View Full Version : YS Engines Support
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16]
17
18
- New YS 140 Sport - Name?
- Ys F120
- YS140L Sags with Positeve G
- Dz
- 140 DZ 3D 3 blade props
- YS 120 NC Quits
- 63 fz rpm question for dave
- ys 140l leaking through exhaust and carb...
- Regulator Disassembly
- YS FZ 63 Four stroke
- My 120NC quits after 2-3 minutes!
- 140 Dz
- YS 53 Prop Size
- YS 1.40 DZ with the DP Ultimate
- YS 140L Manuel
- Ys 120fz
- 91FZ question
- ys-91 Top End Power
- YS 120 / 140 tuned pipe
- do i have the real thing?
- 61 ST I or ST II?
- YS140FZ - Piston Rock
- needles and regulators
- YS 120 leaky carb!!!!!!!!
- YS63 hard to start.
- YS in NV or Central Hobby
- YS 120 NC Prop and fuel ?
- need to send in a 120 for overhaul
- 91FZ --> 110FZ conversion possible?
- F-120 leaks from carb
- 140 Dz - Regular Synthetic Oil?
- straight in flow muffler 140 sport
- No tools with new 140 sport
- YS 140L eating CAM & other questions
- Ys 110
- Ys 91 Ac
- New YS110
- 140L FunFly Prop
- Ys 120fz
- Solvents/HC gaskets for YS63
- my 120FZ starves at Full Throttle
- YS Service Thanks Dave
- 2 YS-63 hard starting problem
- 120 Nc
- YS 91FZ idle question
- 140dz
- New 140L
- Nose Ring Tape?
- YS 140DZ fuel question
- Piston compatible?
- concerned
- DZ140 problem (Dave)
- How to change cam bearings
- 140 Sport spitting fuel
- When does the new 110 come out?
- Check valves
- Wanted__nib 91fz
- 120NC Carb Modification?
- YS91 Will Not Quit
- Tank on CG
- 91FZ dies hovering (Dave)
- Ys120nc
- Engine speed while flying.
- New Web Site ?
- YS 120 SF "Stiff Needle Valve"
- YS 63 jumps out of time
- sick 91AC
- DZ 140 Prop size (Dave)
- ys 63 no compression
- YS 91 AC + Hyde Soft Mount... Nose Ring, Yes or No?
- YS 91 AC Mufler
- YS 91 FZ "Won't Start" - Dave Comes Through Again!!!!
- Ys120fz
- YS 91 Fuel Line Routing
- YS 91 AC Threaded Crankshaft
- ys 63 starting problems
- YS91 AC lean on top end
- YS 91FZ Fuel
- I agree
- YS 1.40 Sport Fuel Consumption
- YS 91ac muffler
- DZ 140 - Too Lean
- Mounting YS FZ-120 On DuBro Mount
- Any Helpful 63 Owners????
- YS .63 Problem
- YS 63 poor transition & carb leak
- YS 91Ac-FZ Question?
- Ultrathrust
- 140 Sport Problem
- DAVE??correct plunger question?
- YS MUFFLER
- Pizzaz 40 with a YS 63, anyone have any tips?
- YS-63FZ Mid range running Problems
- YS 45 Operation Help
- YS 63 prop for break-in
- YS 110 on 15% Coolpower blend
- Leaky DZ 140's
- YS Plug or OS ?
- YS63 leaking fuel
- YS 45 hasn't been run in a long time ...
- YS 140 FZ fuel consumsion
- YS 91FZ idle problem - at end of my rope
- YS 91 - I know nothing!!!
- HS Needle valve adjustment?
- mounting YS 63
- YS91 don't run at idle for more than few secs
- YS120 regulator?
- YS 140,pressure to suction
- YS 110 Size
- YS53 midrange
- 120 SF Valve Leakage
- YS .91 AC fuel from carburetor
- YS91FZ break in problems
- YS .63 will not stay running
- YS 63 break in procedure question
- Inverted YS 1.20NC
- Muffler for 140DZ
- ys60re question
- FZ63 muffler baffle?
- fuel mixture problems
- Ys-45 only turns 11,000 rpm
- YS 63 break in
- What Aluminum Spinner for YS63?
- what prop size
- YS63 Question for Dave(or some1 that knows)
- 120 gaskets
- Coolpower 15%(Green OR Red?) Anyone??
