- YS F120
- Idle Mixture adjustment for the old YS120
- YS 110 pattern prop
- YS91AC
- YS engine performance figures
- 110fz rpm figures
- YS 1.10FZ Max RPM
- exhaust temperature
- YS .61 LS RE - Running problems. Anyone help?
- Fuel tank setup for YS 140DZ
- 110 FZ
- YS 140 l prop
- 140 Sport Issues
- After Run Oil In YS Engines
- YS 120 AC running erratic
- Throttle barrel retainer
- estimate
- New Engine Size?
- SF120 performance
- Add oil to Coolpower?
- 91 FZ goes lean in the air
- 1.40 sport pressure question
- 1.20 NC, Damaged Threads
- NIB YS 45 Question (Dave)
- 120 ac running too rich
- YS 140 DZ Cam failure No#2
- YS 110 beginner help
- YS 1.40 Sport Questions
- 140L manual
- 91AC
- YS45 parts
- No .91 AC/FZ parts listings?
- YS 60 or 45 2 Stroke - Fuel Question
- Another Run in Question
- What fuel and prop for .63FZ?
- New YS63FZ sticking throttle.
- YS 91AC broken head
- 120AC
- YS .61-R
- motor designations and rpms
- YS HAS THE BEST SERVICE - THANKS RICHARD!!!
- Dave, can you identify this motor please?
- 120ac
- YS 61
- YS 120
- YS 110 stoping
- Fuel for YS63
- Exhaust pipe and muffler installation
- prop selection for 1.10FZ
- what kind of rpms are acceptable
- YS 63 What %nitro?
- 140DZ upper RPM Limit
- Break In for YS63
- YS 140DZ Cutting
- whats the factory set position for the regulator on DZ?
- Question about new head for 120NC
- Overheating YS 1.10
- YS45 Glow
- 160 DZ ?
- The NEW YS 63S
- Bladder Tank
- ID this YS 120 (Pictures this time)
- 110 with bent crankshaft.
- YS140L initial start problem
- YS 45 Parts
- YS 63FZ header/muffler
- SC 120
- Will it hurt power?
- DS out of town 2/19 to 2/23
- 140 DZ Spare Part ?
- Ys110 effects on low end without muffler
- What can cause my dingo to act this way?
- Questions about YS.91
- Muffler for YS 120
- 120 After run oil
- ys 110
- YS 140L stiff throttle arm
- Number of fuel lines
- Tank and plumbing recommendations
- YS 110 at high altitude
- YS 63 Strange behaviour
- YS FZ63 Startup Problems
- YS 53
- YS 110 EXPECTED RPM
- ys140dz leaned out
- Need YS 45 manual
- throttle barrel retainer ys 110
- ys 45 running rich!!
- YS 120SF
- 140 DZ Muffler
- YS 140 DZ vs 140L dimensions
- 140 DZ Fuel Tank
- .53 not quiting
- 110 repair
- YS 140 DZ Help
- Pinch test
- New YS63?
- YS and Fuel
- 110 not producing tank pressure
- YS 1.40 DZ castor oil fuel
- 140 sport bench run
- YS 63 Hard Starting
- YS leaking fuel from the carb
- Muffler for a YS110
- Need Overhaul
- Break-in procedure for Ys 140DZ
- Header tank with DZ
- DZ140 anf fuel tank
- 18-6 prop and hand priming and starting a YS 140 Sport
- YS 1.10 Starting
- What's up with these mufflers?
- Ys 140 DZ Idle problem
- YS 120 SC
- YS 63 Muffler
- best propYS 140 DZ's props
- YS 110 on 30%
- YS FZ63
- YS 91AC
- YS 91 idle problem
- YS160
- what is the difference
- YS63
- Hyde ARIA mount with YS-140 DZ
- YS service
- what oil to use to store my YS-110 before I decide what plane to put it in
- Throttle barrel on YS-140 DZ
- ys91AC
- Where can I find a prop chart?
- The best tuned muffler for DZ140
- YS 61R-AR prop question
- wrist pin access plug on the DZ140
- 140 Sport VS 140FZ
- Fuel to use for YS140FZ
- Use of Fueler Valves
- YS 63 Problems
- Surging Dingo
- why isnt my dingo idling for long?
