- Nemesis and Genesis tires ?
- Genesis ?'s
- Nemesis Gearing Question
- genesis plastic dive shafts
- MY NEMESIS in race trim with matrix wing
- Replacing piston and sleeve
- running temp
- GPM Aluminum Suspension Parts
- Back and bashin!
- Matrix Wing ?
- Nemesis New Axles Question
- Electric Genesis and Nemesis
- Thanks CEN
- Rear axles and dogbone problems
- HELP PLEASE- genesis differential
- Nemesis in the UK?
- replacement needle
- GST RCCA Exclusive And COVER!!!!!!!!
- How about a Fully Optioned Matrix?
- installing metal brake disk
- CT5 two speed transmission
- ff tuning???
- 2 Speed alloy hub confusion
- Matrix Carbon Fibre Chassis
- wohooo my car is working again
- indestructable
- Help me tune my Matrix
- Genisis drive cups
- Does anyone have a tr4
- CEN owners in NJ?
- Come Race in Texas
- nx76 + mt2=??
- im back and have questions
- Genesis pulling to one side
- Engine
- tiger drive on talon nx
- CT5 Body
- Matrix Update
- MXS20 Aluminum Clutch Shoe Question
- Matrix bodies
- Magnum NX clutch problem
- Question about new body on Genesis
- running temperature and wheel free movement?
- Brake problem
- Cen is this another truck that came up missing
- Titanium parts
- It's all good
- Talon nx
- Removing Gears from Clutch Bell
- Oh no.. Not another!!
- Temps on Matrix
- Roto-Tech Starter
- Nem/Gen New Revised Axles???
- Fuel tank/motor issues.... Again...
- Servo saver spring....
- New Cen Matrix C-1 RTR
- GENESIS or NEMESIS?
- Talon nx 3.0 engine
- Measuring tools
- GX1 call-out
- Nemesis troubles again!
- Engaging 2nd gear... again...
- MOVED: Wheel hex nuts
- MINI MADNESS!!!!!
- K&N air filter
- Bit quiet - what u guys up to?
- genesis diff
- 27MHz FM Crystal Sets
- NT 16 head aches
- Genesis Exhaust / Muffler Question:
- Motor heatsink Screws for Genesis
- Air charged cen shocks
- Team Infinity .18 engine
- hey CEN
- is it me or do revo people think there truck is the greatest
- magnum nx and os 18, no mix?
- Tire question?
- steering on genisis.
- CNC c-hubs Om matrix rtr
- Check Out This Month's Issue OF Radio Control Car Action!!
- GX1 Suspension
- CT 5 Electronic Help!
- Magnum NX?
- After market shocks, Nemesis
- talon nx part ?
- Melted the pull start cord!
- Genesis sleeve
- Rally Tires ???
- You Have Gotta See This!!!
- BAD Cen Genesis LE
- ---> NEW TOOL FOR GENESIS/NEMESIS <---
- Centriforce Clutch on CT5
- Just wondering if this part will be strengthened in the near future? (Matrix)
- Genesis LE Transmission
- Front engine bearing for .26
- Any spur for the CEN MATRIX from another brand?
- who has these on there genny..??
- Could someone please help
- Nx.16 rebuild.
- Genesis Problem :(
- where can i get nemesis shocks?
- Whats This?
- wich one?
- --> AWSOME! CEN Racing Truggy Video!
- Genesis LE torque
- Genesis LE 2nd and 3rd gear settings
- The MX3 for Genesis LE settings (HELP)
- Summer Nitro Fest Results from the FARM II
- Starting Mech.
- Need Parts for Fun Factor
- Snaped the allen screw from the pinion bell
- Genesis transmission
- Hyper 7 clutch and flywheel in a Matrix?
- Best servos on a budget
- It feels nice not to refuel every 8-9minutes
- new trucks and bad tank filter
- One ways cheap fix.
- Tuned pipe question
- CT5 Gearing Ratio ?s
- Genesis temp problems
- Just a CEN observation...Hmmm
- Magnum NX support needed
- Bigger Flywheel in the Matrix?
- genesis problem
- CT5 bigger wheels/tires foam
- Toyhaus- Another good source.
- genesis engine wont start
- Mx-3 radio channel
- My genesis engine temp is more than 450f..
