PDA
View Full Version : Losi Monster Trucks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34
  1. are there other spur gears and clutch bells availabale for the LST???
  2. white lightning fuel
  3. Rotor start not cranking
  4. Video size????
  5. First day out bashing today. And first repair required.
  6. What do I need??? Broken everything$$$$
  7. Radios
  8. Were is the best place to get new clutch shoes from
  9. best spring/oil combo lst bashing/jumping
  10. lst rollbar/skid plate
  11. Proline Dish 40's with bowties
  12. NEW MEMBER new lst took the washer out truck 9362
  13. Anyone order O'Donnell 20% from Microtech Racing and ...
  14. ok run lst with only three shocks??¿¿
  15. Harper Adams in the UK
  16. New LST
  17. Flywheel help needed
  18. Bashmaster
  19. some random wheel/tire weights
  20. newbie tunning ?
  21. crankshaft screw
  22. Billet Differentials for Spider Gears?
  23. Pro-line F350
  24. My motor locked up HELP
  25. HAS ANYONE BOUGHT THIS???
  26. What shock covers available?
  27. tire foam inserts
  28. LST Standard Hub Size?
  29. BOYZ -- 9365 is HOME !!!!
  30. roll bar
  31. Got MY High Capacity Tank
  32. IMEX K-ROCK tires
  33. Wish List
  34. Alum Diff?
  35. Grinding Noise...
  36. what FAILSAFE is everyone using???
  37. Pull start
  38. Team Losi LST hopups
  39. can you believe this
  40. I Finally Got My Own LST LOL
  41. 2nd batt back (hump)
  42. Tiger Drive?
  43. Shift??????????
  44. Gearbox whine
  45. HELP Required
  46. Does your LST pop wheelies?
  47. What Hop-up to buy to protect steering servo's.
  48. LST starting problem_____HELP MEEE
  49. Broke in Half
  50. Newbie Here !!!!!!
  51. Lst #11685 has arrived
  52. Newby With Tuning ?
  53. new wheels
  54. Car Stand
  55. Clutch
  56. port and polish?
  57. Cool Hauler
  58. one for the uk guys
  59. LST Model Number
  60. Anyone?
  61. SH .28 owners!! I Need help!
  62. help needed with secondary gear cover
  63. What`s the biggest "Badass" motor for LST!
  64. Looking for a Track in the Chicago Area
  65. Charging the onlybatterypacks.com batteries
  66. wheels
  67. some Questions
  68. Gearbox problem, Gear change and reverse
  69. Thoughts on why the diffs are cracking
  70. Need some more advice ......
  71. Is there a correct direction for clutch shoes?
  72. Radio Signal just failed, but ...
  73. wheel nuts for mip cvds
  74. 6 tanks and a washer
  75. Contents of the LST box
  76. Best Glow Plug
  77. 23 mm hex velocity/bowtie combo
  78. What is the correct torque setting for this locking nut?
  79. is anyone using the 1200 mah hpi humppack??
  80. My LST just gave way?
  81. screws
  82. Losi starter question
  83. Happy New Year
  84. Orion .28 installed
  85. LST gremlins
  86. Brake end-limit won't go beyond "50" ?
  87. Holy Cow, I just bought an LST.
  88. Newby!
  89. fun with cameras
  90. is this a good deal?
  91. Bow Ties and SPEED
  92. Anyone using new Losi clutch springs?
  93. High Capacity fuel tank LST installed!!
  94. High performance brake kit installed.
  95. under armor
  96. gear gaurd
  97. Help with Charger Selection
  98. NEW LID FOR MY LOSI!
  99. New LST Racer Body
  100. CRCRC Indoor Gas Champs
  101. crazy nut brake help
  102. Try this..spin the tranny shaft without the spurs /slipper on
  103. Break in problems
  104. Diff Help???? Please...(Nevermind)
  105. where to get all the good gear?
  106. Brake modification (cure for chatter)
  107. problems on break in...i thought this was durable!?!
  108. Questions from new LST owner
  109. Brake Question
  110. new lst on the block
  111. Sportwerks .26/Mach .26
  112. servo question
  113. removing low speed gears
  114. 2 speed slipper - help!
  115. Clicking Noise
  116. Big Newbie Question
  117. CEN Genesis wheels on LST
  118. wheel problems
  119. Lst body in the bodyshop
  120. Hot racing or New era aluminum A-arms
  121. Losi LST for a K2
  122. Street Setup?
  123. How can I tell if the washer done me in?
  124. turned out ok.