- Is this fuel O.K for DZ?
- 120 AC Prop Question
- Ys 140L manual
- New 1.10 leaks fuel from carb
- pumps and design
- YS 60 FR
- ys 45 problem
- YS63 - Fuel System at idle
- After burn oil hurt YS engine?
- THIRSTY YS63
- Y.S. .63FZ question
- F-120 Valve Followup / Pictures
- help with new ys .63FZ
- F-120 Valve
- YS120SF turning apc15/10 9700rpm
- 140 sport props
- dave got my dingo back from ys now i need some info before running it.
- YS 1.40 Sport Muffler Broke
- Dingo question (blown oring)
- 140 L & sport
- YS91 AC
- Contact information of YS manufacturer in Japan???
- ys 61-r, AR or RE?
- owner manual
- Ys 91FZ won't stop running.
- Step-by-step YS 63 setup
- YS .63 prop selection and rpm's
- Transition/idle adjusting
- Ys Dingo help !
- YS won't richen
- YS 91FZ Mod?
- Suggested props
- 140 DZ hp ?
- Set Idle 140DZ
- .91ac fuel routing.
- YS140L - Replacement of Silicon Tubes
- ys 91ac
- Dave do you have a personal email address as Ive sent my engine for repair and need to communicate.
- YS110 inverted?
- I`am loosing power on my Dingo,what could be the problem?
- Strange idle on FZ 1.10
- Which fuel tubing????
- Need valve for YS F-91 four stroke, where?
- YS 91 AC doesn't like to stop running
- ys 45 fs
- Kltoz techninplate KL 200 as after run
- 110 FZ with no muffler?
- ys120 Needle Valve set screw
- 91ac problems
- Need some more info dave.
- Looking for after run oil - off the shelf for ys engines?
- YS 91 High Speed Needle
- Your opinions on the YS 140 Sport
- YS 110 HP?
- YS ENGINE DESIGNATIONS AND POWER
- Check valve/ glow plug included ?
- Can you run a YS 63 without a muffler
- Need help in getting ys 110 to idle at 2000 realibly.
- YS 61FR Needle assembly & Shadel AAR setup
- Help with my YS91
- A question for Dave.
- 61 ST2 on a plane?
- ys 63 compression
- Overview on the 140DZ fuel system?
- Disassembling a YS 61-R Long AR
- how much vibration is acceptable on the Dingo?
- ys 120 fz
- YS 140 FZ blown muffler
- Which prop for the 110 FZ
- 140DZ clunk or bladder tank?
- YS 61-S
- Fuel Tank for a YS 53
- YS 120 NC Idle & Regulator Screw Exist?
- Timing on YS engines, cam gear is it 12 or 12:30 (installed) ?
- 140 DZ
- YS110 regualtor screw?
- 140FZ running hot?
- YS 63 low end adjustment screw
- Engine ID for a 140L
- 120 identification
- DZ power problem
- YS stripped muffler thread in the air!
- YS140 muffler vs YS120 muffler
- Low end needle on YS 53 FZ engine
- YS 63 Upgrade to new Version/Case/Regulator Possible later?
- Castor & YS engines - Dave?
- YS 53 FZ engine quits at full throttle
- YS 91AC Repairs and breakin?
- After run
- ys 91ac muffler
- 63 idle difficulty
- YS-120 FS bent crankshaft
- YS 45 Prop Size? 11-5?
- My First YS Fuel Tank/Line Setup Instalation???
- Storing a DZ for winter
- YS 110
- MORE YS91 ENGINE PROBLEMS
- YS 91 fz fuel question
- need a little fz110 help
- Exhaust baffle gone is this my tuning problem?
- YS 91 Fuel!
- 91 AC crank
- Dirty 140 DZ
- YS 63 Setup Blues
- YS 110 won't idle
- YS 91 WON'T IDLE!
- YS .63 and 12k RPM's?
- YS tecknickel information
- New exhaust valve is different
- YS-91 FZ Gas Port Mod
- YS 110 Help !
- YS 140L Crankshaft
- YS 91 type question
