PDA
View Full Version : Losi Monster Trucks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. how important is the engine brace?
  2. Help with washers for Proline Wheel Hexes
  3. Loss of top end
  4. Is one of my C-HUB's on backward?
  5. Searching Clutch Shoe Upgrade....
  6. Quieter Exhaust for LST2?
  7. lst2 truggy conversion
  8. integy rollbar / handle or others?
  9. Udairi Speedway, Kuwait
  10. LST2 OUCH !!!!!
  11. looking to buy a lst
  12. LST2 little warehouse for ordinary maintenance
  13. LST2 wing kits are out!
  14. Losing Signal???
  15. Antenna Wire
  16. Traxxas Top Fuel in LST2
  17. Electical Parts Cleaner???
  18. My Basher hittin the launch ramp.
  19. Tire Alignment
  20. sh 28 p-6 question's.
  21. RS300 LST2 Reciever - Question about BEC?
  22. LOSI LAGGING
  23. Interested in the LST2
  24. psycho-tek chassis
  25. Servo protect or NOT
  26. help with slipping owb
  27. TRANNY IS SET AT LOW OR HIGH
  28. friend selling LST
  29. WTH is WRONG !
  30. getting in to raccing
  31. Engine noise on lst2
  32. buy a new engine; what else is needed?
  33. JR Battery Connector.....
  34. LST1 tires
  35. would this motor work in my LST
  36. Blew my LST motor...what can I replace it with
  37. measuring heat on lst2
  38. high idle
  39. LST gears all worn
  40. Aftershock release date?
  41. spur gears?????????????????
  42. Putfile Site......
  43. will the 8ight share the same motor mount setup?
  44. Mach 427 characteristics
  45. upgraded engine
  46. Looking to get a new basher
  47. high torque servo on throttle/break
  48. question about lst2
  49. What is the best clutch shoe?
  50. Should I install a picco 32 in my LST
  51. Saving Bodies.....
  52. Carbon fiber linkage rods
  53. Tuning tips, glow plugs and break-in on the LRP spec 3
  54. How do you pull bearings from a crankcase?
  55. It doesn't want to stop!!!
  56. do you get alot of oil buildup between the engine and fuel tank?
  57. Steering Knuckles/Spindles, Should I upgrade???
  58. spur gear tight, but still has alot of play
  59. team losi fuel
  60. lst adjustments
  61. broke my LST, need help ASAP
  62. I need some shocks
  63. So... what are the top runner up engines ATM?
  64. WHY? Why?
  65. LST hints and tips
  66. upgrade
  67. battery pak for Lst
  68. What did i do wrong???
  69. Plastic Dye
  70. Same day shipping
  71. Carbon fibre chassi plate
  72. Please help:Mach 26 with sportwerks carb/needle settings?
  73. Bulkheads & Differential Retainer
  74. Added more goodies
  75. Reciver In The XXX-NT RTR
  76. LST RACER
  77. more videos from down under !!
  78. Fuel tank dimensions
  79. Some issues with LST2
  80. lst diff
  81. diff screws
  82. slipper clutch
  83. Anybody have a source for conrods cheap?
  84. part # please
  85. DIff Outdrive cups
  86. mach 427
  87. spur loose in LST
  88. Engine Help
  89. My Lst2
  90. Can we make LST turn more?
  91. JR throttle servo failure....
  92. Who else has a picco .28?
  93. Crazy carb issues with my race modded Picco .28
  94. My super lucky crazy deal of the year!
  95. Chronic Overheating
  96. Savage body on LST2
  97. The best way
  98. long weekend in nyc :)
  99. What did I forget?
  100. Hey.. :)
  101. Finally, I Post a Pic of My LST2......
  102. My first LST 2 Racer
  103. Racing LST2
  104. losi mini trucks
  105. Carbon fiber chassis ?'s
  106. Help Please
  107. DRIVELINE????
  108. Maintenance after 1st Gallon
  109. Anybody know if this will fit? I am sick of breaking headers!
  110. Chassis Mods
  111. projet e lst
  112. After market parts
  113. Shipping methods
  114. HH LST wing
  115. Jammin X1 CRT or Team Losi LST2
  116. My new banana chassis. OOPS!
  117. Stomp'en Revo's!
  118. change from 4x4 to 2x4
  119. NOVA TOP owner ATTN
  120. Stuck in first gear??
  121. roto start
  122. Electric LST Project: Pics.
  123. What's Your Top 10 Upgrade List For The LST2???
  124. Brand New LST2 will not prime or start.
  125. Suspension Towers
  126. LST2 steering woes
  127. diff oil
  128. Slipper housing
  129. LST2 carrier/spindle upgrade?
  130. 5x35mm or 5x40mm?
