PDA
View Full Version : Losi Monster Trucks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. aftermarket diffs/racing diffs
  2. Mach 26 stalling.
  3. Other headers that might fit?
  4. LST1 for $450? Or just wait for Aftershock?
  5. clicks from the truck under heavy braking?
  6. need some help
  7. this summer
  8. LST2 Spare/Tuning Part Availability?..
  9. LST / LST2
  10. just got lst 2 #003525
  11. Aluminum Spindles for LST2 with full steering articulation?
  12. LST 2 In the sand
  13. After-run Oil procedures?
  14. Complete setup - New Body and Paint!
  15. LST2 with M11???
  16. sportwerks carb w. stock insert? please help
  17. Soft springs front or rear ?
  18. why are motors hard to start after they sit for a while
  19. what is this for?
  20. Sirio 30 in my LST1, What gearing?
  21. Where can I buy me a new Losi
  22. pipe?
  23. mlst
  24. integy piggy backs?
  25. Engine damaged??
  26. Orion Clutch- Motor Mounts, and Sleeved Bell
  27. Lunsford turnbuckles for RPM arms, 35 or 40 mm?
  28. will aftershock hurt the revo 3.3 sales
  29. The Unofficial Team Losi Aftershock Thread
  30. 2003 Hummer ppg auto paint on lst (pic)
  31. Need Servo Help
  32. I got the clicks ???
  33. how tough is ur LST ? :)
  34. aluminum shock towers
  35. ti ni spur gear ?
  36. Bad race run today, need tire help, confused !
  37. do you like my lst i just bought off ebay?
  38. tuning help
  39. Carbon fiber upper deck
  40. LRP - SF - Collari
  41. Strange Driveline binding
  42. NEW LST2 DIFF PROB
  43. lst or lst2 kits?
  44. new to losi & lst2
  45. Lst moves again?
  46. lst2 exhaust seal
  47. Quick question
  48. Are the MIP clutch shoes out yet or what?
  49. JR Z9000T......
  50. wow so my front diff is toast and I had no clue
  51. Raw Power 2
  52. Losi AFTERSHOCK thread.
  53. New Losi monster truck...
  54. Lst1 bearings
  55. New LST2, Got Problem I think???
  56. Raw Power wanted
  57. Whaaa why do my wheels fall off?
  58. help :(
  59. how often do you replace your brake pads?
  60. Best Hop-Ups to make my LST2 the ultimate basher?
  61. Clutch Bell Not Spinning
  62. proline crimefighters and 420 rims, dyed, mounted, and lookin good
  63. Tires, Wheels, and Adapters.....
  64. Batteries......
  65. Hardened bevel gears?
  66. Battery Pack for my JR
  67. new toy
  68. Any chance of objective feedback??...
  69. Sportwerks Carb, need a bigger cooling head?
  70. Sway Bars........
  71. what the heck glue am I supposed to glue tires with?
  72. Front Diff......
  73. ribbed Pipe
  74. What not to wear at a major race event
  75. starting lst2
  76. Axial .32, do you leave the stock copper piece or the Axial piece?
  77. Turning the carb.
  78. 1
  79. lst2 pipe
  80. Post next 5 words to make funny story.
  81. truck keeps stalling.
  82. Clutch bell screw for the Axial .32
  83. Need Help: Wheel hex damage (pic)
  84. Does anybody use Beadlock wheels?
  85. Need some shocks
  86. Crime fighters Vs. Bow Ties
  87. Lipos in the receiver comparment, now what!
  88. tell me what you think
  89. LST 2 Engine Temps
  90. how do you shut off your engine?
  91. Will these fit....??
  92. Bodys for LST
  93. takes off slow
  94. unsteady idle problem
  95. tyres
  96. Rod Ends and Pivot Balls
  97. lst2 FOC
  98. How long should a glow plug last for????
  99. Diff Upgrade Time.....
  100. Are LST2's as good as they look on videos?..
  101. Charging my TX batteries.. in the radio?
  102. I swear when I woke up this morning I didnt need anything for my truck...
  103. Revo 3.3 vs. LST2? I know you hate this!
  104. f/r shift fork
  105. Imex Baja Maxx Tire
  106. Do you replace or rebuild engine?
  107. Rear End
  108. New lst2 product
  109. LST racer body with flames!
  110. tranny prob....
