- Savage X Flux wing mount options
- HPI Savage X nitro with center diff?
- Identifying RC car.
- savage xl with lrp zr 32
- Free Savage Project
- What water boat do you recommend?
- Hpi Savage
- What hpi is this?
- Fork in the Road
- Spur gear an slipper clutch
- Help tuning HPI Savage with SH .28
- Substitute Head Shims for LRP.28R ?
- Clutch shoes
- Savage x 4.6
- HPI Savage X 4.6
- Maintenance before play?
- Anyone out there?
- Been Out the loop for over 10 years.
- Picco
- batteries
- roll bar
- Savage X Bogging When Accelerating
- 1:10 4x4 Truck: Grinding and Hesitating
- Spring Project
- new savage 4.6 tranny wobble?
- Picco .28
- Cen Racing Genesis 7.7 question
- Hpi savage 3.5
- Savage .25 Brushless conversion
- Nitrorcx?
- HPI Jumpshot gearbox and thoughts about Bliz/Firestorm
- does any one make the savage 5t plates fo my build anymore?
- Post a picture and info about your tuned Baja
- Hot Bodies .26
- Should I? Used savage x 4.6
- Buying Used HPI Savage 25 + Enough parts to make 2 more - So he says haha.
- Savage XL - Shocks and Radio Gear Upgrade
- savage x steering glitches
- My savage xl bruslesh conversion home made ; )
- Convert Wheely King to electric
- Kershaw Designs Direct Drive
- K4.6 engine issue
- New savage owner seeks up-to-date info
- TWIN TRUCKZILLA parts needed...
- Wheely King redo
- Cylinder/Piston Set Nitro Star K4.6
- Savage 5.9 Photos
- Ceramic bearing question..
- HPI Savage 21 with 4.6 engine having fun in snow
- HPI Savage 21 (4.6 engine) having some fun in the snow
- spur gear and clutch bell size??
- LST shock conversion for Savage
- K5.9 for savage xl
- hpi baja tuned pipe
- Upgrade of unbuildable unreliable 550 titan 21T into a buildable 550 for Wheely king.
- What savage do i have?? Please help!
- Savage x 4.6 to xl
- No Savage XX S in stock anywhere in the world right now?
- Want to convert Crawler King into a Monster Truck
- New HPI Bullet video
- Need a couple new screws for my savage.
- Breaking dog bones on the Savage Flux XS
- ESC with no on/off Switch
- Replacement of the E-savage
- Bought a used Flux. Having major issues. :(
- New xl 5.9
- Slipper clutch rebuild G3.0
- avage flux hp batteries
- Can someone please simply explain how to extend the wheely King
- Wheely King - Is it still possible to extend the wheelbase
- Can anyone tell me which truck I have?
- When will HPI release the Savage Flux XL?
- Hpi Savage Flux Hp ESC
- Nitro engines. Whats still available?
- bought a new project needing advice
- Flux blur esc inside picture needed!!!
- Identifying motor
- What RC Truck Do i Have?
- Where to buy bodies for savage xl 5.9
- Will Badlands/renegade fit my XS?
- Thoughts - Trencher X and 18T pinion
- Savage X parts question
- roto start snapped off inside motor help!!!!
- Savage XL Octane - Transmitter/Receiver loose contact after few seconds
- OTB Tests XS Durability - Won't Stop Tick'n
- Savage wont start
- OTB HPI Savage XS Double Front Flip - BIG Air
- 17mm spline hex's for savage.
- OTB XS Front Flip Bashed
- Have you submerged your HPI?
- 76mph Savage X
- buku clutch in a savage
- Leaking from top of head
- Savage XL Octane & the Losi XXL 2 WORTH IT??
- Which Hpi truck have I got?
- Savage flux xs - should have done this and not that?
- Can some one help me with the identifying this truck thank you
- HPI Bullet MT 3.0 Nitro
- Savage Flux XS body
- Savage 4.6 Steering Servo
- HPI Savage X4.6 engine issues.
- Can you ID this chassis?
- hsp monster truck 94188
- Savage wheels?
- Savage XL Upgrade Suggestions
- Noob
- Savage 4.6
- Help with savage 25 to X version
- Savage 25 to XL f4.6
- Not much happens here
- Savage engine upgrade
- SAVAGE 21 won't stay running, the fuel line goes empty
- 5.9 will not start
- K5.9 Savage XL...convert to brushless?
- Savage x spur gear problems
- savage x as destroying rear diffs
- New Savage XL Engine Question
- Hpi savage 4.6 running problems
- What part's are these??
