- STOKES PIT tomorrow at noon????
- Spur gear.....
- Reverse?
- Will it be safe to run it in the snow?
- fuel tank cap
- reverse module shift linkage problems
- REVOvs.SAVAGE
- new high speed 3rd gear
- FLM hybrid diff cases.
- Mach 26 worth putting in my savage???
- Look at the name ebay gave for the savage
- whats body works for an extended tvp savage?
- not good
- How do you like your Savage 4.6 RTR?
- Little confused about LSN tuning....
- savage ss 4.6 with axial.32
- So
- Tuning help
- Thinking about the truckzilla, any one have any advice?
- Difference between Savage and Hellfire diffs?
- Joyce Park Hamilton, Ohio 2 awesome tracks+airfield
- Unofficial Savage XL thread
- BUKU POWER EXHAUST
- SavegeX4.6 Toe??????
- what mods have u done so far on ur trucks
- Mid tank Mod link
- Too rich???
- savage radio/receiver replacement
- My newly built savage
- Will Tsais muffler be in the way?
- ANY one want to go to srokes pit on saturday
- Ok, who has the new Savage!?
- Tsais header and Dynamite 053 muffler
- engine brace
- Fuel Tank Guard...
- Savage shocks..
- BRAKES
- How much would it cost to get a Savage running?
- Discussion of tuning parts
- RC Packs Battery Pack Question
- Is this normal...
- hpi savage x
- Ofna .28 Hyper Mach or .28 Picco
- What do you run in your diffs?
- LRP vs. F4.6
- 40 series mulcher
- LRP break-in question
- need new servos!!!!
- Xss for $175?
- Savage X vs GST 7.7
- Servo Questions
- Lincolnton North Carolina anyone???
- virginia.......anyone?
- First Start up.....
- Savage RTR REVERSE is out !
- Savage SS Back wheels and a few questions
- What engine should i pick?
- more questions??
- my savage is making a wierd noise
- Need help with savage slipper clutch!!!!!
- RTR or Kit
- new to white rock wanna bash?????
- Help with a few issues
- Savage shifting???
- Stupid idea? but i am bored.
- Glow plugs
- will reverse impede speed
- Drivetrain upgrades
- What happened to the "help a buddy out" post?
- 1st videos
- Best Brakes
- Long day, finally running
- Is the Savage BIG?
- Savage X 4.6 Starting Trouble(help)
- Bash day wreckage in NW Ohio
- One Way Bearing fix (F4.6)
- anyone in battlecreek mi thats has monster truck
- ANY ONE IN WHITE ROCK WANNA BASH TOGETHER???
- What Maintenance?
- gearing
- Axial 32 tuning
- Which one to choose
- O'Donnell 100 Glow plugs?
- How much for a savage 21?
- savage throttle linkage
- Savage Gearing
- High ENd Needle floppin around
- savmaxx lol t-maxx mixed with savage
- Savage Plans
- short little vid.
- Clicking sound when braking?
- How much of an improvement from the K4.6 to LRP Z28 Spec 3?
- a new heart for the monster!!
- Rpm A-arms
- savage runnin bad!!!!!!!!!!!!
- how to get clutch off?
- WHO'S BUYING A SAVAGE XL 5.9
- Alloy Vs Plastic
- Shock spacers
- LRP truggy vers. to Roto/Pullstart.
- Receiver battery switch
- savage diffs
- Project: FLM Savage
- A Day bashing at the local BMX track.
- Best pipe for top speed?
- savage fuel switch
- mugen mid tank question
- how do i remove the front arms off my savage?
- savage question
- Going to Build a TRACK!!!!!!!!
- which is stronger - super glue or Araldite Epoxy
- Integy Chassis Support Brace
- Best Bearings
- Guard for underneath savage...
- Slipper clutch slipping?
- How much maintenance do you do?
- Savages with JP pipes chime in
- tires
- savage antenna
- shock oil???
- hi-speed gears
- Savage CVD's
- servo plate swap
- New Era Wing Difference?
