- problems
- Which performs better w/Axial .28? Werks or TSAIS
- Great....now what should I do?
- What's this with my TF-3 radio and reciever?
- should i convert to steel spur gear?
- Lightest 40 Series Wheel(with 17mm) for Big Joes??
- aa batteries
- roto-start!
- AXIAL 28/TRUCKZILLA, HOW TO GET FULL THROTTLE?
- My poor truck!
- Center Rear/Front Axles Upgrade Query....
- oil filled shocks???
- Pro line wheel/tires?
- hot bodies gtx2 twin
- Gearin
- Racing shocks..
- engine tuning
- truckzilla
- Will DIRT BONZ fit on BEADLOCKS?
- SH M28 P3 In my Savage...Should I?
- Ran my Savy 4.6 SS for first time 18 months
- tire question?
- Which wheelie bar is more durable?
- SAVAGE DIFF COVER ON Hot bodie LSP
- What weight shock oil for these.
- New savage!
- Jumping practice
- Spure gear
- x ss asembly
- decisions
- Getting frustrated....
- 3 speed
- Questions about a new Axial .28 and my Savage X
- F/R Alloy Diffs on Savage X SS Inquiry
- Howlong did your k4.6 last?
- Cen diffs on savage HELP!!!!
- Clutch shoes, leading or trailing edge whats better?
- New from HPI: Savage X 4.6 RTR
- Savage on the way! Glow Plug?
- can stock savage x tranny handle F4.6?
- throttle
- Control improvement..
- ofna force .32 for savage
- PXP Racing Video - Episode 1
- HB Lightning GT10 Was FLYING Last Night...
- Brakes
- NEW Savage 4.6 RTR
- Need some quick 3-speed help!!
- 4.6 problems
- EXHAUST RECOMMENDATIONS NEEDED!
- RTR...my version
- OMG the sh 28 HAULS
- Locked up the stock .25 (PICS) BOUGHT STS30!
- Concidering upgrading hyper 21 8 port
- where did the torque go?
- Broken A-Arm
- Hot Bodies Truckzilla .46 Conversion Savage
- Transmitter JR
- new x
- Digital servo?
- Which shock oil should i get?
- savage carb question?
- how to clean my truck
- One Way Bearing Problem
- I have made my descision
- servo chatter?
- Throttle Slit
- Truck Sputters at Full throttle
- should i upgrade to the savage x??
- Savage x upgrades
- Help a nitro NEWB! Got the X SS started but....
- what else do i need
- Breaking knuckles
- what socks
- Which truck for my 11 year old?
- savage .25 ?
- Supercharger - anyone used it?
- New Body Pics!
- Why do you like your Savage?
- Leaning towards the STS .30/lrp spec 3
- integy aluminum clutch shoes
- transsmission stock settings
- What engine are you running?
- FLM chassis and shock tower ?'s
- Trials Zone
- O-rings for diffs
- Need an Opinion.
- pinch nut screw stuck
- flywheel for axial .28
- Cheap SH prospec
- is it possible to do a brushless conversion?
- shock socks for Savage
- wheelie bar
- Stuck at TDC
- Bought RPM wheels, now I'm just bitter!
- RPM upper arms
- Fuel Pressure Gone
- anyone have INTEGY MSR8 SHOCKS on there savage?
- antenna
- savage fuel 16% or 20%
- Cheapest place to order a Savage X SS
- HELP 3 speed shift point for 15/52 gear set HPI Savage 25 LE
- Body Mounting Suggestions
- how hot do you run your savageX 4.1
- Pics of my Trucks
- Spur Gears
- Roto start on a XSS??
- 3 speed tranny shifting help?
- few pics
- chronic
- HPI Savage XSS & Roto Start
- Perry pump...
- Fiddling with HB Lightning GT10 Engine....
- savage electronics gone wild!
- spur gear
- What colour
- About compression
- HPI Savage with CEN Genesis pipe installed ?
- tuning tips and tricks please help
- Pics Of My Street Savage......Just Ordered A Rossi Top 528 Engine
- Chart vs Experience?
- Shifting Problems
- Help a dude w/ a strange noise.
- Spur Gear Problems
- axial .32...should i or not
- Savage CVD's
- tires and rims
- Receiver Problems
- Sts D30M pipe????
- Wat do u think....
- Savage Doctors - what's your diagnosis??
