- clutch shoe question
- new bodies for my savage.
- To buy new or used?
- MAX TEMP
- Pros/Cons
- LRP glow plug equivalent???
- f4.6 carb removal
- X vs Pre X transmissions
- Savage XSS questions
- Re-gluing Dirt Bonz
- LRP.30 Pipe Application
- clutch shoes/bell question
- tire/rim options
- Starting up your savage in decent weather
- front pinion
- I MISS MY BABY!!!!!!!!! After 2 days
- question for the engine guys?
- problem, but i got it solved and wanted to share
- Picco Pain
- My Savage X SS
- New LHS Store opening up down the street!
- FLM bulkheads not compatible with XL
- My Savage XL *Grrr I hate the 5.9 - edit
- Am I crazy?
- savage xl?
- Running Savage without shock oil in rear left
- Flux ESC, how hot is hot?
- Always lock your car
- Flux owners-leaky shocks?
- 5.9 busted piston
- Is this buy worth it???
- XL Terra Pin Tires on X SS
- clutch
- quick question
- How should I run my diff oils?
- 2 years no run = solutions
- Savage Tuning Help
- Does the Piston.....
- Has anyone tried these?
- My new Xss slammed grave robber racer!!!
- Savage XL?!?!?!?!
- Can't figure it out. 5.9 problems....
- savage plug problem
- What would a bad header gasket cause?
- resurrecting Savage to modern warfare X
- ques. on before starting savage thread
- Plug Selection - Trinity Monster 25% / 5.9 Engine
- HPI safety engine stop??
- Help, SAVAGE ss spur gear compatable with SAVAGE X series?
- Backplate?
- Missing drive-shaft mystery?
- Savage X SS Upgrades
- anyone know for sure?...STS pull start/roto one way setup........
- taller 3rd gear
- Reciever/Transmitter NEWB Question
- GooD Engine???
- TURBOO (6)
- Clutch shoe question and a close call....
- Throttle looses Signal
- Buying XL maybe?
- Savage x parts on Savage 25?
- i gotta problem
- cannot break in savage x
- put sts in sav x and not working
- Clobbered My Friend (Funny Story)
- New LRP .30 pull start engine
- reverse problem
- Looks like i picked up another savage!
- stock exhaust
- Long or Short?
- Badass onboard video
- savage xl problems
- what do i need to use 17mm rims on a savage 21
- Camber setting for the X SS
- this a god engine to replace the savage 25?
- STS one way bearing!!....specific to STS?....I messed up
- How i fixed my drive cup
- X SS to XL Conversion
- better when cold
- found craigslist HPI savage 25 for $125. Engine might be shot
- Parting ways with my modded Savage XL
- New body for my Savage XL
- Running only hot.
- One way keeps wetting...Sidewinder fuel garbage????
- Brakes not returning
- fastlane chassis install question.
- My new buggy with the S-.25 in it
- Nitro shelf life
- I think I pulled a no-no
- carb inserts?
- Burning out glow plugs
- .25 center drive cups wearing....
- Adjustable Upper Arms
- Springs and oil for jumping?
- Dog bones falling out of cups?
- LRP30 fitment issues
- Tune by ear and idle problem.
- Stock Savage XL... What first?!
- Any video comparison of pipes?
- New Savage owner here...
- Best Tires To Bash
- Is this the original???
- Polished HPI tuned pipe
- Integy, Golden Horizons or RD Logics
- best pipe for LRP
- Most Suitable Engine
- WELL.... I RUINED MY CUDA BODY ALREADY! LOL
- F4.6 and 3 Speed Gearing Question
- Oops!!
- Nitro Deflector
- WoooooHooooo!!!!!!!!!!
- braking linkage won't ga back to neutral
- Got some video with the new clutch today
- busting steering servos
- LOW CG CHASSIS SHAFT PROBLEM
- What improvements would you like to see HPI make to the Flux?
- Question about LRP .28 in an XL
- Finally got to run my XL!!!!!!
- Spark plug problem?
- Question on XL engine
- My Savage 25 Bash Video
- K4.6 Lean after full throttle
- THE HEADER I GUESS ?
