View Full Version : Speed - RC Gas Boats
- is it worth it
- Conversion of gas engine to nitro??
- Jet drive for Gas boats
- coleman fule in a g260
- Who sells Expresscraft Thunderbolt
- is gas faster than nitro?
- super cat
- G230rc engine cooling question
- break in?
- stainless tuned pipes
- suggestions for moding a g26
- FULL RACE PORT TIMING 26PUM ZENOAH
- EHAUST WATER LEAK
- twin gtx
- Looking for deep v with gas engine.
- picture of my frame
- is this a good boat
- 31cc ryobi weed wacker motor
- trim tabs
- GTX AND A QD25
- who makes this hull
- WHAT HULL IS THIS?
- How long before you throw out fuel???
- Slippin' collet... ARRRRGGGG!!
- Rudder depth below keel?
- need for speed
- Building 2nd boat.....
- pipes
- cooling prblem
- Torque setting
- Does anyone know of a transfer case
- looking for drives
- Powder coating
- air vent ideas?
- Need help please!!!
- Quality Stinger type surface drives?
- Single rudder?
- You're going to love this!
- Stuffing tube
- QD Zenoa...Homelite ??????
- engine
- Radio boxes
- Thunderbolt Build Pics
- size of stringers for a 48inch boat?
- loun?
- Need Advice on Properly Setting up Throttle Cable
- Fresh Quad cat video, 26th March
- thicknes of wood for building.
- plans for race boat.
- Big engine, small boat?
- Expenditure Evaluation
- prop thrust bearings
- callan cat
- Blackhawk hobbies cat
- aeromarine
- best sites for free good plans for a boat
- SHOW OFF YOUR BOATS forabuck 51
- Ebay Hull "Arrowshark"
- Advice when removing return Spring on WT644
- need a larger hull cat or vee
- Gel Coat Cracks
- r/c boat plans.
- enforcer gp???
- Hifgh speed spin out
- What engine is this?
- hardware
- Decal Shadow
- Any ideas for this?
- new project
- New rc boat video taken today!!
- looking for boat hull
- Bottom Dead Center.......
- Sponson ride pad
- Show off your Boats!!!!
- G260PUM weak spark. Help!
- 1/6 scale nor-tech 5000 super cat
- Inline twin polini engine? Total of 100cc?
- Butch blocks
- Opinion Needed
- Hydro Junkie - predator plans
- NEED HELP ON SIKK 27CC CONVERSION
- RC boaters in Portland/Vancouver
- Need ideas for my retrieval boat
- paintinng my wood boat hull!
- Boat stands
- My first scratch built boat, help please
- hydro
- Motor ID
- How much does your boat weigh??
- trim tabs
- Zenoha Idle Speed
- a couple of tubs
- zenoah not sure what kind I have.
- mini moto bike engine in a boat 49 cc!!
- Thundercat's max speed?
- Foam flying hydroplane
- 39cc to 50cc engine upgrade??
- Zenoah engine Problems?
- Gas tuned pipe
- Flipping a jug
- SENT FOTO
- Zenoah Jug removal
- graupner
- Any info on 53" Aeromarine Jersey Skiff?
- help
- what you see error in the photographs
- Gas Rc Engines
- And a special thanks to Raj too
- Video of my boat is now on the net!!
- Zenoah Crank Seals???
- First gas boat...
- What should I buy?
- A special thanks to Justaddwata, Frogman524, Izvagias, Paulm
- best gas mix?
- NEED TIPS ON PORTING A 27 SIKK!
- What paint to use?
- hydro hull
- Setting up First boat need some help
- MOVED: chris chianelli
- should I buy this ?
- Water cooling Flange
- my first build ?'s
- Drive Hardware Setup Question
- looking to buy a deepv
- weed eater engine tips
- where to run
- IV bags
- Hobbyshops in Phillipines and Singapore
- prop for 48" PI deep V?
- PROboat MissLlumar??
- Speedmaster's
- Who Make's This Motor ?(The Conversion!)
- Boatman Hobbies Hull
- what do yall think?
- Possible Scam, Beware!
- anyone have this boat?
- Free plans, E-Bay scam!!!
- Jumping back in
- Prop recomendation for 53" Cat
- Pressurize Fuel Cell
- I want silence!!!!
- Gas Can with pump
- GPS
- Looking for a plan!!
- Forabuck 51"
- looking for cleats
- help
- whats to much for paint???
- autobailers revisited....again
- Volvo XS-1 Boat
- Braided water lines
- Hull Materials
- Racing
- Kill switch ???
- PROPS ~~ Have a look
- thunderbolt
- should I dare?
- how much do you think shes worth?
- Zenoah Hardware
- Looking for zenoah/sikk (Found!)
- whos the hottie?
- paint
- Pictures
- WOF or fiberglass?
- Cracker Box
- bending fiber glass
- Hull Materials
- Clutch info
- Team Believer
- A few questions...
- prop 2 or 3 blade & why???
- Decals kits for boats???
- more free plans
- free boat plans
- ZENOAH PROBLEM...ªªª
- Expresscraft Thunderbolt Build pics
- full gas boat build
- Question regarding Hulls
- Where to find videos
- Checking balance of prop
- GAS RIGGERS
- Bilge pump
- Hi!
- 56" Apache build
- check this hull out!!!!!!!!!!!!!!
- budweiser stand
- Engines
- Beta Testers Needed!
- How cool?
- linkage for MHZ S6 drive?
- how do you build
- Best Surface Drive, Rudder Selection, and help with prop selection
- Need porting job
- website
- Wet Tuned Exhaust
- cat plans
- TRANSMITTERS
- new style popeye hatch look
- what boat?
- donzi 49" & challenger 48"???
- pics
- bonzi 64" fountain
- Best or safest way to drill holes in hull??
- expresscraft
- llo all
- Engine Temperatures.......
- engines/gas/mods/paint,polish,braided hose
- New Lawless outboard G-Drive for Zenoah
- New Sikk engine
- 1/8" "door skin"
- Miss Bud 1/8 flying by on the lake....
- Anyone use 3rd channel for kill switch?
- battery charger
- Greasing the flex shaft
- Avenger vs Thunderbolt
- COBRA MAX 51inch
- What size engine?
- Super G hatch
- V24 Throttle Travel Solution - Easy Fix
- Sealing hole for wires in radio box??
- still not sure what boat to go with
- Zenoah Engine..
- new member
- apache w 23 or 26 zenoah LOOK
- Engine swop and conversion to surface drive
- Shockwave 55 Motor Mounts
- mhz?
- ryan trimmer motor
- RADIO OR SERVO BOX
- First gas boat
- zen vs. sikk
- clutch engaging to soon
- big problem
- Flex Cable grease
- Cat with twins...?
- Retrival boat
- Prop under water depth?
- FailSafe Unit
- Shockwave parts
- Zenoah carb
- prop
- HANDLING
- Sikk 25cc tear down
- Sikk stuffer crank fits the 260
- petrol rc boat
- Mystery engine
- will this be fast ???
- Water pickup location?
