View Full Version : WildHare R/C Support
Pages :
1
2
3
4
5
6
7]
8
9
- Edge 540 28% Almost meets its doom! VIDEO!!!
- pictures of my extra
- what engine for my 28% extra special? ZDZ 50NG vs. DA50. ALso what muffler?
- Help Balance 28% Edge540T
- Need 28% Edge Fuselage
- Pics of my Wild Hare Edge 540
- GREAT CANOPY LATCH..
- I need an extra 260 landing gear
- DA50 Vs ZDZ50 vs BME 50 for Extra Special 28%
- Which servos on 29% Ultimate
- which pilot figure on wild hare extra 28%
- ULTIMATE INCIDENCE
- Wing Bolt Problem
- 33% 260 vs 35% 330
- 540 Edge ARF
- What should a EXTRA SPECIAL weigh,,,
- help with electronics hookup please !
- possible trouble with MPI Voltage Regulator s
- Extra 260 Questions
- Another 300special!!!
- 28% Extra rudder setup??
- Wing and canopy bolt insecurity
- Sukhois are here
- Another Ultimate balance question
- DA 50 Vibration
- Ooops... wrong forum... sorry
- FYI-Necessary DA50 Ignition Battery Capacity
- Giles as a first gasser
- 5.4/6.0 Volt Regulator
- Stab Incidence on Edge 540t
- ultimate weight
- Hundredth Flight Celebration
- Best Tail wheel for the Edge 28%!!!
- 260 Maiden
- ? FOR WILD HARE,,IS THERE A YAK IN THE WORKS
- canister muffler on 300s canit be done?
- Baby Edge with a gas engine
- Using Gorrilla glue???
- Desert Aircraft Decals???
- Got my 28% WH Extra 300LX!- Now, Build Thread
- 260 incidence question
- Extra 260 for IMAC?
- Cannister Mufflers & Extra 260
- extra 260 cowell will this fit?
- I need help with my Pants!!
- Ultimate First Flight
- Last flight for my Edge..**NEW PICTS**
- Tiger Sukhoi
- 73" Edge 540T 1.20 Build
- EVO 58 arrived
- Modified Extra scheme
- Fiberglass gears
- My Ultimate First Flight
- 28%300spec thrust??
- DA-50 or Brison 3.2 for WH 28% Extra LX?
- A General Comment on Wild Hare Planes
- a little paly betwen wing tube & channel
- Is it ture? The problems with the 73 inch edge?
- How I lightened 28% Extra
- Carbon gear and tube...Where?
- Ultimate Balance
- Stupid DA question
- WH Ultimate
- Antenna question
- Best 28% plane for Windy conditions
- Has The New Shipment Arrived?
- My WH Edge! (Parts/set-up)
- Needed Help with Ultimate
- da-50 ignition
- Extra Special----->TR-260
- Edge 540 Landing gear
- Wing tube & choke question for you 28%'ers
- Spoilerons....How Much ??
- Ultimate landing gear, any fiberglass in the future?
- wild hare extra 260 ailerons
- Ultimate coweling fit
- Please read Tom
- be careful when trimming the canopy
- Wild Hare Planes under the name Perfect Models
- Rudder Pull Pull
- Fuel Tank Mounting in 300LX
- Edge 540
- Wingbags for sale
- 28% Wing Bolts....
- Edge 540T Flapperons?
- How does the 29% Wile Hare ultimate fly?
- WildhareRC 73" Edge 540T - Electric!
- Elevator servo position?
- Edge 540t 28% HELP
- Maidened WH28% EXTRA 300LX
- Edge 540T....Up thrust needed ????
- extra special and zdz carb linkage(s)
- Motor Choices
- clamping the wing tubee
- 36% Extra Carton Size
- Hitec 5745
- question on hardware pack
- Anyone running a ZDZ60 on their WILDHARE
- 36% EXTRA 330SX
- 300 extra special
- I am so close!!
- tank plumbing question
- WH35% EXTRA and ZDZ160
- play in the hitec 5945
- 4.8 or 6.0 volt
- da 50 on extra300 spec.
- near disaster
- Wildhare Edge Help
- 73" Edge And MOki 1.80
- Posting Pictures - Problems
- props
- Slimline DA 50 muffler on MVVS/EVO 58
- ZDZ 60 on an Edge?
- some new products
- Slimline Muffler Mounting on a DA 50?
