PDA
View Full Version : HPI Monster Truck Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. Anyone use nova aluminum shock towers?
  2. Thinking about a Mid-Tank Mod. Some tanks to look at.
  3. clutch springs
  4. savage x diff beef ups
  5. Shock oil in stock shocks
  6. full throttle afterburn
  7. Savage crash pictures and details
  8. New style of Diffs - Very Expensive
  9. New Ramp..
  10. Quick Tuning Question...
  11. hellfire clutch bell
  12. Need some input on a new suspension.
  13. savage 25 neeb help
  14. looking for a differential tutorial
  15. Savage X - Sudden lack of performance - Part I
  16. LST2
  17. engine keeps dying
  18. simple question
  19. What's the best engine available at Tower??
  20. k4.6 compression out of whack?
  21. Pictures of my Savage Racer
  22. HPI conversion kit
  23. leak!!!
  24. How much is it worth?
  25. paper test for setting spur HELP
  26. Plastic or Metal bulkhead?
  27. best kit racing truck
  28. i give up
  29. MOVED: Places to Bash in Northeastern NJ
  30. savage ss with a chain saw engine
  31. What?? Are they crazy?
  32. Few upgrades to my X.
  33. xtm 457 problem
  34. savage x or hellfire? plz help!!!!!!
  35. clutch bell bearings
  36. El Camino body question..
  37. K4.6 engine problems...need help.
  38. axial .32 keeps stripping gears
  39. Pull start slippage
  40. savage X battery box ?
  41. Recently ran truck!!!(help)
  42. Ofna/Picco One Way Bearing - Question
  43. Ode To Savage
  44. savage transmission
  45. Whats the difference?
  46. problem with my savage x!
  47. Any headlite pics?
  48. RD LOGIC'S Dual exhaust tuning?
  49. Can you recommend a good beginner monster truck?
  50. Food 4 Thought
  51. novarossin528xrs
  52. questions and more questions
  53. fuel tank
  54. best pipe for savage
  55. servo saver question
  56. sts .28 killed my spur
  57. hellfire
  58. Bigger tank for savage
  59. ?what about thunder tiger EK-4 .70 truck
  60. diff locker any good
  61. savage questions
  62. New Savage X Radio
  63. priming with rd logics dual rear exhaust
  64. Change rotostart to pullstart
  65. Truggy wheels on a Savage??
  66. im back
  67. new savage x will not run...need help
  68. need some help fellas!
  69. Adjustment on shock tower.
  70. f1 motor ,how long does it last
  71. Savage .21 wingmount???
  72. When to charge your hump pack
  73. hellfire help!!!!!
  74. Body-cutting with a dremel??..
  75. Savage "X" SS 4.6
  76. Best pipe for the X
  77. help me get this going plz...
  78. Problem with brakes on my SS 4.6
  79. Savage takes first place against Revo’s
  80. gear alignment?
  81. wide tires for sav x
  82. best engine upgrade from .21?
  83. second transmitter
  84. picco 27 help
  85. Savage X radio glitching when running
  86. Savage 21 upgrade
  87. Which Servos!? Help Appreciated
  88. So I installed those Nova Clutch Shoes.**BETTER AND MORE PICS**
  89. orion v6 clutch (again)
  90. here are some pics of a ported XTM 457
  91. Stripped head screws
  92. LRP Z.28- but which exhaust?
  93. Savage problems?
  94. clutch shoes
  95. carb wont tighten up
  96. HOT WHEELS RADAR GUN!!!????
  97. FG big foot ''gas'' monster tuck!
  98. what is the best aluminum rims for savage?
  99. Clutch Bell
  100. sh28 pro
  101. savage x - whats wrong with my rear diffs?
  102. Do you balance your tires?
  103. how do i make a winter savage
  104. savage cutting out
  105. Spur gear questions.
  106. Engines
  107. hot bodies lightning stadium pro what is it worth?
  108. Duratrax Flashpoint
  109. Oneway bearing
  110. Post your wheelie pics
  111. Savage X SS w/ LRP Z.28 3 Spec
  112. reverse with mixer
  113. xtm 457 and savage
  114. Dirt Demon
  115. savage x or revo
  116. heres my savage(pics)
