tank
  45. CG 5" behind spar what to do?????
  46. 2" pvc?
  47. dogfighter
  48. Spad Building Contest Now Open
  49. What Is Woodpeckering
  50. Recruiting Spadders
  51. Deb Firewall Material
  52. How much does your QHOR weigh?
  53. Spadders in W. Ma.
  54. PBF - 1/4 20's attaching vertical stab?
  55. Coflute + glue no hassle
  56. Bamboo skewers
  57. Pvc Rails
  58. New Spadder alert (soon hopefully)
  59. New to Elevon's
  60. My hangar
  61. PBF radio
  62. SPAD X-wing
  63. SPAD Throttle Servo Location
  64. bult my first wing!
  65. New Q-Hor thread
  66. Commercial coroplast planes???
  67. Need a .32 size spad, bad (Elgin IL
  68. Not gonna make it to SPAD fest
  69. A New Pilot???
  70. Dominator
  71. Coroplast supplier in So. Cal
  72. What is the best tranmitter for trainer
  73. will this really fly...???
  74. Thanks to all
  75. Deb 2nd gas tank
  76. Poly glue
  77. 2nd plane recomendations
  78. Another beginner spad w/ material questions
  79. Seven Iron
  80. Qhor W/fuse
  81. New quick build delta!
  82. I need some 2mm coro
  83. found source 4 x 4 vinyl posts
  84. possiblle lighter wing ???
  85. will a debut fly with an ap .15?
  86. WHICH eng for first SPAD
  87. corodust
  88. debonair?, spadet?
  89. Will it hover?
  90. what is spad
  91. 1st Debonair plus Questions
  92. my 1st SPAD and dam proud of it
  93. Delta Wing?
  94. Harbor wont ship 3' x 4' anymore?
  95. $100 for coroplast?
  96. Twin Tail BUHOR?
  97. pbf landing gear???
  98. New LLONNNGGGEEERRR QHOR
  99. Wing prototype testing platform
  100. The "real deal" on Q-HORS ?
  101. Hybrid Wing Const Coro over FoamRibs
  102. Houston, We have liftoff! (tee dee QHor-FF)
  103. Wing
  104. Teaching with SPADS
  105. wings help
  106. semi & semetrical wings help
  107. Need tank for OS 91
  108. How do you tell when the CG is right on a PBF?
  109. BUHOR alternate material question
  110. Kansas City area supplies
  111. Spadet Landing Gear Help...
  112. Hor Rivets
  113. new guy in need of advice
  114. Any spadders for southwest Georgia or southeast ALabama?
  115. SPAD builders in Middle GA?
  116. Lightening hole dimensions
  117. 1" pvc pipe spar
  118. Venting some SPAD Frustration!!!
  119. Q-mini-spazzler
  120. Hi Tattoo and Kraut!
  121. Where can I get the PVC???
  122. Who is "GodSpad"?
  123. Perry Ga. swap meet Spad Report. Spads and Spadders were there!
  124. Them spadtothebone guys done it twice in April 2003 R/C Report! Bonus spad dps how 2!
  125. Prop Strike.....with Picture
  126. Need Help!!
  127. Thanks
  128. Plan CG importance
  129. Just sayin Hi
  130. Question on Aluminum
  131. Another QHOR
  132. Need SPAD Info:
  133. Problem trying to make the Spadet vertical stab?
  134. Big Q-HOR w/folded spar
  135. CC Edge 540 Video!
  136. magnum 46 Qhor
  137. advanced scale techniques
  138. Micro Edge
  139. First SPAD Delta Stealth
  140. Coro source? Lodi or Stockton, CA?
  141. Aluminum size for HOR?
  142. What is Goop?
  143. Looking For Spad Fliers And Builders In Oregon
  144. No Ailerons nor Elevator? Coro-Later!
  145. Qhor 25 size with os fx 46
  146. What do you use for aileron hinges?
  147. Looking For Spad Fliers In Oregon
  148. Dad's Bad Spad - my new baby
  149. I dood it! The Sickle flies
  150. Giant SPAD ??
  151. need spad ideas for a os 10
  152. pizza box flyers?
