PDA
View Full Version : Tips & Techniques
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. Engine Test Stand Mods
  2. Help figure out what bend to use
  3. Controlling covering paper
  4. Wing tote and wheel chocks
  5. Easy to make Wire Bender
  6. Shop Around
  7. Fuel Proofing Acrylic Paints
  8. Cutting Wing Rib Servo Wire Holes
  9. Using a Spray Gun
  10. Rattle Can Paint
  11. Landing Gear Bending Brake
  12. Hobby Lobby funster flap elevator mix
  13. NAV light in a ARF
  14. Balsa repair
  15. Paint Matching on Eflite 1.2M T-28
  16. Shaping Ailerons or Flaps from Solid Balsa Stock.
  17. Painting Sunglasses on Pilot Figures
  18. Ingredients to cut foam wing cores?
  19. wing sheeting contact cement?
  20. EZE-KOTE and epoxy compatible?
  21. Electric Stareters
  22. decal paper
  23. Kobalt hobby tool kit
  24. Light ply ?
  25. Whats best way to cut large holes in balsa sheet
  26. Simple Glue Station
  27. Airbrushed paint-Protective coat?
  28. Cockpit kit tools
  29. Ultracote Oracover - germany
  30. A far better foam for receivers
  31. Custom Landing Gear Suggestions
  32. For What It's Worth
  33. Balsa Storage, Part 4
  34. Using Plastic Film to imitate Aluminum
  35. Painting epo plane
  36. Hinges
  37. soldering help
  38. Simulated Hinges
  39. Sanding Epoxy Glassed Models
  40. Trimming fiberglass parts
  41. Aircraft Tail Trap
  42. Field Toolbox Ideas
  43. Weight FibreglasS cloth for wing join?
  44. P-47 Bubble Canopy
  45. Custom Woodcraft Flight Box - foam padding replacement
  46. what can I use for a releasing agent for fiberglassing
  47. GOOP Shines Again
  48. Packing & shipping large/giant planes!
  49. Painting fabric
  50. Tips on Exact Wire Bends
  51. gluing Dowels in plywood, what glue/what method
  52. butyrate dope on fiberglass
  53. filets on plug in wing
  54. Composite canopy copy
  55. Smooth and Graceful Landings
  56. Weights for building
  57. An Aviation Work Day
  58. Gyro with two elevator chanels ?
  59. SUV Airplane Transport.
  60. Help My Computer Crashed
  61. LED Light and a Save
  62. Painting tips wanted
  63. Advice needed with Hobbico mechanical nose retract
  64. Bell Crank or Servo?
  65. Wing rack for truck with cap
  66. Does anyone use the slower West #206 resin hardener for peel ply projects?
  67. Advise Help on braising Brass
  68. Tool for spreading clevises
  69. gas engine repair
  70. covering a bi-plane wing
  71. Klass Kote epoxy primer
  72. Plastic to Painted WIng Surface
  73. Mobile Plane Stand
  74. Need advice on large scale foam core wing
  75. Robart hinges and hinge pockets
  76. Where to get slides for center shelf in a trailer
  77. Help me decide on new cordless drill...
  78. DX8 Smoke Programing
  79. Are they vinyl or water based decals???
  80. How to trim Monokote over Monokote???
  81. Fast curing silicone
  82. 30 minute epoxy & alcohol?
