View Full Version : Losi Monster Trucks
- It's about time
- wheels dont want to spin, any ideas?
- Installing HP brake pads LST?
- how to clean your truck???
- Diff Replacement, Quick Question
- The MAch .26 Engine? how do you guys like it?
- Hi guys...I just tried
- Engine Runs only sometimes w/o Igniter
- gear cover= chewed gears????
- clutch removal
- tires and rims??
- This truck is just flat out crazy!
- Problems shifting in and out of reverse
- muffler
- up grade suggestions and help????
- upgrade muffer & header pipes???
- Rollcage?
- RACE VIDEOS, PLEASE!!!
- Higher end radios
- first paint job
- Drake Wins NitroMaxx Challenge
- Steering prob..
- How to tell if engine is stopped at BDC?
- Collari v.s. Mach ???
- Hmmm...4 wheel steering??
- one way BEARING!!!!!
- Snapped Trans Output Shaft...
- glow plug burn out
- SHOW LST LINK VIDEOS, PLEASE!!!
- JR XS3 RADIO
- Broken RearArm..
- WHAT ARE SOME GOOD HOP UPS FOR LST
- Hump Pack
- gearing
- Help with LST batteries
- Titanium A-Arms!!
- Emissivity Setting
- Help from Spain
- Missing plate?
- Duckt tape in tires??
- LOSB3505 pin failure
- something about the temp.
- bashin engine?
- Losi Super King Pins
- Fuel Filter removed
- biggest roto start mah to fit
- How do you remove the steering servos?
- Wish me LUCK (Washer killed #000741)
- Cheaper steel gears?
- Good bye LST
- LST serial number significance
- I think I've been ripped, what can I do?
- eBay LST disappointment.
- Transmission Hi/Lo Not Staying Put
- Crank Case Stripped???
- Broken dif cases
- Best price on Losi LST?
- Race setup for the LST (tires mainly)
- Glow Plug remote ignition?
- Proline 23mm hex hubs
- slipper clutch thrust bearing
- Glow Plugs
- What else should i get?
- Which tires?
- RPM arms in stock at Tower
- fuel type
- Mach .26, Can't tune!! Overheats!!
- Possible Reciever Failure
- After break-in
- Finally!!!!!
- SH 28 clutch issue
- Shop Sticky?
- Dilemma
- Starting Problem
- help!!! input for locking diffs.
- Temp Gauge on Venom!
- Hesitation running down hill. Why??
- K&N Air Filter
- Beach Truckin
- #012715.... goes to ME!
- Out of anwsers and need help!!!!!!
- alloy hubs
- Way too much brake and no wheelies?
- Will this Rim/Tire Work?
- mach and xtm pro=same engines???
- difference between 2 n 4 stroke?
- RCX Expo
- Losi Super King Pins on 40 series?
- Gearbox Shim Set
- Im sorry Horizon hobby!
- sportswerks carburater
- lower suspension arm
- SKID PLATE??
- Rims?
- Set of RPM arms for $101.00!!!!!!!!!!!!
- Glow Plug Question
- carbob fiber chassis
- HARDENED STEEL PINIONS
- venom racing smart temp monitor
- Setup sheets??
- LST vs REVO
- revo!!! ha thats nothing!!
- Had to paint a new one.....
- Mach = destroyed
- Durability of the plastic
- oh_my_god...
- single servo?
- overheating please help
- New LST owner
- Threaded shock bodies... Losi vs. Hot Racing
- LEMON No 9521
- Diff Case Retainer
- setting your LSN
- Help removing spur gear circlip/ clutch problems
- THE BIG DOG EATS!!!!!!!
- had to change
- brts
- Adjusting the RPM arms
- shift into reverse
- rd logics pipe
- FIX FOR DYNAMITE ALUMINUM STEERING CONVERSION
- Breakages
- No. 14509 nearly ready to roll
- LST Braking
- Need new rims
- pros/cons of lst
- See my LST-dirtjump
- Half Shafts and Centre Shaft upgrade!!