- Are these Broken Parts Covered under warrenty.
- Found a CT5 belt wear problem
- 2 Speed Tranny for buggy/rally
- Fun Factor Subaru Problem
- TMaxx shafts on FunFactor - complete guide!!
- Magnum NX/FF ventilation
- Headrush Hobbies ROCK!!!!
- bought gear and doesn't fit
- Hobao MACH .28 Big Block in a Matrix?
- ****CT5 HELP*****
- FunFactor.. Getting too hot ??
- Magnum NX RTR foam inserts?
- CEN + Customer Support = 100% + Vid of CT5
- **HELP** Genesis 1st/2nd gear removal ?? :-(
- has anyone try these
- .46 Cen engine one way bearing issue
- Fun factor PICS
- Rear belt mod for CT4s
- removing clutch bell stripped screw
- Magnum NX
- Fun Factor (& Magnum?) 2 Speed rebuild/fix help for newbes
- Chassis repair
- How do I install a .28 engine in my Nemesis?
- Tamiya FS-18R V's OS 1.8 CVRX
- Clutch Bell
- Aftermarket header pipe for NX76
- New Lid on CT5
- Novarossi Serpant .12 Motor
- customrccars.com Thank you!
- Silver states?
- Tire Question
- Recomend me a good Matrix engine
- CEN STOCK RX?TX issues
- Genesis Airtronics MX3 Radio upgrade?
- *CEN Matrix Drive Cup Warranty*
- Read this before you start your brand new Genesis\Nemesis
- Gear Question
- FunFactor not selecting 2nd gear
- ???'s about upgraded alum. shock assembly
- Top speed on CEN rally
- Question on CEN's new product
- Forward and reverse gears, teeth numbers!! Help!!
- MOVED: ill handeling xxx t
- Tire offset CT5
- Body size for Fun Factor?
- In the search for more power, .28 ct4s
- Nemesis Engine?
- Boil Graphite parts
- Ceramic clutch bearings
- GS 089 Pinion Gear?
- Gen LE Third Gear ??
- Difference between Talon NX and Magnum NX
- Bashing.. Broken part need help
- Nemesis Top Speed
- AI R FILTER
- GENESIS SUPERCHARGER
- Hey Losmosis
- Genesis 46 - Lots of power but no go!
- Diff recomendations
- CEN
- New GEN LE owner with question??
- Using a Hyper .21 engine in the Matrix?
- TRANS NOT ENGAGING ON GENESIS
- Edited
- NX26 problem...
- Genesis reverse wheelies
- NEED A PART!
- CT5 and the lack of off the line punch
- Nemesis Idling Issue
- Genesis veering right
- Steering help
- Matrix Pro is stepping up
- RGX Matrix Bodies
- Roto Starter problem/Question
- Bout to break-in
- Bad quality screws?
- Ebay Score
- Question
- What size?
- gen/nem owners hsn setting
- Will these fit?....
- Given up with my Cen already...
- Transmitter Question
- Quick question guys!!!!!!!!!
- Matrix Setup
- gear stripped????
- Buggy/Rally Dog Bone Shaft 66
- CEN reccomended engine settings
- MOVED: can you help me plz!
- 4.6 Genesis conversion into CT4S or Magnum NX? Possiable?
- O.S. RG-P .21 in Magnum!
- first cen product
- Wanting and getting!!
- Deals from CEN
- modding engine mount for .28
- Camber and Toe in
- Which Exhast Do You Use??
- cen chassis
- Genesis roto start
- Genesis piston/sleeve
- Update > It runs.. But eating spur gears..
- Run time
- Rotostart on NT-16??
- I think I bought a lemon...
- CEN RCX 2006 Photos
- question for ct5 owners with genesis steel gear
- problems with stock FF controller
- Custom Wheels
- help me
- O.S. .18 Tuning
- New Nemesis 7.7, need some info
- Aftermarket Exhaust Header For NX76???
- Are Ofna Starter boxes compatible with the Matrix?
- nemesis or genisis?
- GeneLE 46 Question?
- first time at the track
- Good Airfilter for the Matrix?
- Congratulations CEN!
- Converting ATX to MT2
- Glow plug temperature ratings?
