PDA
View Full Version : Ikarus Aerofly flight simulators
Pages : 1 2 3 4 [5] 6 7 8 9 10
  1. Frame rates of 1100 with a laptop
  2. 6 Channel Heli Control Config
  3. New add-on for AFPD
  4. Free Airplanes for APF Only
  5. Hanger9 Showtime 4D 90 for AFPD?
  6. How to use AFP planes in AFPD simulator
  7. IPAC Aerofly Professional Deluxe
  8. What Video Card are You Using?
  9. AFP Deluxe Shadow
  10. Will the G2 phono to Futaba square adapter work?
  11. 3 channel airplane models for Aerofly pro Deluxe
  12. Drop bombs anf fire missiles
  13. Video Card Questions???
  14. AFPD USB Cord
  15. Boomerang trainer model for AFPD?
  16. AFPD wont run, maybe my graphics card? Please help :(
  17. AFPD NOT WORKING, IS IT MY GRAPHICS CARD? PLEASE HELP
  18. Changing Engine Sounds in AFPD
  19. Anybody using a 8UAP or 8UAF to run AFPD??
  20. Fed Up Looking for AFPD large (85+")WWII warbird...
  21. Which 3D modelling software options for AFPD?
  22. 1/4 scale/100" Corsair or Messerschmitt
  23. Large S.E.5a by Mr. Wedel
  24. I bought the AFPD with the USB cable. Would like controller
  25. hobbico superstar or nexstar or similar
  26. aerofly pro deluxe.
  27. AFPD using 7CAP
  28. 35 or 40% Extra 260
  29. RAFALE
  30. Aerofly pro deluxe won't start! Please help!
  31. AFPD coupon code!
  32. Using AFP Serial Dongle With AFPD
  33. AFPD Vs G3
  34. Aircraft models for AFP
  35. Problem With Members Area
  36. OMP planes for AFPD
  37. Downloader page malpropism?
  38. Blank or white planes
  39. Volume of some Aircraft.
  40. how do you share your recorded videos?
  41. Who will make a plane for me?
  42. heli 4 channel asignment
  43. AeroFly Pro No Cable detected Brand New?
  44. AeroFly Pro vs. AeroFly Pro Deluxe
  45. how to make afpd scenerys
  46. No Sound on some downloaded Planes
  47. Can someone please help me with the values in AFPD?
  48. Add on disk Vol1
  49. Tx ON or OFF
  50. Game Commander stick ptoblem
  51. Help installing planes
  52. Help installing planes
  53. pattern plane for AFPD
  54. USB interface dead?
  55. Extreme Flight Extra 300 for AFPD
  56. making aerobatic planes more realisitc
  57. Mouse Disconnecrts - Help
  58. AFPD control problems
  59. Newbie Question
  60. How to change sun position
  61. AFPD vs. G2 info needed
  62. 6XAs works but 8UAF doesn't. Help needed!
  63. AFP and JR transmitter
  64. Looking for Yak
  65. Airfoilz for AFPD
  66. New Problem
  67. USB interface for AFPD
  68. Add On Disc - Vol 1
  69. Shocky PPS 4D
  70. Aerofly pro and XP 64bit
  71. AFPD Download ?
  72. Need help converting a 3ds max file Lego? TWRC?
  73. AFPD Planes not installing properly..
  74. AFPD models
  75. AeroFly Pro Deluxe and Futaba 9CAPS
  76. AFPD problems
  77. need to know
  78. Aero Fly Pro - Deluxe features
  79. version pach problems
  80. F-104 Starfighter WANTED
  81. lmh for aerofly?
  82. Airtronics radio to JR interface
  83. DO-335 for afpd?
  84. T-REX 600
  85. aerofly sim not working
  86. Building A Car in AFPD
  87. jet models
  88. afpd control problems
  89. Full screen mode
  90. Dual Rates Problem After Calibration
  91. re-installing problem
  92. repainting
  93. building my own afpd aircraft
  94. IDEAS FOR PLANES FOR AFPD
  95. My Blade cp for AFPD
  96. BLADE Cp for AFPD
  97. redbull pitts special skin.
  98. URL Changes for OMP & AFPD
  99. AFPD model designers (Editing .TMD file!)
  100. Common Issue with downloaded airplanes
  101. DELETE QUESTION
  102. downloads from AFPD not running
  103. Top reasons your AFPD LOCKS UP?
  104. Please Help--Downloading New Planes in AFPD
  105. ADP (standard) With Game Controler -- USB converter?
  106. Multiplex Magister - no floats
  107. Need help !!! New AFPD does not work !!!!
  108. To AFPD 3D modeler !
  109. Making planes for AFPD
  110. Pattern Planes
  111. A-10 Warthog
  112. 2 player mode
  113. AEROFLY PRO INSTALLER
  114. BMP to TMT file
  115. Interface cable
  116. Setting up helis in AFPD with the remote commander
  117. Downloaded sceneries that say for 1.9
  118. AFPD Graphics Card Recommendation
  119. Aerofly Pro requirements
  120. T-Rex for AFPD
  121. Information
  122. Aerofly on a Dell D610
  123. Any DA50 Based Yaks for AFPD
  124. The benefit of using AFPD
  125. A little screenshot fun
  126. AFPD Upgrade 1.8 to 1.9
  127. Ipacs-Convert-program
  128. Futaba 9CAPS doesn't work with AFPD
  129. First post - AFP?
  130. Control line
  131. 4D in original AFP???
