- New addittion to the family
- Precise setup
- how much longer will the 50 kit make my 30
- flying below 0
- toki 40 any good in a 30?
- New Raptor 30v2, Houston help
- Raptor 30 question
- New to Heli's
- OS Warranty contact info?
- GY401
- Raptor Titan servos
- OS 50 Hyper Overheating
- why rotor spins even at idle?
- Clutch Liner replacement made easy
- Tight clutch
- Pitch Curve
- Blades for Raptor 50 Titan
- Help : DX7 Programing
- newbie question
- DX7 Mixing
- Few rapy 30 v2 questions
- Engine and Gear problem
- This 90 looks a lot like the 60!
- Custom Canopy
- Mini Titan Singapore
- Fried glowplug adaptor?
- can anybody recommend me a muffler???
- Pitch Gage
- Setup on Futaba T9CHP - question
- Too high of a headspeed damage piston?
- setup my Fut 6exh for my 30 v2
- Raptor 60 to 90 upgrade
- Got heli and engine now what muffler?
- Should I waste my time?
- Which engine for Raptor 90
- lining measure
- I did it!
- Raptor 50 VS 30
- leak in engine
- Glow Plug Extension?
- OS 50 Hyper fuels
- What brand of pipe is this?
- raptor 30 first heli!!!!
- Idle Up?
- Align BEC w/Glow Driver & Lipo - Voltage Light Accurate?
- Hyper 50 performance problems
- Bad fuel?
- Gyro Setup Confusion
- Blade Grips?
- Flourecent colored decals or reflective tape
- RAPTOR 50 info needed
- Rapto 60 to do or not to do
- Which glow plug?
- AUTOS
- Need a little tuning help please
- My First crash
- OS 50 Hyper - DEAD!
- can I do this?????
- New Maverick blades?
- gap between carb and motor?
- quick question
- Hopefully something better?!
- DX7 Help
- Good setup to fly 3d
- OS Hyper 50 trouble
- Raptor 60 -- TT70 Engine Problem
- question about loctite...
- futaba 611 gyro
- Raptor 60 Main rotor pitch in full Up/Dn elevator
- White Rubber Bands
- Throttle arm positions.....
- tail Wobble on Raptor 50
- how long should I charge this things?????
- Push pull upgrade.
- Chicago area
- Roptor E550 cooling
- R90 part number for material BK0698 ??? (header tank spacer)
- Question about the fuel tanks tubes and autorotation switch...
- TT Mini Titan short flight times
- Mini Titan canopies
- OS 50SX Hyper engine
- Raptor Frame
- Raptor Dye Experiment
- JR Gyro position question...
- what is the best way to remove a stuck glow plug....
- Hellooooo, helppppp.... Tuning my TT39 engine....
- question about a burning smell comming from my raptor 50
- Futaba S9252 or S9402
- Tail Belt Life Span
- Fromeco Arizona Regulator Placement?
- Hardware problems
- performance of the raptor 30 V2 with TT39
- OS Hyper 50 Temperature
- Raptor 30 Conversion
- Raptor 30 Muffler
- TAIL SERVOS: To Boom mount or not??
- BLOWN CLUTCH?
- TT70 Pro & Hattori 992
- Exhaust Systems.....
- Professional builders
- Mini Titan
- Raptor 50 - Spektrum AR9000 RX Position
- question about upgrading v1 blade grips to v2
- raptor beginner
- Futaba 9Cap super and Revlock Governor question
- question about the raptor 30v2 and the telebee gyro
- question about the fuel tank
- Kasama Heli Products online
- CLUNK LINES
- PV0409 one way clutch
- PROBLEM WITH THE OS-MAX 70SZ-H!!!!!
- One problem or two?
- R90 Play in swashplate
- Clutch engaging
- what is the difference between these batteries???
- how do i remove the clutch bell?
- TDR Raptor CNC T/R Grips
- Servos/Lipo Questions...
- ENGINE HEAT?
- Fuel spraying out of carb?
- programing futaba rdio to raptor 50 HELP!!!
- futaba 7CHP with raptor 50v2
- Raptor 90 TR gears
- Titan washout assembly
- Which hole for the control arm on Washout assembly?
- Which paddles?
- question about teeth in main gear of raptor 30 v2
- Raptor Titan tailboom supports
- raptor90 hover question???..
- how to balance fan/clutch combo
- Raptor 60 pinion change.. wow
- Another clutch problem.. clutch not completely disengage
- RL20 Problems
- Help here please - what battery is recommended for this Raptor V2??????
