PDA
View Full Version : Smart-Fly (Quest Engineering) Support Forum
Pages : [1] 2
  1. Use of Different Mah Batteries
  2. Servo wiring
  3. Ignition cut off LED will turn off but engine continues to run
  4. Smart-Fly Power Expander for JR Receivers
  5. Ignition Cut-off shutting down engine without user input
  6. Competition 12 servo voltage
  7. R7008SB Futaba Receiver
  8. Turbo EQ-6 - Ignition Cutoff
  9. Input & putput voltage of EQ6 regulator
  10. Input & putput voltage of EQ6 regulator
  11. BatShare to Regulator Wiring
  12. New to Smart Fly products, need advice on a system for my 50cc, 27% Pitts Python!
  13. Opti Kill Cutoff
  14. power system sport plus
  15. for smoke and ignition
  16. EQ6 Turbo and Futaba 617FS plus aileron question
  17. Powersystem sport + Futaba R7008sb
  18. Futaba r6014 with eq10 smartfly
  19. Welcome to Guangzhou Model Fair
  20. Opti Kill Instruction Sheet
  21. Power System EQ6 Turbo
  22. Futaba R7008SB Compatibility Issues with EQ6 Turbo
  23. Large Plane Power Expander and Ignition Cut off
  24. Ignition Cutoff
  25. Adding regulation to an existing ignition cut off system due to bat change
  26. Need help with a AR600 receiver, Please
  27. Equalizer II Flashing LED'S
  28. Mounting Smart-Fly units
  29. BatShare for gas engine ignition
  30. PowerSystem Competition 12 Plus use with Futaba S-Bus
  31. Ignition cut off
  32. sukhoi su 35/Devo 12s setup problems
  33. PowerExpander Micro-14F
  34. FailSafe for cutoff
  35. electric gear
  36. Programming EQ6, Help I Have No Hair Left!
  37. Power Expander Servo Extension Plugs to Pin Connections
  38. Smart-Fly single-receiver Ignition Cutoff
  39. Power Expander Sport Plus
  40. EQ6
  41. Equalizer II Question.....>>>
  42. 2 different mAh batteries?
  43. Ignition cutoff
  44. PowerSystem vs PowerExpander
  45. SMART-FLY TURBO REGULATOR
  46. Ignition cutoff location question
  47. Best setup?
  48. Hangar 9 Beast set-up
  49. Comp Arf Pitts setup
  50. Equalizer 3D and II
  51. Powersystem SportPlus and Futaba R6008HS
  52. Smart Fly EQ10 question
  53. Damaged Power Expander Sport
  54. Ferrite Toroids
  55. Ignition Cutoff operating voltage
  56. BEC usage
  57. A123,s with a Bat Share
  58. Smart Fly Comp 12 turbo pigtail hookup question
  59. POWER EXPANDER PRO & JR
  60. HiTec A9 warning for Opti-Kill Sws
  61. What's this pigtail on this old Power Expander 4804?
  62. eQ-6 Turbo
  63. eq10
  64. Super Reg Question
  65. A123's and the Suer Reg
  66. Power System Sport Plus w/IGN
  67. eq 10
  68. Booma Ignition switch
  69. Power on-off eq6
  70. Set Up Question
  71. Eq6 Turbo
  72. Rcv'r won't power up
  73. Equalizer II
  74. Jr 1221 RX and PowerSystem EQ6
  75. Uneven Batt voltage draw
  76. H-9 46% Ult Bi-Plane
  77. EQ6 Ign Question
  78. EQ6 set up questions
  79. Best way for 14 channels
  80. EQ6 and Sullivan SkyWriter
  81. dual switching BECs into Power Expander?
  82. equalizer 3d max voltage?
