PDA
View Full Version : SimJet Turbine Direct Support
Pages : [1] 2
  1. Simjet 1200 SP starter motor
  2. Simjet 2300 with xicoy fadec v6.0
  3. Simjet 1200
  4. Simjet 1200 cool down sequence on start up
  5. SJ3000 rpm flips and flameout.
  6. World wide Service for SimJet Turbines!
  7. Simjet 2300 problem
  8. Simjet sonic 7000
  9. 2300 dead...
  10. SimJet Turbine Help
  11. Simjet 1200 starting problem
  12. simjet??...
  13. Simjet2300
  14. Simjet 1700 glow plug
  15. 1650 problems
  16. simjet 700 wanted
  17. Simjet 2300 start up issue
  18. Simjet 85 starter pod
  19. New ECU
  20. Simjet 700
  21. Simjet 3003, cable question
  22. Simjet 1200 Bearing Replacement
  23. 2300 parts
  24. 2300 parts
  25. 2250 ? Any good?
  26. ECU parts
  27. Simjet 3000 low rpm
  28. Simjet 1700 conversion
  29. Simjet Battery queerie
  30. new ecu?
  31. Simjet 3000 problem on XL
  32. 2300 Case
  33. Simjet 2250... Lipo ?
  34. SIMJET STAFF WANTED
  35. Simjet 2300 for sale UK
  36. 2300 pieces ???
  37. 2300 Starting Problem
  38. Simjet 3000 - start failed
  39. Fadec Gaspar problem
  40. Simjet 1200 Help wanted!
  41. Sent in Turbine
  42. SimJet 1200-18 AES GE help
  43. Simjet 3000 RPM
  44. Simjet 3000 EGT reading
  45. simjet 1700 starting issue
  46. simjet 1200 parts needed
  47. simjet 1200 18lb help needed
  48. Start Issue.
  49. Nexus ECU problem
  50. simjet 700 problemsss¡¡¡¡¡
  51. manual simjet 2300
  52. Upgrade of 2300 ECU
  53. Simjet 3000
  54. Simjet 3000 parameters for convert to Fadec 06
  55. EGT probe calibration on Fadec
  56. Simjet Fadec Max Battery Voltage?
  57. fadec2002-d2 data sheet
  58. Simjet 85+
  59. kero start and ecu battery
  60. Kerry, check your PM's
  61. simjet 2300 fadec 2002 d
  62. 1700SP Upgraded to Gaspar ECU
  63. 2300 Starter Motor
  64. Gaspar Software on win98
  65. Gaspar ECU and reset funksjon.
  66. Simjet 1200 ASE startup problem
  67. SimJet 3000 Gaspar issues?
  68. Inner tailcone-Simjet 3000
  69. Simjet 2300 RPM Problem
  70. Distance from engine to tailpipe?
  71. Start goes to 15000 rpm then stops!!!
  72. Test run trouble.
  73. Motor type
  74. Which battery for Simjet Fadec 2002-D2
  75. Rpm issue with Simjet3000 & Caspar
  76. System Upgrade
  77. Need to contact Simjet for spares
  78. Simjet 1200 - Distance to duct
  79. SimJet AES 3000 turbine with ProJet Hornet ECU?
  80. US SIMJET email address change
  81. Sonic 8000 Kit - almost running
  82. Oil leaking from front cover?
  83. Sonic 8000 Kit
  84. Discontinued Turbine
  85. 3000 distance from bell mouth
  86. simjet nexus => destroyed compressor
  87. SJ 2300/ 3000 "S" Models
  88. Simjet 3000 and Gaspar Fadec parameters ?
  89. sim jet 1200-14 need to get a operating manual
  90. Are my bearings good on my Simjet 3000
  91. Simjet 1200 manual
  92. fuel valve
  93. its a miracle!!!!!!!!!!
  94. Nexus 3600
  95. Please help!!!!!!!!!!!!
  96. start sequence
  97. Bad ECU?
  98. 2300 can't reach full power
  99. Simjet 1700 overheating at startup
  100. propane valve
  101. does simjet have any service?
  102. What electric motor is in the 1200sp turbine bullet
  103. 2300 not starting
  104. SJ 3000 Front Cover Removal? *New Questions*
  105. Simjet 1200 failsafe
  106. SIMJET 1700
  107. SimJet 2300 Idle Problem
  108. urgent help for simjet 1200
  109. Clearence
  110. message RCPwFAIL on gaspar fadec with simjet 3000
  111. Nexus RPM/Thrust table
  112. simjet 2300 need help
  113. 2300 on the way
  114. Simjet 1200 leaking fuel
  115. Fuel Pump
  116. Simjet USA on Vacation?
  117. Simjet Denmark. Where are you?
  118. Simjet 2300
  119. Simjet S120 overheating?
  120. 3000 bad sound
  121. contating simjet Demark
  122. simjet 2300 dead ecu?
