PDA
View Full Version : RC Airboats
Pages : [1] 2 3 4 5 6 7 8 9 10 11
  1. New airboat build need advice
  2. Skulls scheme help !
  3. Static model air boat
  4. AWANFI 3S LIPO TESTED Aquacraft Cajun Commander SWAMP BOAT!
  5. Pulley drive
  6. Nitro airboat build
  7. what size engine.
  8. Air-Cor
  9. choosing a prop for a brushless motor
  10. Largest scale airboat built
  11. cajun commander
  12. 60cc airboat maiden voyage
  13. What is this airboat?
  14. Motor replacement
  15. dumas air boat help
  16. Which propeller for my airboat?
  17. Fins on AirBoat ?
  18. Expresscraft is Back
  19. My Daughter's scratch airboat
  20. Airboat Woes....
  21. Build #10; Farman "Water Taxi"
  22. Dumas Swamp buggy
  23. .15 Size Airboat Plans
  24. Can't start my Webra Speed 35 (Heli) Airboat
  25. Gas tank position - below motor??
  26. New Builder/First Air Boat
  27. Airboat Kits
  28. waterproof servos blasted by props
  29. Forward / Reverse Control Needed For Electric Motor
  30. Dumas Big Swamp Buggy
  31. Aquacraft AirForce Airboat
  32. North Florida Rc Airboater's
  33. Planning an Electric Airboat Build from Scratch.
  34. wont turne left
  35. Burning up motors
  36. Cajun Commanders at the local pond
  37. A couple of new Cajun Commander Airboats tested today
  38. Aquacraft commander goes hunting!
  39. Cajun commander rids the scum!
  40. Homemade Foam Airboat
  41. CXN Mini Airboat
  42. HK Swamp Dawg
  43. Who's going to make one first?
  44. Driver/pilot figure
  45. S13 60 airboat
  46. Another newbie question ...
  47. Just finished building/testing one with a nitro gas engine
  48. Puddle jumper MK2 the build
  49. spray rails
  50. First Airboat Water Test.....
  51. .61 HP gold cup engine props
  52. Stupid Air Rudder Question
  53. 1.5mm carbon fibre rod
  54. Two total newbie questions
  55. finish my first airboat "Puddle Jumper"
  56. aquacraft cajun commander cutting the weeds!
  57. fuel probs
  58. Skimmer 400 Plans Request
  59. Dumas Windy Or Similar Plans
  60. Fiberglass advice please
  61. Anyone else getting a pic error
  62. antenna questions.
  63. Help designing/scratch building small airboat
  64. 50cc airboat?????
  65. Selph Inflicted Tapered Flat Bottom Plans Availability
  66. Prop and hull size recommendation
  67. Hardware advice for total novice
  68. .40 Size Airboat Build : With Questions....
  69. Glue For Laminating Plywood
  70. Airboat Engine Question
  71. Cajun Gator Airboat Plans Wanted
  72. Unique Airboat Design Advice Needed
  73. Reverse ?
  74. custom scale / micro rc airboats
  75. Need help with dimensions for OS .25 glow engine
  76. surf airboat
  77. Making an online calcularor for Airboat!! (thrust, speed motor & prop calculator)
  78. Need help with a new 30 inch cat?
  79. Help getting the right brushless motor and prop
  80. Dumas Swamp Buggy vs Windy Air Boat
  81. Customized setup for airboat hull (electric)
  82. I need a customized airboat plans for sell, Can someone please help?
  83. TAIYO EDGE R/C Hovercraft
  84. Make Your Own Fast RC Airboat
  85. Sears Lobo: standad 27 mhz tx or special?
  86. Duma Windy Airboat Need Suggestions
  87. EDF Boat HELP Needed
  88. 9th RC airboat build - Selph Inflicted .40 series Tapered Flat Bottom
  89. CXN - Airboat Pod ....convert your boogie board into an airboat.
  90. Tupolev A-3 Aerosledge
  91. propulsive airboat
  92. 29.5cc tractif airboat
  93. help please unknown airboat
  94. Air boat in reverse?
  95. Neverwet hydrophobic spray on rc boat hull
  96. Jett 56lx hull swap
  97. Airboay hull idea
  98. .15 RC airboat build
  99. ID me, Dumas large but single rudder?
  100. Hull size for a .15
  101. Dimension Questions
  102. How big of an airboat can I build with an Axi 4130 or Axi 4120?
  103. Air Boat for .40 nitro motor?
  104. Nfmaba race
  105. Rcaw
  106. my airboat is pushing water
  107. small air boat 20X8
  108. small air boat 20X8
  109. air boat on hard snow = no brakes = crash!