- Yep, lots of A-Arms
- Losi LST Dish Wheels
- Testimony to the RPMs
- Lithium Polymer receiver packs???
- Venom Smart Temp.
- Diff Oil thickness for LST racing and bashing
- i
- i
- LST spring colors. What do they mean?
- Project: Race Losi LST (Article)
- new design Lst skid plate on ebay
- Reciever Range!
- What diff oil should i use for wheelies?
- UK LST on ebay
- A question on the High Capacity Tank
- I got her Dirty!!
- LST made the front page.....
- zombie-max opinions?
- jeep body
- crowd pleaser body saver?
- help please
- RPM a=arms in stock???
- Best temperature for motor
- Sway Bars?
- New LST Owner Sticky!
- before and after
- I finally decide to buy a LST Truck!
- LST Pics
- Ok I bought one
- BROKE BOTH FRONT AND REAR DIFFS LST!!!
- FINALLY GOT THE LST BACK TOGETHER
- Glow Plugs?
- better lst brks
- How do you convert the SH 28 to a Roto start type starter
- LST: Race or bash?
- Psycho-Tek LST Upper Chassis Set - Carbon Fiber
- WHAT'S THE BEST LST CLUTCH?
- WARNING! don't let your Daughter paint your truck
- jammin jp1
- problems starting lst help needed?
- Was having fun, until.......
- LST rpm a-arms or aluminum
- what is the best replacment engine
- Savage 25 vs. LST?
- Monster Bash! READ!
- Mr BillUp's LST!
- New paint jobs finished
- steering servos upgrade
- whorarizon hobby=poor customer service!
- Yet again, a broken output shaft.
- Are you happy with the stock .26? JR Radio?
- shock rise
- Mach .26 pullstart
- Sometimes I scare myself...
- On the menu tonight - roast slipper clutch
- Yip Yip Yippee!!
- Broken Clutch
- hot racing shocks??? anyone....?
- LST on it's way
- Has anyone built an LST from the ground up?
- LST Mach .26 Stock Compression?
- Setting up the LST to Work With the 3PK
- LST Engine doesnt run without glowstarter...
- Secondary Gear Cover
- New Era Skid Plates
- New Sirio .30
- CPU Heat Sensitive Paste!
- Video
- Weight distribution
- nomadio radio
- LST ENGINE GETS WARM AIR DEVELOPS IN FUEL LINE ENGNE STALLS
- hopfully not a stupid question
- Losi or HPI
- Hassle
- What are the lightest rims and tires for the LST?
- Lst has to go
- Get them while they last!
- LST, 5 Cell Battery
- failsafe wont bake LST?
- Clutch springs
- Steering Servos
- RPM Arms Install(ed)
- .50 did the unthinkable
- Anyone know if U can Dye white 40seri-Dish
- LST Overrev!
- LST on the way!
- Help- brand new lst reving by itself
- DIRTFIGHTER INTAKE
- is it worth it to change to diff fluid?
- King pins review
- Real Sluggish Hole-Shot....everything else okay.
- Second gear spur problems
- Tini Gears on Ebay LOSB3428
- .46 in lst
- output shaft
- LOSI LST BROKEN ROD
- is smaller Better?
- Axle pins....snap
- cooling head for sportwerks?
- Engine Died, What Now?
- Trying to cut weight ...
- LST Strengths
- Cleaning solution
- F.O.T.C ?
- Racer Body Glo Plug Ignitor?
- engine stalls everytime i refill it...(help)
- just wanna get this right b4 i attempt...
- gearing up the lst for sport traxx tires
- Nova .28 3 port Carb help?!!!
- Why does my LST make this noise?
- Motor Temp
- fsdfdsfsadgfg
- collari .30 fuel!!!!!!
- How do I? Removing LST's reverse&Low
- how many gallons have you ran in your lst
- Just scored me an LST!!!!!
- Sporwerks Carb..and other ?
- using a motor saver filter
- so what is your final high-speed needle setting
