PDA
View Full Version : S.P.A.D. Aircraft - Coroplast design
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18
  1. honest opinion with the spad3dt
  2. 2mm or 4mm ?
  3. help with gnat
  4. Porker spad3dt
  5. Upscaling corostang to 46 size
  6. engine for crash survival
  7. Where can I get 2mm coro in California without a 100.00 minimum?
  8. Painting Coro
  9. SPad Tools
  10. my first pbf
  11. Score
  12. buildin gnat
  13. Dagger question
  14. QHOR 40
  15. 25 Gnat
  16. THE SHUTTLE FLIES
  17. Rule 9 aint a crime
  18. SPA3DT is HEAVY
  19. GeeBee_Spa3DT, First flight
  20. CraigA's Corocub revisited
  21. Looking for deadstick vids of QHOR/Spa3D
  22. Consistant CG: Tanks Placement
  23. Starter Adapter
  24. Have BUHOR question.
  25. Weevil
  26. can't log on
  27. woodpecker ?? help!!!
  28. Polyurethane glue - how come it says not suitable for polyolyfins?
  29. Wing question
  30. SPAD-Simple Paper?
  31. how do you stiffen the spa3d wing
  32. UK SPADers - Loctite Super Plastix glue
  33. OFF TOPIC, BUT PLEASE HELP!!!!!
  34. Polyurethane or polypropylene Glue?
  35. Dominator wing - do I need a wing wrap?
  36. Can anyone help me?
  37. Which SPAD before 3D
  38. Does any1 have any pics of building a QHOR?
  39. U channel or tube???
  40. I sanded the wrong part of the aieleron :(
  41. Muffler Extensions
  42. What is the wall thickness of 2.5 x 2.5 gutter pipe???
  43. plastic hinges
  44. Dominator wing - do you have to pre-bend spar lines?
  45. My New Low wing
  46. Spad long eze
  47. PQHOR questions about CG and prop wash
  48. Benefit of two aeileron servos - could i make this mod to DPS?
  49. Preliminary Gas SPAD Pics
  50. spad fly-in
  51. 1/2A Spad - Any suggestions?
  52. Carbon Spars in PQHOR
  53. bashed spa3d???
  54. my new spazzler
  55. Warp in Airlerons ?
  56. Here goes nothin'!!!!
  57. Do you put formers in between the struts in 2 strut models?
  58. dominator 2 strut vs dps 1 strut
  59. Need plans for OS .46
  60. BUHOR Dogfight!
  61. will this wing fly
  62. UK - Fuselage gutter pipe + dominator wing question
  63. spa3d neutral ailerons placement
  64. The best trainer ever!
  65. Need dimentions For A .61 Debonair
  66. DPS - can I use one sheet for wing rather than top and bottom?
  67. can you spad with 4mm correx/corroplast
  68. A Spad, Spad Story
  69. how to color black coroplast?
  70. CA not holding Coro
  71. deb with .50 engine
  72. UK Spad'ers - help!
  73. Spad questions
  74. Pics of my wifey's first SPAD
  75. i need a spad3d built for me
  76. looking for 2mm in UK
  77. Problem With The Rudder Move.
  78. spa3d cg ?
  79. Twin Engine Gnat
  80. SPAD with .61 engine?
  81. Soloed With The FNS
  82. Is SpadWorld Down?
  83. WHat is the best Spad for this setup?
  84. CARDBOARD WINGS????
  85. Seeking 4chnl novice plane design
  86. My 1st SPAD - Modified MUGI
  87. Tail Dragger Takeoffs.
  88. Help with Airleron servo
  89. 40 size Corospit?
  90. Design advice wanted
  91. inverted vs. right side up problem
  92. Need guidance in placing 196 in/oz of ballast
  93. HELP WITH 1st SPAD!!!
  94. How do you paint a coro plane?
  95. Seeking novice/trainer wing+tail design suggestions-Newby
  96. CORO-2-CORO STICKING??? HELP!!!
  97. Electric spad
  98. DELTA'S CG??? HELP!!!
  99. only 2 m"m coroplast here...:-( wht can I do?
  100. New plane-the H.O.G
  101. 2 Questions About U Can 2 Spad Glider.