- picco ???
- Tire size, shift problem?
- Savage Off Road R/C Racing Video's
- You don't need the Castle Link software for Flux ESC.........
- hpi savage flux
- Savage Idle Question
- The RC Gods are angry with me....
- Got my new clutch in!!!
- torque problem help me please
- lrp 30
- savage x ss
- XL brushless conversion
- FLM SAVAGE question.
- shattered gears
- Tested the flux today...
- Savage XL Run Times?
- which tires?
- 17 tooth clutch bell
- Savage X SS Brakes
- Racers edge .32 engine
- Savage transport
- Odonnell wax lubricant substitute?
- Digital servos for X SS on Futaba 3PM Fasst recommendations
- What do you think
- Newbe to the world of savage.
- 3rd gear upgrade?
- glow plug recommendations
- screw size?
- Somewhat disappointed in the LST2 shocks...
- Used O86
- picco, lrp or what
- WARNING: DO NOT ORDER FROM EBAY SELLER "BIG HEAD HOBBIES"
- Savage Flux : Center Skid Plate
- ??? Savage XL, paddle tire question ???
- Engine stuffed?
- PARTS
- Posi Diffs
- stronger gears for flux?
- RC Buggies and Truggies
- SAVAGE WITH A REVO SPUR GEAR ?
- Bent Another Shock Today
- Hobao Mach 28
- Savage extended lower chassis
- fastest savage around?
- wierd back fire on savage???? please help
- Savage Mods
- Getting into racing
- few questions about a savage
- E-Savage w/Mamba Monster 2200kv combo!!
- SAVAGE 4.6 OR REVO 3.3 ????
- thinking about buying savage
- Some new tools for me !!!
- Engine help for a n00b!
- automotive grease?
- Savage Radio Box Management
- Just Ordered a Bunch of Stuff
- A Redneck fix..
- transmissions
- savage 25 engine swap
- Savage 25 SS Upgrade to X
- Want to hear an old Picco howl?
- If money is no object....
- customized custom plastic roll cage for savage XL
- Next Flux upgrade
- Savage Flux Action Pics...
- Can Flux become Truggy?
- Savage Flux questions
- schumacher raptor carb settings.
- Savage X project
- pipe for force 36
- Savage X SS Questions
- New guy here
- savage xl color?
- ace outlaw pipe
- 40 series bead-locs
- A couple Flux questions....
- Fuel Question
- Transmission Problem!
- savage k4.6 in a mbx5t ?
- Brand new Picco with no pinch?
- Cuda body in the sun -pics -
- Upgrades X 4.6 servos!!!
- LRP 30 possible Group Buy
- Tranny ?
- what spur gear
- Savage XSS with 1/5 Body???
- Hight Speed Wabble
- Anyone use beadlock wheels?
- Havent seen third gear yet?
- Any plans on new Savages or equivalent coming out?
- Savage Forums are not responding...
- Is it OK to run a 30% in a Savage XL
- If you love muscle cars.... check THIS out ;)
- savage xl engine not getting hot
- Crappy video, need opinions
- 5.9 pull star conversion
- ***Whats it worth***
- Keep blowing out Slipper Clutch pads on FLUX
- best glow plug for picco 28
- Sway bar for savage xl
- Hop Ups on the Savage XL
- My twin tank mount
- pull start broke
- Savage Flux - Huge Double Back Flip Jumps
- Forum site changes coming?
- My first bashing jumps video..
- tranny lock
- First Finally got her runnin.....then the police came.
- Steel Spur gears
- how to break in picco
- LRP z.28 questions
- HELP EMERGENCY !!!!!!!!!!!!!!!!!PLZZZZ
- setting auto-lipo help
- X OR XL?...So confused...
- steering servo replacement help
- which pipe
- what engine
- Carb wont tighten
- Tranny Question
- Its been a while
- Rant - Sorry :/
- clutch bell
- losi nitrotane
- Any body ever run this in a Savage?
- Savage Flux tranny blows
- turbo head ?
- Ahh... Birds chirping, sun shining... It's almost that time.
