PDA
View Full Version : RC Car Engines
  1. Nervous about break in settings.
  2. Traxxas 3.3
  3. Novarossi p5xlt sputters and dies
  4. Tuning Issue
  5. Removing Carb from a Dynamite Engine
  6. Help with hot (but reliable) engine
  7. Nitro clutch catches and stalls engine
  8. Kyosho KE21R issues
  9. in need of help on LRP Z.28r SPEC3
  10. My first rc got a 30cc engine
  11. Bearings for Ultimate M5 tuned engine
  12. Novarossi rex Paloma. 21
  13. VX18 Piston Rod
  14. Anyone know how long a nitro engine will last under normal use?
  15. Big red .28
  16. Mach .15RE Engine Help
  17. Metal Spur destroyed my Pinion Gear
  18. Traxxas T-Maxx 3.3 motor not staying running
  19. Picco 12R C Speed
  20. Best header (manifold) for OS 18 CV-RX engine
  21. .21 with full crank
  22. Sh.28 engine
  23. Os .15 turbo head / button head
  24. OS Engine Max-28XZ can i put a starter on it?
  25. good 1/10 scale buggy engine
  26. Throttle arm question.
  27. Idle screw faulty?
  28. Confused about brushless motor/ESC combo
  29. Traxxas Jato 3.3 Not starting.
  30. CRE P5XLT Break-in
  31. SH Engine Stalling Issue
  32. 25:1 oil mix help
  33. Clutch Belle bearing issues
  34. RB Concepts engine
  35. Nitro engine tweaking and hopups...
  36. Losi 3.4 Starting Issues
  37. Would it work?
  38. Considering a new engine....
  39. engine help
  40. Clutch issues, HELP!!
  41. Engine Revs are going weird.
  42. Car Help In Desperate Need.
  43. Were to find a hpi .12r ss
  44. carb loose.
  45. Roto Start and Pull Start bearing [Help Please]
  46. Starting A Nitro Engine That's Been Sitting
  47. Fuel shelf life
  48. Hpi g3.0 engine problem!
  49. Duratrax road car
  50. which engine will fit my redcat tornado s30
  51. LRP zr.30 Spec 2 help.......
  52. Looking for a Unique Engine
  53. roto start issue
  54. Picco. 21 pmaxx
  55. T-Maxx 3.3 Big Block Conversion Help!!!!
  56. help identifing German made gas truck
  57. Honest opinion on worth of some motors?
  58. Bought a new pipe but things were not as expected
  59. World's First Turbocharged, Supercharged, and Nitrous Injected 2-Stroke RC Car!
  60. Help choose Charger
  61. Anybody know anything about SH .21 engines
  62. Anybody familiar with Team JR Racing. Have there piston rod what era?
  63. Knife edging conrods and port timing questions..
  64. Nitro engine clutch question
  65. Converting Nitro Buggy to Electric?
  66. 1/8 buggy
  67. any one ever cut os crankshaft?
  68. Ceased piston & broken conrod
  69. So what really sets one engine make/model apart from another?
  70. A question on Novarossi engines. Are you there Neal/Supertib?
  71. Hpi 3.0 on redcat shockwave
  72. Do you recognise manufacturer of this engine?
  73. breaking in os 18 cv rx
  74. Thumb screw for throttle and brake linkages
  75. Dynamite .21 Sport for RC8.2?
  76. broken engine piston
  77. 0.21 crankshft not round piston
  78. Z .28r engine , what can I replace it with?
  79. My break-in method is Right or Wrong?
  80. Old ( really old) buggy engine
  81. slalling when brake
  82. slalling when brake
  83. Stock idle crew help.
  84. redcat tornado s30 break in Q?
  85. My wheels won't stop turning!
  86. SH 28 - end of life signs?
  87. Carb set up himoto mbx 2s
  88. defective brand new motor
  89. Newb nitro questions
  90. Os .12 cvr(p)
  91. RB .21 Engine Cant Figure Out What Pullstart I Need
  92. Ofna JL .28 to LRP Z.28R
  93. New rc owner
  94. distributor novarossi
  95. Os 26 SC four stroke opinions
  96. carb issues
  97. HPI RS4 Engine blown up after one run.
  98. .21 Nitro Engine Wont Start... NEED HELP!!!
  99. Pin lining up piston sleeve gone??? HELP...
  100. Circular Grooved Piece on the end of crankshaft!?!?!? HELP!!!
  101. Nitro Engine Exhaust Filtration
  102. Rich and overheating?
  103. Ofna Force .28 nitro engine keeps breaking the crankpin
  104. Stock needle settings
  105. WANTED: in need of a Thunder tiger pro 70-bx ek4 engine
  106. .21 engine question
  107. Traxxas 3.3 failed after 1.5 gallons of traxxas 20%
  108. Hpi nitro star k5.9 engine???
  109. RC Engine
  110. Servo Actuated Clutch
  111. Hpi baja 5b help!!!
  112. Possible enigne leak :/ Please help
  113. PatATi Asymmetric Transfer and Intake Two-Stroke
  114. Where can I buy rebuild parts for this engine.
  115. Engine desicion for titan
  116. Engine stalling
  117. Question about Fuel Shelf Life
  118. Help with needle settings - Force 25
  119. Engine off Ebay was modified...need a hand.
  120. a problem that my local rc mechanics could not figure out, please help me
  121. please help with earthquake 3.5
  122. Brand New O.S. 15CV - FLywheel doesnt fit....
  123. WANTED mccoy .19 tetherline car engine or parts motor
  124. traxxas engine Xpower
  125. O.S. 21TM running hot?
  126. Can some one identify this exhaust?
  127. Can someone help me identify please
  128. 6900kv or 7700kv? big difference?
  129. OS 21XZ-B engine
  130. gas engine exhaust setup
  131. exceed hyper speed engine upgrade HELP! !!!
  132. glow plug questions
  133. Nitro Star 18ss outlaw crankcase bearings
  134. schumacher menace .21-.28 engine conversion
  135. Need KC-44 Manifold Adapter for Kyosho Vanning
  136. Colt 15 engine replacement
  137. Piston skirt
  138. New Dynamite .19 tuning issues...stuttering/4-stroking on decel
  139. tmaxx 2.5 not running well after easy roll
  140. head gasket product dosages and engine damages
  141. Anyone else leaking at the front bearing?
  142. 3.3 or .26 ??
  143. Engine troubles
  144. RC engine - Fuel not getting to the Engine
  145. Cooling heads
  146. Engine not getting fuel
  147. OS .30vg one way
  148. i need help with a os 18 cv-r.
  149. traxxas easy start conversion
  150. Name this engine and help me find the impossible1!
  151. problem starting smartech engine plz help!!
  152. collari 32 connecting rod ,replacing it?
  153. question
  154. O.S 12TZ 3 port
  155. OFNA Force .32
  156. evo 100 any problems
  157. T-15 Hpi into an RS4
  158. Please, Help Me!!! Problem With My Car Engine
  159. Larger 4 Stroke with a clutch???? Custom car
  160. OS RG problems
