PDA
View Full Version : 3D Electric Flying!
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. Looking for good 3D Park flyer
  2. 3DHobbyShop 58" Edge 540 and 59" AJ Slick
  3. YAK 54 Carbon Z Landing Gear Hopup
  4. Precision Aerobatics Katana MX Build
  5. 4mm EPP foam. where to buy??
  6. Flitework Edge 540 66.9" problem
  7. Looking for Sig edgetra build
  8. Flying on the EDGE 3D Skills
  9. Value Hobby 32" EPP Laser
  10. ESC turned it's self into a roman candle
  11. "my ultimate depron foamy"
  12. Hobbypartz 3 Axis Gyro
  13. Inverted flight with UMX Micro Revolution 3 Bipe
  14. Exceed rocket on a FT3D
  15. Precision Aerobatics headquarters relocation sale up! Up to 50% Discounts!
  16. EPP Hobby 3D foamies
  17. Precision Aerobatics Labor Day Sale! 15% Discount!
  18. mini E3D by Gary Wright Model Products (GWMP) - Discountinued.
  19. What 3d foamy with 60" plus wingspan?
  20. PrecisionAerobatics.com Fathers Day Sale! 15% Off!!
  21. Flite Test Baby Blender Indoor Flight
  22. HK Edge 540 EPP
  23. Self contained LED's
  24. Adding Leds
  25. e-flight Micro Yak 54 Jitters
  26. Good, neutral point for balancing a Yak54
  27. Another Tale of two Yaks__ Flying The Twins
  28. Videos 3D
  29. Throttle on idle rpms
  30. PA Extra MX or AeroWorks Extra 260 Freestyle?
  31. 3D easy flyer
  32. QuiQue Yak 49 inch I need a cowl, anyone know where I can get one?
  33. EF 60" Edge 540T-EXP - elevator sero or servos...
  34. Looking for a replacement from years ago
  35. 3G-A,almost works as good as the original 3AX 3D Stabilizer
  36. SU - 47 Swept Forward Wing - Breaking the laws of Physics
  37. 72" sukhoi 29 and prop question
  38. Which One Should I Get?
  39. Can anyone identify this plane?
  40. Sebart su29 140e 3d monster
  41. Dynam SMART Trainer
  42. QuiQue 49" Yak 54 landing gear
  43. Sukhoi SU-37 3D aerobatic (Active Canards)
  44. Sukhoi -> SU - 47 Swept Forward Wing
  45. Hello. Need plan Extra 300
  46. 3D switching help needed.
  47. EF MXS 64" Motor
  48. pz extra 300 d7xs setup
  49. 3D Foamie kit help.
