PDA
View Full Version : Losi Monster Trucks
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. Issue with Mach 427 and Aftershock
  2. Hub Spacing
  3. noob question?
  4. LST2 rims
  5. options for new diff gears/housing for LST2
  6. new tires and aluminum wheels
  7. LST2 Basher into a RACER!!
  8. Muggy clutch issue..
  9. LRP Z28 SPEC 3 WITH LOSI ROTO START
  10. 1/2 offset or standard offset?
  11. rechargable batteries for ur radio pistol LST2?
  12. Motors for my muggy
  13. rb concept and roto start
  14. LST2 radio question..
  15. Touchy brakes on Aftershock
  16. Need LST2 Starting Help
  17. lst shocks and towers on a mgt
  18. Team Losi has made me a believer. I've turned to the dark side.
  19. thinking about an LST2
  20. mach 427?
  21. Muggy - LST2 Diff Ratios Explained
  22. See what you guys started
  23. My new LST2 :)
  24. any body want this?
  25. Muggy Starter Box Troubles
  26. someone tell me what pipe i should use with my muggy
  27. Aftershock Hex Starter
  28. broken header HELP pic inc
  29. HIGH SPEED GEAR SET
  30. Mega Baja vs. lst 2
  31. muggys screwed up
  32. need help finding a pipe for my muggy
  33. aftershock
  34. Wheels and tires
  35. Time to open up a can of worms....
  36. I am about to get a Aftershock is there anything i need to know?
  37. Which tires are these?
  38. fuel tank
  39. best pipe for aftershock
  40. DIff Oil
  41. Muggy v. Aftershock
  42. Losi & Sportwerks diffs
  43. Steering link hits servos?
  44. Glow Plugs...
  45. What engine next for my lst 2
  46. LST2 Springs
  47. acceptable price for glow plugs?
  48. lst2 or tnx 5.2
  49. Mug this...
  50. glow plug heat range
  51. Aftershock Steering
  52. PROLINE WABASH WHEELS
  53. 7000?
  54. So Im Building A LST2 Racer....THE DAY AFTER THE TRACK
  55. My New 8ight T!!!
  56. IM BACK!!!
  57. clutch shoes worn???
  58. lean machine lst
  59. check out my new lid
  60. Broken Piston Rod.. Less then one gallon
  61. losing power when running
  62. break problem
  63. Just whipped up a new bash-bod...
  64. fast idle on aftershock
  65. my first breakage
  66. so my old man just bought a muggy
  67. in-line transmission
  68. HOW TO JUMP MY LOSI
  69. A LST2 transmission question.
  70. Brake adjustment on Aftershock
  71. need help please....
  72. LST2 parts for Aftershock
  73. Aftermarket Mug bodies?
  74. Muggy or 8ight T
  75. wheels wheels wheels
  76. The Ultimate LST/LST2/Aftershock Body Thread..
  77. my new lst
  78. mud guards for the muggy
  79. Pull Start String
  80. Cleaning...
  81. sluggish ss26 aftershock
  82. LRP spec 3 in my mug
  83. Increased Turning Radius
  84. removing tyre from rim
  85. Aftershock questions
  86. Getting an LST2 (What Upgrades do you Reccomend)
  87. The diffrence between a muggy and a lst2
  88. Steering and brakes
  89. posting
  90. mega baja
  91. TX battery and charger....
  92. Charging 1100 mah rx pack
  93. clutch shoes
  94. aftershock break in
  95. lst2 wing?
  96. more acceleration for aftershock
  97. I GOTS AND IDEAR
  98. bumpers
  99. Lst header problems
  100. Finally
  101. cv joint
  102. spur gear
  103. Best place to buy LST2 parts
  104. Brushless 8ight-T
  105. lets talk clutches
  106. aftershock gots the runs
  107. Which reciever pack?
  108. Would This Body Fit A Team Losi Aftershock?
  109. posting photos
  110. Savage aluminum pipe on aftershock....WOW!
  111. Is this normal?
  112. Aftershock transmission problem....Please help.
  113. Engine swap for the Aftershock?
  114. Test #2: PASSED!
  115. Upgrades needed to make LST2 race ready?
  116. trailers ????
  117. imex truck pull tires..