  132. AFPD music problem
  133. AFPD Stopped working
  134. new skin?
  135. new skin?
  136. slow fps - need help please
  137. afpd demo?
  138. how to make a scenery for AFPD???
  139. Recommended video cards
  140. Any download sites with a good range of electrics
  141. Getting AFDP running on LCD 1600x1200
  142. IMAC setup for AFP roland matt 330s.
  143. is there an oxalys?
  144. Aerofly Pro to Deluxe Question
  145. Aerofly pro deluxe patch
  146. OMP Fusion F3D cannot find !!
  147. how to import a Slow Stic Model
  148. where is the 4D plane? still looking!!!
  149. Trouble Installing Models to AFPD
  150. Is IKARUS AFPD completely uncaring?
  151. Plane flys off the screen
  152. Sig Mayhem or UCanDo available?
  153. Why is AFPD avoiding the Question?
  154. AFPD needs help
  155. Multiplayer?
  156. You Gotta see this Yak 54sp skin.heeee
  157. Unable to control folding wings
  158. Is there a GWS SlowStick program
  159. My Dual rates are gone!
  160. DX6 compatibility
  161. Controller Setup for 3d Helicopter
  162. Goodbye and thank you!
  163. differential ailerons
  164. Modeler help
  165. FuntanaS 90 2M in AFPD
  166. F-86 Sabre For AeroFlyPro
  167. change the size of the fus?
  168. How do you setup throttle hold/practice Autos
  169. Saving Controller settings
  170. Sikorsky - Collision bug ??
  171. AFPD Take off and ground handling
  172. Extra 330 or Edge 540?
  173. Aircraft Mods
  174. quick connector
  175. How can i use a gamepad with aerofly???
  176. Aerofly pro deluxe
  177. changing the weight of a plane
  178. AFPD not workin with jr 9303
  179. Folding Wings on Corsair?
  180. AFPD on a 1.3ghz athelon Gfource 6200
  181. Diablo40 model
  182. Any FP heli's like Corona available for AFPD?
  183. Suggestions for Controller setup
  184. jumpy throttle in AFPD
  185. GP Stik added??
  186. Workshop: How to create your own models for AFP/D
  187. Mouse Movement Problems
  188. Please help! Where can I download new airplanes for Delux
  189. Scenery Problems
  190. will AFPD work with a ATI 7200 64meg
  191. interface cable finally won't work anymore
  192. 3 channel model
  193. Glider airbrakes on AFPD?
  194. Chip Hyde Vision 3D
  195. P-40 Warhawk for AFPD
  196. Show Time 4D
  197. AFP - downloaded planes are extremely slow
  198. For STLpilot: Need help with creating planes AFPD...
  199. AFPD Canopy Control
  200. Thanks for excellent service
  201. deleting planes
  202. AFPD on Dell E1505 notebook? - will this work?
  203. AFPD Detects cable, but not the radio
  204. Video Locks Up
  205. Composite Arf FANTASY skin for 2.6 YAK
  206. ADD-ON v1.9.1.1 crashes......????
  207. Can AFPD use a USB based system - no serial port?
  208. the best photo scenery for Aero Fly Professional?
  209. RCU Flatout Bipe V2 for AFPD
  210. AFP or AFPD?
  211. Aero Fly Free Installer Problems
  212. Blade CX and CP available?
  213. not idling
  214. AFPD problems
  215. AFPD need Someone to send me there Config. File
  216. AFPD can't find interface cable....HELP!?
  217. downloaded plane stops program
  218. Graphics Card?
  219. Now controller not detected
  220. AFPD No engine sound at all
  221. AFPD Upgrade - smoke not working
  222. virtual trainer for AFPD??
  223. True Warbird Takeoff Characteristics
  224. guide to AFBD for newbies????
  225. VIBE for AFPD
  226. AFPD Add Onn Smoke problem
  227. RCUniverse.com Flatout Bipe
  228. Problems editing planes in AFPD
  229. AFPD Game commander service in the US
  230. AFPD New Install Problems
  231. AFP, plane Disappeared
  232. afpd futaba 7cap glitch
  233. New site with useful things
  234. VTOC 2006
  235. Does the replacement Y cable work with an Airtronics VG6000 tx
  236. Aircraft Changes in AFDP
  237. 4d Planes for AFPD
  238. What makes a surface transparent or opaque?
  239. AFPD causing me 2 crash
  240. AFPD won't install...
  241. G2
  242. Smoke density at idle
  243. AFPD Upgrade Questions
  244. Volume troubles
  245. How to make color schemes
  246. No motor sound
  247. what do i use to convert my AFPD video!!!
  248. bandit for afp or afpd
  249. AFP (D) vs Reflex...
  250. Full scale sim models?
