- Nova's lower arms..
- sts 30 advice wanted
- help..truck dies when brakes applied
- k4.6 questions
- HELP!!! TUNING PROBLEMS...
- Savage Help needed
- servo arms
- savage ss 4.6 problem
- Fuel leak?
- Savage x cluch problem
- What Problames Should I Expect???
- Savage driving by itself?
- Clarification please
- ideas for a race savage
- 3.3 engine
- Axial-----Good ----Bad-----??????????
- 30% nitro on k 4.6 engine?
- LRP 36% Energy Nitro Fuel
- Got the STS 30 with STS pipe
- Hoping to get some lights
- mid tank mod?
- Drive Axle Set Screw
- Savage servo setting?
- Radio and Reciever???????
- SAVAGE FAN BOYS CHECK THIS OUT
- savage header tank mod
- carb body of savage 25
- What is the good brake for SavageX
- Tires for Street Use
- savage plugs and drive train
- Ideas for money
- Tranny Problems
- Savage superchargers and nitrous systems
- MACH 28 AND 3 SPEED GEARING??????????
- better lighter tires
- dogbone
- E-Savage Diffs
- HPI Roto Start 2 Glow Plug Igniter Attachment??
- Nitro ports....
- fuel line help please
- savage ?
- tunning for torque can u help me .
- 7'' gearing
- Savage X SS Help!!!
- motor stalling
- help tuning..bogs
- new buyer
- looking for a lift for my truck.
- which tvp package to get
- k 4.6 engine carb
- Looking to get my second Nitro Truck
- Too Lean?
- Will the K4.6 HO drop into a Savage X?
- help!!.. not sure how i put this o.s flywheel togeather!!..lol/ pic inside!
- hpi savage
- Any problems with a Savage 25
- My X SS build
- shipping NITRO overseas?
- Wheely King and mamba
- Savage XSS engine upgrade - advice needed
- 4wd not working??????
- CARBURATOR JUST FELL OFF
- maxx paddles or PROLINE 40 series paddles
- More Traxxas posts than Savage posts..
- How much does lowering help with handling
- Savage X SS Throttle / Break linkage.
- bashing???
- Hot Bodies 46 engine for Savage... need help
- savage 25 problem
- Fuel tank broke during first pull start..
- Some simple questions
- axial .28 carb needle problem
- old savage to savage x
- clearing the after run oil out
- Savage truck engine
- High Idle / Temps after running custom blend??
- Engine won't start, please help
- Reverse mixer?
- finding peers
- spur gear trouble
- savage x shell painting pics
- Savage SS 4.6 Vs. Cen Genesis 7.7. How do they compair?
- Sts .28 or Sts .30????
- clutch shoes
- .New Padles 4 my Savy.
- clutch spring question/ other bits aswell...cheers!..pic inside!
- just did my 1st bash!
- servo linkages
- Which Motor Saver do I order ?
- Roto-Start vs. Pull Start
- Which truck? AND WHY!
- clutch shoes
- Savage X 17mm wheels on a Savage SS.
- My first crash :O :O :O
- Hot bodies body
- Tips for Loosening Screws with Loctite
- quick advise
- pricing question
- What do you use to seal your Aluminum Diffs?
- savage suspention conversion set
- Missing part
- Savage Question
- please help
- Break In Procedure
- Suspension Tuning!!
- is it true about the 3 speed?
- shifting to reverse problems on my savage
- servos for the xss, good or bad?
- advice please with my "x" please/ pic inside.
- new savage x engine help please
- Latest Power Upgrade from Estes
- A couple of questions.
- Help.. Winter tuning.
- savage x hop ups
- savage x tranny question?
- best pipe?
- My first paint job.
- PURCHASED A SAVAGE TODAY!
- Might consider buying a savvy
- right-front hex size different?
- is there an easy way??