  50. What plane for a OS.20 four stroke
  51. Help me schulze ~~
  52. Small Gas 3D Plane
  53. PA Ultimate AMR
  54. Carbon-Z Yak batteries
  55. Stingray variable pitch quad doing 3D
  56. Texas RC Planes / OMP Katana 70 V2 Electric Conversion...>>>
  57. EPO 3D and some Pattern (40" range)
  58. help me out here
  59. Inverted foot launch, dangerous?
  60. backyard 3d foamy
  61. slow flying competion
  62. Will this work? First electric foamy question
  63. Fundango
  64. Four brushless outrunner reviews test
  65. New Hobbypeople 3D stabilizer,AVCS setting issue
  66. Elevator/Flaperon mixing on a foamies
  67. METIS by fmd planes
  68. sukhoi su 35/Devo 12s setup problems
  69. best "small" electric 3D bird for football field area
  70. Parkzone Visionaire
  71. E-Flite Tribute
  72. will lengthening the sticks slow down the control
  73. New plane idea for Horizon.
  74. Millenium Master
  75. New E-Flite Edge 540QQ 280
  76. New 3D stabilizer,any one know?
  77. RC Polaris Sea Plane
  78. color dark bottom vs light bottom
  79. ********Extra brotherhood**********
  80. BNF or RTF foamies?
  81. 3DHS 47"Extra SHP
  82. eflite twist 480
  83. Charging Question
  84. Art Tech Yak 54 from HK. CG? Motor?
  85. NEO 25 890kv set up for 3D flying
  86. 3D Hobby Shop 41" Edge 540 set up
  87. 3DHOBBYSHOP 42" Slick Landing Gear Alternative
  88. 35% Electric Extra
  89. Great planes edge 540 motor?
  90. Pilot-RC YAK 19% Set-up?
  91. Hacker A30-12XL v2 motor problem
  92. 3D plane for park 400 out runner motor
  93. Eflight Quique Yak 54
  94. Stats for Motor, Esc, Battery set up for a 48 inch plane
  95. PA Addiction
  96. Which Yak did you buy?
  97. PA Addiction X??
  98. Indoor 3D setup?
  99. 65cc Rimfire or C80-80 Turnigy
  100. watts needed
  101. What Is the Smallest Brushless Electric Motor Available?
  102. Need help with eflight mini edge 540
  103. Twisted Hobbys CRACK YAK
  104. PLANE stays in last aleron setting
  105. Help finding new fuse for my components.
  106. Extreme Flight Extra 300/45'
  107. 3DHS Edge 48 - Cheap Motor/ESC Recommendation
  108. Prop questions for an electric noob....
  109. Making A 3D Foam Airplane
  110. aeroworks qb 52" extra 260
  111. EFLITE POWER 52 MOTOR
  112. Mojo 40 Electric Motor - Need your suggestions!
  113. Techone / Hobbyking Angel EPP 3D kit
  114. The New Sport Pilot's Guide To 3D
  115. Seb art Challenger S C/G??
  116. Value hobby Sabre 51in?
  117. CMP Katana SR
  118. E-flite twist
  119. MCPX HP05 Brushless UPGRADE
  120. 3DHS Edge 48 question
  121. as3x (or gyro)question
  122. Led lights for Mcfoamy
  123. Indoor Flying Foamie Videos
  124. Yak54
  125. Extremeflight Edge 540 EXP 60" Servos
  126. Old school micro 3d, the Drenalyn!
  127. GP Reactor Biplane 61 electric set up
  128. Mcfoamy as trainer with buddy box, and foam repair
  129. Hello anyone here??????????????
  130. Need advice on finding a Foamy
  131. Thought I'd made up my mind, but...
  132. best deal on micro servos
  133. Need help with rolling Circles
  134. NEW HOKUSEI MODEL !!!!
  135. Dynex Nano 2.4 using 4-site guts.
  136. What prop for Banana Hobby Pitts?
  137. 3D Hobbyshop 38" EPP Slick
  138. Are there anyone here knowing about Banggood?or buy something RC items from it?
  139. PA Bandit
  140. UMX Beast 3D battery question
  141. 57" Extra 330 50EP
  142. How do you KNOW
  143. 3D Hobby Yak 55
  144. Telink 3Dbuster building thread
  145. West Michigan Parkflyers McFoamy fast build instructions
  146. Castle Creations
  147. Confused about first 3D to buy
  148. IKARUS Shock Flyer - Whats as good?
  149. Help picking motor and servos for Extreme Flight 48"
  150. AJ Slick elevators
  151. Sbach 342 3D70
  152. DELETE THIS THREAD
  153. DELETE THIS THREAD
  154. Aerokinetix 42" Vizion
  155. DW Foamies Juka 40
  156. VIDEO: New ARROW V5 in action
  157. Is 10A too much power?
  158. HK Turnigy Easymatch .60
  159. Mini-Funtana where is the CG location?
  160. best prices for Trex 450 v2 v3 ! v2 ONLY 168USD
  161. Sniper X II 3D
  162. Precision aerobatics Extra 260
  163. helmet head pilots
  164. Need opinions on motor selection for large electric.
  165. Eratix by Eflite
  166. Velox 58 Electric Set-up...Please Help!!!
  167. Warped Aileron - 3dhs Edge 41
  168. E-Flite Yak or 3DHS 48" Edge?
  169. NEW NEVER FLOWN E-FLITE TENSOR, the last one?
  170. Hovering
  171. 3D Hobby Shops 48 Edge
  172. 3D Aerobatic Aircraft Shootout!