  118. boggin down
  119. HPI Clutch Shoes For Aftershock
  120. Wheel adapters
  121. clutch shoes
  122. Which bashing tires?
  123. Who owns an lst2 and savage?
  124. Carb Boot?
  125. What Tires and rims for aftershock
  126. FORCE 32 SWAP
  127. Edit---is this the same?
  128. My shoping list!
  129. servo?
  130. Aftershock roll cage
  131. One question?
  132. Anyone ever shorten their HT stinger?
  133. locking the diffs
  134. New pics from Today
  135. Whats a fair price
  136. Excuse my ignorance...
  137. New Body
  138. HAHA
  139. HONG NOR WHEELS ON A LST
  140. LST2 Wing Kit?
  141. STACKS!!!
  142. O! M! G!
  143. WHICH SPRINGS
  144. well i did it...
  145. Lst 2 query
  146. brushless muggy
  147. mini t or zk-2
  148. Muggy or LST2
  149. forward only or reverse ?
  150. More input would be nice
  151. throttle servo
  152. Whats the problem? Video included
  153. JR XS3 Radio - Battery Pack
  154. Best Shock Springs for this setup?
  155. after shock steering problems
  156. .26 rpms
  157. My local track (pics)
  158. after shock shifting troubles
  159. Foward only conversion
  160. sluggish acceleration
  161. Test #1: Failed.
  162. Where is your favorite bashing place?
  163. Hey guys
  164. Pics of my Aftershock with my new LRP
  165. mini aftershock
  166. what are the main improvements
  167. brushless aftershock
  168. Throttle linkage.
  169. did losi ever get their order corrected?
  170. Where to put my RX battery pack??
  171. LST2 Idle
  172. Tuning ????
  173. help please
  174. Air leak?
  175. LST dying
  176. Anyone Know What This Is
  177. LST2 Won't Go
  178. Misson Complete (UPDATE PICS)
  179. Mach .26 Carb
  180. 23mm 40 series Wabash wheels?
  181. Problem with LST2, started before now will not start
  182. what is the cause of the muggy clutch ?
  183. carb swap 427 ?????
  184. xxx-nt rear diff upgrade?
  185. Which failsafe?
  186. new in monster truck hobby
  187. Team Losi Kit???
  188. Got a Muggy Roller on the Way - Need to Bashproof....
  189. Got 'er broken in...
  190. losi 8t wheels on lst2
  191. os 30 engine ?
  192. Tools for LST2
  193. muggy single steering servo
  194. Axial .32 Spec 1????
  195. Tire questions???
  196. What do you own?
  197. Well... I got a little impatient
  198. picks of my Aftershock
  199. muggy bashin
  200. aftershock + new engine= i need help
  201. **Team Losi "Rides" Ratings thread**
  202. LST2 Body Question
  203. some pic's of my losi lst
  204. Which is the best engine for the buck?
  205. xxx-nt engine upgrade
  206. did you know?
  207. Action Shot!!!
  208. A quick question about the LRP
  209. Its Tuning Time
  210. Fail Safes - Which is best...and what do they do
  211. 8ight-t or another truggy?
  212. Best Way to Stop Engine
  213. Axial .28 spec 1
  214. modded sts30....need help please
  215. Racing setups question
  216. New LST2 Engine Runs - but truck won't move - Help Please
  217. mach 427 from a mach 26
  218. Best bang for the buck LST upgrades?
  219. Got my LST2 today
  220. need help ebaying a new losi
  221. LST, REVO, Mugen Box, Exergen
  222. mega baja thread
  223. undecided
  224. whats a better egine to put in
  225. LST, REVO, 8ight-T, 8ight.....
  226. Tanks
  227. Jammin .28
  228. proline body for aftershock???
  229. Muggy bulkhead
  230. LST2 or Muggy
  231. Same Engine???
  232. Run Away Truck.
  233. aftershock need help
  234. upgrading my aftershock!
  235. muggy clutch in a lst
  236. GPS Results
  237. WHICH IS FASTER? YOURS ARE MINE
  238. Revo vs Muggy...
  239. AFTERSHOCK + UPGRADES = LST2 ?
  240. Aftershock Problems
  241. Gear Question
  242. turning problems
  243. stupid question maybe...
  244. just got my LST2.
  245. Differences between Mega Baha & Aftershock
  246. Lets get some pics from everyones rides :D
  247. muggy body for lst
  248. tuned pipes
  249. Bashing lst2 what breaks?
  250. Parts for Aftershock