- WH Ultimate (Help)
- DA 50/Edge Props
- Fuji 64 in a 28% edge anyone done this
- Fuji 64 in a 28%
- 28% Extra Special - tends to snap
- WH Edge 28% Stcok Landing gear Weight?
- When R 28% planes coming?
- BATTERYS, WHAT KIND
- Edge 540T - R.I.P.
- Question for Brison 3.2 owners with MSC prop
- Tom strikes again
- Check those incidences!
- Sorry I've been out of town
- Ultimate servo suggestions
- Question for Tom
- couple questions about 73" edge
- Wild Hare Transport
- mounting elevators on extra 300 LX
- regulators
- Moving batteries back on Extra Special
- lightened 35% Giles?
- WingTote wingbag size ??
- Edge Imac setting
- da 50 prop drilling
- Need help with Ultimate struts
- Flight report, MVVS-58/Extra 260
- HS-81MG servo on throttle?
- Kavan wheels on 28% WH
- composite extra
- I missed somebody, please read
- Hard Point holes?
- Exaust system options 29% Ultimate
- 300 LX Pull Pull
- The word is getting out!
- Tom, how do you like my new skins on my white plane?
- Edge540T Any weak points ?
- Edge CG & Elevator Trim ???
- 28% Extra wing sheeting
- Edge 540T bent wing tube
- servo help on 28%
- LR-1 Question
- Problem with 28% Extra rudder
- Fuel dot troubles
- incommunicado
- What plane would you like wildhare to sell?
- Servo requirements calculator...
- Ball links?
- Brison 3.2 timing control
- Houston area Ultimate flyers...
- Wild Hare Extra 260 or 330lx??
- Canopy on Extra 28%
- 300 LX take's a trip to the LHS
- G-62 in an edge
- Yakking about new planes
- **Update** New 300 LX video.
- Edge 540T problems proving unresolvable
- Weight right on!
- DA 50 Choke
- 35% extra
- Restraining your plane while starting.
- Finally Going To Maiden !!!
- MISSING HARE
- 300 LX gear
- Ultimate bipe, Wild Hare vs theirs
- Haigh tailwheels?
- Rick Adams Video of Giles 202
- Tom - Thanks for the Tip... saved my gear
- 28% for 3D - Edhe or Extra?
- 28% 540 wing security
- Wild Hare Rc is terrific
- 300 LX
- Edge 540T CG
- Glow engine for 29% Ultimate?
- ST3250 on WH Ultimate?
- Waxing cowl/wheel pants
- Edge 540 How much elevator is to much
- Extra 300LX & Special or Edge 540T
- Edge Wingrock revisited
- WH Extra 260 and 3W-85 B2
- Edge 540 Owners check this
- MSC Prop (22-8) Spinner Cut ??
- 300 SP
- 28% 300LX Ultracote
- 28% Edge-What Are Your Surface Deflections ?
- Servo arm length
- Edge 540T Canopy mounting
- Ultimate question
- How much weight will Carbon Fiber save!!
- Smoke on WH Edge anyone??
- Throttle/choke servos???
- Giles elevator question
- 1.20 Edge540 (MOTOR CHOICE)?
- Ultimate covering
- 28% antenna routing
- Another time..Thx Wild Hare
- WH 260 w/ ZDZ-80... ug.
- 50cc engine fine tuning
- Flight Trimming....
- Stand-off length
- 28 % 300's
- Any Ultimates left?
- Servo leads?
- Edge 540 Elevator Throw/Travel
- Securing wing tube
- My 300 Special Setup and Maiden
- Single or twin seat for the Sukhoi?
- Sukhoi scheme, what do you think?
- Rabbit running my way
- little correction
- 33% Wild Hare Extra 260 question?
- Colors on R/Y Extra
- NOISE NOISE NOISE
- 28% Edge engine range
- I got a bet
- extra 300 wing tube
- Fiberglass Gear Broke on First Flight!
- Lateral Balance W/H Edge 540
- W/H Comp Sukhoi-coming soon!
- A Day With Wild Hare
- latest shipment?
- WH Extra 260 build thread?????????
- Wing Length
- How good is the Edge?
- How big diffrenece is it between the Edge 28% and the Extra 260?
- CHECK OUT THiS 300LX VID!
- Wild Hare 35% Extra?
- 300Lx
- WH 28% Edge OR 1.20 Edge
- WH All Ordered
- MVVS 45 is a sweetheart
- Help balancing 300LX
- Edge or Extra's ????
- 28% Edge Covering
- Brison 3.2 First Run
- Any Pics of the Composite Gear?