  110. I just got this Vintage RC boat!
  111. I just got this Vintage RC boat!
  112. Aeroflyte Platypus
  113. Large Scale Airboat
  114. Build 8 - Wood over foam (my first ever) twin engine flatty
  115. What is it??? please help
  116. Rc airboat prop cage
  117. Swamp Dawg in soft snow
  118. Cox twin engine airboat imformation?
  119. Build 7 - R/C Hovercraft
  120. Air Boat on snow?
  121. On Board Cam video
  122. F1 Tunnel hull as an airboat?
  123. Cobra plans underway
  124. new to airboats got a question about motor and prop
  125. Swamp Dawg air boat comminf?
  126. Boogie board
  127. Rcaw?
  128. Car wax on carpet big help!
  129. Gas airboat project
  130. air boat prop question
  131. A/C engined hydroplane
  132. mini aligator tour on 3s lipo?
  133. 21cc echo flatbottom build
  134. a few engine/pusher set up questions
  135. Airboat using seaplane floats
  136. Suggestions & Comments on 1st build
  137. Length from Stern?
  138. Airboat Outrigger build (foam core)
  139. Black Widow 2.0
  140. Carbon 'Selph Inflicted' SI3-60
  141. Does anyone know what this is?
  142. 45cc homelite step hull
  143. Rescue Barge
  144. Sam's Flatty
  145. Water-foil rudder....Thoughts please!
  146. Calling all experienced outrigger builders, need advice.....lots of advice!
  147. Engine thrust
  148. First Build Coro-airboat
  149. epoxy resin advice
  150. new aluminum gasser build
  151. First run with GoPro onboard.
  152. need gyro smarts.
  153. Dumas Li'l Swamp Buggy Build Progress
  154. Polish AirBoat
  155. In-Line Twin projects
  156. Saying hello
  157. darn cats
  158. HELP: What airboat dimensions with this setup?...
  159. Convert Shockwave 26 (Proboat) to aitr boat
  160. prop cage materials
  161. How much engine do I need?
  162. swollen battery
  163. Boogie board airboat lake run
  164. SI 1/4 scale 3 pt hydro electric conversion.
  165. Its been a while
  166. Tempest
  167. airboat with 3w70
  168. Had a get together in Minnesota. VIDS
  169. BSB plans
  170. BSB
  171. Refirb
  172. Cheap bubble-free glow fuel tanks
  173. Bought a project airboat!
  174. Aquacraft mini alligator tours brushless
  175. Grim Racer Lipo
  176. Prop hub for cy clone engine
  177. BSB questions
  178. fast air boat plans
  179. Best clear for the bottom of a BSB
  180. thinking about selling :=(
  181. puller prop angle
  182. depron foam repair
  183. airboat surface drifter videos posted
  184. Ice Boat or Sled
  185. Scratchbuilt Airboat on ice (video)
  186. photo in post help
  187. Different Type of Scale Airboat
  188. Plastic vs wood
  189. Tempest airboat
  190. new flatbottom
  191. Cable
  192. rc airboat construction
  193. rc airboat with cox0.049.
  194. lets try this again foam build help
  195. areo surface drifter
  196. Propeller for a new airboat, question
  197. Nodd's Airboat
  198. Canard configuration airboat CG ?
  199. Beginner Airboat for My Wife
  200. GoPro on board.
  201. Brushless ESC for an Air-Boat
  202. "S-I" Goose Chaser
  203. Miss-Take, air drivern hydroplane
  204. Would You Say This is an Air or Ice Boat?
  205. Anyone know what this is? Ice boat?
  206. Latest Model
  207. First Airboat
  208. First Airboat
  209. scratch built airboat
  210. 7.5 cc MVVS engine
  211. Where are the scale airboat's
  212. Build 6: SI3 Hydro .60/.90 size
  213. Newer 26cc homelite?
  214. Night EDF Air Boat
  215. super tigre 27re alligator tours tuning
  216. Kyosho Tom's River Airboat
  217. what size prop should i use
  218. Triceptor 1 Engine Upgrade
  219. How to mount homelite 26cc mightylite
  220. Electric power system for Lil Swamp buggy
  221. Old Cox Black Widow Engine Not Running
  222. Finally Time for PLAY
  223. Electric airboat for sale
  224. Chasing the Silver Bullet. 60 series SI.
  225. What kind of motor?
  226. 27cc cy, or 42 homelite??
  227. 42 cc homelite
  228. My first boat pics
  229. posting pics help
  230. New boogie board air boat problems
  231. New Build...Need Help
  232. K&S airboat
  233. Foam catamaran airboat?
  234. Boat gluing ?
  235. Boat gluing ?
  236. qestion
  237. weedeater question
  238. airboat adjustment for straight running
  239. Scratch built Air boat with OS .61 fx
  240. help on identifing my engine.
  241. Which electronics do you need for an electric airboat?
  242. Solar Airboatee needs help!
  243. Custom Painting
  244. Information on scratch building
  245. Kamacopy rides again
  246. Boogie Board Airboat with Zenoah 260PUM
  247. NEED MOTOR FOR 22" SCALE BUILD
  248. Alloy Gasser Engine Mount!
  249. First electric airboat build...suggestions?
  250. I have some Electric Swamp Buggy Questions.
