PDA
View Full Version : RC On Road Nitro Cars
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Am i gonna need different engine mounts
  2. Will these fit my HPI RS4 3 EVO
  3. Need Help
  4. Adams Racing Foam Tires WOW!!
  5. 4-tec engine question?
  6. Traxxas 4-tec roto start????????
  7. Hi,these tires will fit these rims,and work fine
  8. Has anyone switched SH.18 to OS .18 in any Redcat? Or any other .18 for that matter?
  9. wheels keep turning at idle
  10. smaller gear not turning wheels
  11. question for the tuning guru's
  12. Spektrum dx 3.0 binding
  13. Nitro 4 tec convert to 3 speed
  14. TG10 rally converting ?
  15. D-M1 single brake
  16. body fitment
  17. diff .
  18. TRX 3.3 question
  19. Foam Tires on HPI TE 37 wheels?
  20. Is the 4-tec 190mm 0r 200mm when it comes to body
  21. hpi rs4 rtr evo + with acura nsx body problems
  22. Exhaust back preassure cooler work?
  23. Drive problem with CEN CT5
  24. Hpi rs4 parts
  25. Will 3.3 4-tec belts work on a 2.5
  26. They stopped making the 4-tec 2.5 didn't they?
  27. Adam Drake Rocketman??
  28. smartech car pipe/header upgrade
  29. Need Help! Kyosho Spada 09 Steering Servo
  30. GTP2 nitro th KILLER
  31. Rc 10
  32. multiple questions about a ntc3
  33. New and need some help:)
  34. Is This Right?
  35. Hi does anyone know if this is a good onroad
  36. What engine
  37. Engline question
  38. 2 speed pinion gear change? pls hlp
  39. How fast?
  40. Compagnucci 1/8th scale GAS car
  41. kyosho fw06/06 gear rotio change?
  42. Engine Question
  43. smartech commando
  44. rs4 clutch bell bearing size?
  45. DuraTrax Street Force GP
  46. Foam tires for on road inferno?
  47. on road pull start engine options
  48. HPI RS4 3 EVO Shaft stuck
  49. Traxxas 4-Tec w/ Pro .15
  50. Centax Clutch Help
  51. Centax Clutch Help
  52. hpi rs4 its not going anywhere
  53. hpi rs4 12SS no start
  54. Traxxas engine replacment program
  55. Removing threaded pinion gears
  56. RS4 evo motor fitment
  57. Nitro RS4 RTR 3
  58. I'm new to nitro and need help
  59. What are the different year models that will work
  60. Serpent Vector spec 2000
  61. RS4 tire recommendations, just for bashing
  62. Jaco NitroShoes Offset
  63. No feed back there,maybe i'll do better here,it's an on road
  64. what car?
  65. RS4 3 Evo+, 4Tec 3.3, TC3 Nitro?
  66. Smartech winner two?
  67. twin gtp build
  68. megatech parts!!!!
  69. What's it worth: Kyossho GP Landmax
  70. Gear help for IGT Spur, tech related
  71. BEST PLACE TO LOOK FOR USED 10TH OR 8TH SCALE COMPETITION ON ROADER
  72. Cheap wheels/parts
  73. Engine options
  74. need help with my nitro 4-tec
  75. 1/8 Wheels
  76. Ofna Hyper ONE Seven
  77. What is the difference in RS4's
  78. You guy's gotta check this out,some may have already
  79. 1/12 Nitro On-Road Servo/Receiver Advice
  80. Nitro 4-Tec question
  81. one speed Schumacher fusion
  82. mugen seiki msx3
  83. one speed Schumacher fusion
  84. rs4 help please
  85. Hpi nitro rs4 shuts off!! help please!!
  86. rs4 engines help
  87. need to find a easy starter
  88. traxxas nitro 3.3 4 -tec
  89. need info on my nitro rs4
  90. clutch shoe worn too low?
  91. Serpent 966 Build.
  92. 1/8 on-road setup?
  93. HELPPP!!!
  94. ? for one of the guys down in the bottum miami
  95. HELP WITH SERPENT VECTOR
  96. How low is too low?
  97. 4-Tec OS upgrade
  98. hpi rs4 brake/throttle problem
  99. OFNA ULTRA GTP2
  100. is this worth it? (HPI RS4 3 EVO ) craigslist
  101. Flywheel and clutch assembly help
  102. HPI RS4 EVO engine swap question
  103. Need setup tips for a rally car build!
  104. help identifying this car
  105. Good price for used HPI RS4
  106. flipped my 3evo+ and now the engine/throttle goes all out
  107. Dad needs help with engine and break in
  108. Dad needs help with engine and break in
  109. What rc model is my car???? PLease help
  110. body super nitro rs4
  111. Looking for a Nitro Kit
  112. Mod question
  113. Shocks oil and Springs.
  114. Converting an R/C Nitro Car To Tether Car
  115. need help my engine slevee is to tight to go inside block does it need changing?
  116. rs4 rally conversion
  117. Hpi nitro 3
  118. Whats the difference between these items??
  119. Nitro RC Car Tricks To Improve Performance
  120. RS4 for Beginner?
  121. rs4 3 wont go straigh after left turn
  122. Foam Tyres
  123. brushed motor in nitro cars
  124. Rpms or horsepower
  125. Help needed.....
  126. gears wearing down in minutes
  127. kyosho fw-05/06 clutch upgrade?
