- os 30vg and k5.9
- Does HPI make their own engines?
- Setting help?
- Diff cup replacement?...differences....explain please
- .25 tower hobbies motor for savage x?
- Cycling New LRP
- DIFF Play?....video inside.....
- Aluminium upright and c-hub -=which is the best=-
- Savage X F4.1 RX Antena Length
- BRAKES?...link to know how please.
- EFRA RB Concept 2086P
- Finished Savage X
- Stop Go Stop Go
- factory setting of 2 gear and 3 gear ?
- Using Blue Thunder Fuel
- convince me!!!!!
- Finally - 3 speed shifting correctly!!!!!
- STS 30 or Picco .28
- thinking about going brushless....
- Pipe Dent
- which one?
- great truck
- savage shift?
- Savage Glow Plug and Clutch Question
- Savage rebuild - Picco questions.
- Heat Cycling LRP
- Servo Noise
- JR Xr3 Reciever
- 40 series tire and beadlock rim
- Engine with airleak
- Gyro's....
- Help with factory Low end settings on a XL
- Airtronics switch harness
- Spur Gear/Clutch
- Hump packs?
- Jr racing fx-3 Radio
- spektrum dx3s
- Thinking about going X4.6, few Q?
- Aluminum clutch shoes
- wheelie bars
- Pipe mount
- Savage 25 Comapare to X 4..6
- ss & xl trans the same?
- sts d30m
- Going brushless, battery help please. (MRC 977 help too)
- The wait is over
- stock xl servo or tower mg995?
- 086 on xl
- Another BudBud boring video...
- Snow Monater Jam, pic and vid
- XL 5.9 GT
- SOOO.....What engine IS this?!?!?!?!?!?!?
- 086 header on a savage x?
- What can i use to re glue tires?
- cant fix pullstart
- I CANT FIGURE IT OUT!!!
- does it really matter??
- tear down questions
- My XL *build* and questions regarding it
- CB/SG problems
- pipe for the Picco P3
- Roll Bar..Handle?
- Diesel HPI
- Replacement Engine for Savage 25
- Monster Jumps
- wana get a truck
- Eating up glow plugs
- How to Replace throtle Servo
- Just installed my picco, comment please!
- ****CARB TUNING HELP PLEASE!!! GuRu's!! AssemBle!!!
- roto start ????
- charger advice
- How cold is too cold?
- SAVAGE X4.6 or SAVAGE X SS????
- Picco Vs. LRP
- radio?
- 4 stroke in a savage
- Shock Springs
- T-maxx 3.3 vs. Savage X, which is best, in your opinion?!
- nitro fuel
- My New Custom 2650Mah Hump Pack....
- help my savage has a mind of its own
- Fail Safe issues
- Is This Charger ok for my hump pack?.....
- Good Pipe for stock savage x 4.6
- vented clutch bell
- what do you prefer?
- Tires
- HOW TO USE TF 4 transmitter?...steering adjust help
- JP@ Pipe Won't Fit
- tmaxx or savage
- Servo upgrade?
- savage xl breakin
- diff oils?
- Shocking Problem
- convertin x to xl < budbud ;)>
- XL Differential
- planetary gears keep braking
- Shimming diffs
- Got my XL started!!
- Swap XL frame for 4.6X Frame
- XL tire recommendations?
- Read a ton of posts, still have a few questions about the Picco .28 in Savage XL
- Battery plug
- First Nitro, Help me decide :)
- savage flux..what battery/charger
- Savage xl servos
- no power rear differentials
- All in a day's fun...
- bashed and broke parts; which of these can I pull off an XL?
- what does this sound mean
- Bodies for XL
- Clutch bell and bearing problem
- Roll Bar and Motor Gaurds
- interchangeable parts
- Newbie needs direction
- Multi station Chargers?
- Integy tank gaurd
- The best suspension?
- hellfire???
- Removing 5.9 engine
- Shock Oil Weight
- Steering Servo Problems......*help please*
- gearing
- Savage Rebuild
- Motor Pipe Gearing - Am I In The Ball Park?