  102. CARDBOARD PLANES???
  103. CANT FIND SQUARE PVC OR ?
  104. Question about the SPA3d
  105. COROPLAST IN UAE??? HELP!!!
  106. instead yardsticks
  107. Spad help needed!
  108. 163 Komet maiden flight Video
  109. Wing jig
  110. Spad Gliders
  111. Spad Racing
  112. new spad!!! opinions please
  113. Cant Find Pvc.
  114. SPADS Are Catchy, Plane #2
  115. Today was a good day...
  116. SPA3D
  117. Selling Everything
  118. another spa3d le question
  119. SPA3D
  120. Mixing Spad Designs
  121. Coro Wing-foil
  122. Some Help?
  123. Want to share some tricks I learned
  124. Cheap Engine
  125. I need some plans for...
  126. Hurt my BUHOR today...
  127. What is a SPA3DT?
  128. SPA3DT and airfoil quesiton
  129. How do I.....
  130. The boys from Pinamunde are at it again
  131. Foam laminating ideas?
  132. Gutter pipe and CA
  133. Can I handle it?
  134. How to secure fuel tank?
  135. How to get correct wing shape ?
  136. Has anyone done a mid wing SPAD??--in->
  137. SPA3D!!!
  138. Wanted 60 sized ARF low wing S.P.A.D.
  139. Supply goldmine & Coro Question - Help!
  140. Cardboard Models
  141. Spads really are tough
  142. Wing construction
  143. Spadstick Wing Scallops
  144. best "2nd plane" SPAD?
  145. Coroplast source around Bellingham Washington
  146. Cutting flutes for Spad Hinges
  147. Proper Antenna Placement
  148. HOR wing question
  149. Coroplast locator
  150. household tail dragger
  151. Landing backwards
  152. LT-40 inspired: Tourmaudo
  153. PBF and Mousse Can Muffler on OS 25 fx
  154. Coroplast hinge broken
  155. Leading edge
  156. Coroplast question
  157. Ideas, recommendations for a club event
  158. PBF Questions
  159. Yesterday was a good day...
  160. a SPAD smile
  161. New Spad3D couldn't fly too windy!
  162. BUHOR FLEW!!!
  163. Had family problems since Oct, what's new in the world of SPAD?
  164. tufflight 4d finished w/pics
  165. SPAD balance and antenna ???
  166. Well I built and flew my first SPAD. (with pics)
  167. Looking For Parts
  168. OHHHHHH YAAAAAA Baby !!!!
  169. Spad Bipe plans
  170. tufflight 4d almost finished
  171. Which muffler for OS 25 Fx
  172. Twin SPAD
  173. How's this for a spad fuse
  174. Control Engine Tank servo / receiver
  175. Great ARF SPAD
  176. yippee
  177. Combat Spad
  178. Todays PBF fun :)
  179. Sickle Video
  180. What did I buy?
  181. Spa3dt ?
  182. Glue
  183. Draco Question
  184. FAST Spad needed
  185. Large Deb and new Gnat
  186. New Micro SPA3D
  187. LOST SPAD
  188. S.P.A.D.--SPAD VIII & FOLKER DR 1--COMBAT
  189. Spad Building Help Needed !!!!!!!!!
  190. Flew my mini pizza box today Also My First SPAD
  191. cajun spaders
  192. Schoolroom Spitfire
  193. BUHOR Question
  194. Delta Wing Spad
  195. New mini pizza box with K&B sportster 20. what prop?
  196. Dominator Problems
  197. Spadhq still in business
  198. way, way off topic Aussie thread
  199. PBF pics
  200. The FNS
  201. Is it possible????
  202. Another It's not coro but...
  203. slow surviveable ships
  204. SpadStick fuse.
  205. Coro 3D
  206. Todays flyng
  207. Assembly Tips ? Flying Tips ?? for 'GNAT ARTF'
  208. SPADFEST 2004 SPADS INVADE RANTOUL
  209. My new Spadet-ette
  210. New spad prop jets
  211. engine heeeeeeeeeelllllp
  212. O-rings to hold OS 46 mousue can muffler to mount.....where can I find one?
  213. DasPlasStick
  214. Coro Floats
  215. Check out my dad's Spad (new pictures!!!)
  216. a "Zagi" type SPAD
  217. Foamy Coro Hybrid
  218. Q on DPS style wing for Deb
  219. Hey Guys
  220. Corostar 40 Warbird Extraordinair assembly instructions needed
  221. I want a 20 size 3d spad design.
  222. Wing question?
  223. Tail Dragger Debonair Question
  224. FIRST SPAD
  225. BUHOR Questions
  226. corro to a new level
  227. ANYONE WANT TO SELL A RTF ELEC.SPAD
  228. DDust
  229. Debonair finished
  230. SPA3DT
  231. How many Spa3ds ?
  232. spad hovercraft??
  233. Kingpost on QHOR 40
  234. Mmmm, that was fun.......
  235. I hate this.......
  236. FOAM SPAD Material Questions?
  237. 8 oz MCP work on a 60?
  238. Hybrid Aerobird/QHOR Spad??
  239. My spa3d
  240. over-powered spad
  241. My New PBF
  242. Designing a SPAD
  243. MrG's Draco
  244. Ground loop
  245. Need a link
  246. SPAD3D materials in the UK HELP!!
  247. The Best 3-View site
  248. SpadStick
  249. Anythings Possible with Coroplast-Me-109 .25FX
  250. Has Anyone Tried This