- Is a bearing puller kit necessary for X SS?
- My Old Mid tank that might help some one
- Where to go from here???
- I am going to do a mid TANKS mod.
- HOW FAST IS THE SAVAGE X
- should I get a Nitro Star S-25 motor?
- Hot Bodies Lightning GT10 Arrived!
- Gearing
- Alloy diff rebuild questions!
- WHAT ARE THE BEST SAVAGE AXLES?
- LTS 2 Shocks
- Are the Savage, T Maxx, and Revo considered 1/10 scale?
- question about savage x and x ss
- Help: Dent on my Savage X SS Tuned Pipe
- throttle/brake servo question
- 2 speed shift adjustment
- Firestrom 10t?
- Buying a savage x ss very soon, so need some advice
- Shock Boots
- D30M Motor Break-in broken?
- Best price on an XSS
- Breaking in Savage X SS
- Are Aluminium Parts Really Weaker???
- What temps should I be aiming for with my Axial 28 and Mach 427??
- hit brakes then savage x cuts off
- fuel
- Slipper clutch?
- 4.1 pullstart problem
- Calc of Viscosity
- My shocks are leaking!
- Zombie Maxx & Axial beadlock???
- Why did you change the stock savage x ss rims?
- Whats my Savage worth?
- 4.6 meshing with sav 25 body
- changing clutch bell
- FLM tvps
- HoT Bodies Lightning GT10 Wil Be here Monday....
- wheely king charger needs help!
- savage pipes
- Axial .28 or STS .28 or STS .30 ??
- Violent STS 30 video
- Truckzilla
- Savage Trials course...need your suggestions.
- Confused on pricing for HPI?
- tnx 5.2r flywheel
- HPI LCG TVP set?
- Reverse Mixer for LED light switch
- Mach 427?
- Savage Engines ?
- is this the pipe for my axial .32
- Wheel only turns left when sitting still on the ground..
- savage X SS Nitro Fuel Options
- strongest shocks
- Header Tank Mod Not Working, Please Help!
- Starter box?
- Quick Question TY
- My local TRACKS ON AND OFFROAD (PICS)
- clutches???
- Radio Interference Problems!!
- LOOKING FOR A SMALL LIGHT WEIGHT ROTOR START!
- Woah, that's what I call braking...
- Would u recommend Savage X Kit??
- e -savage upgrades...
- <<Carbon Dream>> 04/18 Update
- help - Roto start not cranking engine
- Bash Day - Vancouver, BC Area
- 17mm hexs
- beginner truck?
- R/C Monster truck world fianls at Gravediggers Dungeon!
- Question about HPI Aluminum Clutch shoe set
- savy 25 halfway tank problem
- Size of the HSN o-ring?
- Spur gear and clutch bell
- Typical Bashing Mis-haps
- I am all about hellfire size 17mm wheels/tires on Savvy now
- Savage In Build
- savage .25
- Which Savage do I Have?
- Help, Blew Rear Diff
- quick question
- rims/wheels
- How is STS .28/.30 working out for ya?
- savage x and wheelies?
- Basher Gearing?
- Savage X Shocks/Springs?
- Savage X SS - Problem, Steering.
- blown bearings!!!
- im confussed, i blew rear diff.. again!!
- Pipes.
- 3 Speed adj. on XSS
- sealants
- i love this
- Ring and pinion gears dropping like flies
- just got an E-Savage
- Is there even a second gear?
- RTR...HPI Engines...oh dear...
- New Savage X Spur Gear problems and more.
- Roto start question?
- RC Innovations vs LST
- No wheelies?
- Savage X Questions
- Cleaning and Maint. Need some help...
- Reciever chip keeps popping out... SOLUTIONS???!!?!?!?
- Do you know anything about or can comment on a Novarossi N528XR
- Slips too easy.
- DO I NEED THIS?
- WHAT'S BEST SERVO FOR THE SAVAGE
- rear wheel drive out again
- diff lockers good or bad idea
- HPI's customer service (UK)
- WHO MAKES THE BEST GLOW PLUGS?
- I think I have an idea!!!
- FUEL?
- Savage SS vs Savage X SS
- brakes question
- Savvy got a new lid and shoes!
- What % nitro are you running
- Savage 25 Reverse Module. Problem?
- ANYONE EVER GET THE LOW CG SAVAGE CHASSIS?