  153. Q-BUHOR almost ready
  154. Any spaders in Kentucky/Ohio area
  155. "1/2 A" & "1/8 A" Coroplaste Plane
  156. help
  157. Just A Thought
  158. My first Q-hor
  159. What's the most usable engine in the .25 to .40 range?
  160. A new born SPAD
  161. Night Flying PBF
  162. Speed 400 PBF Plans?
  163. Coroplast 10 MM material
  164. Bicycle spokes as pushrods
  165. Have You Did This???
  166. Yet another SPAD boat
  167. How much Corplast does it take to make a SPAD plane?
  168. HDPE motor mount question
  169. LE CRUSHER! (Simple Rounded LE Jig)
  170. QHOR with 3/4" Square Tubing Fuse
  171. SPlaTH
  172. Debonair
  173. OK, so where can I get Coroplast to make a SPAD plane?
  174. Flat Bat Fuselage - LawnDart.Bat
  175. cheap wire pushrods
  176. Engine mounting..opinions wanted
  177. Qhor Rocks!!!!!!!!!
  178. Debonair Engine
  179. B size C/L SPAD?
  180. Qhor-Hell Ya!!!!!!!
  181. Building a FatBat
  182. 9 New Designs!!!!!!!!
  183. Got Fuse ?
  184. QHOR,30kt winds and me!
  185. What's the easiest way to lighten the fuse?
  186. 1st Plane **Micro Rudder Rail**
  187. 2 more videos
  188. CG Locations for Skewed PBF
  189. Any SPADers in the Springfield/Bolivar MO area?
  190. Debonair
  191. test
  192. Got wing bolt methods anyone?
  193. PVC size for OS 91 FX
  194. Thanks guys for all the help started it today....
  195. SnoMoSpad or Spad-Sled???
  196. Ways to bond wings together
  197. Anyone fly in Chapel Hill, NC?
  198. Wing mounting for a symmetrical wing?
  199. Pvc Cleaner For Flashing
  200. SPADFEST Events
  201. New to spad
  202. First Spad - The Holy Roller
  203. Wil the snow & rain STOP
  204. DuraPlane = Qhor
  205. SPADFEST 2003 Update
  206. Factory cut ends on PVC
  207. Design opinions and a reader question
  208. Yet another new QHOR
  209. hey hack
  210. Hey Mike
  211. Downthrust....how?
  212. Vanilla Coke QHOR
  213. Debonair wing with no dihedrial
  214. Coroplast wing on a Sturdy Birdy?
  215. Antbody in the UK
  216. Trainer style .15
  217. QHOR flight report
  218. Qhor- Model "FF" (funfly)
  219. Spad Finishing Tricks
  220. Wooden Yardsticks in the UK ?
  221. PBF for cpmbat?
  222. Can you identify this plane and tell me about it?
  223. Coroplast and PVC pipe
  224. 6 foot wing on Debonair??
  225. PBF first flights
  226. Gas engine conversions
  227. Wing Tips Anyone?
  228. Hand Toss Glider for my boy
  229. 6 foot wing on BUHOR.....woohoo
  230. Is my Debonair too heavy?
  231. Spad Demon
  232. Spad Demon Tail Feathers
  233. Picture posting problems
  234. giant dura-spad
  235. Micro Mini 8" Wingspad Spad Tri-plane!
  236. My new low wing spad!
  237. I think we all need one of these!
  238. Wingload Questions
  239. Spaggis, Coro Zagis
  240. Here it is The NEW Fuzz
  241. Wing weight...
  242. Where to find clear coro
  243. RC Report mag..
  244. Giant Spadet...
  245. (QHOR & SPA3D plans here) Wing with no spar and no glue needed
  246. Redneck Windsock
  247. Who has the smallest pbf out there that fly's?
  248. Fuse Former Question
  249. Its too heavy, but i'll post it anyway (tee dee stick
  250. SPAD Cub
