PDA
View Full Version : ZDZ & RCS Support
Pages : 1 2 [3]
  1. Water cooling conversion
  2. intial start up on a zdz 80 where do I set the needles?
  3. (mike) is rcs having supply problems?
  4. ZDZ 40 Hard first start
  5. RCS Support = Great
  6. Brisk spark plug equivalent
  7. RCS 44cc Twin Fuel Consumption?
  8. A little help with adjustment
  9. RCS turnaround time
  10. Octane content
  11. RCS 180 won't draw fuel
  12. this is for MIKE
  13. ZDZ80 Mount
  14. Spinner backplate prop bolt advice
  15. zdz 160 runs for 2 seconds then dies
  16. RCS 1.40 on a TF Cessna 182
  17. ZDZ 50 mount ordered from RCS
  18. zdz 40 RE tuning
  19. zdz 40 won't draw fuel
  20. ZDZ80 won't stay running
  21. Rcs 1.40
  22. RCS 1.4 / Black Goo
  23. convert 40 side in 40 rear
  24. Convert ZDZ 160 to 3W 150 Prop Bolt Pattern?
  25. ZDZ 40 Manual
  26. zdz 80 -rich inverted
  27. ZDZ Center Bolt
  28. RCS 1.4 question
  29. Champion RPM Expectations
  30. zdz 40b sportsman carberator problem
  31. ZDZ 40 Hard to start
  32. ZDZ 80 Tepm readings
  33. ZDZ 80 has no spark
  34. ZDZ50 break in prop
  35. ZDZ50 performance
  36. come on, some help please
  37. ZDZ 80 is it too rich?
  38. RCS 1.8 Sputtering Problem
  39. Falcon Ignition
  40. ZDZ 50 Problem??
  41. Broken Prop bolts
  42. Zdz-140???
  43. ZDZ Break-in
  44. Break in oil ?
  45. Moki 20 SA
  46. Prop Bolt Torque Settings
  47. ZDZ 160 champion
  48. zdz 60 carb bolts
  49. Help with RCS 140
  50. RCS 140 plug gap
  51. ZDZ 40B Odd behavior
  52. Zdz40rv-l
  53. ZDZ 80RV TAC and Temp readings
  54. ZDZ 80RV Throttle Question
  55. New ZDZ 80 w/problems-stuttering ignition, low power/thrust
  56. newbe to gas
  57. ZDZ80 stripped plug thread
  58. zdz 40b sportsman
  59. RCS 180 funfly prop
  60. Zdz40ri
  61. ZDZ 40 in Hostetler Libert Sport
  62. ZDZ80rv fuel tubing size?
  63. zdz 50 fuel tank size
  64. ZDZ 80 needles for MIke D.
  65. Mike HELP!! Ignition module????
  66. new zdz80
  67. ZDZ 50 piston
  68. ZDZ 120 and 160?
  69. Jr Nes910xz
  70. single bolt hub
  71. Zdz50
  72. Ignition wire routing on RCS140
  73. Zdz 40b
  74. Rcs180
  75. Mounting - ZDZ 80 vs 100 twin
  76. new ZDZ 50
  77. Service Question for Mike Dooley
  78. ZDZ 80 timing again! for Mike D
  79. ZDZ Break in Oil
  80. Will the ZDZ-80 RV work for my application?
  81. Ignition Battery
  82. Rcs 44b2
  83. Zdz50
  84. zdz 80 timing
  85. ZDZ 80 Ignition Battery
  86. ziroli corsair
  87. Question for Mike - ZDZ80
  88. slop in bearing ZDZ 80
  89. Zdz 50
  90. Bing Carb.
  91. What engine for CA models 27% extra
  92. ZDZ 80 flooding easy
  93. ZDZ80 prop bolt size
  94. Have a ZDZ service question
  95. 160 Champ Plumbing Question
  96. Spark Plug?
  97. what give's, my 80 stalls
  98. zdz 100 backplate mount
  99. 3 Blade prop on ZDZ 50
  100. Electronic Ignition Interference issues (worries)... Help!
  101. Battery connects to ignition...HOW?? RCS 140
  102. JMB can muffler installation
  103. Ignition Unit Earth
  104. ZDZ40RVL ides when going vert
  105. TF corsair 60"
  106. ZDZ 60 question
  107. ZDZ 80 HELP Please
  108. 210 versus 160 Ch.
  109. RCS 140 vs. Dynaflite Super Decathalon
  110. Zdz100
  111. rcs215
  112. 160 Champion Questions
  113. RCS 1.4 prop
  114. Please let the manuf. reps answer the questions posted in this forum....Thanks!
  115. Does zdz make a heli engine?
  116. 120 champion ?
  117. Rcs 75cc
  118. Isolators on ZDZ 80Rv
  119. 160 Champion
  120. ZDZ 50 Choke and Throttle linkages
  121. re:hp discrepency
  122. ZDZ 80 and inverted header for in fuse can
  123. RCS 140 and GB Ultimate
  124. ZDZ 80 on and AW 31% Extra
  125. Ball links on throttle / choke ?
  126. Avation fuel or racing fuel?
  127. rc showcase
  128. RCS power
  129. ignition power consumption
  130. Waiting time for ZDZ 80 S, 100 twin
  131. ZDZ 120 Help
  132. zdz 80 rv bearing replace on front
  133. Falkon PCI 1.3
  134. Walbro carb on ZDZ 80B2-L
  135. Preferred Oil ?
  136. 1.5 year old ZDZ 80..3 blade prop options
  137. ZDZ 80 with bing carb
  138. zdz 60 - zdz 80
  139. Shorter plug?
  140. ZDZ 80 Rail mount?
  141. ZDZ 40 and 100 info
  142. ZDZ 80 muffler choices
  143. ZDZ 75itwin plug (shopping)
  144. ZDZ octane requirements
  145. ZDZ80: Low End Popping/Gurgling
  146. Anyone home at RCS???
  147. Walbro Carb for the ZDZ40?
  148. rcs 140 and DP Ultimate
  149. ZDZ Counter rotating engines
  150. engine recommendation?
  151. ZDZ 40 timing
  152. ZDZ 80 RV: Prop spindle shaft/nuts not included anymore? Baffled Supersonic?
  153. zdz 80 break in/oil question
  154. ZDZ 40 - No Fuel!
  155. ZDZ 80 throttle problems
  156. ZDZ 80 Mung & Drool
  157. RCS 140 Need help
  158. Great customer service RCS
  159. Tech Question
  160. ZDZ 40 - won't run right - please help
  161. RCS 140 Bearings or Bushings ???
  162. Prop hub for 1.8
  163. ZDZ 40 very very hard to start
  164. rcs 1.4
  165. Rcs140
  166. Exhaust Couplers
  167. ZDZ40 tough to start
  168. ZDZ 60 muffler size
  169. Best darn Engines...
  170. Rsc 180
  171. ZDZ & RC Showcase Engine Direct Support Forum!