  173. 3D Model Fly Sbach 342 55"
  174. 71" and 59" slicks by 3DHS
  175. Co-pilot set up for Katana Hover position.
  176. E-Flite Carbon Z Yak 54-New!
  177. motor for 3D flying
  178. Intro to 3D: Recommendations for existing hardware
  179. Gyro calibrated Katana for Hover
  180. 3D Fly Airplanes 39" S'bach
  181. *Extreme Flight 60" Edge 540T-EXP*
  182. need 3d parkflyer
  183. EF 48" electric profile
  184. Where can i get foam cheaply?
  185. Pilot Seduction Freestyle - Conversion?
  186. E-Flite Carbon-Z Yak 54 Problems
  187. Hacker Brushless Motors question
  188. Completed my Big Banchee - Prop advice?
  189. Eflite Carbon Z Yak glue???
  190. WhiCh one!
  191. Electrifly E-Performance series Reactor or Yak-54?
  192. electrifly yak 55m ?
  193. Just aquired Cermark Banchee E-3D airframe - Advice please :D
  194. Fliton extra 260 mini CG adjustment help needed
  195. U-Can-Do 3D EP
  196. Donuts Models?
  197. I FINALLY FOUND IT!!!!
  198. Need suggetions for a .10 size kit
  199. Aerobatic Aircraft from RCWarez.com
  200. best plane for 3d specifically hovering
  201. Edge 540T E-Performance Series 3D EP ARF 50"
  202. AJ slick
  203. Carbon-z YAK engine mounts
  204. Spray Painting Depron Foam
  205. Durable 3D Foamie for Soccer Field
  206. First 3D plane: Mini-3D GeeBee Balsa
  207. Xoar props
  208. E-flite UMX Extra 300 3D (Ultra Micro Extreme)
  209. Need help setting up a plane
  210. What airframe Velox or MXS
  211. Thrust Vector on 2 Dog RC Yak 52 EPP !
  212. E-flite YAK45 CarbonZ with Lighting Kit - 3d flight by MOHAMED ALDHAHRI
  213. ARFMFG.com Yak 54
  214. Videos of maiden and second flights: 3DHS 72" Extra 330SC
  215. Wildcat 3D
  216. E Flite Carbon Z Yak
  217. help with throttle responce/curve
  218. Xoar Electric Beechwood 16x6 Prop
  219. Is hot glue ok to use?
  220. Motor Prop and Battery selection??
  221. Lipo size and weight compare
  222. Hyperion ZS3025-10 Manual
  223. Blade micro heli 3D
  224. 42" slick engine10 or 15?
  225. 3-d model for eflite 15
  226. Yak broken motor mound
  227. Gh0st
  228. Which plane should I buy
  229. 3d plane tip stall??
  230. 3DHS stock status
  231. pilot rc sbach 342 26%
  232. Parkmaster 3D: a flying problem; please advice !
  233. Faomy Survival
  234. Parkzone Extra 300 fine tuning
  235. Hinge Tutorial?
  236. good plane for 11.1 2200s
  237. aileron flutters
  238. Foam 3d plane 6-9oz
  239. airfoilz edge 540 setup
  240. cant hover piaget 3d with a rimfire 300
  241. Edge 55 or Extra 330SC
  242. have um 4 site electronics what can i do with them?
  243. need help with my eflite
  244. Scorpion 4025-10 and 4025-12
  245. addiction thrust 20 prop shaft
  246. want to start, what to get, RTF?
  247. 3D
  248. What would be a good Plane to fly at a Baseball field?
  249. E-flite carbon z yak 54 build and fly
  250. CRASH REPAIR , HELP!
