- How to paint foam?
- 1st in..
- saving a CANOPY?
- monokote seam over open areas
- bubble wrap
- Retract Mounts
- Painting on Monokote or Ultracoat
- Dave Brown mounts and mounting screws
- Need Help.....building Mishap.....
- Windex Sprayer
- Spring Air Control Valve Arm?!?
- Landing gear on jkaerotech P51
- How to remove burn marks from lite ply
- Repairing Wing Covering on Four Star Beauty
- Paint primer
- Leading edge slats?
- Canopy tinting how to
- Hobbico MK II Voltmeter Lens
- F4U Cowl flaps
- How to Avoid the dreaded Snap Spin???
- Seniorita Ailerons
- Canopy Repair w/ Butyrate Dope
- Building a field box.
- A soldering Iron and or heat gun will unseat epoxy
- A nice trick for removing covering without leaving a scar in the wood
- tips on converting
- e-poxy
- best retract instalation?
- J-3
- Long Term Storage of CA
- Landing Gear Collars??How to??
- Thunderbird Paint Scheme
- Trailer charging systems, how did you do yours?
- Wing area tapered wing
- Probond Caution
- f8f bearcat
- Anodizing aluminum.
- Water Based Contact Cement For Wing Sheeting
- Soderung wire
- Southern's Sorghum....HUH ?
- Canopy Glue Removal
- Removing a hinged surface?
- Carbon Fiber winglet
- Which to use? Epoxy or Poly. Resin
- Is automotive spray paint model fuel proof??
- colored epoxy
- Will this work?
- Recovering My Old Fun Scale Stang
- Rebuilding a lite ply fuse
- Best way to adhere decals ? Windex ?
- bending aluminum bar stock?????
- Where can I buy Homasote
- Hood latches?
- Cradle design needed for SIG Field Box
- Which plane for saito 5 cylinder?
- please help
- Tip Floats
- glueing foam
- Robart Point Hinges
- Pull pull or normal push rod
- Fibre Glass
- Removing Stix-it
- Swivel ball links safe for ailerons?
- vehicle carriers
- Falcon 56 Wing
- Retracts and gear doors?
- Logos & Graphics
- ace hardware masking tape....JUNK !!!
- Best/lightest weight fuel proofing?
- Fiberglassing wing joints
- Cleaning iron socks
- How do I harden K&S soft aluminum
- Stika and Masking Film
- How do you sheet foam wings?
- 2 color fuse
- Monokote matching paint
- Pull Pull with Tail servos
- cub fabric covering
- Keeping glue tips clean, addendum
- Slo Zap Remover off Clothes ?
- Looking for a kit
- Nelson Hobby paint
- Mixing correct amounts.
- J-3 Cub markings.
- My Latest Project, though not complete. (transmitter Tray)
- SPAD stuff and stuff
- New...Sig Somethin Extra Yahoo Group
- epoxy cure
- non conventional designs
- correcting a wing twist prior to covering
- Recommend me some cheap paint!
- Weighing airplanes
- Covering Question
- Just Wondering
- Fuel tank location for a Pusher...
- Retract question...
- home made carbon push rods
- Tinting canopy
- Mechanical Retracts
- What is best way to mount a tail servo in ARF ?
- 300S foam wing repair
- Monokote
- Flite Metal
- Teach me how to cover a plane
- F-6F Hellcat
- looking for parts
- What primer to use?
- Canopies for Scratch Builders - Where?
- How to paint clear canopy ?
- Ca Thin And Baking Soda
- gp f-14 ducted fan????
- good balsa ply??????
- Teach me how to build!
- Airbrush> what paint/colour
- Paint or Monokote
- Use of after run oil
- rewind salvaged cd-rom motors for e-flight
- Flite Metal aka Home Deopot Aluminum Tape Burnishing Help
- Monokote to Dope transition
- dupli-color auto paint?
- DP Extra: need advice on finishing
- EPOXY....Are there good and bad ones ?
