- Sonic Spad
- My little twin.
- free plans
- Low Wing, Tail Draggin S.P.A.D Debonair
- Setup on Sickle
- spad-buggy anyone?
- How do I make a catapult?
- 31cc ryobi
- Coroplast in Cedar Rapids, IA ?
- SPAD Sickle with pics
- What about the wing incedence?
- Dogfighter crash
- New Diesel 61 SPAD
- Anyone have a picture of a dual aileron setup?
- Corocub flight report with pics
- Maidened my first SPAD today.
- FNS .15 Carnage
- Tufflight 4D design, Tattoo
- Flying GTP Car
- Wiffle ball bat designs
- Dogfighter all done!
- A new Delta on the air - Faaaaassstt
- Wing spar glue
- Need ideas for my next SPAD
- Check Out the "SGV3"
- Float Fly May 6&7 Binghamton, NY
- SPAD Bipe Plans
- Where to buy square PVC tube?
- need corospit advise
- Delta Designe for 46 engine
- Corocub question
- 4 Channel FSN .15?
- FX Cirrus Electric
- Semi symetrical wing saddle
- In/Out List...
- Spad.. Beginning again
- PVC Formers
- Wing question
- It flys! Yes!!!
- Where to get bat
- Tapered wing question
- Electric fankenstein GNAT
- New PBX build
- Indy Flying Car
- Difficulty with leading edge of airfoil - novice
- Debonair graphics
- I FOUND A SUPPLIER OF CORO FOR CHEAPER
- 4* 120 wing
- 2 Mil. & 4 Mil. In Stock
- Robart hinges
- need help scaling down a Qhor!!
- Spad arf's
- Flying Indy Race Car
- Where to buy Coroplast in Germany?
- Alcohol or acetone?
- Post pics of recycled items useful for SPADs
- Coroplast for a foamie? x2
- Bulsa guy w/ a Newb To Spad(S) ?ion
- Balancing
- .90 size edge 540
- Coro Prices @ Harbor Sales
- Dobonair Wing
- SPADS OVER TEXAS Fun-Fly
- Flashing... No not that type...
- 1/12 P51 Check it out guys
- Coroplast in Corona, CA ??
- motorglider trainer
- Hockey sticks assorted
- The latest Debsulator
- First Flight
- Debonaire in progress
- FX Bandit Elec. Conversion
- My 90 size SPAD
- Anyone in the SW WI area wanna buy some gutterpipe?
- Spadet LC-40
- Zip tying the fuel tank
- One more question....or two
- HELP INFO WANTED ON LARGE GAS 3D SPAD
- SpaTens or / Profile Bipe
- Another Newbie Question
- SPA3D full flying horizontal stab
- " flashing "
- Can CA expire or go bad?
- Props
- New to SPAD
- Magnum Pro .36 SE ????
- new to this
- joining ceroplast wing panels
- Whats the formula for calculating fuselage length?
- My Second Ultra Stick
- Will this work???
- what .40 for aerialphoto?
- gutter pipe supplyer locally
- Gutter Pipe
- Building a SPAD for a trainer plane
- My first R/c Plane
- spa3d
- Thrust Line?
- EVO 60 on a Deb?
- My latest. Any tips for throttle adjustment?
- landing gear & push rods
- Can I build a SRR with a 4mm wing and a .25?
- How do I deal with this?
- What effect does spar height have?
- My 2nd Gasser
- 2 3/8 OD CDN
- Not exactly aircraft per say but...
- Motor mount options.
- Coro Electric Profiles
- Question about building techniques.
- New design spad pics. What do you think?
- How would you attach a wing to PVC pipe?
- Got 80" wings and a Quadra, Ideas pls
- video 2nd day spa3d
- Bulldawg assembly ?'s
- PVC 2 1/2 size pipe (Sqaure)
- Coroplast defined
- OT: $38.95 ARF trainer?
- What to use to glue gutter pipe
- Mini Dinoii?
- clip of Chris's Coro Cub doing a torque roll
- other twin designs?
- Effect of cutting fuselage short.
- 1/2 scale Deb?
- Anyone know of a SPAD parkflyer?
