- "Wanted : Firebaby parts"
- Kansas City Fly-In
- Fox Stunt Plug
- Tell me something about this engine
- Wichita Kansas CL contest - Aug 7-8
- Rossi spares
- STERLING FLYING FOOL
- When I Was Young
- Graupner plan
- Solved: wanted Mike Gibson's eMail about WW2 foamie wing kits
- Select Hobbies PT19 CL
- Too much engine?
- Ducted Fan Jet CL?
- Sterling Flying Fool
- Old Man Flies Airplane, Crashes
- Going CL with tis R/C model
- Old Time Stunt
- Magnum XL-15A BB ABC
- New Flight Box
- Pictures of Your U-Control Handle
- what magaine was Moody Mooney article in?
- Brodak Super Clown ARC - any tips before covering?
- Glow plugs
- Sarpolus Challenger
- Spitfire .15 Build.
- gws gm tissue
- engine comparision question
- Top Flite Nobler ROCKS!! Video link
- question on the ASP .21
- Squirt plans
- C-Speed model plans
- Texarkana CL Contest Results/Pictures
- E-power swap out for OS 15
- what type of lines should I buy
- Veco Tom-Tom
- Tip weight
- Which is Upline ?
- Best prop for a 46LA-S
- Neatly Adjust CG forward
- Gas engine?
- Re: Sterling F-16
- Texarkana CL Contest May 1st and 2nd 2010
- Hobby Fasteners contact info
- can't decide which plane?
- Super Tigre Needle valve question
- .15 Mosquito Kit?
- R/C to U/C conversion question
- Why is there no U/C in the review section?
- A bit off topic but We all can enjoy this for a short while.
- converting .40 sized rc cub to control line
- FIXED RUDDER
- Fireline
- Flaps or no flaps
- ? on typical flap elevator setup
- Venturi Bore?
- Watkins Scale Clinic - June 11-13
- Covering UC
- New C/L Stunter Kit.
- Plans for this
- .15ci / 2.5cc size C/L Questions
- build and performance Questions.
- Gilbert .07
- 049 racer
- I need a site with Control Line 101
- enlarging a AkroMaster?
- cox Stuka parts needed
- Alternative to .008 cable
- ? on CG and bellcrank position.
- Kenhi Mustang
- 1/2 A Mustang
- CG on Ringmaste Jr.?
- A few build questions
- Mr Palmer's Smoothie 1952
- MOVED: Mod-able helicopter
- OK Cub 149 manual
- Coquette 0.10 Stunter from 1955
- suggestions on for the cox049
- Rabe Mustang Plans
- cox 049 ?
- control line
- Control line trainer
- Searching for an AJ Fireball kit
- Info on old kits
- Old Time CL kits available:
- OS .15 in CAD
- Berkeley kits, did you build them?
- Sig Acromaster
- cox .049 ?
- Control Line Flyer on Lancaster PA Train Layout!
- 1/2A Dacron flying line?
- scientific kingpin
- mini zilch
- Belcrank?
- Who knows about the Fox Stunt Runt?
- 21" 1/2A combat wing cox .049 powered
- 24" w/s ringmaster
- Enya 15 III
- Balsa wood
- This is How I Got Started
- blending fuels/nitro?
- wasp .061, tank to use
- Help
- Minneapolis Piston Poppers New Year's Freeze Fly
- Ready to cover and paint
- What Paint?
- Build Threads
- Some Questions
- Flaps
- Name this plane.
- 1st time posting with a few questions
- Tank location?
- Questions on Cox and Holland Hornet 2 Speed.
- os .20
- Sterling Sterman CL12 kit
- eng case bushing
- Under the lights?
- Line Tension
- Holland Hornet 049
- Fox 15 instructions?
- Aviastar Control Line Engines
- ? on lead out lines
- what fox eng. is this
- Coming back I think
- How far is far enough
- Leroy cox
- Can anyone identify this engine?
