- savage ss 4.6 diff
- New engine!
- Hpiracing07 savage project
- savage 25 parts on savage x?
- 3 Speed tranny Help!
- tight enough
- ok its time for new engine,4-6,sts30
- savage 4.6ss Problem!
- Offset choice
- stripped screw...please help!
- F4.1 rotostart backplate on an Axial .28
- spacers on shocks on stock savage x
- Aluminum Clutch Shoes
- question on break in....
- K4.6 Performance
- spur gear?
- Full throtle on break in
- which new pipe?
- new servo ?
- how too change rim and rubber
- Savage X brake help
- Broke a Steel Spur
- lookin" for a savage
- Wider Savage
- Is it just me or does the HPI wheelie bar suck?
- My X SS was a PIA today...
- 30 minute ramp VIDEOS (PICS) UPDATED
- The death of my F4.1
- Savage 25 Limited Edition
- savage video part two!!.. oh yes!!
- Need help!!
- My winter project with Titan body.
- link for set up and hop up info
- new mods and new pics
- RING AND PINION MESH???????
- stock HSN,LSN and idle settings
- HOw do you remove the carb from an F4.1?
- New HPI Savage or an update?
- It's nice to be back (seems like a fun forum again)
- help or i'll go crazy
- Took backplate off - what is this pin?
- Busted fin on heat sink
- Savage X high operating temp, over 300!
- Measuring Speed
- engine bearing
- differential cases
- Break-In
- Building an Exhaust
- Radio upgrade
- Hump Pack for Savage 25
- Pollution
- GPM steel spur gear - junk??
- savage tranny?
- X not starting
- savage drive train question
- Changed fuel & engine dont like it.
- The ESC
- idle problems
- A couple picures of my Savage SS 4.6 in the snow /mud!
- pull start
- Axial .32 gearing
- New X
- What After Market Shocks???
- Anyone running Sirio .30?
- Just finished my first body
- Grease in the Diffs Question
- problem
- savage 21
- Savage X center diff
- Winter Ski Kit Vs. 4WD
- Need a quick lesson on camber, toe-in, and all that...
- Roto start problem!
- savage gearing
- Fwd savage.
- savage in the snow
- Axial pics
- Trouble tune..
- Powerline Center Skid for an X RTR
- racing savage , need some great ideas
- Lockers
- Can I use this grease in the diffs?
- Savage help!
- What is this part?
- TX antennas?
- servo servo servo...
- Got my new wheels/Dirt Bonz
- STS .30
- mmmm power but raido problems.
- Just bought a brand new Savage X What should I do to breakin the motor?
- OFNA TITAN VALUE!
- Question For You Engine Gurus.
- Dual Server set up for savage?
- Roto start to pull start
- These tires with these wheels
- better handling for savage
- Savage 25 and 4.6 OWB Help!
- Savage 25 and ss Hump help! Charge leads?
- shutdown
- Ordering an Axial .28 for my Savage X RTR Checklist
- help on the sts 30
- hump pack
- servo problems i think
- my TITAN 4.6
- Hot bodies .46 parts?
- Quiet PIPE ??
- Axial .28 and stock Savage X RTR gearing
- First post break-in day...
- axial .28 or the hot bodies .26
- SH 28 Pro spec or STS D30M
- gearing and fuel info on the sts engine
- 25 to 4.6
- Savage 25 problems
- recent savage pics
- savage servo's
- NOOOOOOOO!
- Clogged Pipe
- refund or is it worth the money??
- Nova clutch shoe weight configuration
- Savage X brake linkage issue
- How to waterproof electronics?
- SH .28 engine pull start
- Vantage Racing Pipe?
- Savage 25 Orion .26 help Please
- tuning my X 4.1
- Stock settings?
- Engine Problem Serious
- SURE FIRE .32 pipe?
- pull or roto?
- Batery/Servo Problame
- just recieved the sts .28
- Reverse module for Savage X
- OWB
- Savage X triple rate springs.....which way?
- my one way
- Best weekend EVER! (so far)
- Replace Brake Pads
- Looking for the right pipe
- help please!
- low speed needle on savage 25 with stock nitro star s25
- Chronics TVP's and MIP drive kits??????!!!!
- New upgrades
- question on the savage x ss
- Roto-start
- Washing savage caused this
- BDC
- these or these.
- racing savage is now on the move!!.. pic inside!..
- Getting out, sales advice
- Weird Savage Symptoms
- HPI Dirt Claws
- Rotostart
- hard startup
- Battery Level Indicator
- silicone grease and shock oil
- Need help with Radio controler for my new X
- Differentials: Grease or Oil
- Help on CHASISS
- Best Basher tires
- Nother New Vid
- I think my S-25 temp is too high
- BEST SAVAGE TO BUY?
- X-spur gear
- Big block?
- Savage 25 to Savage X Parts Compatibility
- Dirt Bonz: S or XS Compound?
- New to R/C
- Upgrade?
- Pull start question!
- upgrade for x
- Axial .28 or HPI K4.6?
- E-Savage
- Wing Kit for the X
- my savage x wont start!!!!
- im new
- I Cracked My F4.1 Carburator Who Else Has???
- Axial Fuel Filter Installation..
- warm up
- Oh-oh.
- crankshaft removal s-25
- first injury
- Spur gear difference?
- Wrong part number for bearing listed in Savage X manual
- E-savage
- K4.6 HO
- Should i get this savage x ss combo??
- new engine
- Just finished my SS
- <<THE Carbon Dream>>
- RotoStart + Backplate.
- Read this before you think about starting your RTR Savage
- savage 4.6 ss diff
- savage 21 old school
- Rear differential help needed
- Cheapest nitro?
- pull start for my x
- Savage xss suspension upgrade
- savage x
- no compression
- cooling head
- Tracks Around Sydneys West ??
- New Paint... 2 bodies... (pics)
- cant decide what to do. help needed!
- what should i upgrade now ?
- Brake pad Replacement Setup
- 4.6 oneway bearing
- NEED HELP QUICK!!!
- savage 25 performance
- Spektrum DX3.0
- mt2 18ss or savage x
- Savage 25 questions
- Best RTR (Ready To Run) Truck to Buy?
- My first wreck
- How can I get more power from my S-25
- savage 25
- Savage X upgrades
- Which 23mm Hex adapters do you have?
- 528, sts30 or lrp .28?
- just bought the sts .28
- Foam Question for Dirt Bonz
- DELETE - DOUBLE POST
- Does the savage really handle bad??
- how to shim the diffs.
- Best way to bleed a shock.
- SAVAGE X 4-stroke
- RRP Extra Hard Clutch Bell
- Old steering servo
- Nitro retrofit
- Savage X (monster truck) vs Stadium truck
- The Punisher project with big props to Chronic
- whats the best way to
- THS Pipe Installation Savage X Problem
- E-savage into racer
- rpm skid plate
- Just upgraded the brakes on my Savage X RTR
- Roll cages
- nooob here plz read
- Which fuel?
- wow i fixed my one way!!!!
- savage durability
- nooob here MGT plz help comment you veterans
- YES!
- oil b4 breakin?????
- DRIVE TRAIN
- fixing my one way
- roll bar
- shim kit?
- what should i get.....hmmmm
- Problem savage 25
- Thanks guys for the advice
- Converting to the Dark side- Tmaxx