  123. Manual Overide of the Simjet 1200 Starter motor
  124. delivery time
  125. Simjet repair? where and who?
  126. simjet 2300 PROPANO IGNITE
  127. fadec 2002 problem on simjet 1200
  128. 2300 fluctuating idle RPM
  129. AE 2300 Heat Problem
  130. Problems with Sim jet Nexus
  131. .
  132. Simjet 2300 & 3000 !
  133. Simjet 2200 Acceleration
  134. Does anone own a 1200-14 ??
  135. E-Mail
  136. simjet settings for gaspar ecu
  137. 2300?
  138. Elec Starter and FADEC for Sonic 7000
  139. ecu
  140. repair simjet
  141. Simjet 2300
  142. Exhaust Pipe Distance
  143. simjet 2300 power
  144. Falcon Wings Simjet 1200
  145. Simjet 1200
  146. URGENT HELP NEEDED 3000
  147. Looking for someone to trade....
  148. simjet 3000 ,when turning on the reciever
  149. Skymaster F15 Turbine Center
  150. Well earned Thanks
  151. nades ecu instructions
  152. 2300 turbine
  153. Foul Starting after 53 flawless runs
  154. SimJet 3000
  155. 55.000rpm on a 3000AES!!
  156. New Simjet 1200 18lbs
  157. Need new fuel pump assembly for 1200
  158. Green LED Blinking and does not go off
  159. Simjet 2050 battery upgrade to Lipo
  160. Kerosene start?
  161. slow ramp up to jet a1
  162. Fuel supply question for a 2300
  163. simjet denmark
  164. simjet 3000 AES Strange Problems
  165. simjet 3000
  166. Sonic 7000 Parts Needed Help!!!
  167. O-Ring Specs?
  168. Simjet 2300 Trouble
  169. Config for Lipo Batt to replace the Nicad
  170. Total Run Time has changed?
  171. Projet for AES2300 or 2200Value
  172. Ed, sent you a PM
  173. Rebancing turbine
  174. Simjet 3000 Bearing Failure
  175. Stuck Solenoid
  176. Still Slow Ramp to Jet A
  177. Replacement ECU battery
  178. Startup on windy day
  179. Shortening shutdown time
  180. Slow Ramp to JetA?
  181. Priming fuel lines in a new plane.
  182. Strange temp readings
  183. Front cover removal help
  184. Charging ECU battery
  185. SP120 Torque
  186. Green LED not blinking
  187. simjet3000
  188. ECU Failsafe delay?
  189. starter motor
  190. simjet 3000 repair
  191. Simjet mounting Question
  192. sealant
  193. 2300GE fuel leaking problem...
  194. Adjusting Thrust
  195. 2300 Correct shutdown procedure
  196. I'm sorry to say I cannot find any info
  197. problem with throttling up on Simjet1700
  198. 2300 Glow Plug
  199. 2300 Idle RPM
  200. 2300 fuel cosumption
  201. Sonic 120 Fuel & Propane Tank
  202. Sonic 120 SP questions
  203. AMA Required Log & Simjets
  204. Lithium Batteries for 2300 ECU???
  205. Simjet 1200
  206. constant wet start
  207. Acceptable EGT increase due to FOD screen?
  208. Sonic 120 SP
  209. 50 MHz and Simjet
  210. Simjet 1200 AES Upgrade?
  211. Nexus?
  212. problem ?
  213. Starting Temp
  214. sim 1700 need help !
  215. Will it Void the Warrentee???
  216. Fuel shutoff
  217. Simjet at Toledo
  218. Duralite ECU Battery Pack
  219. Propane regulator
  220. Setting Max. RPM speed on 2300 AES?
  221. Maintenance Schedule
  222. Simjet and Lithiums
  223. Florida Jets 2004
  224. Simjet 700
  225. Simjet Orders
  226. Three questions for sonic builders
  227. Simjet 2300
  228. SimJet Speed Limiter?
  229. Feul for starting
  230. Ed or Kevin - Please contact me...
  231. Bp 2197 turbine-oil for lubrication?
  232. Glow plug replacement
  233. ECU putting out lots of RF noise
  234. SimJet Rep on US West Coast?
  235. New failsafe regulations
  236. FOD Screen 2300
  237. Speed Limiter
  238. Tubine oil from SWB
  239. Simjet 1200
  240. SimJet 700
  241. Simjet Sonic 7000 HELP !!! *PLEASE*
  242. SJ setup on Futaba 9C
  243. Trim wheels
  244. 2300 temp problem.
  245. Simjet 3000AES thrust issue
  246. 1200 AES ASD problem
  247. start gas bottle question
  248. SimJet 1200
  249. 1200 Thrust Problem.
  250. Simjet 1700 Bendix
