PDA
View Full Version : HPI Monster Truck Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. lean or rich on 16% fuel?
  2. Stock x ss gearing?
  3. Check it out
  4. Who's running CEN GST shocks?
  5. BACK PLATE ROTO START AND brake/gazLINKAGE ISSUE NEED HELP
  6. Order
  7. LRP owners step up! Pipe shopping....
  8. savage xss shock upgrade
  9. k4,6 gearing help
  10. How long has the XL been coming?
  11. How can you tell when fuel is bad?
  12. Savage X vs Savage X 4.6
  13. Savage X Roto-start question
  14. NEW SAVAGE XL
  15. traxxas tmaxx vs savage xl
  16. Roto start conversion 4.6 to lrp z28.r
  17. tmaxx body/ savage body
  18. linkage mod
  19. What is the best steering setup?
  20. Diff question.
  21. Is it still strong enough or do I need new plates?
  22. Whats this?
  23. Hey New Rubber!!!!
  24. XL width versus the Savage clan
  25. Wow, I want these brakes!
  26. do you have a really nice savage?? LED LIGHTING GUY
  27. failsafe yes or no
  28. Ever feel like a dummy?
  29. Axial .32 front bearing leak.
  30. Help finding part number for LRP pullstart.
  31. HALF tank lean issue AND CARB TUNNING
  32. Axial used motor tunning problem
  33. Not STARTing
  34. Nova Axle extensions
  35. ripped foam????
  36. axial28 pull start question??
  37. Savage X 4.6 RTR
  38. fuel for firestorm
  39. SAVAGE X MUD BOG!!!
  40. Savage X or XL
  41. First savage body!
  42. Blacked out savage?
  43. NEED HELP ON SPUR GEAR
  44. How to ruin a savage
  45. if you have a 3 speed manual somewhere...
  46. RCDriver XL review
  47. wing mount
  48. HELP!!! What Savage did i buy? UPDATE !!!!
  49. 3 speed pains
  50. gearing
  51. SavageX vs SavageXL
  52. The Ultimate Savage??!!
  53. What the...?
  54. Range bags? What do you guys stock?
  55. 4.6 savage x
  56. Lowerd And Strengthend savvi
  57. Savage X axial .32
  58. ok here's the deal
  59. Attaching brake pads..
  60. Funny! T-Maxx jump
  61. 3 speed
  62. Happy Fathers day
  63. A Traxxas Revo 3.3 or a Savage XL???
  64. What starter for the savage?
  65. Getting a savage 4.6
  66. Starting
  67. For the guys that use the heat cycle method..
  68. stripped set screw
  69. Killing glow plugs by stopping engine with exhaust.....
  70. HPI Savage X engine troubles
  71. Protection
  72. 3 Speed factory settings
  73. SAVE YOUR FINGERS!!!
  74. Tire Foams
  75. HPI Rant
  76. Savage x beating
  77. Upgrades
  78. Tire glue
  79. neon green its bright.
  80. Fuel tank guard? Are they worth it?
  81. Waterproofing a servo
  82. AArrrrhhhhhhh!! This is not going to work!
  83. shredded 2nd gear
  84. fuel line setup
  85. Sand tyres
  86. Failsafe
  87. Wheely King Upgrade Motor
  88. Power Loss???????
  89. clutch shoes
  90. savage 4.6
  91. Savage 25, Savage 21, Savage X
  92. XL vs 4.6 dogbones
  93. Post pics of your busted/bent cooling heads
  94. Low speed bog
  95. lcg and extended lcg tvp's
  96. portable air compressor?
  97. Brake problem on savage
  98. Axial .32?
  99. Savage shock ends?
  100. x4.6 and xL jumping
  101. aluminum vs plastic!!!!
  102. Problem
  103. HPI Savage question
  104. man i hate radio gear!
  105. takes off slow
  106. brakes stick at idle
  107. THS CVDS a good solution to a costly problem?
  108. Loose stearing
  109. savage x wont move
  110. Possible carb damage? (picture)
  111. Nitro Rush Evo problem
  112. exhaust deflector
  113. A Little Side Project
  114. Stock savage servo question
  115. Savage Dual Steering Servo mod
  116. axial bearings
  117. pullstart k5.9
  118. savvy x 4.6 problem with "rebuild"
  119. Matrix
  120. Robinson Racing Spur and clutch bell problem.
  121. savage 3 speed shift problem
  122. LST2 shock oil
  123. engine mount brace.
  124. ring and pinion gear
  125. New problem to me
  126. Savage steering mod
  127. pipe ?
  128. couple of questions about wheely king?