- Finished product...
- Legality of taking signs...
- maidened the spa3d....video
- Need your advice on stripe pattern.
- Anyone know which spad this is? Kinda cool.
- Stepped Poly firewalls...Any interest??
- SPAD idea
- SPAD made the AMA magazine!
- Anyone have some (24") Canadian PVC they want to get rid of?
- Hydrofoam - Corflute or Depron
- Triple DPS with flight report and video link
- My new plane
- Building a SPAD Canard
- The Chrisstick 31cc
- G3 Simulators
- my new PBF
- Anyone use Regal Plastics?
- Any alternatves to a HS-81 metal gear servo for a Debut?
- Coro Edge 540 Improved Landing Gear
- Has anyone used Epoxy on coroplast?
- i want to build a 3d spad
- which prop?
- Aileron flexing on Deb
- new landing gear for my SPA3DT
- Yet another Deb question regarding throttle push rod..
- Front sitting a 1/4" low...
- .75 Schoolroom Spadstick
- Lost PBF build site
- Need carb mount help for a TT .46
- How do I mount the landing gear on a homemade firewall/motor mount?
- Mikoyan-Gurevich Mig 7 Coroplast
- 40 la on MCDDD
- What size wheels for a deb?
- Krylone Fusion Paint - Good Stuff!
- Need help setting up dual rudders on the Deb
- WaVe in leading edge...
- PBF (video)
- SPAD Combat
- Debonair landing/nose gear selection...
- Is an all white plane a bad thing?
- How rough can these things be and still fly/Deb wing is killing me!
- Low-wing spad, how do you mount it??
- All the signs I'm findng have holes...
- Spad club project
- Does anyone know of a source for a precut firewall?
- Sign Vinyl use
- I was Banned - To any admin or moderator at spadworld.net
- How do you hinge moving parts.
- us aircore
- FX_B.U.F.F. STIX 80" WS with LA46
- OS 40 e-z build and fly?
- First Spad
- Low Wing Spadet (Pics) **FLIGHT REPORT**
- Building the Flying Lawn Mower
- patriot with swept wings
- Counter Balances
- Where can I buy 2mil coro on the web?
- how well does the spad fly?
- Coro Edge 540
- Coro wing problem??
- FX Hobbies
- 2mm in Cleveland Oh?
- SuperDecathlon
- Help - servo case dimensions
- Coro Ultimate Biplane
- Brand of CA
- Coro rip off?
- Junkers airborne pics
- Another Plastic Plane makes a Maiden Flt
- Mini PBF
- unsure which spad to build for second plane?
- ultra spadstik with a 90 4 stroke?
- how do you make you own landing gear?
- AirCore 40 Trainer Instructions
- Tubular Coro Edge 540 plans
- Hand launch spad?
- Table launch the Delta
- 1st SPAD
- SPAD-o-holics....
- chris
- u can do spad?
- spad 3dt for second plane?
- My new FX hobbies Bandit
- 2 1/2" PVC Down Spout
- 4mm Vs 2 mm
- Class 214 Edge
- dps biplane?
- How much CA?
- Coro Field Box
- Smokin USS
- Fly In
- My First Spad Questions !!! Qhor
- coro edge video from yesterdays flying
- Big Red
- Looking for a specific model, maybe SPAD
- How do you glue to Vinyl ????
- my home made moose cans
- "resist the urge to ...degrade, insult...someone in your post."
- First SPAD please help
- New DDUST prepared for flight
- Ducted fan SPAD!!!
- QHOR failure
- Dumbo, take 2
- New build 100inch correx trainer
- American rippled PVC and Canadian pipe
- Coroplast sheets
- using round pipe for fuselage?
- Electric Sickle
- Probably has been done before.
- Which SPAD for beginner 3D?
- oak for spars??
- looking to build 1st spad ,help?
- Where to find coroplast...
- PVC Pipe (Found the right stuff this time)
- Tip of the Day: O-rings...
- 'Scoring'
- Found PVC Pipe
- Nevermind
- "ML Spattern"
- Two new Spads flew today
- S.P.A.D. Fun Fly
- Plans for Sickle or The Shark Wanted