- glo-starter
- Paint job, look alike???
- recomendations
- Failsafes
- savage x 4.6 wont prime
- Savage SS
- pics of my trucK:D
- savage x spur gear
- Savage Youtubers
- XL pipe
- Hump Packs
- help needed converting my X 4.6 RTR brakes to the SS 4.6 Brakes
- anybody use this
- tyres
- savage x center skid plates
- To cold to run your truck outside???
- Savage 2WD now need help!!
- Hpi Svage Xl 3 & 1/2 gallons review
- k4.6 midrange needle
- radio
- how are mgt tires and rims for savage
- Using nitro to clean cooling head?
- THE hpi flux savage thread
- which model savage to buy?
- Engine Upgrade.....
- We hit the mag this month!
- Would this reciever/controler be good for my savage?
- Quieting down a motor
- please help
- dirt bonz tire
- Has My Motor Been MODDED??? (pictures)
- Stalling after rev
- Springs
- HPI MT2 .18OS
- nitro engines
- carbs
- What's your guys thought on the Buku pipe
- One way bearing help please!!
- hpi vs tmaxx
- 4.6 carburetor help
- Need some Info...
- revo or savage??
- Engine Break In
- HPI Flux
- New XL owner
- Is HPI MT2 18ss+ a good choice for a noob?
- Here it is. The first non-HPI Flux video
- Running In Snow and cold
- New used savage. What would you do?
- Savage XL parts interchangeablity?
- Battery Gurus!!! is this charger any good for...
- 4.6
- Will the SC8 body fit the XL?
- Bad XL Diff bearings!
- HPI Savage Flux RCU review thread
- e savage or e maxx?
- Savage x diff up grades.
- new to nitro need help
- Official Brushless Savage from HPI
- Savage X SS K4.6 Glow Plug / Tuning question
- can i add oil in the gear box ?
- Which way to run fuel line?
- Difference Between Savage X and SS
- Servo Saver question?
- TWIN ENGINE?.....on ebay....
- Rebuilt Savage X Or Purchase XL
- Savage x VS Tmaxx .25
- half tank lean!
- Savage XL review
- lookie here
- XL electronical Issues
- Brake shoe replacement for Savage 25.....
- HPI engine parts compatability question
- Which sav? hpi newb
- Savage XL Won't start
- tamiya f150
- Stingers?? WHAT ARE THEY
- Firing up the savage for the first time in a year!
- Rear Exhaust Vs. Side Exhaust
- Cheap MODS or lil improvments
- HPI Nitro RS4 MT2 right 4 brand newbie?
- Need some info onmach427 pullstart
- This was probably already asked before
- XL driveshafts
- 3 speed transmission settings question....
- ANybody know where to get the Low CG engine plate?
- Need help?? & (video)
- Savage x Tunning Problems= Help
- Which engine?
- hpi wheelie king
- The wait is over... modded 5.9 video
- HotBodies Pipes?
- Looking to get a Savage XL
- 3 speed tranny install
- E-Savage Help
- transmission
- duals
- Hellfire diffs in a Savage?
- Savage Xl build
- TVP's
- Quick retarted question
- just thought id share some pics
- Battery "issue?"
- Savage no more
- MSR8 shocks
- LOSI shock conversion help!
- Savage is the best
- Lookie what came in the mail today!
- Temp rises in grass/how did this happen?
- 427 in savage
- Nothing but problems?
- front right dog bone arm bent?
- Does the OFNA manifolds fit the Savage X?
- Good deal or rip off?
- ENGINE FROZEN WONT TURN
- X 4.6 Shifting Question
- VIDEO OF RUNNING TRUCKS
- savage x 4.6 break issue
- Maximizer Beadlock Broken
- Carb closes all the when when i hit brakes?
- Anyone have any experience with these gears?
- A Few Savage X Questions From New Owner... Where Can I Get A Rear Exhaust From? Etc.
- HPI Savage Flux HP Thread
- How to wash/oil air filter
