PDA
View Full Version : HPI Monster Truck Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. I want my savage x4.6 body shell higher
  2. Oil/Fuel leak below clutch bell
  3. New Parts- Carb
  4. After all these year's I understand why! update
  5. Axial Beadlocks
  6. looking for a video
  7. nova cooling head
  8. battery questions
  9. Pullstarter and one way bearing concerns..
  10. tired of t-maxx,going savage
  11. Carb? Question
  12. ???savage x upgrades???
  13. Exhaust do-hikey?
  14. Brand new to the scene w/ a Savage 21 on the way off Ebay
  15. Carb question?
  16. radio control
  17. which servos are you using for the savage?
  18. Axial .28 or .32
  19. Slipper Clutch Confusion
  20. 2-in-1 Pull and shaft start backplate for K 4.6
  21. 13ft+ Upside down landing, oops!
  22. New Savage owner
  23. not sure. does savage x 4.6 come with fail safe
  24. Finnaly got my savage x 4.6 today wooo hoooo
  25. savage and the LRP Z28 Spec 3
  26. Helping stabilty
  27. time for a new body
  28. Picco .27- anyone still or used to have one?
  29. HPI 1/8 Savage X 4.6 RTR Nitro QUESTIONS
  30. OFNA FORCE .28 for savage
  31. help!!!
  32. My new Savage, (ebay swipe)
  33. second gear
  34. Clutch question
  35. Putting the exhaust cone in a savage X.
  36. Roto Start in Axial .28 spec1
  37. help reverse gearbox
  38. Where is Frost and 46u.. and that dude who made wooden TVPs?
  39. ugh... noob in distress :D
  40. Tune up and antenna routing
  41. Few Questions
  42. Home remedies/easy fixes
  43. Axial pullstart problem
  44. FUEL
  45. Savage X SS
  46. Differences between Savage and SavageX/SS
  47. what engine should i get?
  48. F4.6 Help.
  49. Tuning project and i need ur help
  50. converting a savage
  51. My servo setup.
  52. Should i get get an os moter?
  53. What would be a good first upgrade for the X?
  54. 5T
  55. Savage twin exhaust pipe!
  56. Aluminum gearbox and difs
  57. reverse gear slipping any help plz
  58. Venom Smart Temp/Fail Safe in Savage X?
  59. Question about dogbone damage.
  60. rcnitronation.com and their RB modded Axial engines
  61. New pipe for my axial .28 RR
  62. best airfilter for my x
  63. snorkel for my x?
  64. My Break in Nightmare
  65. Half tank lean?
  66. OFNA clutch bell shim kit
  67. Exhaust loose in exchaust coupling?
  68. savage roller chasis
  69. fuel line
  70. Reverse Module Install
  71. HELP! - I forgot to switch off my receiver for several hours!
  72. Break in Problem
  73. K4.6 problem
  74. Savage Worthy?
  75. question on steering on Savage X...
  76. Faster Savage
  77. Stripped and glued wheel nuts.
  78. CRASHed BIG
  79. Savage X SS clutch shoes?
  80. Axial .28 Temp issue......
  81. How to fix stripped screws
  82. my hpi savvage what you think ?
  83. How To Remove Silicon Diff Oil?
  84. gear probs after eng upgrade
  85. Is a HOLE in the body necessary?
  86. Which savage has the 4.6 motor???
  87. STS 28 questions
  88. X brakes help
  89. stuck in first
  90. Savage 25 / Savage X SS ??????
  91. How many hours?
  92. Genral lee body
  93. help drive problems!!!
  94. sts engines
  95. electronics puzzle
  96. wheely king shock shaft
  97. ok Breakin Complete....
  98. removing tire from rim ?
  99. Building a Savage help please...
  100. first nitro rc
  101. What could be wrong?(throttle)
  102. I need savage 3 speed instructions!! HELP!
  103. Which Spread Spectrum Brand is Recommended for Savage?
  104. Baja 5B electronics on the Savage
  105. Savage X SS Stance!
  106. axial backplate
  107. trouble with sts 28 engine
  108. Savage Suspension Upgrade
  109. high pinch = not completely break in?
  110. Savage X SS, glow plug?
  111. what fuel
  112. help with savage 21
  113. 1 thing leads 2 another
  114. Savage spur?
  115. IS PREHEATING THE ENGINE BAD?
  116. And who says a Savage cannot be a racer???
  117. I'm pissed off
  118. soft landings
  119. SH Engine mount problem
  120. Axial .28RR opens up this weekend
  121. wat can i use?