- possible causes
- Teaching Boyscouts
- Anyone Flying Delta Wing C/L?
- General Control Line Discussion forum at AMA
- fox 15
- enya .35
- fox 15 os 15
- Control Line Crash......................
- tools
- cable type
- Hobby People has the AP Wasp .061 on sale for 39.99
- Yak 9 engine question?
- Help identify
- Voodoo U/C Video
- Check this out.
- AkroMaster CL-20
- Fox Rocket engine questions
- Spinner for Fox 35
- Best Prop for these engines
- Name the plane
- Need help from some Motor experts
- c/l old stunt
- Jim Pearson's Ukey
- Nobler ARF Advice
- Keilkraft remembered
- Simple Saber Control line trainer plan
- Line length for norvel pathfinder?
- pulse jet video
- How do you set this tank up??
- Fox 35 stunt eng setup issues
- Word of waring on Brodak ARF
- Need a fuel tank for a VooDoo
- Fuel proofing?
- Electric Control Line Speed
- sterling flying fool scratch build
- Help on building an Electric Ringmaster Jr
- Comming back to u/c maybe?
- BCD Carrier Video?
- Profi
- Svensson Pinto plane
- Ringmaster Fly-A-Thon
- OS Max-H .35, OS 29X others
- Black Hawk Pitts Special in stock???
- Hi, i have a ucontrol plane i wanna restore
- F3A? Not anymore! (conversion photos)
- Aldrich Nobler - different type of engine
- Skyray 35 plans
- Testors and cox .049 glow heads
- How to use cox .049?
- O.S. Pet .099
- Norvel 061 Diesel Conversion?
- 2009 car nats
- Wing Mfg. B-25 Build
- ..1/2 A peanut
- Whip Powered
- WHY U/C ROCKS!!!!
- Engine break-in?
- Modifying a c/l design [plus building photos]
- Brodak Electric Super Clown
- plans/dwgs for the old Sterling beginner series
- Need a engine
- 1/2A Brodak Pathfinder question
- Flew a electric control line
- Foam
- c/l 1/2A combat?
- fuel tanks?
- Berkeley AT-6 Engine Recommendation
- Berkely AT-6 Engine Recommendation
- returning and a test post.
- Merco 40 (needs needle&spraybar assembly
- Where can I find a Lil Snip...
- Good Modern Engines?
- Wanted: Old PT 19
- freeflight
- Crashing problem
- Phantom from scratch
- line slack?
- Tanks
- Phantom Mite
- Webra .61 c/l mod?
- Gilbert 11 heads
- Kookaburra Plans , Spitfire VIII
- Props?
- 1/2A Combat engine ?
- Wichita Control Line contest - Aug 8-9
- Fox 35 press question
- Designing 1/2a CL, need input
- Supertigre or Evolution CL engines
- Fox .15
- Ahhh...
- adding castor?
- fuel
- Top Flite Combat Kitten
- question on Fox engines
- You Got'em Post'em
- Infantwagon with TD 020
- FOX .15 STUNT ENGINE
- Mouse Racing Plans or kits
- Please Help... Jr Ring Master Plans
- Line Tension
- Hanger 9 Pt-19 .36 Arf 54' wing
- DeBolt Speed Plane
- What is it?
- WANTED! Your help in my recovery of stolen engines! REWARD!
- perfect fuel tanks
- New to control line
- Need a fuel tank for my new balsa airplane.
- U-Control C-46
- Recent vintage combat projects
- Competition - Super 70's?
- Flite Streak 15 plan needed
- Fox, K&B and McCoy fuel
- JAURES GAROFALI, in memoriam.
- TeeDee Thrust washer removal
- Memoriam: Rusty Brown
- Does anyone have this book?
- old engine parts
- New OS FP .35 P/L sets?
- A cautionary tale for seniors
- anyone recognise this spitfire
- cox gone?
- Need help with a part for cox Motor
- Control Line in Kansas City
- Why don't we put technology to work ?
