PDA
View Full Version : Smart-Fly (Quest Engineering) Support Forum
Pages : 1 [2]
  1. Ignition cutoff
  2. Ignition Cutoff LED
  3. SmartFly regulators
  4. Power Expander Sport Plus & Fromeco Wolverine Switch-
  5. Power Expander Eq10
  6. i'm a little confused
  7. Smartfly cut-off question Spektrum
  8. which regulator for a jet
  9. Smartfly Regulator wo Failsafe Switch Problem
  10. Smart-fly ignition cutoff question
  11. Turbo Reg and edr 111 setup
  12. Pin Switch Threads
  13. Redundancy setup without power box?
  14. Power Expander Sport
  15. EQ10 won't power up
  16. Power expander sport and Spektrum AR9000
  17. Pin Switch
  18. SmartFly quality question
  19. Questions on choosing the correct hardware
  20. Equalizers
  21. Max capacitance allowed on expander?
  22. Batshare fail open,closed?
  23. Super regulator switch
  24. Smart-Fly Equipment
  25. batshare with hobbico hydrimax 3800 *2
  26. Super Regulator
  27. 2*2600ma+1x2600 li-ion with batshare?
  28. SmartFly and XtremeLink
  29. PowerExpander Pro - Super Reg Problem
  30. Spektrum problem.
  31. Problem with a pin switch??
  32. superreg draws from both batteries equal?
  33. Power Expander or Equalizers
  34. Turbo Reg problem.
  35. Basic Power Expander Sport Setup
  36. Turbo Regulator Set up
  37. regulator installation
  38. Bat Share
  39. Power expander regulator
  40. Charging thru Smart Fly regulator
  41. Power Expander + Vibration=???
  42. LED Question
  43. Pwer Expander review
  44. Optical ignition switch??
  45. Can I use two regulators in parallel?
  46. more eq 10 power expander questions
  47. Spektrum DSM2 2.4GHz Compatibility
  48. The Super-Reg is enough to my setup??
  49. 50cc Power Expander
  50. Equalizer II
  51. Optical Ignition Question
  52. SmartFly optical switch
  53. TurboReg is not a fully redundant regulator
  54. Charger for Li-Po's
  55. Power Expander Pro problems
  56. Planned purchase of Power expander
  57. Smart-Fly Power Expander Pro
  58. Info on batteries for Superreg
  59. Optical Kill -LED Installation?
  60. Charging with Accu-Cycle Elite
  61. 1/3 scale Gee Bee Z landing gear.
  62. Kudos for Smart-fly!
  63. Another power expander question
  64. QQ Yak 102' Flight pack??
  65. power exanders
  66. Super Reg
  67. Wiring diagrams.??
  68. Spectrum radio... old vs new?
  69. Super Reg failure mode?
  70. Power Systems and DX7
  71. Question about charging with SuperREG
  72. Equaliser 2 (rev c)_
  73. 14MZ power expander
  74. smartfly EQ10
  75. Switch Questions
  76. How small a plane for Power Expander?
  77. Equalizer II and Power Expander.
  78. Power Expander Sport or Pro?
  79. Adjustable regulator for ignition?
  80. BatShare vs. BatShare 2-pack ?
  81. Dual receivers?
  82. ignition or standard regulator
  83. Power expander
  84. HD BatShare
  85. Kill switch
  86. Older Power Expander?
  87. Turbo Regulator Setup question
  88. power expander
  89. Where can I buy your products
  90. Optical Kill voltage limit question
  91. Difference Between Old & New
  92. Smart-Fly Regulator Recall
  93. General Questions Selecting Smart-Fly products
  94. Equalizer II Confusion
  95. Need Help - Unreliable Smart Fly optical switch
  96. Amp Meter ??
  97. Power Expander with Hitec 5955
  98. Dual Battery Regulator Differences
  99. dealers list ?.
  100. voltage checking on super regulator
  101. Sevro programming and PE problems
  102. Tech Questions
  103. Equalizer II and Hitec 5645
  104. super regulator infos
  105. problems with my PowerExpander
  106. Adjustable Regulator, how do I adjust?
  107. Pin & Flag Switches...
  108. Equalizer II Now Glitching problem.
  109. regulator question
  110. Direct Servo Hookup
  111. Clarification required on Expander
  112. Do it myself servo extensions
  113. HELP!!! Need an Equalizer II
  114. Batshare on 4.8V
  115. Smart Fly Regulator Question
  116. Thanks Smart-Fly
  117. Smart-fly Tx module dead in the water!!!
  118. BattShare
  119. Optical kill switch
  120. Equalizer II Question
  121. equallizer II
  122. Power Expander II
  123. Smart-fly ignition regulator question
  124. Lipos on a Turbo reg
  125. Optical Kill Switch
  126. Requisition
  127. smart-fly heavy duty regulator question
  128. regulators
  129. sanwa gemini ii vs ko propo vantage esprit ii
  130. galloping rudder
  131. Power Expander - Product suggestion
  132. What happen IF a reg fails.
  133. .....
  134. Mounting my Batshare and Regulator
  135. Equalizers II
  136. Power Expander + Turbo Regulator
  137. powerbox and matchbox
  138. smartfly expander
  139. Equalizer II
  140. Power expander set-up
  141. Complete setup recommendations
  142. power expander question
  143. Battery polarity - for super regs
  144. Optical Kill Switch Question...
  145. TX LiPo Batteries
  146. Current management for 40%
  147. LET"S SEE IF I HAVE THIS RIGHT
  148. ??? Turbo Regulator ???
  149. One Equalizer for two ailerons?
  150. problems with dual redundant system
  151. Old Style Equalizer--Setup Help
  152. Turbo Regulator "DUAL SWITCH"
  153. Smart-fly Voltage Regulator Question
  154. Ignition is 3 wire , cutoff is 2 wire ?
  155. Turbo Regulator?
  156. Power Expander Hook-up
  157. Now I'm really confused...
  158. Possible cause of crash
  159. batt share question
  160. equalizer
  161. Equalizer 3D
  162. regulator question
  163. Dual-Battery Regulators
  164. Optical Kill Switch battery charging?
  165. Equalizer II set up
  166. Equalizer II problems
  167. whats need to run a 87" YAK with 3 batteries
  168. Optical Kill Switch - FM vs. PCM Versions?
  169. Optical Kill Switch - FM/PCM Versions?
  170. Power expander battery connectors
  171. Power Expander - Dual Receivers
  172. Batt Share
  173. Power Setup Help
  174. Need some help...
  175. Power Expander N Bat Share
  176. Batshare Question
  177. Power Expander
  178. Smart-Fly failsafe on regulator 6V question ?
  179. Welcome wagon
  180. Welcome To Smart-Fly Support Forum