- YS 91 - discontinued ?
- YS120F won't run
- Dave: Ys 110 Best Rpm Power Band?
- Dave, question please. How to remove nuts from prop.
- YS 140L Hyde Mount ?
- YS 63 Muffler
- Operation of YS Regulator Assembly
- Info on the YS-91-FZ
- Question for Dave?
- bent crank YS .63
- Whats up with the YS 63's?
- YS 1.40 DZ smoking
- fz91 Idle problem
- YS 63 goes Lean in flight
- YS 63 inverted installation
- YS .63 Valve setting, and engine break-in questions
- Does my YS 91FZ Hate me??
- 120 SF Intermittent
- Disassembling YS91FZ
- Ys 91 Fz
- YS 63 availability? Redesign?
- YS 120 ac+ DP Ultimate
- Range of Prop Sizes for 110
- YS 1.20 s? loose muffler
- 140 Sport
- ys 120 sc ?(Dave help I am confused)
- venturi restrictor - 140 DZ
- Fuel Filler for 140 DZ
- YS rpm problem
- yamada YS63FZ
- Ultrathrust for OS 91 FX
- Fuel Injector Nozzel on 140DZ
- YS 45 Tuned Pipe
- New Here..Need YS 120SF Help..PLEASE!!
- Need Tips On How To Set Valve Clearances On Dz
- No compression on YS63
- Reversing 140DZ?
- YS 120 FS piston, cylinder ,rods ?
- YS91 FZ, runs rough 4 clicks above idle - Help please
- YS 46 two stroke?
- YS 91 Problem
- YS140 Limited
- To invert....or not to invert.....
- Replacing head on 91ac - help !
- YS 45 FR pipe ?
- after run oil
- ys .6O exhaust
- Need info on Ryan STA 1/4 scale
- NC Spitting Fuel
- YS80 Engine Manual
- Dave, ys 63 > some ?'s
- YS 91 Heli engine in plane
- Ys 63
- Status of the new 110
- 1.40 DZ fuel clunk
- YS91 Problem , (help Dave!)
- YS140FZ Surging
- Ys 61
- YS 63 Fuel
- YS After Run Oil
- YS .61 heat
- Which Prop for my YS 61 FR Long Stroke?
- Nitro in YS140
- Ys140
- ys 53 needle valve
- Over- rev a 91 AC
- A couple of YS questions
- Need info on Ultrathrust Mufflers
- Wildcat Fuel, 18% Oil, 15% Nitro
- YS91AC Parts
- 63 Problems
- Q
- Whats the best RPM for YS80 Heli engine
- The same problems...
- YS63 Prop Prob
- YS 140 DZ "M" (with factory soft mount)
- Heli YS80 Engine help/ys91?
- ys63 too rich
- ys 63 problems - rich midrange
- New YS rebuild question
- Prop test
- Ys91st
- YS - performance degradation
- Wildcat/ 140DZ
- Is 2000 RPM idle realistic?
- 140 DZ quetion for Dave
- Y.S. 45 header bolt thread size??
- new to 4 strokers
- more 63fz questions for dave shadel
- 120NC idle probs
- still problems with fz63
- YS Question For Dave
- Ultrathrust noise
- Ys 45 Silencer
- YS-63 Myth or fact?
- ys 4-stroke engine on twin
- Fuel shut off valve for DZ
- Ys 45
- 53FZ Timming Question
- Prop selection for YS63 on Kyosho Spitfire
- Dave please help...YS 61ST-2 idle problem
- Ys 120 Sf
- ys perf overhaul
- Strap on Ultrathrust
- ys 63 wont stop
- ys 140L prop, Help...
- 91 ac does not seem right on top end
- ys63 rpm/ are these figures normal?
- YS-91ACH conversion
- Problem with a Y's 140L motor.
- YS 91ZF leaking....somewhere??
- YS 140 DZ Thrust numbers ?
- ys.45 re questions
- Muffler for DZ 140
- Fuel YS20/20 and 30 % heli. High versa low viscosity oil .
- YS 91 FZ problems
- Ys .80 Stii/st3 ???
- 140l
- Starting procedure for YS 120FZ
- ys 120 fs opinion
- YS 120 FZ Problems
- Dz Bench Run
