PDA
View Full Version : TEAM RCU - Mike McConville
Pages : [1] 2 3 4
  1. List Of Your Designs
  2. A forgotten model
  3. e-flite Extra 300 32e Plan?
  4. Remember ?
  5. Side Force Generators question (SFG's)
  6. Wanna Do It Right
  7. Midwest Super Stinker up/down thrust
  8. Flitemetal and 2. 4 JR 921 receiver
  9. Sukhoi 26MM with Evolution 80 Canister?
  10. The Dark Side
  11. Hangar 9 Advance .40 and E-flite Advance 25
  12. Extra 260 35%
  13. Hanger 9 Ultra Stick 120
  14. H9 EXTRA 300 COWL FIT THE OLD 260?
  15. setup extra 300 35%
  16. Evolution 80GX muffler issue
  17. 3.1M Sukhoi
  18. 35% Extra 300 ARF NEW!!!
  19. Midwest Giles G-202 control surface throws ?
  20. Yak-54 Hangar9 carden
  21. 35% Extra 260
  22. Funtana 125 pull pull set up
  23. H9 Beast Pipe Tunnel?
  24. Futaba 6EX 6-Channel 2.4GHz Air w/4 S3004 Servos
  25. Help with H9 33% Edge 540 CG
  26. Hangar 9 frenzy
  27. 46% Ultimate airfoil question
  28. saito gas engine performance
  29. Do you remember what airfoil on Midwest Extra
  30. CONSIDER KITS?
  31. 3W 85cc CS on H9 Extra, will it work?
  32. Mike McConville Rules!
  33. Any updates on "The Beast"?
  34. SU-31 33%
  35. New Extra 300 ARF???
  36. Ultra Stick 120 Lite G26 and Spektrum DX7 setup
  37. Help w/CG of Hangar 9 cap33
  38. 35% Extra 260
  39. Servo Arm Question
  40. New Offerings?
  41. Positive snap from inverted?
  42. Showtime 90 tail incidence?
  43. tail wires
  44. twist60
  45. HANGAR 9 EXTRA 260 35% WITH DA-85??
  46. Engine Offset - Thanks Mike!
  47. Extra 300S-Thanks Mike
  48. Engine Offset
  49. 35% Extra 260 Engine Offset
  50. 35% Extra Servo Questions
  51. Hangar9/carden yak
  52. Hanger 9 SU-26 Questions
  53. Hanger 9 1/3 Cap232 single aileron servo
  54. Original H9 33% Extra CG
  55. Fuel tank position relative to carb.
  56. SFGdesign
  57. Desire question
  58. Extra 330s cowl ducts
  59. Which plane for 3D fying?
  60. max weight for 120AX
  61. 46% ultimate engine incidence
  62. Sundowner Formula 1 tuned pipe
  63. Hanger 9 new aircraft
  64. H9 Ultra stick lite
  65. Soon to be new
  66. showtime 90/FG20 4-Stroke Gas Engine ??
  67. hanger/carden yak
  68. Hangar 9 Extra 260 35%
  69. Torque rolls???
  70. 46% Ultimate TOC Missing Key Parts
  71. knife-edge attitude in Yak
  72. H9 Carden Yak w/ 58GX2 Exh??
  73. HELP WITH THE 9303 AND 4 SERVOS ON WINGS
  74. DX & ??
  75. Mike I can't believe it.
  76. .....
  77. Showtime 90 4d CG help
  78. Hangar 9 /Carden YAK 54
  79. 33% Extra 330s Hardware
  80. X9303 defect?
  81. DS9411 Problem
  82. Another ultimate question
  83. JR X 9303 2.4/ dsx 9 problem
  84. DSX 9 CONNECTION TO SIMULATOR
  85. Soft mounts verse hard mounts
  86. Any new profiles?
  87. Schedule???
  88. katana and the stall
  89. yak 54
  90. 2 Strokes or 4 Strokes For Showtime 90?
  91. Hey Mike
  92. PROBLEM WITH H9 SUKHOI CANISTER INSTALL
  93. softwere
  94. do you prefer ???
  95. 27% Cap 232G ARF
  96. Edge 540 33% Hangar 9 Engine choice
  97. Edge 540 33% CG point?
  98. Redundent systems?
  99. Thanks Mike
  100. FuntanaX 100
  101. Showtime 50 - Engine choice
  102. Ultimate Servos
  103. Showtime 90 hor stab concern
  104. Midwest 72" G-202
  105. 27% Extra 260 electric
  106. Showtime 90 questions
  107. funtana 100???