- what is better
- going to glamis...
- savage clutch
- carbon bending
- Help With Shock Setup
- savage x 4.6 fuel and slipper Q's....
- Hot Bodies Pipe vs. HPI Polished Pipe
- recommend this ???
- 4.6 midrange needle o rings
- Savage engine disasembly
- Atomic R/C parts
- savage gearing
- clutch slipping? and temp?
- Thanks Government
- Ford F-100 body
- No Wheelies and no shifting
- savage 4.6 questions.....
- Can't keep either of my savages running
- HPI Firestorm Aluminum Threaded Shock Set
- ive got problems
- Spur gear
- Lost performance? A little HEADS UP!!
- is it lean or rich?
- Maiden flight
- $865.99 for a SAVAGE XL 5.9!... NO THANKS!
- SAVAGE XL 5.9 PICS AND INFO FROM HPI EUROPE
- Who has a 3-speed?
- feels good
- vids of your savages
- Is it safe?
- shocks
- market for new savage
- savage x 4.6 Center slipper...
- NEW LRP Spec 3!
- Bronze rust inside engine already?K4.6 roto start backplate dont fit?Pics
- roto start mach 427????
- fastlane or new era chassis
- savage k 5.9
- broke an upper and lower arm..time to upgrade.
- Opening up the K4.6
- Twin exhaust? - This any good?
- Savage 4.6 of Associated MGT 4.60?
- axial .32
- LST 2 shock adjustments. Weight.. springs etc etc
- Traxxas Revo 3.3 v HPI Savage 4.6 ?
- Steering throw
- OUCH!!!
- Product Warning
- Forums?
- Pics of your savages 2 read first
- Good 17mm hex kit
- New Savage "XL" K5.9 Pics...
- My pimped out savage
- ANOTHER BLOODY PROBLEM WITH MY SAVAGE!!!
- Savy lowering?????
- pull start/electric start
- Roll Bar
- Dual Engines?
- newbie trying to fine tune.....help
- Pull starter won't budge
- Can I drill out/modify the carb slide??
- Your advice and opinion please
- spur gear ?
- anybody own a O.S. 30 VG P
- Engine Guard
- Savage X 4.6
- Bodies
- best pipe?
- New Savage Build Process
- What Shocks Are Better, LST2 Or Losi Aftershock
- one way bearing maintenance question.
- MBX5T Hex Wheel Hubs Inquiry
- New motor
- Battery Charger - which one???
- Brought my 2nd Savage x 4.6
- shock oils
- 0LD SAVAGE .21 and .25 VIDS
- 053 pipe suggestion
- sts.30
- acting weird ?
- New alloy shoes eaten in one sitting!
- savage carnage pic
- Savage X "optional charging jack"
- Clutch Bell
- Best upgrades for a Savage 25
- Hobbico Quick Field DC Charger MkII 12 Volt
- Rubber piece for X radio box
- Best?
- Shock Springs
- Sluggish off the line
- Can it be too cold to start the engine?
- My 1st savage x upgrades
- Shock, spring spacers??
- Cordless drill instead of RotoStart??
- Where can i find this servo...?
- Which engine is next to try???
- Glow Plugs
- LST SHOCKS ON A SAVAGE X
- Drifting is fun!
- FUELS
- Beadlocks
- Slipper Clutch
- Need help with Savage 4.6 dogbones!!!!
- 19 turn wheely king
- 4.6 Glow Plug life
- Glow Ignitor?
- whats the best set up
- Lcg tvps
- savage tuned pipe
- Drivetrain
- cold starts
- new servo plate
- 053 pipe
- Wings for savage x 4.6
- OS a3 or os 8 plug?
- how far will your savage go????
- Well these work
- Exhaust tubes? Proper Name? Where to get them?
- rollcage opions?
- Drive shafts????
- SaVaGe HeLp
- Starting an engine for the first time
- building a monster ideas please
- How long can fuel stay in the tank?
- Where to find 4.6 Rotostart assembly?
- Antenna Wire length