  83. Band Saw Blade Recommendation and Setup
  84. Installing Robart Cub gear
  85. Hysol Question
  86. Wheel Collar Retainer
  87. weathering my vickers guns
  88. My Speedy Engine Tool
  89. Repainting a painted airplane (but only certail areas)
  90. Resource for wing tubes
  91. How to repair dents in EPO foam
  92. Bed Frame Repurpose
  93. P-51D canopy Enlargement
  94. Bob Dively masking HELP!!!
  95. Polycrylic on koveral
  96. Grass Runway Maintenance.
  97. Cowl hatch for engine tuning access
  98. Is "crazy glue", or "super glue" the same as LHS (BSI) CA?
  99. Threading wire rod
  100. Looking for tips for the disabled. Flying field gear, hints, etc
  101. Turbo-Cool Spinners or Vented Spinners on glow or gas?....why not?
  102. How to remove a stripped head phillips servo style screw or larger...
  103. Painting MonoKote?
  104. Substitute for Ironex?
  105. Rehinging Rudder on a Foamie
  106. What To Do With Paint Runs
  107. Wing Jig
  108. Servo Connector Extractor
  109. Transmitter case on the cheap
  110. Airtop 8" balloon wheel help !
  111. 3 part wings
  112. Reapplying old plastic film covering
  113. Fiber Fuse: Ply Formers
  114. RC Plane trailer setup
  115. Life Battery Surgery
  116. Anyone using UV activated resins for aircraft building ?
  117. Favorite method for fiberglassing wing center sections
  118. Fiberglassing questions
  119. Can u spray on balsarite
  120. Ultracote Wrinkles
  121. prop question
  122. Tips on how to register your drone with the FAA
  123. Working on MY old Patriot 40 Kit
  124. HDI PCB Flexible FPC MCPCB Aluminum PCB Prototype Manufacturer in china
  125. Building wing panels from plans
  126. Hobby King Covering
  127. Dummy brakes for a cub, scratch build
  128. Parkzone Sport Cub S2 Maiden with Snow Skis:
  129. Laminating a Static Prop for a WWI Warbird
  130. muffler on the loose
  131. Foam Glue
  132. Using the Runcam RC Camera in Time Lapse
  133. Clear Plastic Repair Canopy.
  134. Help with my shop work bench
  135. Making scale looking strap hinges from styrene
  136. Fuel proofing required for 0% nitro fuel?
  137. Any solvent for canopy glue?
  138. Paint to use on Solartex Fabric Covering ?
  139. Aluminum Landing gear reinforcement
  140. DX7S setup for Parkzone Sukhoi SU29mm
  141. Magnum 91 4stroke valve adjustment
  142. what you have learned over years , to Keep your Glo planes flying reliably
  143. Cleaning my plane before re-covering, material removal.
  144. Help My OS 65 Keeps Overheating
  145. harbour frieght
  146. Skylites in Roof
  147. Harbor Freight Diagnostic Scope Saves the Day
  148. Try Minwax wood strengthener on weak Balsa.
  149. Servo Screw Trouble
  150. Shop Power Supply n Foam Cutter
  151. Troubleshooting 21st Century covering iron
  152. Build a scale like tail wheel assembly
  153. Super Strong Magnets
  154. Warped balsa fix please
  155. Mono show through problems
  156. best way to clean a gumed up nitro carb
  157. polyester vs. epoxy for covering / filling
  158. Stripping an ARF to paint
  159. DynaTron Starter Battery Box
  160. Belkin auto shut off
  161. Latex Paint Question
  162. Retaining or Re-establishing Panel Lines
  163. Glue for rare earth magnets
  164. Flight box power panel
  165. How: Fiberglass and Paint
  166. Let's Talk Fiberglass Fillers, Gap Fillers and Finishing putty....
  167. Flying Stabilator
  168. Fuselage Cradle
  169. Easy CG method for large planes.
  170. Full HD 3D Aerobatics Tutorials
  171. removing monokote trim
  172. Using Poly Lite cloth. Do I dope the cloth.
  173. Soldering tips
  174. Adjustable Engine Test Stand
  175. Flight Box
  176. user friendly paints for "foamies"
  177. Need Help: Control Push Rods:
  178. What is the best way to hold a cowl on?
  179. How to fix the stripped plug threads on cyl head.
  180. fuel shutoff for combat u control
  181. Tile Saw as a Table Saw?
  182. My work surface
  183. A Non RC Use of CA Glue
  184. Paint and Fiberglass resin!
  185. Hobby KIng West coast waqrehouse
  186. Need wiring info for SPMA3081
  187. Power switch/charge port/other switches compartment
  188. Sleeve for carbon fiber pushrod
  189. Standard for switch positions in RC?
  190. CG calculation by weight
  191. Restoring old iron on....
  192. Cowl Latch Suggestions
  193. how to make perfect round holes
  194. Servo load calcutator
  195. Starters and 12v batteries
  196. Refreshing epoxy
  197. Best way to remove and repaint foamies?
  198. Epoxy tip
  199. What is a "wet coat"?
  200. Pull-Pull Rudder cable geometry ???
  201. Blind nut in very rear of plane
  202. Sanding Sealer Recommendation
  203. landing gear tips needed
  204. Separating Epoxy Joints
  205. toughflon covering?
  206. Wing template
  207. Top Flite AT-6 ARF with E-Flite Retracts
  208. Widows......how to?
  209. Hanging Airplane Storage Cube/Box
  210. Dollar Tree foam board
  211. Starting screws and nuts in tight places
  212. landing lights
  213. Cubs and fabric covering details
  214. Paining lines with liquid mask
  215. Simplified Fueling Valve
  216. Flat Sanding Small Peices
  217. Bending Undercarriage Wire, the right way!
  218. Sport .46 glow engine reviews and testing
  219. Need help with home made smoke system.
  220. I need help finding an item for building.
  221. Painting... suggestions on how to fix this spot
  222. How to drill holes 90 degrees to the end ribs of horiz stab ?
  223. Sanding Tool
  224. How to make monokote stick better to OLD wood??
  225. engine mounting
  226. Decatlon hatch door
  227. Lengthen a nose gear
  228. Engine too long
  229. making decals stick
  230. Hobbistar tail repair
  231. Need Help Making Fuselage Storage Rack in Garage
  232. Vertical airplane storage
  233. How to Repair Cowl
  234. Valspar Ultra
  235. Parkzone T-28 ultra micro repair
  236. using Star Tron
  237. Fuel proofing the common spray can paint like Rustoleum
  238. What's the best paint to use over Solartex??
  239. Robostruts
  240. Quick Tip to keep your Monokote Iron off your Manhood
  241. Panel Lines: How to do Rounded Corners?
  242. How to locate mounting holes on a new cowl??
  243. Finally Achieved Zero Fades
  244. Pilot RC CF gear for 50cc Slipstream SBach 342
  245. Cheap electric glow fuel pump
  246. Wing Depron Construction Using Balsa Technics.
  247. Add Lift Spoilers to a wing?
  248. Repair Question
  249. Free fuel filler
  250. How do you remove paint over spray from MonoKote ?