  108. KE snap to KE
  109. rolling circles
  110. DX7 Programming - 2 items
  111. Cap 232G
  112. H9 Cap 232 33% ? for Mike
  113. New Electrical Systems
  114. Dangerous Stall in Showtime 90
  115. Saito FG 36 Gas in a H9 27% 260
  116. PNP 1/4 scale H9 Cub
  117. H9 1/4 Scale Cub
  118. Dear
  119. Need plane for Saito 125
  120. Looking for 3d plane
  121. Mike - 1/3rd CAP 232 Ultracote Don't Match?
  122. H9 Tango
  123. Torque Rolling article, re: EX-100 Gyro
  124. Twist 150
  125. SU-31 33%
  126. Showtime 50 Problem
  127. Trimming YAK-54 don't know where to go
  128. Hangar 9 Extra 260 27% Servos
  129. H9 33% Edge Problem
  130. Yak54-40 Second Maiden
  131. 35% Extra 260
  132. Extra 260
  133. H9 Funtana X50 question
  134. Sundowner exaust with 180 saito problems...mike??????????
  135. Servos choice for showtime 50 rudder
  136. 35% 260 Cans
  137. Mike web page
  138. Mike, Will Your New SU-26MM run ok with a DA 100?
  139. Older H9 33%ers with tuned cannister
  140. SU-26MM HEADER QUESTION
  141. Kit airplanes
  142. H9 35% 260 Stab Tube Bolts
  143. i-hobbies show
  144. Edge 540
  145. NEW Hangar 9 85cc SU-26MM Sukhoi
  146. H9 sukohi questin
  147. Hanger 9 Twist 60 ARF - CG?
  148. 35% 260 Servo/RX Power
  149. H-9 Suhkoi & DA 85
  150. iHobbies show
  151. Sundowner Motor Mounts
  152. H9 ultimate questions
  153. H9 Sukhoi
  154. Showtime 90 - OS 1.08 or Electric???
  155. Saito 36cc Gas
  156. 35% Extra 260 trimming question
  157. Showtime 4D stabiliser
  158. Hangar9 Extra 260 v Cap 232
  159. Retrofit or New?
  160. H9 Extra 260 27% and DA-50
  161. FIREWALL EXTRA 27% AND DA 50R
  162. Hangar 9 1/3 CAP 232 Aileron Throw?
  163. Radio Gear
  164. H9 Extra 260 27% CF Gear
  165. Benefits of Positive Wing Incidence?
  166. F1 Sundowner and lighter motors...
  167. H9 EXTRA 260 VS CAP 232G ???
  168. Sundowner and the Saito 180
  169. Any plans for a bigger FUNTANA?
  170. 46% Ultimate SetUp?
  171. 3D prop size for st with an os 108 2 stroke
  172. Hangar 9 Cap232g
  173. Knife edge MIx vs. Torque roll
  174. JR 9303 2.4 GHZ with 921 RX
  175. Showtime 50 Prop recc....
  176. FS One Tools
  177. hanger nine twist 150
  178. Sundowner / Saito 220
  179. Sundowner
  180. H9 Extra 260 Twist Aileron
  181. H-9 33% Cap balance
  182. JR 9303AS Help Mike
  183. New 3d plane
  184. Non linear throttle
  185. Problem With Showtime 50
  186. Carden 330
  187. extra260 27%
  188. Hangar 9 33% Cap is BACK!!!!!
  189. re fuel cell
  190. fuel cell
  191. Eflite Extra 260 3D 480 ARF
  192. vid and more pics, please!
  193. Sundowner
  194. sealing control surfaces on showtime rd 90
  195. The new hotrod
  196. 35% Extra 260
  197. Toledo Show
  198. Thanks Mike
  199. Hanger 9 Cap 232G reciever
  200. Showtime 4D 90 Landing gear
  201. Hangar 9 33% Extra 330S Set up ?
  202. H9 CAP232g
  203. Showtime 90 incidences
  204. Hanger 9 Cap 232G
  205. Oh Yea!!!
  206. Using a servo reverser
  207. H9 Ultimate CG
  208. 'Old' H9 Extra vs New
  209. 33% Cap Landing gear question
  210. Thumbs or Fingers????
  211. 50 cc machines in the pipe line
  212. 2.4 gig modules
  213. Two DX-7 receivers?
  214. Hanger 9 Sukhoi Carbon Gear
  215. CAP COLORS
  216. Carden extra 260 40% elevator question
  217. Mikes DX 7 set-up
  218. Uncovered models
  219. Flying The Nosen Gere Biplane
  220. EVO45 GX
  221. Hangar 9 T-34
  222. Need help with Extra 330S
  223. Want to build a 42% Edge
  224. Hangar 9 F-22 Raptor PTS Trainer
  225. Spektrum question
  226. E-Flite Showtime?
  227. 33% Profile?
  228. What batt. and servos for FX100?
  229. DX7 Radio
  230. H9 Spitfire and Saito 100's Muffler
  231. Showtime 50 & Saito .82
  232. Showtime 50 vs Showtime 4D
  233. Evolution 45GT Muffler problem
  234. JR Gyros in 40% carden
  235. H9 33% Edge- "Left" Rudder Trim?
  236. 10X and Li-poly
  237. Showtime 50 fuel tank
  238. incidence setup for showtime 50
  239. Showtime servos
  240. Happy Holidays
  241. Showtime Hinges
  242. incidence and lateral balance
  243. F90 elevator servo set up query
  244. Midwest Little Cap 232
  245. Funtana90 and X100 Question?
  246. Attention Mark
  247. New H9 P51D 150 size
  248. Yo, Mike, how about an AMA pattern PNP?
  249. Give us the sneak peek
  250. H9 Edge 33% Set Up