  125. Reading my glow plug
  126. Sportwerks carb
  127. web site
  128. Flooded Engine?
  129. any one seen this?
  130. receiver wire
  131. onlybatteries.com wires too short?
  132. can i use a drill
  133. Tougher Chassis Side rails?
  134. Glow plugs?
  135. Off Road Race Setups
  136. losi bead lock rims
  137. steel 2-speed convertion
  138. Can't select Lo range
  139. HELP!!!
  140. Is this pinion/spur alignment normal?
  141. bunp starts?
  142. Wow (i need help)
  143. Masking link?
  144. I have some movies, anyone post for me?
  145. temp problems again :(
  146. Rough Start
  147. Y does my losi
  148. New RC club and track in the Pittsburgh area
  149. Who has best Alum A-Arms?
  150. quick question
  151. what oil for the diffs
  152. LST under $500 Delivered!!!
  153. clutch and tranny question..
  154. Wheelstands
  155. Alum diff cases
  156. OH NO!!!!!!!!!!!!!!!!11
  157. Snow!!
  158. No Laughing!!!
  159. Mach 26 pullstart
  160. Want to buy set of LST shocks
  161. does anyone know?
  162. Main tranny shaft update????
  163. Polishing the pipe
  164. Hexes
  165. Two easy-to-answer questions...
  166. How do you
  167. Who has alum diff cases in stock?
  168. HOP UPS
  169. engine removal/servicing
  170. Why does the diff case break anyway?
  171. Merry Christmas
  172. No Reverse/low range conversion
  173. Bow Tie 40 Vs. BRT1
  174. plastic gear cover or aluminum gear cover
  175. New body for New Year!
  176. New owner of LST #9302 !!!
  177. Turnbuckles/Lunsfords
  178. Clutch
  179. Tranny in Somthing else?
  180. New LST owner..some questions
  181. Part numbers plz
  182. Clutch follow up
  183. 1st time out shock problem
  184. duel receiver pack question
  185. Another LST VS Savage vs MGT weekend
  186. My Diff Case broke...
  187. Ever notice this???(washer deal)
  188. Temp gauge
  189. Fuel Tank Bubbles
  190. Throttle/Brake Linkage
  191. high temp problems
  192. Aluminum Diff Cover Install Question
  193. CVD Kit?
  194. willl Monster GT Clutch shoes fit the LST?
  195. Warhead
  196. PDF of Manual
  197. HPI Bodies on LST
  198. Having a look at the LST :)
  199. first LST hop-ups for $100.00
  200. Hot Bodies Keep Breaking
  201. clutch bell question
  202. Wear And Tear
  203. I bought some parts
  204. maybe buying a lst
  205. Heat Gun Heaven
  206. I've given these guys plenty of time to redeem themselves.
  207. 30% Nitro?
  208. Road Tyres
  209. Removing striped head screws...
  210. Who all has the Sportwerks Carb
  211. Aluminum a-arms?
  212. Titanium Trans shaft
  213. Another 6 tanks
  214. 27Mhz to 75Mhz swap
  215. Bit of Fun
  216. Digital servo's buzzing
  217. It lives but it fought me tooth and nail
  218. Blue Roll Bar on LST
  219. Novarossi .28 3-Port
  220. Yet another new LST owner, and a noob in the RC market.
  221. Diff setup
  222. i've found out what it was
  223. Effective Brake Setup
  224. Another new owner - #8296
  225. JR XS3 Manual
  226. Got my LST, questions
  227. servo ups?
  228. Got to work on the LST before Christmas
  229. 2nd gear shift point
  230. Breaking In
  231. New problem - Gremlins again
  232. Clutch shoe/springs questions
  233. Transmitter Frame Rate
  234. What next
  235. power issues???
  236. Fuel mess
  237. LST got a lil brother last night
  238. JR Servos
  239. Got my LST yesterday!!!!!!!!!!!!!!
  240. Fuel Filter
  241. break issues
  242. Meats on sale!
  243. Ordered New LST now I have questions
  244. I got my new truck
  245. Collari LC30MT Monster truck motor!
  246. Onboard Video Camera
  247. Shock oil for these pigs
  248. Reason why CVDs break
  249. USE a washer!!!!
  250. Clutch ponder