  117. new wheel and tyre set for a 'truggy' like appearance for savage
  118. To buy or not to buy
  119. Need Help
  120. no rear wheel drive
  121. plastic spur
  122. slipper clutch pads
  123. NOW 2 Problems Need answers
  124. Savage 4.6 ss build**PICS**
  125. After run
  126. Savage X SS on sale here>
  127. Won't Start Once Hot
  128. Easy (and Cheap) Header Tank
  129. good upgrades for ss 4.6
  130. Fluid coming out of exhaust pipe
  131. hotter than hell
  132. Fun Day At the Track
  133. Savage 25 to X
  134. motor question help
  135. Tires??
  136. How to remove wheels from rims - A Tip
  137. HSN leaks fuel
  138. e-savage = hot bodies ezilla
  139. Shiming the diffs of savage 4.6ss
  140. Should I ditch my X and get an X SS 4.6?
  141. Piston Sleeve pinched...
  142. is this temp gun worth a crap
  143. Savage X chassis hop-ups
  144. not getting any fuel to motor
  145. extreme bumpy conditions,stripping spurs/sav x
  146. Mounting THS 8025??
  147. Low Shock Towers?
  148. EDIT MORE: Savage Questions?
  149. savage 25 havent started it in a while.how?
  150. 3 speed tranny not down shifting
  151. Diff stripped..
  152. tuned pipe
  153. which way is rich
  154. big blocks and hot plugs
  155. Which Shocks??
  156. Clutch Bell problem
  157. servo help
  158. priming
  159. Are you supposed to put oil into the Savage's Transmission?
  160. Gearing
  161. HPI Steel Spur Gear - need fix!
  162. is it because the hsn is rich?
  163. Sealing the Savage Engine
  164. Savage X engine trouble
  165. what roto will fit??
  166. K4.6 "missing" at top end
  167. Why Does My Savage X Have the Old Style Slipper Clutch?!?!**PICS**
  168. MIP CVD's
  169. s25 low speed needle
  170. MOTOR MOUNT!
  171. flywheel options
  172. What are specs of Hellfire SS?
  173. What are all the virtues of the Hellfire SS?
  174. Trans or Diff?
  175. ooops
  176. Hiya yall
  177. SAVAGE X NECESSARY UPGRADES
  178. rotostart with lcg tvp's
  179. Crankcase does not fit mount
  180. my savage 25 project
  181. X shock towers
  182. Do not use silicone for airleaks hobby store said
  183. savage x worth the price?????
  184. Savage X Truckzilla
  185. best break in method
  186. Orion CRF V6 clutch
  187. battery monitor...
  188. Savage X Or Savage SS 4.6 for bashing
  189. What is this Engine??..
  190. I upgraded to the x
  191. savyX diff&trans in savy 25
  192. Is this a good hop up for a racer?
  193. A place for our Savvy's to roam/my summer project
  194. best clutch
  195. HPI E-Savage
  196. New to Nitro trucks,,,,,,,,, sugestions
  197. Help identifying tvp's
  198. grrr
  199. Replacement Savage X TVP's
  200. These clutch shoes look fishy! **PICS**
  201. savage rebuild
  202. My recent build
  203. can't get the crab off
  204. HPN needle for savage .21
  205. Any good deals for the Spektrum DX-3?
  206. Helping A Friend Get A Truck
  207. Anyone run a Picco .28 in your Savage?
  208. Need some Help with spurs and reving high problems
  209. Savage X pricing?
  210. SHOULD RCU HAVE CHAT ROOMS???
  211. savage 21 tank
  212. diff problem
  213. Cen Genesis Engine
  214. Ebay Savages?
  215. Spur gear 4 savage X problem?
  216. HPI .30 OS savage Extended All alloy
  217. Getting savy 25 ready to race
  218. No Brakes
  219. @Nyc/NJ people.
  220. broke axle
  221. New project
  222. OMG!! STS .30!!!!
  223. STS D.30M
  224. Wats up with my savy x?
  225. Does Savage X parts fit in Savage 25 ?
  226. Looking for Reverse Module
  227. S25 sucks!
  228. broke the black plastic picec thats in 87040
  229. xtm 457 help before i buy
  230. xtm 28 vs k4.6
  231. Radio Help: DX3--OR--XS3 Pro
  232. Running temps for Savage X??
  233. Fuel for torque or horsepower
  234. spur ?
  235. FOUND A SAVAGE X CHASSIS FIX!! (maybe)
  236. HELP
  237. testing the paddle tires. video.
  238. hellfire
  239. spur gears stripping every 5 minutes????
  240. STS .28 Rotostart Backplate
  241. what is the best engine for a savage
  242. Mugen springs and shoes.
  243. os 30 roto start
  244. a guide on how to install ofna clutch shoes please...
  245. broken crankshaft
  246. changed my mind!
  247. Pics of one of my best trucks!!
  248. QUICK HELP ON SAVAGE!!!!
  249. spur gears ?????
  250. X Chassis