- OOPS
- Blade Geometry Help!?!?!
- Voltage Confusion and other ?s
- Looking for a feathering spindle
- Low speed wobble
- Good or bad?
- Incredible Save-What happened here?-VIDEO
- price to get raptor 30 flying
- Oh, the Humanity!
- Raptor 30 Tracking Problem
- Phasing?
- Raptor 50 push pull collective??
- JR 7703D GYRO
- whats it worth?
- raptor 50 in cold weather - any failures
- Raptor Titan 50 Upgraded!
- IF you had....
- Rear servo mount on R30v2 question (again)..
- How do YOU do it?
- Which gyro tape to use???
- Should i wait for Futaba 7C or get DX7 now?
- Raptor 50 V2 SE setup Help with Gyro
- Engine Re-Assembly Question!
- Flying problems with Raptor 30 V2
- How is your gyro mounted?
- 30v2 conversion to 50 gearing
- Correct running temps for Hyper
- Raptor 50V2 shaft driven?
- Help needed Upgrading Raptor 30 V2~!
- pics from sunday
- Align RCE-B6N BEC Users?
- Seek Owner Out, or Keep Heli?
- Raptor 50 V2 SE Rattling.
- One-way bearing won't anymore.
- New OS 37. Piston problems
- Check your clunks
- anyone else...
- Anyone with a TT titan 50/JR8103 setup help
- Raptor 50 pitch setup problem...help needed
- Source for receiver crash case?
- 50v2 crash, titan upgrade time?
- first crash
- Eurocopter 130 Fuselage
- 50 vs 60
- TJ Pro and Auto Glow
- Building 50 Size: TREX 600N or Raptor Titan?
- flybar weights and paddles
- Raptor 50 V2 resonating
- Gasser helicopter forum?
- JR 10X using a 7 channel rec.
- Banner towing with a Raptor 60????
- OS 37 engine Raptor 30
- Help Needed!!!!!!!
- G3 and a Futaba 9chp
- Crashed my R50 Titan, need help on what parts to get
- what size rx battery?
- Raptor 50 Titan Hardware Suggestions...???
- header tank plumbing?
- How "BIG" is too big for a beginner...
- Raptor Titan, Spektrum DX7 and JR g500t gyro settings
- Hatori SB-50 and the OS 50 Hyper?
- Funkey blades good or just cheap?
- Best fiberglass canopy?
- RL20 setup
- First Loop Success!!!
- R50 SE, 50 hype and Throttle Jockey gov setup probs.
- R50 Titan w GY401 tail not turning fas like before
- Quick UK isn't all that good...
- Shop in Edmonton
- Raptor 50V2 gasoline conversion
- How do you transport your Helicopter(s)?
- Engine won't fire
- Raptor 30 w/ OS30 Max loses Power
- can I swap or program a MODE 1 version DX7 to use with an Heli????
- raptor vs. gohbee
- Help with Upgrades and Setup
- OS .91 head gasket
- Engine Trouble
- V2 head Dampners on V1 head?
- why is important to get a good muffler????
- removing prop hub from TTPro 50H engine
- do I need this for the AR7000?????
- dampers
- Programming a DX7 on a Raptor 50
- Raptor 50 Vibrating
- feathering shaft
- Raptor 30 - can it do basic 3d easily
- engine trouble
- Gryo Issues-Raptor 60 v2
- Muffler Fitting
- OS MAX-91SZ-HRING PS-Hyper HELP
- what is a GOVERNOR?
- Raptor 30 v2 oscillation
- blade "flutter" real bad! had to set 'er down..
- what is "breaking in" an engine?????
- what receiver do you recommend to use with a raptor 30 v2 and DX7?????
- are these servos and gyro good with the 30 v2?
- is it possible 3d flight with raptor 30 v2?
- tail problems
- MAIN SHAFT
- Rev max and Titan 50
- Quick UK fan removal
- O.S. 50 SX-H Fuel??
- Wood Blades VS Carbon fiber? 600mm
- Battery's For New 50 Titan Build???
- OS 50 SX-H Temperatures
- raptor 30 v2 rpm unstable
- Which Rays dvd's for titan 50 build?
- neh531 or ds821 servo for raptor60???
- ENGINE PROBLEM!! URGENT!!!!!!
- 30 V2 OZ 37
- V1 to V2
- Raptor 50 Titan Kit Build Time??
- Kasama Head experience
- h
- Wrong Spindle