  128. HPI rs4 3 1 nitro car 1st generation convert to t3.0 engine and 2 speed trans
  129. team infinity .18 engine too rich and floods
  130. My Nismo GTR34 crash-test ;)
  131. Grinding a crank pin to eliminate pull start?
  132. HPI RS4 2 Clutch Problems
  133. Kyosho Gx-15 Overheat
  134. HPI Nitro RS4, snow-ride :)
  135. Nitro Tips and Tricks
  136. New World Record 120mph for nitro!!
  137. Kyosho GT transmition Problem need help!!!
  138. Kyosho Gt trans. Problem need help!
  139. Serpent sparepart
  140. more problems with 4 tech pro
  141. F1 Nitro - 1/8th Scale
  142. 4 tech pro
  143. Miamiz Finest, I need your opinion
  144. rs4 3 evo
  145. traxxas 4-tec help
  146. Help finding a body
  147. Which glow plug to use
  148. Can I use other brands of piston/sleeve in Novarossi
  149. kyosho super 10 FW-4
  150. suggestions for fist time nitro
  151. need help with 4 tec
  152. Novice - Restoring a mistreated GS Racing Sonic 1/8 RTR
  153. New body for the NTC3 mua ha ha.....
  154. 2 speed upgrade help
  155. power plant
  156. ofna gtp tires
  157. Official Team Magic G4 Thread
  158. DIY drift tires
  159. Hyper GPX4
  160. .18tz in a rs4-2
  161. Original HPI nitro RS4 parts ?
  162. TC3 RB Concepts Rody
  163. Max Speed Run Setup
  164. Old HPI Nitro RS4 replacement engine
  165. RS4 Super Nitro Question
  166. Schumacher Nitro Fusion 28 Turbo RTR
  167. anybody know if the cen crt 5.0 anygood?
  168. Which small block?
  169. V1 RRR Evo2 WC parts questions.
  170. Im the McGyver of Nitro Rc cars!!!!!!
  171. wanting to buy a on road. got 2 choices, which 1 is best?
  172. BELT TO GEARBOX CONVERSION
  173. post your 1/10th scale on-road car..engine size doesnt matter
  174. 2WD RS4
  175. drifting a rs4 3 evo+
  176. The 18TZ of big blocks
  177. rs4 fuel line fix
  178. Kyosho DRX
  179. Converting a second hand RS4 into rally
  180. Auto start issue Please help.
  181. HELP **WHATS THIS MODEL PLEASE**
  182. Chassis Identification
  183. RS4 as a drift car?
  184. hpi rs4 not shifting
  185. please help
  186. front and rear belts too tight on the most loose setting
  187. did i get a good deal?
  188. rs4 no low speed needle for tuning?
  189. whats wrong with my steering!?!?
  190. can anyone help me with 1/8 tyres
  191. fail safe for a rs4
  192. new to rc nitro cars and need help already
  193. CONVERTING TO RALLY
  194. how long do belts last on 1/8 on road kyosho evolva m3
  195. CAR ID PLEASE
  196. ISC Speed run is coming again. Whos going?
  197. fun factor
  198. fun factor engine question
  199. new to on road cars.
  200. New to racing is the Tamiya TG10 MK2 good for 1/10 Touring Races?.
  201. NTC3 two speed in a LD3
  202. HPI RS4 RTR or Associated NTC3 for bashing?
  203. need someone to identify this for me
  204. Tuning my Rs4-3
  205. Bolink Nitro Legend
  206. having trouble with driveshafts on kyosho evolva m3
  207. rs4 questions ?
  208. where is the best place and serface to setup rc car on hudy setup
  209. need a lil onroad car help
  210. Kyosho Mystery Car???
  211. Impulse Buy... What do I do Now?
  212. RS4-3 Engine swop info needed
  213. TS-4n V.2
  214. Good glow plug for byron 55% fuel
  215. Thunder Tiger TS-4n issues
  216. Thunder Tiger TS-4n issues
  217. wheels and tires help
  218. Pull start won't work on my new Great Vigor car
  219. pros and cons
  220. Nova race pro head on OS 18 CVR install...
  221. HOW TO USE A SLIDE CARB ON RS4 3 .18 OSV
  222. I need help...what hpi car is this????
  223. Servos Behaving Weird
  224. thoughts on the hpi rs4 3 evo+
  225. Old but new to sport!
  226. Stripped gear on Ofna LD3
  227. Rs4 3 won't shift?
  228. rs4 running
  229. Custom rear exhaust for my NTC3
  230. Rat Rod project (Russia, Moscow)
  231. Help!! Please
  232. My NTC3 Video....
  233. Tamiya TGX 2 speed shift problem / PLZ HELP ME !!!
  234. any ideas?
  235. Maintenance on Nitro RS4, thinking about firing it up tomorrow
  236. HPI RS4 3 EVO+ Dead Engine?
  237. car breaks when im in neutral
  238. Tc3 shifting.
  239. clutch bell dosnt move when cars pushed backwards on the flloor
  240. clutch problems
  241. RS4 Question
  242. competitive racing
  243. [Thunder Tiger TS4N] Tuned pipe question
  244. What Kind of Tires
  245. Tc3
  246. Glow Plug for the .15 Pro and .18SS HPI
  247. Traxxas 4Tec Pro 15 engine tunnin high idle
  248. tires
  249. Questions about adjusting gear ratios
  250. New HPi RS4 Drift help