  111. I lost reverse
  112. K&N
  113. Steering servos just quit.PLEASE HELP
  114. Clutch Bell Binds against something! Help.
  115. Is Losi getting more popular?
  116. Flywheel
  117. Who has LiPos in their LST?
  118. Fighting servo question?
  119. Clutch Shoes for Tini Gears
  120. Where was the site for LST2's cheap?
  121. Need Assistance with Drive Drain Problem
  122. starter issue
  123. RE .32 killing my diffs.....solution?
  124. Click, Click, Click, While Braking and Turning Right.....
  125. **Mach 427 please help?**
  126. Bodies?
  127. LST2 missing all the diff bevel gear shim.
  128. steering servo upgrade
  129. How do you turn the Axial .32 carburetor around?
  130. Clutch shoe suppose to look like this?
  131. will this glow plug work
  132. Just got a new engine - Question about operation
  133. What li-po fits?
  134. alittle help deciding guys
  135. pullstart?
  136. air filter oil. how do you use it?
  137. HELP FAST
  138. C Clip Tool
  139. Newbi
  140. hi-lo knob is broke
  141. little brass bushing - where does it go?
  142. Mach Trouble
  143. lrp.28 it is
  144. ROLL BAR
  145. crystals
  146. LST Wing
  147. axail.28 or lrp.28
  148. Help Me!
  149. lst pics
  150. mid to high end tuning help
  151. LST SHOCKS?
  152. Idle......
  153. Closed the deal
  154. New LST body
  155. Best Engine
  156. strange sound from car
  157. Holshot carbon fiber?
  158. My newly rebuilt LST2
  159. axial 28
  160. What plug for Picco .28?
  161. Torque steer
  162. OS 30VG engine
  163. HPI Nitro Star K4.6 HO in a LST?
  164. diff grease/ tranny
  165. LST2 getten Hot
  166. Secondary gear cover & FOC
  167. losi instructions strike again: how do you install the sway bar kit?
  168. steering problem on a lst2
  169. LST2 gettin waxed by tmax
  170. Bigger carb suggestions for .26 engine
  171. mini lst
  172. sts.d28m question ?
  173. dyeing rims with the tires
  174. LST 2 CV Driveshafts
  175. Starting the LST - What RPM do I need?
  176. Weird Probelm
  177. What would you offer?
  178. which is a better buy
  179. wich is a better buy
  180. where to buy
  181. whats a better truck
  182. Steering servo savers.
  183. team losi lst2 engine problem
  184. and one more.
  185. another small video
  186. whattya think?-LOTS of pics, don't bother if you're on dialup
  187. why i should get a lst
  188. ugliest
  189. Needing fello rc guys opinion
  190. changed my tire question. best tire type and reducing weight?
  191. Recommend a Quality Failsafe Unit for LST2
  192. Want new engine, what is my best option???
  193. HOW MANY GALLONS??
  194. Stripping chrome off from wheels?
  195. LST burning glow plugs, can't figure this out!
  196. O.S .30 VG in LST
  197. Easiest Way To Get Steering Servos Out?
  198. me-0; you all-1
  199. Broken Diff Retainer - No Where to Get the Part!
  200. steering
  201. This might not be new, and its not for the LST [:@]
  202. Tiny Screws On Skidplate!!!
  203. What breaks the most on LST2
  204. Help!! Air leak
  205. LST2 on Track!!!
  206. 2nd Gear Too Quick!
  207. i want another nitro rc
  208. Stronger Steering Servos?
  209. new lst owner needing a lil advice
  210. LST or LST2?
  211. New Losi LST - Engine Question
  212. anybody considering 1/5 scale mowery truck
  213. That ad you see above this forum THEY SUCK!
  214. Black Losi Springs, Oil weight...
  215. check out my paint job
  216. speed up
  217. Any setting up tips or problems i need 2 know before buying LST2?
  218. Clutch Bell for Tini Gears: Need Clarification
  219. High Speed Gear Set??
  220. Installing TiNi Gears: Need Help with Circlip
  221. LST WITH PICO 27 CVD PROBLEMS
  222. RPM A-arm adapter kit for the Losi LST 2
  223. CV Shaft
  224. Need info on motors that dont fit...
  225. attempt to post video
  226. Need clutch help.
  227. How wide is the Losi body and chassis? Non-Losi owner asking.
  228. LST2 WHEEL UPGRADES
  229. Cold Blooded, Why?
  230. Spare parts for LST2
  231. Where does the battery box go???
  232. pull start or roto start
  233. starts, idles, goes, dies...
  234. weird tuning problem please help?
  235. Has anyone cryo'd the clutch yet?
  236. Anyone used Team Orion CRF V6 adjustable clutch?
  237. Losi Parts House
  238. LST2 wheel hexes found
  239. Race Results ?
  240. LPR Z.28R Spec 2 Power?
  241. Need Help Installing Crime Fighters
  242. LST2 trans problem
  243. Saving up for LST2
  244. Operation: Race build LST2 #000599
  245. engine ever die and carb bubble with fuel?
  246. Truck Rolls When I Fire It Up!!!
  247. cvd
  248. tranny
  249. cleaning 427 motor
  250. LST gets a new mill and clutch