  122. LSN Problem
  123. Good news to all you Savage fans!
  124. Sand-Proofed Savage
  125. how do you transport ya rig?
  126. 4.6 into sav 25 any mods needed?
  127. savage in pond
  128. need some new tires
  129. sts help?
  130. S-25 front diff blown *question*
  131. Savage
  132. question
  133. Shopping List
  134. does any body know if the savage x forsale at ultimate hobbies........
  135. savage clutch removal
  136. Straight shocks VS Piggy back shocks
  137. cleaning up
  138. USED SAVAGE WOES
  139. Savage X ss components different from RTR???
  140. what does rtr mean-please type
  141. what is a good price
  142. i need advice
  143. what is better? savage x or savage xss
  144. Got a new motor from HPI. Broken crank!!!
  145. What radio options do I have?
  146. hey guys
  147. 3 speed or 2 speed transmission
  148. new engine
  149. Savage X 4.6 Pipes
  150. What to buy MT2 18SS+ Kit or hpi hellfire rtr
  151. What is the purpose of the baffle cone?
  152. HPI MOTORS
  153. help...run away Savage
  154. barely used savage x, how much does it worth?
  155. Axial 28RR - What to do??
  156. purchasing a savage soon...need advice for upgrades
  157. drive cup
  158. convert a savage to a savage x
  159. I'm gonna switch to the LST big bore shocks!!
  160. Sav X 4.6 tuning question/problem
  161. problem with rotostart on savage x ss
  162. Savage X (4.1 rtr) Issues
  163. STS pullstarts
  164. 15% fuel any good?
  165. a good high end pipe?
  166. STS throttle
  167. blown savage ss motor
  168. Old vs. New radio box
  169. Savage XDrag Project
  170. i want a bigger savage
  171. Trouble keeping brakes
  172. savage 4.6 (.28) or savage truckzilla .46
  173. Nitro 20% v 30% in Savage
  174. glow plug issues
  175. turning
  176. Axial .28 install WHOA! and a question
  177. Savage X and Pull Start...need some help installing
  178. SHOULD I BUY [savage x]
  179. Savage 25 to X
  180. RD Logics Pipe Problems
  181. Help with a 4.1
  182. A fast question
  183. Help: tips in preventing stripped hex wheels
  184. finding a pullstart
  185. Clutch shoes?
  186. savage problem?
  187. X 2-speed/Old 2-speed interchangability?
  188. Will old savage spur gears work on x
  189. "Run away" SAvage
  190. HB-Lightning GT10-Help w/Dogbones
  191. LST or LST2 shocks and adapter any feedback?
  192. hpi4.1
  193. Removing engine heatsink screw
  194. Hot Bodies???
  195. My savage 25
  196. New edition
  197. novarossi rx.21 p5 carb on sts d30m
  198. Low profile towers!
  199. Engine stops when I use the brakes.
  200. 40 series dish wheels
  201. Cheaper options to stop stripping spur gears
  202. Screws backing out
  203. help !!!! exaust is melting
  204. storage
  205. engine problems
  206. to lower or not to lower,that is the question...
  207. hitec servo?
  208. which engine is better: k4.6 or F4.6?
  209. does anyone make?????
  210. heat cycling ?
  211. My Savage is all Black'n'BLue
  212. Nitro Star F3.5
  213. hellfire
  214. Nitro content myths
  215. What is it?
  216. My on-road Savage X SS
  217. My bash spot
  218. Suggestions on my racer
  219. Wheelie bar wheel
  220. Axial .28 v Hot Bodies .26
  221. Action shots.
  222. savage x ss getting air
  223. What kind of paddle tires should i use?
  224. clean my truck
  225. Pictures
  226. i need a place to bash my savageX
  227. Bashing Video
  228. Realy good question
  229. Savage 30
  230. Steering servo
  231. TOOK THE SAAVY OUT MUDDIN!!!!!
  232. Hitec HS-5955TG for savage steeering ok?
  233. Temp Gauge or Temp Gun?
  234. Need Help Engine issue
  235. savage x ss turnbuckles
  236. Knight rider savage
  237. savage losses connection
  238. 17mm conversion Q?
  239. Old Body + 3 hours = I Can Run it Again!!
  240. Visible signs of worn out clutch?
  241. Savage X 4.6 RTR, break-in problem :(
  242. I give up
  243. tryin to buy somethin right now
  244. Cant get my Carb off?????
  245. Fast Lane TVP upgrade
  246. Are they coming out with a 2 stroke gas savage
  247. Savage X Battery Level Indicator
  248. Who would win on curiousity...handling/speed
  249. Savage 4.6 rtr, breakin problem
  250. 30 percent