  83. Frysky bind time
  84. Which unit for all 14 channels on FASST?
  85. Sport Plus Lighting Issue
  86. Battery connectors
  87. Set up question
  88. Smartfly ign reg - gap on heatsink ?
  89. Power System Sport Plus Kill Switch Problem
  90. Power expander sport
  91. PowerExpander EQ10 will not servo adjust
  92. Unit won't shut off.
  93. EQ6 and Formeco 8-Ball
  94. RX Power from SportPlus
  95. Power Requirements?
  96. EQ10 - flap servos programming
  97. Newbie Setup Confusion - Pwr Expndr Pro
  98. JR922 Powersafe Receiver
  99. Pin and Flag
  100. Which Power System
  101. PowerSystem Competition 12 Turbo / A123
  102. Sailplane Use
  103. Power Expander Sport Plus and ignitio battery
  104. FRSKY 8CHANNEL SET-UP
  105. EQ6 - adjusting multiple servos on channel 1 (ailerons)
  106. Voltage Regulator...
  107. Set up help????
  108. Eq6 and charging/other questions
  109. Smartfly power expander sport plus
  110. Power system sport plus set-up
  111. SET UP
  112. Eq6 Turbo and AR9100 Connection
  113. expander signal amplification
  114. cut-off
  115. Ignition cutoff power expander need help
  116. EQ6 transistor temperature
  117. PowerSystem Sport Plus Setup
  118. EQ10 and 2S lipos
  119. Power Expander Sport Plus connections Help
  120. Batshare 2nd output + MatchBox
  121. PowerExpander Sport Plus Ignition Cutoff
  122. PowerSystem Sport Plus
  123. Match Box
  124. Power Expander Pro Battery Voltage
  125. Power Expander Pro, Failsafe Switch and A123 or Lipo Batteries.
  126. separate batteries for servos and receiver
  127. PowerExpander Competition 12
  128. Batshare with JR 921 2.4
  129. EQ6 ignition cut off
  130. Power Expander Sport Pluss - Charging
  131. PE Pro & Ion Cube
  132. Power System Sport Plus Regulator
  133. Power system and regulator question
  134. Split elelvator control
  135. Which system so I need?
  136. LED failure on EQ6
  137. PowerSystem Sport Plus
  138. Super confused, dont want to burn something out
  139. 50cc setup smart-fly
  140. PowerSystem Sport Plus Mounting?
  141. What is customer support?
  142. TurboReg setup & switch question
  143. EQ-10 Set up
  144. PowerExpander 14MZ - revised to competition?
  145. Pin and flag or EQ6
  146. EQ10 Set Up
  147. PowerSystem Sport Plus
  148. Batt-Share??
  149. SmartFly Vs. PowerBox
  150. EQ6 TURBO
  151. A123 rx ign thru battshare
  152. help for first 100cc setup
  153. 2 smart fly regs on a JR R921 rx?
  154. 35% IMAC Setup???
  155. TurboReg with different battery sizes
  156. smart-fly powersystem sport plus
  157. JR Power Expander....
  158. Ignition Cut off
  159. good protection 6014FS
  160. Which Unit Do I Choose?
  161. Super Reg & HD Switch
  162. EQ 10 setup questions
  163. SuperReg and Cellpro 10s incompatibily
  164. 14MZ battery charging
  165. Power Expander & Fasst RX Placement
  166. what to choose?
  167. Super-Reg falling apart
  168. Futaba Power expander PDF
  169. new set-up
  170. Failsafe power consumption?
  171. Futaba Power Expander and 12FG
  172. Power Expander w/FS and A123
  173. Using a PowerExpander Pro with a JR 1221 Rx
  174. Power Management /R790
  175. Servo short protection??
  176. Futaba Fasst
  177. JR 2.4 / SmartFly issue ***HELP***
  178. Eq6 Help !
  179. Dual Lock Velcro Question
  180. Failing (slider) safety switches
  181. Help run out of channels, what do i use?
  182. Bat Share system
  183. Failsafe pin switch
  184. Sport plus w/ 35% plane
  185. EqualizerII, Futaba 7C, dual elevator servos
  186. turbo reg fan doesnt work
  187. eq6 charge jacks
  188. problems with eq10 and power spander sport
  189. EQ6 TurboPlus
  190. Whick Power Expander to Use with new JR 12X
  191. PowerExpander Sport Plus and Zenoah G-38
  192. EQ10 issue?
  193. Regulator w/failsafe switch
  194. Ignition cutoff lead
  195. Advisory: Receiver Connections
  196. Advisory: Futaba FASST Compatibility
  197. Which Smart Fly product is for me?
  198. Recent Futaba 2.4 RX Advisory and Effect on Power Expanders
  199. Power Expander Sport Question
  200. power expander pin connectors
  201. Plastic screws of Ignition Kill Switch Rx Have Come Loose
  202. Can I Use a PE Pro with JR's DSM?
  203. Power System Sport Plus Heat sink problem.
  204. Adjustable regulator question
  205. EQ10, endpoints, and deflection.
  206. Smart-Fly EQ6 Switch question???
  207. PE 14mz switch/charge Question
  208. ADJ REGULATOR?
  209. 50CC Composite ARF what regulator?
  210. Dual 2.4 Ghz Futaba Receivers
  211. PowerSystem Sport Plus battery charging
  212. Power Expander and Kodiak SW
  213. PowerSystem Sport Plus Problem
  214. Smart Fly is moving
  215. PowerExpander 14MZ questions
  216. how to install Superreg
  217. eq6 turbo
  218. Futaba R6014FS Rx & minimum number of servos
  219. Heavy Duty Regs
  220. Ignition Battery Switch
  221. power leads for receiver
  222. Ignition cut-off question?
  223. Ignition Cutoff
  224. JR 2.4 9 Channel Reciever
  225. Receiver mounting
  226. Power expender pro
  227. Damaged PE
  228. EQ10 batery usage?
  229. That regulating I need?
  230. battery q
  231. Smart-Fly in a AW 75CC Extra
  232. ? EQ6 Availability ?
  233. Spektrum and Solder Joints
  234. Batshare ?
  235. H-9 46% ultimate smart fly setup?
  236. reg seyup please help
  237. JR 10X travel volume question
  238. Super Regulator
  239. Bypass switch for Opti Kill?
  240. batshare mounting
  241. Hypothetical Servo Wire Shorting Question
  242. Power Expander usage with Gyro
  243. Hangar 9 46% Ultimate
  244. HELP ! NEED HELP WHICH POWER SISTEM WORKS BEST WITH MY 36% KATANA
  245. PowerSystem Sport Plus - 7ch -or- 8 ch & batt connectors
  246. Any feedback with power expander sport and Futaba 2.4ghz ?
  247. Batshare connectors
  248. Am I safe??
  249. Add a signal wire to the BatShare?
  250. Turbo Regulator Fan...
