PDA
View Full Version : Losi Monster Trucks
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. LST2 bent Chassis. Which Rails to use?
  2. lst running problem
  3. Losi 454 or Lrp Zr.30 spec 2
  4. LST Mach 26 Temp, Car cleaning
  5. anybody run in beach sand(lst2)
  6. LST2 Clutchbell...!
  7. LST2 - Throttle servo problem
  8. rpm arms
  9. Muggy Pics
  10. Raminator vs Lst2
  11. Anybody Run Muggy Shocks on LST2??
  12. tuning the low end
  13. Strange clicking noise...
  14. Bought a used LST2 on eBay - what you think?
  15. Need some advice on Futaba 2.4 VS DX3S Spektrum radio
  16. Spinstart or puller cord not engaging
  17. Parts Interchangeable?
  18. lst intervention
  19. diff pins
  20. LRP LSN adjustment
  21. NEW Aftershock Issues
  22. Come on. . Another XXL Mishap!!!
  23. looking for a set of Losi Claw MT's
  24. Ramminator Nitro Receiver Pack
  25. No low end on lst
  26. New Body For the Mugg
  27. quick question
  28. One way bearing Aftershock
  29. Losi XXL take New era roll bar
  30. how much
  31. family stickers
  32. sway bars
  33. Mach 427 vs Lrp 28?
  34. Newbbie needs help w/clutch shoe
  35. Got myself a roller...
  36. building a LST2
  37. Where do you spend the most time working on your Losi?
  38. Losi XXL Body Mount Posts
  39. Diff fluid
  40. Losi XXL Update 52 MPH!!!!! How fast are You?
  41. Shock mount spacers.
  42. MC 59 glow plug and LRP
  43. dx3s dsm
  44. LST/LST2/Muggy/Aftershock Dyeable RPM arms - Group Buy Interest?
  45. SOME SUNDAY FUN
  46. aftershock problem
  47. New Losi Eight-t 2.0 RTR
  48. Dead LRP 30 after 14 tanks. WHY ME!
  49. Eight-t wheels and tires on a LST
  50. Tonight's work.
  51. rc raven
  52. New XXL Body! What do you think! ;)
  53. xxl owner question
  54. ANyone have a homemade wheely bar?
  55. Is there a shock tower to mod my LST2 towers?
  56. xxl wheels on aftershock ?
  57. new lrp 30 for xxl
  58. Lowering LST2 ride height. What's needed?
  59. Blew it up real good
  60. Suggestions on jumping
  61. Losi Aftershock engine dies
  62. funny
  63. LST wheels/tires
  64. Firestone Tire Recall on Losi LST XXL
  65. LST xxl Question
  66. looking for the zig zag body...
  67. losi raminator steering servos
  68. Back plate/Spin start bearing sizes?
  69. need some pics or help please lst2
  70. something funny
  71. Grub screw sizes?
  72. Aluminum Fuel tank??
  73. Where to buy bushings - oil, plain etc.
  74. ATTENTION ALL XXL OWNERS
  75. Anyone have feedback on the Mini Desert Truck?
  76. waterproof steering servo
  77. Bets pipe for LST2?
  78. Will these glow plugs work?
  79. XXL Diffs blowing - Time to upgrade
  80. Aftershock Starting
  81. keep breaking axle
  82. difference in ring and pinion?
  83. homemade roll cage/roll bar ?
  84. Removing tire from wheel that are glued?
  85. New to RC...
  86. new clutch?
  87. aftershock bashing tire
  88. Weekend bashing only, When is a nitro truck not covered under warranty and consider wear-and-tear?
  89. raminator pipe
  90. XXL/LST/Muggy/Aftershock - What clutch do you run?
  91. Check out my LRP at 1.5 gallons...
  92. My solution to bad stock aftershock breaks with out buying parts!
  93. Confused on shock caps
  94. Exact parts need to convert Losi Aftershock 2spd
  95. LST 2 forward only conversion kit
  96. LST XXL body structure?
  97. Aftershock tranny??
  98. losi fuel tank mod
  99. losi raminator
  100. aftershock brakes
  101. Need carb ideas.
  102. Is the XXL, ht pipe the same as the lst2 ht?
  103. bumper brace on AFT
  104. Why only one review of the XXL???
  105. NEW LOSI CAR/TRUCK!!!?????
  106. Ok, so I am really tempted to buy an Axial 28rr
  107. oouch
  108. LST2 discontinued
  109. LST2 and Savage XSS Jumps..
  110. Losi High Roller issues
  111. piston and sleeve
  112. new stuff
  113. From your experience who has the best Customer support?
  114. LST2 Servo Upgrade Options
  115. strange problem
  116. clutch bell
  117. sway bar
  118. Aftershock questions..
  119. LRP 30 - It's here, any takers?!
  120. Best Charger???
  121. New Era Roll Bar on XXL - It fits!
  122. muggy ?
  123. Engine stops after glow igniter is removed.
  124. Convert LST to LST 2 or RPM arms?
  125. Question about the gold upgrade shocks for the aftershock
  126. tranny gear upgrade
  127. LST2 Brake problems
  128. wILL THE XXL STEERING SERVOS WORK IN AN LST2?