  131. Is it common ?
  132. adjusting the linkage
  133. servo saver question!
  134. stuck in second gear!
  135. Has anyone done this
  136. hex set sizes
  137. To Rich LST
  138. headache!?!
  139. How do you know when it is broke in?
  140. Big Air from the Old Country..
  141. hellfire body
  142. My truck
  143. lungsford question
  144. STS factory settiings
  145. CEN 5HP dropped in an LST2?
  146. mach 26 rebuild question
  147. Best MT???
  148. MODIFIED LST HAVING CVD PIN PROBLEMS
  149. Roling resistance
  150. LST 2 Question
  151. losi hop up parts????
  152. Losi parts and number please
  153. Exhaust for the stock 427
  154. few q's to get my lst running perfect.
  155. LST 2 Shock Caps
  156. Removing Linkage
  157. Team Losi Zombie-Max Monster
  158. Making Rx Packs w/ "AA"s???
  159. 3.2" wheels, are they the standard maxx size?
  160. Slipper setting
  161. Rc
  162. TiNi Gears on LST 2.
  163. Upgrade Rx Battery Pack......
  164. Protecting you Shocks?
  165. SKP mounting
  166. LST 2 videos from down under
  167. Picco .28 electric spin start
  168. 17 MM Hex
  169. I got the shaft! Pun warning.
  170. New Body: "BONZ"
  171. Shimming Diffs...
  172. Losi All The Way.......
  173. New LST2
  174. ROAR 2006 Rules - LST2 Illegal
  175. lst2 wing
  176. trukzilla 4.6?
  177. New lst2
  178. LST Break in help (lost)
  179. 8th scale or 5 th scale
  180. 2dmaxlst sweating???
  181. Im stumped on changing the clutch shoes...
  182. i just want to give a shout out to the guys who take the time help everyone
  183. LST2 EATING MY BATTERY
  184. ENGINE HELP NEEDED PART 2!!!!!!!
  185. well somthing broke........
  186. ENGINE HELP NEEDED!!!!!!!
  187. How many of you enjoy 1/8 scale?
  188. enigne!!!
  189. sts .28 wat do ya think?
  190. Nitro Percentage for Mach 427
  191. Recommend Trans and Diff Fluids/grease
  192. I want to run 2 Rx packs...
  193. Rear Differential
  194. Engine Upgrade with most power?
  195. Momma Approves......
  196. LST2 - Just got
  197. Lookin for some old LST1 - Parts...
  198. lst2 slipper
  199. New LST2 Owner Coming Soon!
  200. Losi
  201. 2nd gear
  202. 427 vs mach .26
  203. I can't wait for the Aftershock!
  204. mach 427
  205. engine question
  206. I keep stripping my PROLINE 23MM adaptors...
  207. stupid ?
  208. Please help
  209. WOW! Mach 427 Has Alot!!!
  210. 2DMaxLST!! .......
  211. Lst2 proline tires
  212. lst engine issues
  213. tell me theres another way to get bumper braces.
  214. Piston locker or flywheel pin wrench?
  215. what are the issue with lst2
  216. Lithium Reciever Battery - Questions...
  217. ****WHICH MONSTER TRUCK PLEASE HELP!!!!!!!!!!!!!!!****
  218. Two Plastic Tools......
  219. strange sound in reverse
  220. PLEASE HELP
  221. Toe-in After BAC Steering Link?
  222. how long des the hp brake pads last?
  223. question on new lst2 engine break in
  224. Some LST questions
  225. clutch bell to tight
  226. ****NEW LOSI AFTERSHOCK!!****
  227. New LST2 pinion gears.....Plastic?
  228. Why does it still move??
  229. Racing lst2 upgrades on medium budget
  230. FFFFFFFFF............!!!!!!!!!!!!!!
  231. New Losi: Aftershock
  232. lst2 engine break in
  233. aftermarket diffs/racing diffs
  234. Mach 26 stalling.
  235. Other headers that might fit?
  236. LST1 for $450? Or just wait for Aftershock?
  237. clicks from the truck under heavy braking?
  238. need some help
  239. this summer
  240. LST2 Spare/Tuning Part Availability?..
  241. LST / LST2
  242. just got lst 2 #003525
  243. Aluminum Spindles for LST2 with full steering articulation?
  244. LST 2 In the sand
  245. After-run Oil procedures?
  246. Complete setup - New Body and Paint!
  247. LST2 with M11???
  248. sportwerks carb w. stock insert? please help
  249. Soft springs front or rear ?
  250. why are motors hard to start after they sit for a while
