PDA
View Full Version : Losi Monster Trucks
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
  1. Getting my first Losi...
  2. Engine Ideas
  3. Raminator
  4. new lst2
  5. lst shifting problems
  6. Mini LST 2 Steering problems
  7. integy lst shock query
  8. About Aftershock wing...
  9. Pinion size for LST2 with 40 series
  10. Am I missing anything? Some Ideas for bashproofing....
  11. New LST2, no go...stuck in 'neutral' ??
  12. used LST2
  13. LST2 is the king
  14. What Glow Plug?
  15. Engine question
  16. More Aftershock upgrade suggestions
  17. Engine brace screws
  18. play in my Spur gear/shaft
  19. Which pipe for the 427?
  20. Newbe Question
  21. a couple muggy questions
  22. Fuel question
  23. Running the Muggy on a Track..
  24. Mounting Hitec servos into LST2?
  25. aftershock/lst2 shock springs
  26. Aft. shift point
  27. engine brace
  28. Does Losi have.....
  29. Aftershock Version 2!!!
  30. Losi Eight T Start Box help
  31. m26ss motor on mega baja
  32. General wheel and tire question
  33. ITS FINALLY HERE
  34. What about vg racing roll cage?
  35. Muggy shock shafts
  36. Axial 28 Spec 1 Aftershock
  37. between a rock and a hard place...
  38. what steering servos?
  39. LST2 big-air suspension setup?
  40. LST2 already in the shop
  41. When Reinstalling the Flywheel do you set play....
  42. lst2 binding tranny?
  43. Aluminum front bumper/support?
  44. What to order for my new Shock?
  45. body post
  46. Pro-line bead loc rims. Should i get them? (read post first)
  47. 8ight top speed
  48. Lst2 chassis vs. aftershock chassis
  49. How heavy are dirt hawgs on proline dishes?
  50. Aftershock upgrades suggestions
  51. what is difference between these trucks??
  52. quality allen wrenches?
  53. Aftershock Engine Upgrade???
  54. new servos
  55. LST2 GONNA HAPPEN
  56. 8ight T shocks
  57. guess what I bought!
  58. Servo removal?
  59. Home to NC!
  60. What tires for Aftershock?
  61. Didn't someone want to see LST with Muggy wheels/tires?
  62. Aluminum Diff Cup ???
  63. Best nitro fuel
  64. new owner lst2
  65. rod ends and pivot balls question
  66. how tuff,really?
  67. brakes
  68. lst 2 brake adjustment
  69. Question about mini lst for 6 year old
  70. AFT and LST 2
  71. wierd photos post them here
  72. Throttle return spring
  73. Engine problems LST2
  74. LST2 OWB PROBLEMS!
  75. These shocks?
  76. Lst2+35mph+parked car
  77. starter box?
  78. WHAT THE DIFF.?
  79. Difference Question
  80. Losi Aftershock/LST2 wheely bar
  81. Muggy Wheels on LST2 for Bashing?
  82. Capped wheel nuts 17mm or 20mm??
  83. Chassis problem...
  84. Tire's wont stay glued together
  85. Filter oil
  86. lost control new problem
  87. my poor muggy...
  88. lst2 transmission problem
  89. What wheelie bar for Aftershock?
  90. is the raminator?
  91. LRP Spec 3 Same as Losi 8ight motor
  92. bearing leak???
  93. Whats wrong wit my LST2?
  94. AFT M26SS Pipe
  95. Problems still with the Aftershock
  96. New Era .46 conversion for aftershock
  97. VG racing roll cage?
  98. Engine Rebuild Tips
  99. decal/paint scheme question new info
  100. MUGGY DOUBLE BACK FLIP
  101. lst2 body holes question
  102. LST - Forward only question
  103. Motor and clutch bell bearings gone on lst2.
  104. ballooning tires
  105. Help with Aftershock
  106. Whats the best setup
  107. Help with a Muggy Roto start
  108. stupid question what and were is the throw out bearing
  109. Still Having some trouble
  110. xtm mammoth and team losi muggy
  111. What needs to be done to an aftershock
  112. Clucth and Spring Combinations....
  113. Brake and Throttle Adjustment
  114. Combo pullstart/spin start backplate on Aftershock
  115. ofna .32 in the aftershock. what spur gears?
  116. "new losi vehicle in 6 days"??
  117. switched tires and lost top end help
  118. aftershock fixed
  119. Aftershock in sand
  120. Need Help with my Aftershock
  121. what wheels will fit LST?
  122. spare hex nuts
  123. shock oil?
  124. lst2 rear wheels dont move.. pls help.
  125. Going to dust off the lst...
  126. ground clearance
  127. lst2 shock help....
  128. 17mm hexes
  129. werks racing clutch?
  130. New LST2 transmission troubleshoting HELP PLEASE!!
  131. ofna micro failsafe question
  132. Aftershock aluminum clutch
  133. SHIFT PROBLEM
  134. muggy vs. Lst2?