- Quick Q on WK wheels.
- I must be missing something about this auction.
- Nitro Star .25 Replacement
- Starting Shaft Slipping, Help plz.
- Engine Test off RC ?
- Issues with HPI Savage XL
- Savage x f4.6 cutting off after WOT
- Flux HP Durability Questions
- savage 4.6 wide tuning window?
- savage Xl new engine
- long time coming. new to Savage flux blur
- Savage x 4.6 starting problem
- problem solved with hpi savage octane.
- flux to XL or XL to flux?
- Another conversion
- 112mph twin flux
- Help with bullet mt flux
- Maintanance vs Play Time
- My 1st Nitro RC
- Flux HP 2 or 3 speed transmission
- Hobby king???
- Savage Flux HP Batteries
- Savage Flux HP good tires
- savage cage question
- air filter
- engine needed
- savage diff cover extension for 6x6 or 8x8 Under development
- Best hump pack for savage x 4.9
- Trashin the Flux
- Savage Flux HP stability upgrade
- HPI nitro star .25
- HPI Savage Flux HP good choice?
- F4.1 worth a rebuild?
- Hello & thank you
- Has Your Rear End Blown Out?
- Tuned Pipe Attaching Point??
- xs broke again
- savage xs steering servo issues
- Brake help
- broken crankshaft!
- *Sigh* Broken already
- Top 5 Engines For The Savage - Post Your Recommendations
- Why Is There Not A Sticky Of Savage Mods
- broken gear
- Selling My Savage
- Anyone Make A Homemade Receiver Battery Pack For Savage X
- Stock Chassis Speed Savage
- Reviving my Savage
- I think something is slipping
- Very New To Rc - Differences Between Savage Models....
- XL conversion
- How to clean
- New guy here
- Want a Savage X
- 3 speed tranny
- Tracks good or bad
- quick vid of my savage x 4.6 after run in
- Savage flux hp problems
- HPI Savage X SS (kit) pipe question
- Original Savage 25 looking for new engine.
- part identification please !
- hot bodies dirt demon manual
- Graphite Lube for Bearings?
- 086 Pipe
- Savage x with lrp 32. Should I use 2 speed or 3 speed tranny
- Roto start for lrp zx.32 for savage x
- Picco 28 carb
- Savage X 4.6 to Flux XL conversion
- Converted Savage to Brushless - Mechanical Brakes?
- Sportswerks inline 053 tuned pipe
- Newbie needs help. Savage X SS 4.6 Engine Flooded?
- Savage XS Problem
- hpi hot bodies dirt demon instruction manual
- Savage X Engine Swap Question
- First Savage
- The Horror, The Horror..
- What parts fit on 3 year old Savage 25 with X conversion?
- Question about spur gear and clutch bell size
- Question...
- hpi savage x 4.6 steering issue...!!!!
- Nitro price!!!!
- New guy with a new toy !
- lrp zr.30 roto start
- Lrp z30 problem...
- FS: Full aluminum FLM Savage Brushless Conversion Like new
- Tell me.....
- HPI E-Savage Steering Block Help
- My first nitro, hpi savage.
- Nitro Star 3.0 engine question
- Body change
- HPI Diff, unknown model
- Hpi Nitro Monster King Clutch
- HPI Bullet MT 3.0 - Differential gear ratio?
- Savage reincarnation
- Rzhobby SAVAGE Longzhua
- savage xl engine swap??
- 4.6 rebuild tips
- flux mods??
- Needing some help guys!
- Picco. carb
- New motor in my savy .. What!! A .21 ?
- 100mph Flux?
- New look!
- motor change
- HPI Savage 25 - Need Part #
- Savage flux pinion won't stay put - fix?
- New Savage X 4.6 owner with a couple questions.
- OLD TRUCK RS4MT need help please replacement shocks
- HPI Savage X tuning issues
- Savage differential question
- 2.2" tires?
- GOT GAS????
- rotostart
- how would this combo work for converting a savage x ss to brushless
- Cannot get my new Savage x 4.6 RTR to start
- NEED ADVICE ON LST SHOCK MODS
- Little help with a new savage...?
- Need gearing assistance with brushless conversion on savage x ss.
- hpi savage shock mod
- shock help
- servo help please
- tuneing
- Savage engine?
- shocks
- savage x 4 wheel steer?
- failsafe
- Carbon Fiber RTR Named
- Bank is back to RcU- and RC