- Throttle and Brake help
- List: HELPFUL THREADS/COMMON PROBLEMS
- nitro fuel age
- motor dyno specs
- the most race worthy savage
- savage ss x charging lead
- best site??
- Upgrades for Rush Evo
- Pics!
- Diff oil experience
- ~savage ss 4.6 with hpi rollcage~
- nova and mugen help
- LRP Z28 spec 3 vs Sirio 30
- sticking slide
- savage x ss tuning ?'s
- whats the difference between all the savage models
- Looking for feedback on the Axial 28
- Nothing has changed
- Hold onto your socks boys..STS 30 Vid inside
- integy high power tune pipe
- symptoms of bad 1 way bearing
- steering servo?
- New brakes -- problem
- Finished
- Savage X Brakes - No Response
- Looking for a new truck
- Question about tires?
- more power
- Will this work????
- break in stalling
- lube on gears for diff cup and bevel gear!
- Does the HPI ROTO START fit on the AXIAL 28 engine??
- savage x throttle /brake linkage
- Dual Disk Breaks Question
- ss sts engine break in problems
- How to Find BDC on roto start
- help with new clutch bell
- Servos for X SS
- Getting extremely fed up with my Savage 25
- which combination spur gear?
- SS Upgrades
- Savage X SS or Losi LST2
- dune bugge roll cage for sav
- stock SavageX 4.1 ?
- savage x battrey box
- maxx paddle tyres in sand
- Savage x ss on order
- which is better
- More bearings.
- Mach .28 -VS- ZPR Z.28R Spec 3
- Savage ?
- new engine ???
- SURE FIRE
- Want to go Truck Racing??
- X SS and Spektrum servo
- Best way to get rid of paint run off?
- Savage X or SS
- make diff oil???
- after run oil
- savage 4.6 ss starting problems
- Savage x ss dogbones
- Stock X SS Wheels Tires... any good?
- What is the coldest, you've ran your savage in?
- %@#&* Pull-start!!!
- Newbie's Savage X won't idle on it's own.
- Savage wont idle
- engine upgrade
- Product Reviews
- savage 25 problem
- Mid-Tank lean out
- STS Engines moded by RBmods
- Nova RC Clutch Shoes - Any installed them backwards??
- Stripped spur gear question OS .30
- savage-x any weakness ??
- Best fuel for Break In
- ~4.6 engine tuning~
- why buy Savage X over Revo?
- Savage X not hitting 2nd gear smoothly
- El Camino SX........
- Help me out please....
- savage x ss body questions...
- Integy diff cups?
- Buycrystals.com
- Help Cant start new engine - Tried everything (I think)
- 4 shock savage
- OHHHH... $%#@
- My X SS Build with Chronic XL TVP's..
- NEWBIE WITH A DUMB QUESTION
- LST 2 Shocks For Savage X SS
- some more savage x ss questions...
- savage x radio box
- how to inhibit 2nd geat on savage?
- 2 questions
- X SS Glow Plug question
- Idiot needs major help with Savage Engine
- mirage failsafe
- Pull start problem Quick reply if possible
- Dogbones/MIP CVDs/UV Joints?
- Midas Touch
- who makes the best drive cups
- 2WD Savage
- Trouble with new Savage X
- Oneway Bearings?
- what is this for?
- engine screws?
- Wieght of E-Svage please
- Body Painting Ideas
- newbie w/ SS 4.6, what should i get for 60% at local shop?
- Better shocks for the Savage?
- upgrade
- What is the best engine conversion???
- What are the best grass tyres???
- Painting/Airbrushing question
- Question for Experienced Tuners
- Savage Alloy
- running backwards
- E Savage Top Speed??
- Finally finished my X SS !!!
- Few engine & Rev questions
- Teacher wanted
- X SS diffs
- New Engine :) ahahah!????
- is servo saver needed?
- just finished building x ss!
- do any hpi trucks pop wheelies
- steel spur with stock bell's ?
- axial will not stay still
- isthe savage good for beginners