  135. Does The Muggy Race wit Truggies or Monster Trucks
  136. what is that "wing" that came with lst2??
  137. glow question
  138. Problems, probelms......
  139. Aftershock meets mailbox post!
  140. Need some info here
  141. Lil muggy
  142. air filled tires
  143. Bodies for LST2?
  144. differences between LST 1 pipe and LST 2 HT pipe
  145. NEED HELP!!!!
  146. Muggy or Revo 3.3?
  147. What lst 2 hops not to get?
  148. new losi monster truck...
  149. New Body for Aftershock!
  150. THE GREATEST AFTERSHOCK THREAD EVER!!!!!
  151. Post anything and everything lst 2 on here!
  152. looking for a new monster
  153. Santa finally delivers - a little late
  154. Want to buy two new Aftershocks...body color choices???
  155. radio or rec. probelms on lst2
  156. Nitrotane
  157. cant get muggy to wheelie.
  158. cant get tune
  159. how to make my lst2 do wheelies
  160. Lst2 rpm a-arms, castors, spindles question.
  161. Dynamite engine brace and mesh question
  162. Thinking of going Carbon fiber many questions
  163. first airbrushing what you guys think
  164. FOC for LST2
  165. New Lst 2 owner Seeks approx carb settings at Sea level
  166. Aftershock
  167. lst2 off-road lights
  168. LST2 broken A-arms
  169. what else should i buy with lst2?
  170. general lst2 question.
  171. does it have reverse???
  172. Final steps -- getting lst2. Please help
  173. Mach .26 took a big hit......
  174. Best pipe for the mach .26
  175. O.S 30 IN MY LST
  176. micro-t or micro baja
  177. semi body for Lst2 or E-maxx
  178. LST2 (stock) or SAVAGE X 4.6 w/ 3speed and rev. Need to know before Dec 31!!!
  179. new body
  180. Picco .28 P3 pipe ?
  181. Slam dancin' Muggy ((with pics))
  182. has anyone used the eNVY Bi directional sliding flywheel and clutch
  183. LST2 Transmission question
  184. aftershock gears size?
  185. I SET TIE RODS TO SPECS IN MANULE AND WHEELS ARE NOT STRAIT ANY HELP
  186. Maybe this time it'll be better...
  187. Hex size?
  188. yeah i got another Losi...
  189. Did my first mod on the M26S motor
  190. Losi Spin Starter, PLEASE help!!
  191. Aftershock Upgrades - LST2 Ordered
  192. Are these actually Losi shock???
  193. Muggy a-arms/carriers based on LST?
  194. I NEED A ALIGNMENT ON MY LST HOW DO I DO IT
  195. mismatched servos
  196. Suspension size
  197. LST2 w/ axial .32 which exhaust?
  198. WHAT PIPE IS GOOD FOR A SH .28 PROSPEC ENGINE
  199. Tsais pipe
  200. Mach .26ss tuning problems!!!!
  201. JP3 PIPE V LOSI HT PIPE
  202. the smallest big air u will see!!!!!!
  203. The muggy now?
  204. does anyone know how to get ahold of SH engines
  205. fastest lst???
  206. benefits of forward only?
  207. Dynamite Engine Brace
  208. CHECK IT OUT!!!
  209. 427 carb
  210. what is toe in and toe out on tie rod ends
  211. MINI MGT, anyone own one???
  212. LST2 Wing and Wing Mount
  213. clutchbell removal
  214. WHEELS WONT STOP TUUNING AT IDOL
  215. Losi 2 Radio
  216. NI-MH 1100 raceiver pack
  217. raminator monster jam
  218. servo quality?
  219. Tard LST 2 question....
  220. AFTERSHOCK NOT SHIFTING
  221. LRP 28 SPEC + JP2 UPGRADE ?
  222. PLUS 3'S PINIONS AND IT STILL WHEELIES
  223. which truck,which pipe
  224. Spring Question
  225. Which fuel to use?
  226. Losi 2 Question
  227. Is this normal..?
  228. GPSed my LST2 today(video)
  229. LST2 center diff
  230. MGT body on LST
  231. Aftershock size
  232. hard 2 start when hot
  233. assosited mgt 8.0
  234. What weight diff oil are you using ?
  235. Crowdpleazer body 2.0 + LST2 With wing kit= not fitting help
  236. LST2 yehey cant wait!!!
  237. Aftershock upgrade report
  238. deciding on a price...
  239. motor question
  240. spring rate??
  241. muggy
  242. Used LST
  243. GOOD DEAL???
  244. Mega Baja Question... Stumped
  245. can you do foc without buying the gears
  246. LST2 - making it go faster!
  247. SWAP SH PRO 28 FOR A LRP Z28 SPEC3
  248. lst to muggy
  249. Raminator
  250. parting out LST2's