  129. savage xl question
  130. Savage X Spur not compatable with X 4.6??
  131. can X 4.6 fix on t.zilla wheel?
  132. breaks don't work properly
  133. Tampa Bashers
  134. spur gear/ slipper clutch upgrade for savage x
  135. truck move slowly
  136. P3+086+worn asphalt tires on grass
  137. Battery Pack
  138. the right kind of sealent?
  139. What to get???
  140. Is the XL tuned pipe bigger than the X SS pipe?
  141. reverse module
  142. E-savage/zilla nitro conversion?
  143. cigarette plug?
  144. Full Tank Flooding
  145. savage XL or MGT 8.0
  146. x4.6 vs xL (Video Up)
  147. OFNA Force .26 engine doesn't fit Savage??
  148. Kudos to Fast Lane Machine
  149. roto start back plate
  150. K4.1 Engine Probs
  151. buku pipe
  152. ****Rc solutions cage Question****
  153. Rc solutions cage Question
  154. where is a good place to get 40-series and 23 mm
  155. Picco .26 outlaw
  156. Shock oils...
  157. Keep breaking dogbones...
  158. I am absolutely cursed
  159. Bashing Tires
  160. snapping cranks
  161. O.S. .18 CV-R in a Savage?
  162. 1/8 pipes?
  163. De-anodizing HeatSink ?
  164. Servo no good?
  165. HPI Nitro MT2 G3.0 RTR upgrades
  166. Savage extended chassis?
  167. Warehead Evo Nitro truck
  168. Greatest Vid Ever!!
  169. GEN 2 Byron RACE fuel
  170. I have seen the light! Now a few questions
  171. I Broke The Savage XL !!!!!
  172. Shocks
  173. Stock/Default position of adjustment screw in 2-speed
  174. HPI - Hellfire - What wt. Centre Diff Fluid?
  175. Grenaded pinion and ring gear
  176. how to make my truck do wheelies. savage ss 4.6
  177. Need some Help with the Carb
  178. Half tank lean
  179. Savage X body mounts
  180. firestorm wont start
  181. savvy 2 speed
  182. wont start
  183. Recomended Savage X 4.1 upgrades
  184. Savage XL Terra Pins do fit on Savage 25
  185. Rookie SavageX basher.
  186. Engine starts backwards
  187. savage xl bug?
  188. What's wrong with my OS 30VG?
  189. Wheels for a Savage, that fit Jumbo Kongs
  190. XL =) Oh yea Sweet
  191. Grub screws keep falling out?
  192. Clutch bell screw keeps backing out
  193. The STS 30,and head shims
  194. Head shims in LRP
  195. Savage mount screws?
  196. 086 Pipe?
  197. F4.6 acting weired, help.
  198. What 17mm do i need?
  199. Wheelies Video (As I said I would Budbud) One more added
  200. Fuel Heating?
  201. Another video, at our new location!
  202. A quick fuel question
  203. HPI Website issue?
  204. Monster Truck Racing
  205. my first bash and landing tips !
  206. Savage 5.9 or GST 7.7?
  207. HPI ribbed pipe
  208. savage xl stalling when brakes applied
  209. Dual slipper good?
  210. exhaust manifolds
  211. Is this everything i need
  212. digital servos
  213. Front brearing for hpi 4.1
  214. Lost rear wheel drive?
  215. 3 speed problems
  216. To grease or not To grease?
  217. a few action shots and post carnage
  218. Look at this!
  219. Well this won't do at all!
  220. Nitro Wheelie King!
  221. LRP Trouble
  222. engine dies when taking off
  223. sh one way help
  224. NEW XL OWNERS ENTER ????'SSSS
  225. some pics of the trucks
  226. Engine mount screws
  227. Clutch bell screw
  228. Hey does anybody know the new web address for STSmicroengines.com
  229. axial .28 pooped itself.....
  230. Oh MAN!!!
  231. savage torque
  232. Heads up for people with aluminum servo saver
  233. stripping screws into plastic
  234. The Savvys
  235. First race tonight!!!!! Batesville Indiana!!!!!
  236. supercharger
  237. 25 to x
  238. Melting your spur gear.
  239. CINCINNATI BASH! Speak up here
  240. 3 Speed for the X
  241. Savage Exhaust with LRP Z.28R Spec 3
  242. Wow what a pain ( Clutch Shoes / Springs )
  243. Rebuild Savage 25
  244. Is anyone running a Fioroni sliding clutch?
  245. Tires for the Savage... ofcourse :D
  246. diff oil
  247. Break in Future Problems..
  248. best savage clutch
  249. FLM rear bulk/diff case
  250. rotostart 2 battery....