  129. brake adjustment
  130. aftershock 2 speed problems
  131. WARNING DON'T FIX LST XXL DX3S Scroll Button Repair NO GOOD!!!!
  132. Brushless Aftershock/LST Brushless Conversions?
  133. Can you use an 8-T fuel tank on a Muggy?
  134. nitro storage
  135. battery
  136. Not happy with JST Connectors.
  137. couple of tire/wheel questions.
  138. xxl question for xxl owners
  139. ANyone know the size of these bolts? Eng. mount
  140. RPM LST upper arms, what Lunsford replacement?
  141. best Monster truck???
  142. Will savage clutch shoes n springs work?
  143. fuel problemes.
  144. Ofna Plugs in LRP/Mach?
  145. steering servos
  146. LRP 30 for XXL - Available in 2.5 weeks.
  147. Where can I get an awesome price on an LRP???
  148. which antenna
  149. XXL Throttle Linkage and Brake pic.
  150. engine for my After Shock/ mega baja
  151. Changing fuel thanks to the hobby store
  152. XXL Question
  153. Muggy single piece engine mount extra screw holes?
  154. Do I have a Lst?
  155. Monster MT -XTM- wont shift gears
  156. Can someone recomend shock oil weight.
  157. Lst2 tranny in aftershock?
  158. Best Steering for LST
  159. replacement disk and pad for AFT
  160. Making me MAD!!!
  161. aftershock differential
  162. Prices ?
  163. Muggy Setups Thread
  164. lst 1 help
  165. Does this air filter suck?
  166. LRP 28 or Mach 454
  167. NO BRAKES OR 4WD!!! HELP
  168. tranny grease
  169. New LST XXL Question and Comments
  170. Just Installed My new LRP
  171. LST XXL owners, check your failsafe....
  172. cracked tranny case
  173. reciever battery
  174. sportwerks carb in lst2
  175. weak body
  176. picco .27 in a lst2
  177. Need Advice? LST2 LST XXL
  178. Quick Help Please
  179. RDlogic high performance exhaust for LST
  180. New Era Roll Bar - where do I buy it?
  181. STS 30 Problems
  182. LRP 28 vs. Picco 28 P3
  183. What good, inexpensive 1/8 starter box for Muggy?
  184. Steering Setup
  185. First pics of LST XXL!
  186. Just recieved my XXL
  187. Higher than normal idle revs?
  188. Can I use the Mach 427's spinstart backplate on a LRP Z.28r truggy version?
  189. Aftershock snowblind in baltimore 3/2/09
  190. LST2 best clutch shoes
  191. LST2/XXL RD Logics Twin Exhaust
  192. aftershock stays reved up
  193. Where to get lRP z.28R NPS cheapest?
  194. Do rc companys fix known probs?
  195. Fly Wheel/Piston stuck at top dead center?
  196. any one run their xxl yet
  197. I need help.
  198. LRP Z.28R vs. Mach 454
  199. CHEAP!!!!!!!!!!!!
  200. XXL Comes Friday! What should I do to it?
  201. AFTERSHOCK SERVOS
  202. How to prep/prepare your tires?
  203. Muggy goes out of control
  204. Its Not the OneWay bearing....
  205. hump pack
  206. AFTERSHOCK
  207. glow starter
  208. aftershock clutch
  209. does a air leak make sense?
  210. Lunsford Part #? for RPM A-arms?
  211. LST2 clutch springs- somthing softer?
  212. aftershock transmission
  213. What after-market tires are you running?
  214. Receiver batteries, who has more than one?
  215. Muggy clutch bearings.
  216. aftershock
  217. Muggy: enough with stripped hex screws ... flat screwdriver kit?
  218. E lst2 batteries
  219. are muggy shocks?
  220. does anybody know
  221. Bad Horsie or Outwears shock covers?
  222. Updated pics of your Losi Monsters
  223. AFT crunshing sound when applying brakes
  224. TRANNY HELP
  225. new lrp spec 3 question???
  226. Have LST2-what to get next 8 buggy or Truggy?
  227. Roll bar for Aftershock?
  228. Thinking of Building a Racer..
  229. LST2 Titanium gear question/ newbie
  230. My LST2 vs My Savage X 4.6SS
  231. Losi 8 brushless setup
  232. MUGGY EXTREME
  233. MmMmMmMmMuggy!!!!!!!!!!!!!!!!!!!!!!!!!
  234. thinking of getting a new engine for my shock
  235. replacement to Losi pullstart/roto start?
  236. Roll cage / Handle
  237. I got a Losi muggy today... What parts to buy for smaller wheels/tires?
  238. aftershock with HPI aluminium polished tuned pipe
  239. lst axle problems
  240. Different Losi Pipes....?
  241. Suspension height in LST2?
  242. Muggy Diff noise.
  243. aftershock pull start to spin start converion instructions
  244. Painting bodies ?
  245. rpm a-arms???
  246. RPM A-arms
  247. LST to LST2
  248. Where can I find and buy a LST2??
  249. what exhaust
  250. truck comparison