- Air Op. gear
- Aluminum Landing Gear
- Sig Four Star 60
- Brakes
- Foamming fuel tip
- How to get epoxy off threaded bolts ?
- Fiberglassing
- fuel soaked wood
- Plane Stands
- Dave Brown's "EL cheapo" screws
- joining 3/16 birch ply?????
- Cellophane as a wing covering
- Airplane stop
- How to make homemade decals
- Colomban Cri-Cri plans
- Flying Wires
- Pull Pull ???
- Basecoat/clearcoat finish
- need canopy
- Blindnuts.....how to install ?
- filling the weave
- supercoat
- pushrods
- What paints will work on Super coverite using dope?
- ultracote matches which spray paint?
- New Guy here, question about painting lexan bodies
- GP f15 repair with fiberglass
- Solartrim - checkered pattern on wing
- Questions for a GP skybolt
- Ho do you avoid a leaky setscrew in an air control valve
- 3M77 vs Krylon
- clip art
- panel lines & rivets on film covering
- Covering for Stick & Tissue Projects
- Balsa filler
- Fuel proofing problem
- Tip for cowling the muffler on an OS 1.20 FS Surpass.
- Monokote trim on uneven surfaces
- Epoxy-----Acticvate!
- Fuel tank sealant
- Large Control Arm/Bellcrank needed
- Engine Starter
- Film Covering Technique
- Glues
- Hinges with pins
- CG on P51 ?
- Canopy mistake
- Model Finish Question
- What can you use to remove the paint from mousse cans?
- SIG Supercoat doesn't cover
- MINWAX Polyurethane fuel proof?
- Pull-Pull Controls....How?
- Monokote help
- What kind of Pushrods are best
- epoxy removal
- Chrome Monokote...help!!!!!!!!!
- large scale pinned hinges
- Confused on Clear Coating Latex
- painting cowl
- Scale-like hinge line?
- tinting resin
- Arrowshafts Source
- Landing
- Drilling a cap screw head
- Removing Monokote
- Carbon fiber tow?
- Krylon paint
- tracing paper?????
- Great Planes Ultimate Bipe...
- It's all about technique - I still hate painting
- dent in cowl
- Destroyed Philips screwhead!
- Yes
- paint or film covering
- plans for r/c harrier jet
- Best way for sanding fiberglass over wing joint ?
- Wing Sheeting???
- Goldberg STAUDACHER S300 GS rib trouble
- Is Rust-oleum fuel proof?
- Tower Trainer 40 ARF questions
- Painting a cowling, doing it right this time - I hope
- non iron on film
- Painting Frame inside clear canopy
- poly and baby powder
- Plane storage
- Plans for building a 4 X 8 Trailer
- Foam glue
- Removal of haze in canopy
- trailer talk
- Monokote for hinges?????????
- Why do things seem to cost more at a hobby store?
- fuel soaked balsa
- Crash Repair?
- HPLV Paint system
- Rounding the Leading Edge
- What About Min-wax??
- Monocote removal
- Need Help with Aluminum Spinner
- Super Sportster - general info needed
- Attatching landing gear on SIG Wonder?
- Styrofoam Floats
- monokote residue
- I May Have Found The Miracle Of Monokote Polishing
- Dual Nyrod connection
- Attention fellow modelers..a little help please...
- Mix Monokote and Ultracote on opposite wing halves?
- A "Sticky" situation
- CG Cub Window Kit
- Uncurling a painted Canopy?
- Reinforcing ABS
- tracing patterns from plans????
- fiber glass cowling, how many layers?
- a stronger canopy????
- camera
- Using Koverall and Dope
- How to reinforce plastic cowls?
- Canopy Gluing
- Canopy Gluing
- When to cover
- Homemade decals?
- New Paint Type
- covering/monokote
- Fabric Covering?
- trailing edges - vacuum bagged fiberglass wing
- Aircraft saving advice
- Servo help Aid
- Give me your opinion, Servo drill template
